Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » [Teneo] Setting a "unique-key" attribute on a many-to-one association using Eannotations w
| [Teneo] Setting a "unique-key" attribute on a many-to-one association using Eannotations w [message #70892] |
Thu, 08 February 2007 01:34  |
Originally posted by: Stephen.Egan.csiro.au
Me again. Is there an EAnnotation I can use to set a "unique-key" =
constraint on two "many-to-one" associations in Hibernate? Basically, I=
want to generate a mapping similar to the following:
<many-to-one name=3D"roadGroupMembership" entity-name=3D"user_rgm" =
cascade=3D"merge,persist,save-update,lock,refresh" lazy=3D"false" =
insert=3D"true" update=3D"true" not-null=3D"false">
<column not-null=3D"false" unique-key=3D"user_rgm" =
name=3D"`membership_roadgroupmembership_id`"/>
</many-to-one>
<many-to-one name=3D"userAccount" entity-name=3D"UserAccount" =
insert=3D"true" update=3D"true" not-null=3D"true">
name=3D"`useraccount_useraccount_id`"/>
</many-to-one>
Stephen.
| Re: [Teneo] Setting a "unique-key" attribute on a many-to-one association using Eannotatio [message #70910 is a reply to message #70892] |
Thu, 08 February 2007 03:29   |
Hi Stephen,
This is supported for eattributes but not yet for ereference (many-to-one). Please enter a bugzilla
for this.
The annotation will then be:
annotation on the eclass:
@Table(name="MYITEMTABLE" uniqueConstraints={@UniqueConstraint(columnNames={"MYSTR", "MYINT"})})
and then you would need a joincolumn annotation on the manytoone to set the names to MYSTR and MYINT.
gr. Martin
Stephen Egan wrote:
> <many-to-one name="roadGroupMembership" entity-name="user_rgm"
> cascade="merge,persist,save-update,lock,refresh" lazy="false"
> insert="true" update="true" not-null="false">
> <column not-null="false" unique-key="user_rgm"
> name="`membership_roadgroupmembership_id`"/>
> </many-to-one>
> <many-to-one name="userAccount" entity-name="UserAccount"
> insert="true" update="true" not-null="true">
> name="`useraccount_useraccount_id`"/>
> </many-to-one>
> Stephen.
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
| Re: [Teneo] Setting a "unique-key" attribute on a many-to-one association using Eannotatio [message #70949 is a reply to message #70910] |
Thu, 08 February 2007 06:11  |
Thanks again Martin,
I've logged Bug No. 173429 for this.
//Stephen
On Thu, 08 Feb 2007 19:29:45 +1100, Martin Taal <mtaal@elver.org> wrote:=
> Hi Stephen,
> This is supported for eattributes but not yet for ereference =
> (many-to-one). Please enter a bugzilla for this.
> @Table(name=3D"MYITEMTABLE" =
> uniqueConstraints=3D{@UniqueConstraint(columnNames=3D{"MYSTR ","MYINT"}=
> and then you would need a joincolumn annotation on the manytoone to se=
t =
> gr. Martin
> Stephen Egan wrote:
>> constraint on two "many-to-one" associations in Hibernate? Basically=
>> I want to generate a mapping similar to the following:
>> <many-to-one name=3D"roadGroupMembership" entity-name=3D"user=
_rgm" =
>> </many-to-one>
>> <many-to-one name=3D"userAccount" entity-name=3D"UserAccount=
>> </many-to-one>
>> Thanks,
>> Stephen.
Using Opera's revolutionary e-mail client: http://www.opera.com/mail/
| Re: [Teneo] Setting a "unique-key" attribute on a many-to-one association using Eannotatio [message #602339 is a reply to message #70892] |
Hi Stephen,
for this.
gr. Martin
Stephen Egan wrote:
> </many-to-one>
> </many-to-one>
> Stephen.
The Netherlands
| Re: [Teneo] Setting a "unique-key" attribute on a many-to-one association using Eannotatio [message #602348 is a reply to message #70910] |
//Stephen
> Hi Stephen,
t =
> gr. Martin
> Stephen Egan wrote:
_rgm" =
>> </many-to-one>
>> </many-to-one>
>> Thanks,
>> Stephen.
Current Time: Sat Nov 01 08:56:21 EDT 2025
Powered by FUDForum. Page generated in 0.05350 seconds
