Re: Newlines and CVS [message #70148 is a reply to message #70046] |
Wed, 11 June 2003 02:24 |
Yes. The CVS plugin will convert EOL for files marked as text on
checkout and commit based on the platform setting.
Jean-Michel
Colin Sharples wrote:
> We've been having problems with ClearCase getting confused when a
> locally-edited file ends up with Windows-style newlines is being
> compared with a file in the repository which has Unix-style newlines.
> I just wanted to check whether this would be an issue with CVS. I
> thought I read somewhere that Eclipse will convert the files to use the
> platform line endings when it checks the files out from CVS. Is this
> true? Does it also convert the line-endings back to the appropriate
> style for the CVS repository when you synchronize?
FUDForum. Page generated in 0.02898 seconds
