Running RAP on Tomcat on Linux [message #70228] |
Wed, 16 January 2008 09:59 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: robert.einsle.de
Hello List,
we are testing Eclipse RAP an it looks very good.
But while deploying the Eclipse RAP Project as .war on an Apache Tomcat
5.5.25 running on an Linux Server on Java 6, Tomcat Produces havy load and
logs on catalina.out the osgi-Prompt several Times a Minute.
We have the same running the eclipse RAP-Demo on the Application-Server.
Is it imposible to run RAP on Tomcat on Linux?
Thanks for Help.
Robert
Re: Running RAP on Tomcat on Linux [message #70390 is a reply to message #70228] |
Thu, 17 January 2008 00:57 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: leeguannan.msn.com
yes Eclipse RAP can running on Tomcat or Linux
"Robert" <robert@einsle.de> 写入消息
news:0a3194399f689f80e71679b44a4c83a5$1@www.eclipse.org...
> Hello List,
> Thanks for Help.
> Robert
Re: Running RAP on Tomcat on Linux [message #70410 is a reply to message #70228] |
Thu, 17 January 2008 06:32 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: mario.peham.etech.at
Robert schrieb:
> Hello List,
> and logs on catalina.out the osgi-Prompt several Times a Minute.
> Thanks for Help.
> Robert
You must disable the console in the web.xml
<param-name>commandline</param-name>
<param-value>-console</param-value>
Mario
Re: Running RAP on Tomcat on Linux [message #70463 is a reply to message #70410] |
Thu, 17 January 2008 08:52 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Hy Mario,
> Mario
here a snapshoot of my web.xml:
--- cut ---
<servlet id="bridge">
<servlet-name>equinoxbridgeservlet</servlet-name>
<display-name>Equinox Bridge Servlet</display-name>
<description>Equinox Bridge Servlet</description>
<servlet-class>org.eclipse.equinox.servletbridge.BridgeServlet </servlet-class>
<init-param>
</init-param>
<init-param>
<param-name>enableFrameworkControls</param-name>
<param-value>true</param-value>
</init-param>
<init-param>
<param-name>extendedFrameworkExports</param-name>
<param-value></param-value>
</init-param>
<load-on-startup>1</load-on-startup>
</servlet>
--- cut ---
I think, this parameter is set.
The Application-Server (Tomcat Apacht 5.5.25) run on an Debian Etch
Server, but, when deploying my RAP-Application, the Server reports me 100
% CPU-Load while none is fetching Webpages. And my catalina.out is growing
with "osgi".
Any other Idea?
Robert
Re: Running RAP on Tomcat on Linux [message #70500 is a reply to message #70463] |
Thu, 17 January 2008 09:31 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Robert schrieb:
> Hy Mario,
>> Mario
> --- cut ---
> <init-param>
> </init-param>
> <init-param>
> </init-param>
> <init-param>
> </init-param>
> </servlet>
> --- cut ---
> 100 % CPU-Load while none is fetching Webpages. And my catalina.out is
> growing with "osgi".
> Any other Idea?
> Thanks
> Robert
Hallo Robert
You must remove this line
<init-param>
</init-param>
from the web.xml
Mario
Re: Running RAP on Tomcat on Linux [message #70517 is a reply to message #70500] |
Thu, 17 January 2008 10:37 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Mario Peham wrote:
> Hallo Robert
> <init-param>
> </init-param>
> from the web.xml
> Mario
Oh, sorry, i miussunderstand it. Jes, now its working.
Thanks a lot.
Robert
FUDForum. Page generated in 0.03833 seconds
