Re: [ATL] Error handling for running transformations programmatically [message #71306 is a reply to message #70028] |
Wed, 09 January 2008 16:31 |
No real name Messages: 33 Registered: July 2009 |
Member |
seemingly no possibility exists for getting this information. But would
such a functionality implemented in the future? If not, why has the
method a return value?
Sebastian
bfeater schrieb:
> I am running succesfully a programmatically transformation. To improve
> the stability I want to react to failures which might happen to the
> runtime of the AtlLauncher's launch method (perhaps a faulty rule which
> is rarely called, ...).
> Regardless whether a runtime exception appears or not, I find no
> possibility to react to it, because exceptions are catched within the
> atl vm, some error output is given and the launch method returns as
> usually. And the return value of launch is always null which is not
> realy helpfull.
> So my question: How can I get the information whether the transformation
> was successfull or not?
> Sebastian
FUDForum. Page generated in 0.04694 seconds
