Home » Language IDEs » AspectJ » How rename worked in AJDT1.4.1
How rename worked in AJDT1.4.1 [message #69921] Wed, 28 March 2007 04:51 Go to next message
Originally posted by: diezhongdie.sjtu.edu.cn
The one of new features is that rename refactoring also works in AspectJ
program. Is there any references or guidelines about its implementation?
How to make it happen in AOP program?
With kind regards! Winnie
Re: How rename worked in AJDT1.4.1 [message #69941 is a reply to message #69921] Wed, 28 March 2007 05:07 Go to previous messageGo to next message
The class which implements the refactoring participant for type renames
is AspectRenameParticipant.java in the
org.eclipse.ajdt.internal.core.refactoring package (in the
org.eclipse.ajdt.core plugin).
Search the plugin.xml in this plugin to see how this rename participant
is registered with the system.
For information about accessing the AJDT source, see:
http://www.eclipse.org/ajdt/developers.php#q:source
Matt.
Re: How rename worked in AJDT1.4.1 [message #69960 is a reply to message #69941] Wed, 28 March 2007 06:39 Go to previous message
Thank you for your information. That helps me a lot
>> AspectJ
>> implementation?
> renames is AspectRenameParticipant.java in the
> participant is registered with the system.
> Matt.
Re: How rename worked in AJDT1.4.1 [message #596052 is a reply to message #69921] Wed, 28 March 2007 05:07 Go to previous message
Matt.
Re: How rename worked in AJDT1.4.1 [message #596064 is a reply to message #69941] Wed, 28 March 2007 06:39 Go to previous message
>> AspectJ
>> implementation?
> Matt.
Previous Topic:How rename worked in AJDT1.4.1
Next Topic:Exception softening
Current Time: Thu Mar 13 15:07:15 EDT 2025
Powered by FUDForum. Page generated in 0.04840 seconds
