Using AspectJ with PDE Builder [message #71098] |
Wed, 23 January 2008 16:58 |
Alejandro Bascuas Messages: 11 Registered: July 2009 |
Junior Member |
I'm using Eclipse 3.3 as my builder for my RCP application. I tried
using the pdebuild-ant.jar provided in the org.eclipse.ajdt.pde.build
plug-in. However, this causes the fetch function to fail.
Inspecting the jar file, I found some missing classes and manually
copied them over to the ajdt version of the jar. Fetch then worked fine,
but then I hit another problem: "eclipse.buildScript doesn't support the
"significantVersionDigits" attribute."
Not sure if there is more I need to do to get PDE Builder to generate
iajc tasks. My build works perfectly fine using the standard
pdebuild-ant.jar.
Thanks for any input,
Alej.
FUDForum. Page generated in 0.02098 seconds
