ATL and RSA [message #6264] |
Thu, 11 January 2007 08:13 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: anna.ruokonen.gmail.com
How can ATL results be loaded to Rational Software Architect? ATL seems
to output non-standard XMI format. Is there a converter available from
ATL XMI to standard XMI?
thanks,
Anna
Re: ATL and RSA [message #7789 is a reply to message #6308] |
Mon, 15 January 2007 12:24 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
could you explain some more? What was the output format then (um2, xmi,
ecore)?
Dave Kelsey wrote:
> If you used the MDR model handler then RSA won't understand this format.
> I have used ATL with RSA version 6 using the EMF model handler so I know
> that the output of ATL was usable in RSA 6 (although it was a little while
> ago).
> Dave Kelsey
>> thanks,
>> Anna
FUDForum. Page generated in 0.03563 seconds
