Home » Archived » Test and Performance Tools Platform (TPTP) » How to test plugins lie in workspace
How to test plugins lie in workspace [message #69977] Tue, 09 May 2006 00:19 Go to next message
Originally posted by: laniji.126.com
Hi,all:
How to test two plugins which are in different plugin project and both
lie in workspace.For example if I have two plugin projects A and B, they
both lie in workspace but not in Eclipse plugin directory and A depend on
B. When I test A using TPTP,the error tells me: "B is invalid" .How to
test in this case?
Stephen.
Re: How to test plugins lie in workspace [message #70078 is a reply to message #69977] Tue, 09 May 2006 12:22 Go to previous message
Paul Slauenwhite is currently offline Paul SlauenwhiteFriend
Hi Stephen,
Can you post the actual error message? Are you testing these plugins
with TPTP JUnit Plugin Tests or just TPTP JUnit Tests? Finally, are you
running your tests locally or remotely?
Paul
"Stephen" <laniji@126.com> wrote in message
news:de73ba09fed1d7aeace9e176d81630a1$1@www.eclipse.org...
> Hi,all:
> test in this case?
> Stephen.
Previous Topic:Profiling large applications problems
Next Topic:[AGR] focus command generation
Current Time: Fri Dec 27 03:53:00 GMT 2024
Powered by FUDForum. Page generated in 0.03692 seconds
