Home » Language IDEs » PHP Development Tools (PDT) » Strange Eclipse error: cannot change the .php file size to smaller, cannot cut c
Strange Eclipse error: cannot change the .php file size to smaller, cannot cut c [message #70039] |
Mon, 12 May 2008 02:44 |
Originally posted by: hamasaki.citromail.hu
Dear Eclipse developers!
My problem is:
Any version of Eclipse (newest, old 3.2, easyeclipse, AptanaStudio, etc...
) cannot change the PHP's file size to smaller - only to bigger!
my php file 1000 byte and I delete 500 byte and save: I see good the saved
file in eclipse... but saved file don't changed... only ?> chars at 500
byte... but other 500 byte unchanged and still 1000 byte the file.
If I add new content to 1000 byte and will 1200 byte = ALL OK. But if I
delete content = will 1200 byte again and buggy file from this point...
file is UTF8 but tried with ASCII file too... all same...
Help me! I think it's java or eclipse bug but maybe about java...
Seems like file handle cannot allowed to cut file, only to append
content... It's all about java?
If I edit with this file with notepad / any other editor = can cut the
file content...
Enviroment:
Hardware: Intel Core 2 Duo E6550, 2 GB RAM, SATA, desktop PC
Software: Windows XP SP2 English, IE7, Firefox 2 + 3 beta
jre-1_5_0_11-windows-i586-p
but tried with:
jre-1_5_0_14-windows-i586-p
jre-1_5_0_06-windows-i586-p
j2re-1_4_2_16-windows-i586-p
j2sdk-1_4_2_17-windows-i586-p
And all same...
Last version checked:
pdt-all-in-one-S20080505_RC1-win32.zip
So... I can't belive it's common bug becuase no developer can use eclipse
by this big bug. What is the solution?
Thanks!
Mr. Hama
Re: Strange Eclipse error: cannot change the .php file size to smaller, cannot cut c [message #70063 is a reply to message #70039] |
Mon, 12 May 2008 11:49 |
YES!
For example detailed description, original file:
php code 1
php code 2
php code 3
I delete php code 2 + php code 3 line, left only 1 line, this will be:
php code 1
BUT!!!!!!!!!! I show this with text editor or if reopen file:
php code 1
p code 2
php code 3
And I show CORRECTLY the file if I press "SAVE" after first modification
(but really file size don't changed, only date updated). If I close file +
open again I see the bugged source -OR- I see the only 1 line source
correctly BUT the file bugged because Eclipse stop display after first ?> .
If I use ANY OTHER non JAVA based editor = ALL WORKS FINE and no this bug.
BUT file size will 100% same, file date changed!
So... Eclipse and ALL JAVA IDE don't MODIFY TO FILE SIZE SMALLER.
If I add new lines = ALL OK, but if delete = this sh1t happends...
I don't belive with this bug somebody can use and JAVA IDE... Eclipse
useless with this bug...
-- Eredeti üzenet --
Feladó: Michael Spector
Címzett: PDT Developers
Másolat:
Elküldve: 07:34
Téma: Re: [pdt-dev] Strange Eclipse error: cannot change the .php file
size to smaller, cannot cut content
Let me understand: you delete some part of file in Eclipse, press save
- the file contents remain the same? (i.e. you close Eclipse, and then
open it again - you see the original file)
> My problem is:
etc... )
saved
content...
file
> content...
> Enviroment:
> but tried with:
> And all same...
eclipse by
> Thanks!
> Mr. Hama
Re: Strange Eclipse error: cannot change the .php file size to smaller, cannot cut c [message #70514 is a reply to message #70039] |
Tue, 13 May 2008 19:51 |
PDT developers!
After I'm using EC 3.3.0 this bug is starting again... and still don't
change the file size to smaller.
Good all for 1-3 times AFTER don't change file size to smaller again...
So = this bug still extist after full XP SP3 install + full clean Eclipse
install + full JRE install ...
I have clean, legal, fully reinstalled Widows XP SP3 PC and still this
bug...
(With SP2 100% same)
How can use other developers Eclipse with this fatal bug?
I use Eclipse for editing PHP + eclipse-FTP-WebDAV for FTP support....
But without eclipse-FTP-WebDAV have this bug, the pure Eclipse do same bug.
I tested with test-framework and no error found.
I do:
1. format HDD
2. install Windows XP
3. install JRE what versions needed
4. download eclipse from www.eclipse.org, extract, run
5. this bug found
PC: Intel Core 2 Duo, 2 GB ram, Asus motherboard
ALL PROGRAMS WORK CORRECTLY expect ECLIPSE!
Hama
Re: Strange Eclipse error: cannot change the .php file size to smaller, cannot cut c [message #70776 is a reply to message #70514] |
Wed, 14 May 2008 07:15 |
Originally posted by: pdt.neveron.de
Have you checked the filepermissions of the file giving an error?
Have you created a new file with eclipse and copied all of the content
from the file giving errors into it and then tried to delet part of the
content?
Cause everytime i had problems with uneditable files it was due to file
permissions.
Regards Jan Walter
Mr. Hama schrieb:
> PDT developers!
> Eclipse install + full JRE install ...
> bug... (With SP2 100% same)
> I do:
> 1. format HDD
> 5. this bug found
> Hama
Re: Strange Eclipse error: cannot change the .php file size to smaller, cannot cut c [message #71380 is a reply to message #71341] |
Wed, 21 May 2008 07:13 |
Ok.
But please do it if run many programs, like firefox, and try if about 5
times.
My best test:
new file, with this content:
echo "hello";
echo "hello";
echo "hello";
echo "hello";
echo "hello";
and save
open it, delete 1 echo line, save, close.
then open it, delete 1 echo line, save, close...
and if not bugged = no bug
if left only:
echo "hello";
and smaller file size = no bug.
Re: Strange Eclipse error: cannot change the .php file size to smaller, cannot cut c [message #71398 is a reply to message #71380] |
Wed, 21 May 2008 07:23 |
I did it on my side everytime i had problems with files and it worked
EVERYTIME.
In my last post i asked YOU to try it with the file you have problems
with. I suspect that the source you are getting the files from or the
way you are getting them to your local disk marks them in some kinda of
write protected mode.
Please create in your project a new file via eclipse. Then copy and
paste all lines from the problematic file into the new one via eclipse.
Save the new file, close it then reopen it and test if you now can
delete lines out of the new file without the "bug" you seem to face with
the old file.
regards Jan Walter
Mr. Hama schrieb:
> Ok.
> times.
> My best test:
> echo "hello";
> echo "hello";
> echo "hello";
> echo "hello";
> echo "hello";
> and save
> if left only:
> echo "hello";
Re: Strange Eclipse error: cannot change the .php file size to smaller, cannot cut c [message #72033 is a reply to message #72015] |
Mon, 26 May 2008 07:11 |
Mr. Hama schrieb:
> Same bug...
> The new file is ok, but the saved file is buggy.
> If I save to the new file = no problem but who edit all times new file?
> Dammit, I want modify the files... :(
> Hama
That still lets me think it is not a bug in pdt but a problem you
encounter due to the way you up/download your files.
Try using the new file and sending it to your server and getting it back
and see if it then goes back to your edit problem. If it does the
problem is related to that part.
regards Jan
Current Time: Sat Jul 27 16:37:21 GMT 2024
Powered by FUDForum. Page generated in 0.04532 seconds
