Home » Archived » Test and Performance Tools Platform (TPTP) » HTTP Response Content from HTTP Recorder
HTTP Response Content from HTTP Recorder [message #70557] Thu, 11 May 2006 16:19 Go to next message
Ryan Graciano is currently offline Ryan GracianoFriend
I am using Hyades' HTTP Recorder to load a single URL. My goal is to verify
that the content of the response - the actual HTML page - is what it should
be. I'd like to write my own custom code to do this, so I tried to open up
the class that was generated by Hyades for the HTTP recording. In this
class (HyadesLogonTest.java), there exists an executeRequest(HttpRequest)
method that has the following line:
HttpResponse response = m_httpExecutor[nUser].execute(request);
It seems to me that I should be able to use response.getBody() to access the
content of my response, but this method always returns null. I would really
appreciate some advice here - is there a way for me to populate getBody()
when Hyades retrieves the response? Alternatively, is there another method
exposed somewhere that will give me access to the content of the HTTP
response?
- Ryan
Re: HTTP Response Content from HTTP Recorder [message #70631 is a reply to message #70557] Fri, 12 May 2006 14:09 Go to previous messageGo to next message
Paul Slauenwhite is currently offline Paul SlauenwhiteFriend
Hi Ryan,
This is a defect with the HttpResponse class. Please open a defect.
You can open a defect here:
http://www.eclipse.org/tptp/ >> Submit Enhancements & Bugs >> Report a new
bug. >> TPTP
Paul
"Ryan Graciano" <graciano@us.ibm.com> wrote in message
news:e3vo7j$ulp$1@utils.eclipse.org...
> Hello,
verify
should
up
the
really
method
> response?
> - Ryan
Re: HTTP Response Content from HTTP Recorder [message #70761 is a reply to message #70631] Fri, 12 May 2006 18:40 Go to previous message
Thanks Paul. I opened the following defect -
https://bugs.eclipse.org/bugs/show_bug.cgi?id=141599
- Ryan
"Paul Slauenwhite" <paules@ca.ibm.com> wrote in message
news:e424ul$jfe$1@utils.eclipse.org...
> Hi Ryan,
> bug. >> TPTP
> Paul
> > Hello,
> verify
> should
> up
> the
> really
getBody()
> method
> > response?
> > Thanks,
> > - Ryan
Previous Topic:How to do a "controlled profiling" of a application on a server
Next Topic:TPTP Profiling of WTP Generic Servers
Current Time: Sat Nov 09 05:25:08 GMT 2024
Powered by FUDForum. Page generated in 0.02991 seconds
