Home » Eclipse Projects » Eclipse Platform » Any experience with MKS integration
Any experience with MKS integration [message #70427] Wed, 11 June 2003 01:44 Go to next message
Has anyone had any luck integrating MKS with the Eclipse 2.1 IDE? I've tried
the IBM WebSphere integration that comes with MKS with disapointing
results. MKS has an newer Eclipse integration patch on their web page,
but it requires patching the MKS server, which I can't do myself. I can
try to make the case that our IT people should install that patch, but it
would help if someone can confirm that that patch does make a substantial
difference.
Alas, it is a corporate policy that everyone use MKS, personally I'd
rather switch to CVS.
Re: Any experience with MKS integration [message #74728 is a reply to message #70427] Sun, 15 June 2003 08:41 Go to previous message
Originally posted by: cecconae.ig.com.br
tried
> difference.
Hi, Kenneth :
I don´t know what means "make a substantial difference" we use that new
MKS plugin with WSAD 5. It does the basic this like check-in check-out.
Its better than old WSAD 4.0 plugin, for sure. Its not as good as CVS
plugin yet.
Sincerely,
Antonio
Previous Topic:plugin classpath problem
Next Topic:Difference in wizard modality between windows and GTK
Current Time: Wed Apr 16 04:07:51 EDT 2025
Powered by FUDForum. Page generated in 0.02472 seconds
