Home » Language IDEs » PHP Development Tools (PDT) » PHP not in perspective
PHP not in perspective [message #71187] Mon, 19 May 2008 14:23 Go to next message
Originally posted by: pit190.hotmail.com
Hi everybody.
I have install "pdt-all-in-one-R20080103-win32.zip" and I can't create a
PHP project...and PHP isn't in perspective...However I have PHP in my
features and plugins.
In perspective I have Java, debug, CVS, Resource, Team synchronizing...
but not PHP, the only one I need :(
I don't find anything interresting in the *.ini files.
In the past I used "pdt-all-in-one-incubation-S20070910_RC1-win32.zip" and
it worked fine.
I don't know if I have change something somewhere that makes Eclipse
running bad...I have Java 6 update 5.
Any suggestions ? Thanks for your help and for Eclipse :D
Re: PHP not in perspective [message #71208 is a reply to message #71187] Mon, 19 May 2008 15:08 Go to previous messageGo to next message
D Kelsey is currently offline D KelseyFriend
In Eclipse, go to Help-->About Eclipse
Press Configuration Details and check that you are really using Java 6.
The problem you describe will happen if you are using Java 1.4.2.
Dave Kelsey
tranKILl wrote:
> Hi everybody.
> and it worked fine.
Re: PHP not in perspective [message #71283 is a reply to message #71208] Tue, 20 May 2008 07:18 Go to previous message
Thank you so much !
I have to change the environment variable in windows and not only in
Eclipse.
Previous Topic:Excluding file from PHP syntax check?
Next Topic:Calling c++ dll within my eclipse plugin
Current Time: Thu Dec 26 22:33:30 GMT 2024
Powered by FUDForum. Page generated in 0.03091 seconds
