Re: For those using Teneo from cvs: HEAD is Teneo for EMF 2.3 , Branch: R0_7_maintenance is EMF 2.2 [message #70974 is a reply to message #70873] |
Thu, 08 February 2007 12:07 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Brian,
The platform did deprecate APIs in 3.3 and provided new replacements
which we have started using so I don't think EMF 2.3 will function well
in Eclipse 3.2.x.
Brian Vetter wrote:
> So does moving to EMF 2.3 really mean having to upgrade to Eclipse 3.3
> as it states in the EMF 2.3 upgrade plan or does it still work in an
> Eclipse 3.2.1 environment?
> Brian
> Martin Taal wrote:
>> For those using Teneo from cvs. I am working on upgrading Teneo to
>> EMF 2.3/jdk 1.5. The related changes are being made in cvs HEAD.
>> The EMF 2.2 release of Teneo is from now maintained in the
>> R0_7_maintenance branch.
>> To switch your current version to the maintenance branch right click
>> on each project and select: Replace With > Another Branch or Version
>> Click Refresh Tags and the R0_7_maintenance branch should show up,
>> select it and click ok.
>> I will be doing builds for both EMF 2.2 and EMF 2.3. The EMF 2.2
>> builds with be called maintenance builds (build id starts with M),
>> the EMF 2.3 builds will be so-called integration build (build id
>> starts with I).
Re: For those using Teneo from cvs: HEAD is Teneo for EMF 2.3 , Branch: R0_7_maintenance is EMF 2.2 [message #602351 is a reply to message #70873] |
Ed Merks![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=ed.merks%40gmail.com) Messages: 33180 Registered: July 2009 |
Brian,
in Eclipse 3.2.x.
> Brian
> Martin Taal wrote:
>> starts with I).
Ed Merks
FUDForum. Page generated in 0.03347 seconds
