Re: When does the auto-sync run [message #69956 is a reply to message #69937] |
Mon, 29 June 2009 15:25  |
On 2009-06-29 13:49:55 -0400, "Eclipse Webmaster (Denis Roy)"
<webmaster@eclipse.org> said:
> Steffen Pingel wrote:
>>>>> When does the auto-sync run? Is it at a specific time?
>>>> It runs every 20 minutes by default.
>>> A co-worker expressed concern about a corporate setting where a lot of
>>> developers might all start Eclipse and nail the server at the same
>>> time. I know it synchs on startup, does it start the "20 minutes" at
>>> the point that the first one stops? That would at least build a little
>>> variation into everyone's clocks so that every 20 minutes the server
>>> does not get nailed again. Likewise, have you considered adding a
>>> small amount of fudge to the interval? Like some smallish random
>>> interval added to the 20 minutes.
>>> Finally, can a repository provider specify a minimum interval? So that
>>> someone cannot specify something like 1 minute as their interval?
>> Those are good points Mark. Can you file a bug so we can track that and
>> discuss optimizing the current strategy?
> Cool -- please post the bug number here :) I see a noticeable surge at
> 10:30ET and 2:30ET where many search queries run for minutes on end.
> Most days they all get killed for taking too long, yet no one seems to
> complain.. so I can't help but feel the compute power is simply going
> to waste.
I filed bug 281894
https://bugs.eclipse.org/bugs/show_bug.cgi?id=281894
Mark
Re: When does the auto-sync run [message #597923 is a reply to message #69838] |
Sat, 27 June 2009 20:33  |
On 2009-06-26 18:40:59 -0400, Steffen Pingel <steffen.pingel@tasktop.com> said:
Mark
Re: When does the auto-sync run [message #597937 is a reply to message #69857] |
Mon, 29 June 2009 13:40  |
Steffen
Steffen Pingel
Committer, http://eclipse.org/mylyn
Senior Developer, http://tasktop.com
Re: When does the auto-sync run [message #597940 is a reply to message #69916] |
Mon, 29 June 2009 13:49  |
Eclipse Webmaster Messages: 607353 Registered: July 2009 |
complain.. so I can't help but feel the compute power is simply going to
waste.
Re: When does the auto-sync run [message #597946 is a reply to message #69937] |
> to waste.
I filed bug 281894
Mark
FUDForum. Page generated in 0.04098 seconds
