Re: I have tried but can't get hold of ISourceViewer() [message #552 is a reply to message #540] |
Mon, 21 April 2003 08:54 |
Originally posted by: bob.objfac.com
The sourceViewer is created in createPartControl(). The value is not
available until super.createPartControl() has completed.
Bob
"Syed Rizvi" <sma_r@hotmail.com> wrote in message
news:b7vrrp$nau$1@rogue.oti.com...
> HI all,
> I am using the following method to make the viewer uneditable,but I always
> get a NULL value from viewer.But if I use the createPartControl I can get
> it to work,but in my case I have to call this method with a button from
> MessageDialog after the editor has been created.Is there any way I can get
> it to work.
> public void setEditable(boolean editable) {
> ISourceViewer viewer = getSourceViewer();
> if (viewer != null) {
> viewer.setEditable(editable);
> I get viewer as NULL,I have tried to use the same line
> (ISourceViewer viewer = this.getSourceViwer();) in another code but It
> also doesnot work.
> While using the above method with createPartControl I can call this from
> another class but I get a NullPointerException on the
> super.createPartControl(composite parent).
> I would really apprecaite any pointer.
> Syed
Re: I have tried but can't get hold of ISourceViewer() [message #1643 is a reply to message #640] |
Tue, 22 April 2003 07:47 |
Huh? This is in an editor plugin, right? You can't call createPartControl().
It gets called by the framework.
Bob
news:b811si$cso$1@rogue.oti.com...
> Bob,
> Alright that is what read also,but can you tell me how to get rid of the
> runtime error "Argument can't be null" at line super.createPartControl
> that I get after calling createPartControl from another class.I need to
> get the sourceViewer for my method.Is there any other way to get this
> done.
> Thanks
> Syed
> > Bob
> > > HI all,
always
get
from
get
> > > it to work.
> > > also doesnot work.
from
> > > Syed
Re: Is there a solution for this [message #8851 is a reply to message #5391] |
Thu, 24 April 2003 00:48 |
What's your hurry? The viewer isn't editable before it is created. Just set
a flag in your editor and when the part control is created, do whatever you
need to the source viewer.
Bob
news:b852ne$aop$1@rogue.oti.com...
> Bob,
> There must be a way to go around this or do something else to get the same
> functionality.I would really appreciate any pointers
> Thanks
> Syed
> > Bob
> > > Bob,
the
to
> > > done.
> > > Thanks
> > > Syed
> > > > Bob
> > > > > HI all,
I
> > always
can
> > get
> > from
can
> > get
> > > > > it to work.
but It
> > > > > also doesnot work.
this
> > from
> > > > > Syed
Re: Is there a solution for this [message #8957 is a reply to message #8851] |
Thu, 24 April 2003 05:20 |
Syed Rizvi Messages: 145 Registered: July 2009 |
I understand what you are saying but I invoke setEditable method after the
editor is created,then according to what you are saying I should have the
viewer(I Think).
What actually happens is that I open up the editor frist then through the
Dialog I invoke this method.So if the editor has been opened up then there
should be a viewer.I tried to do the same for retriving text from the
editor and I was having the same problem then.
Or am I missing something here.
Thanks for all your help
Syed
> Bob
> > Bob,
> > Thanks
> > Syed
> > > Bob
> > > > Bob,
> the
> to
> > > > done.
> > > > Thanks
> > > > Syed
> > > > > Bob
> > > > > > HI all,
> I
> > > always
> can
> > > get
> > > from
> can
> > > get
> > > > > > it to work.
> but It
> > > > > > also doesnot work.
> this
> > > from
> > > > > > Syed
Re: Is there a solution for this [message #10323 is a reply to message #8957] |
Thu, 24 April 2003 14:11 |
Notwithstanding Andrew's response, I believe the source viewer is not
available until after createPartControl() has been called. If you are trying
to get it beforehand, you can solve your problem with a hack like this:
private Boolean deferSetEditable = null;
if (viewer != null)
else
deferSetEditable = editable ? Boolean.TRUE : Boolean.FALSE;
public void createPartControl(Composite parent) {
super.createPartControl(parent);
if (deferSetEditable != null && getSourceViewer() != null) {
getSourceViewer.setEditable(deferSetEditable.booleanValue()) ;
Bob
news:b87s7n$926$1@rogue.oti.com...
> viewer(I Think).
> Syed
set
you
> > Bob
> > > Bob,
same
> > > Thanks
> > > Syed
> > > > Bob
> > > > > Bob,
of
> > the
need
> > to
this
> > > > > done.
> > > > > Thanks
> > > > > Syed
not
> > > > > > Bob
> > > > > > > HI all,
uneditable,but
> > I
> > > > always
createPartControl I
> > can
> > > > get
button
> > > > from
way I
> > can
> > > > get
> > > > > > > it to work.
code
> > but It
> > > > > > > also doesnot work.
call
> > this
> > > > from
> > > > > > > Syed
FUDForum. Page generated in 0.15440 seconds
