Home » Eclipse Projects » GEF » GEF EditParts and SWT
Re: GEF EditParts and SWT [message #69635 is a reply to message #69614] |
Wed, 12 March 2003 18:23 |
That's correct. In order to paint handles, connections, and feedback, it
wasn't possible to support the use of heavyweight objects like an SWT
control. Everything is a figure on a Canvas. The EditPart has access to
this canvas, so if you wanted to place a "proxy" figure in the diagram, and
synchronize it with a SashForm that is parented by that cavnas, you might be
able to get that to work.
"Rich Naylor" <rich.naylor@active-endpoints.com> wrote in message
news:b4nrl3$2mq$1@rogue.oti.com...
> I'm trying to create an EditPart which will display it's contents in a
> "split pane" style, such as the org.eclipse.swt.custom.SashForm class
does.
> Looking through the docs for
> org.eclipse.gef.editparts.AbstractGraphicalEditPart, an EditPart needs to
> create a visual component which implements the org.eclipse.draw2d.IFigure
> interface. There seems to be no relation between an IFigure component and
a
> SWT component. I'm wondering if I'm missing something or if what I'm
trying
> to do can be done. I appreciate any thoughts or comments on this. Thanks
in
> advance.
> - Rich
Re: GEF EditParts and SWT [message #69676 is a reply to message #69635] |
Wed, 12 March 2003 19:12 |
Rich Naylor Messages: 4 Registered: July 2009 |
Junior Member |
If I did create a proxy figure linked to a SashForm, would I still be able
to
allow the user the ability to modify the SashForm. I would need to be able
to
add/delete child panes and change the size of the panes within the figure.
Are there any other known limitations of using this technique, or other
alternative approaches which may work better within the eclipse
architecture?
Thanks for your feedback.
- Rich
"Randy Hudson" <none@us.ibm.com> wrote in message
news:b4nu2c$4sv$1@rogue.oti.com...
and
be
> does.
to
and
> a
> trying
> in
> > advance.
> > - Rich
Re: GEF EditParts and SWT [message #69695 is a reply to message #69676] |
Wed, 12 March 2003 20:43 |
news:b4o0t2$71r$1@rogue.oti.com...
able
> to
> to
No magic there. It would just be an SWT SashForm. You could embed
GraphicalViewer's in the left and right sides, but I don't know if that
helps any.
> architecture?
Within the GEF architiecture, you could very easily make something that
looks and feels like a Sashform, but is just a compound figure. Also, it
could be keyboard accessible, unlike Sashform.
> - Rich
it
to
> and
might
> be
> > does.
> to
> and
> > a
> > trying
> Thanks
> > in
> > > advance.
> > > - Rich
Re: GEF EditParts and SWT [message #69934 is a reply to message #69695] |
Thu, 13 March 2003 14:31 |
Junior Member |
Randy -
Thanks for your suggestions on this. I think I'm going to opt for the latter
approach, and stay within the GEF framework. It just seems cleaner that
way instead of trying to blend in the SWT components through a proxy.
- Rich
news:b4o69a$bbv$1@rogue.oti.com...
> able
> > to
able
> > to
figure.
> helps any.
> > architecture?
> > - Rich
> it
> to
diagram,
> > and
> might
> > be
a
class
> > > does.
needs
> > to
component
> > and
> > > a
> > > trying
> > Thanks
> > > in
> > > > advance.
> > > > - Rich
Re: GEF EditParts and SWT [message #70034 is a reply to message #69934] |
Thu, 13 March 2003 15:36 |
Good luck. Maybe you'd like to contribute your results to the community?
There are ways to do this that might allow it to be reused. If you build
this into an EditPart, it won't be reusable because people usually have
their own entire hierarchy of editpart classes. But, if you make it
figure-based, with an additional SelectionHandleEditPolicy that implements
the sash as a GEF handle, it could be reused in just about any EditPart.
Also, handles are keyboard accessible in GEF (use the period key to navigate
handles). Currently a handle has to be on the handle layer, but we have a
bug open requesting that handles be anywhere.
news:b4q4q1$lhm$1@rogue.oti.com...
> Randy -
latter
> - Rich
> > able
> > > to
> able
> > > to
> figure.
> > helps any.
other
> > > architecture?
it
> > > - Rich
feedback,
> > it
SWT
access
> > to
> diagram,
> > > and
> > might
> > > be
in
> a
> class
> > > > does.
> needs
> > > to
> component
> > > and
> > > > a
I'm
> > > > trying
> > > Thanks
> > > > in
> > > > > advance.
> > > > > - Rich
Re: GEF EditParts and SWT [message #70093 is a reply to message #70034] |
Thu, 13 March 2003 18:34 |
Junior Member |
Sure, if I come up with something generic I'd be happy to pass it on.
I'm looking into making it figure based, but the docs and developer
guides are pretty sparse in the Draw2d area. Are there any good
examples of something similar already in use that you're aware of?
- Rich
news:b4q8k9$pa8$1@rogue.oti.com...
navigate
> > Randy -
> latter
> > - Rich
be
> > > able
> > > > to
be
> > able
> > > > to
> > figure.
that
> > > helps any.
> other
> > > > architecture?
that
> it
> > > > - Rich
> feedback,
> > > it
> SWT
> access
> > > to
> > diagram,
> > > > and
you
> > > might
> > > > be
contents
> in
> > a
> > class
> > > > > does.
> > needs
> > > > to
> > component
> > > > and
> > > > > a
> I'm
> > > > > trying
this.
> > > > Thanks
> > > > > in
> > > > > > advance.
> > > > > > - Rich
Re: GEF EditParts and SWT [message #70130 is a reply to message #70093] |
Thu, 13 March 2003 18:48 |
news:b4qj1o$33u$1@rogue.oti.com...
There isn't too much "widgety" stuff in draw2d now. The draw2d part could
be non-interactive, and just consist of a layout manager that left and right
children different portions of the available space (client area). Then, the
GEF handle would be the interactive part to redistribute the space, probably
by setting a property on the layout, and causing a re-layout.
> - Rich
community?
build
implements
> navigate
a
> > > Randy -
> > latter
that
> > > - Rich
still
> be
> > > > able
> > > > > to
> be
> > > able
> > > > > to
> > > figure.
> that
> > > > helps any.
> > other
> > > > > architecture?
> that
Also,
> > it
> > > > > - Rich
> > feedback,
> > > > it
an
> > SWT
> > access
> > > > to
> > > diagram,
> > > > > and
> you
> > > > might
> > > > > be
message
> contents
> > in
> > > a
> > > class
> > > > > > does.
EditPart
> > > needs
> > > > > to
> > > component
> > > > > and
> > > > > > a
what
> > I'm
> > > > > > trying
> this.
> > > > > Thanks
> > > > > > in
> > > > > > > advance.
> > > > > > > - Rich
Current Time: Fri Dec 27 02:05:32 GMT 2024
Powered by FUDForum. Page generated in 0.03234 seconds
