[ATL] NPE in content assist [message #69547] |
Thu, 13 December 2007 18:06 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Matthias Bohlen![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=infomail%40mbohlen.de) Messages: 30 Registered: July 2009 |
Member |
when I activate the new checkbox "Enable auto activation" inside
Eclipse, Preferences, ATL, Editor, Code Assist, and then I click
Ctrl-Space, I get the following NullPointerException:
Warning: one refSetting crashed:
org.eclipse.gmt.tcs.injector.TCSInjector$RefSetting.doItForC ontext(TCSInjector.java:554)
org.eclipse.gmt.tcs.injector.TCSInjector$RefSetting.doIt(TCS Injector.java:695)
org.eclipse.gmt.tcs.injector.TCSInjector.performImportation( TCSInjector.java:284)
org.eclipse.gmt.tcs.injector.TCSInjector.performImportation( TCSInjector.java:218)
org.eclipse.gmt.tcs.injector.TCSInjector.performImportation( TCSInjector.java:167)
org.eclipse.gmt.tcs.injector.TCSInjector.inject(TCSInjector. java:97)
org.eclipse.m2m.atl.adt.ui.text.atl.AtlCompletionHelper.pars eExpression(AtlCompletionHelper.java:170)
org.eclipse.m2m.atl.adt.ui.text.atl.AtlCompletionHelper.comp uteContext(AtlCompletionHelper.java:88)
org.eclipse.m2m.atl.adt.ui.text.atl.AtlCompletionProcessor.c omputeCompletionProposals(AtlCompletionProcessor.java:82)
org.eclipse.jface.text.contentassist.ContentAssistant.comput eCompletionProposals(ContentAssistant.java:1759)
org.eclipse.jface.text.contentassist.CompletionProposalPopup .computeProposals(CompletionProposalPopup.java:478)
org.eclipse.jface.text.contentassist.CompletionProposalPopup .access$16(CompletionProposalPopup.java:475)
org.eclipse.jface.text.contentassist.CompletionProposalPopup $2.run(CompletionProposalPopup.java:410)
org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:67)
org.eclipse.jface.text.contentassist.CompletionProposalPopup .showProposals(CompletionProposalPopup.java:404)
org.eclipse.jface.text.contentassist.ContentAssistant$2.run( ContentAssistant.java:354)
org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:123)
org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3212)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2956)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2389)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2353)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:153)
sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
java.lang.reflect.Method.invoke(Method.java:585)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 504)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:443)
at org.eclipse.equinox.launcher.Main.run(Main.java:1169)
at org.eclipse.equinox.launcher.Main.main(Main.java:1144)
My transformation script:
module UML2EnterpriseApp;
create OUT : EnterpriseApp from PRO: UML2, IN: UML2;
uses UML2Helpers;
-- @nsURI UML2=http://www.eclipse.org/uml2/2.1.0/UML
-- get the root node of the UML model (there is only one)
helper def: modelRoot: UML2!Model =
UML2!Model.allInstances()->asSequence()->first();
-- Transform UML model to EnterpriseApp model
rule UMLModelToEnterpriseAppModel {
from model : UML2!Model
to out : EnterpriseApp!EAppModel (
model
-- Transform UML2 classes that have the stereotype "Service"
-- to EnterpriseApp services.
rule UMLServiceToEnterpriseAppService {
from class : UML2!Class (class.oclIsTypeOf(UML2!Class) and
class.hasStereotype('Service'))
to out : EnterpriseApp!Service (
name <- class.name->debug('UMLServiceToEnterpriseAppService'),
methods <- class.ownedOperation->debug('UMLServiceToEnterpriseAppService'),
sourceReferences <-
class.clientDependency->debug('UMLServiceToEnterpriseAppService'),
model <- thisModule.modelRoot
do {
thisModule.links->debug('TransientLinkSet');
-- Transform UML2 classes that have the stereotype "Entity"
-- to EnterpriseApp entities.
rule UMLEntityToEnterpriseAppEntity {
class.hasStereotype('Entity'))
to out : EnterpriseApp!Entity (
name <- class.name->debug('UMLEntityToEnterpriseAppEntity'),
methods <- class.ownedOperation->debug('UMLEntityToEnterpriseAppEntity'),
properties <- class.ownedAttribute->debug('UMLEntityToEnterpriseAppEntity'),
do {
-- Transform UML dependencies to EnterpriseApp references
rule UMLDependencyToEnterpriseAppReference {
from dep : UML2!Dependency (dep.supplier->first().hasStereotype('Entity'))
to out : EnterpriseApp!Reference (
target <- dep.supplier->first()
-- Transform UML2 operations to OOP methods.
rule UMLOpToOOPMethod {
from method : UML2!Operation
to out : EnterpriseApp!Method (
name <- method.name
,returnType <- method.type
,parameters <-
method.ownedParameter->select(x|x.direction<>#return)->asSequence()
,instanceScope <- not method.isStatic
-- Transform UML2 parameters to OOP parameters.
rule UMLParameterToOOPParameter {
from param : UML2!Parameter (param.direction <> #return)
to out : EnterpriseApp!Parameter (
name <- param.name ,
type <- param.type
-- Transform UML2 datatype to OOP datatype.
rule UMLDataTypeToOOPDatatype {
from type : UML2!DataType
to out : EnterpriseApp!Type (
name <- type.name->debug('UMLDataTypeToOOPDatatype')
-- Transform UML2 property to OOP property
rule UMLPropertyToOOPProperty {
from attr : UML2!Property
(attr.featuringClassifier->first().hasStereotype('Service') or
attr.featuringClassifier->first().hasStereotype('Entity'))
to out : EnterpriseApp!Property (
name <- attr.name->debug('UMLPropertyToOOPProperty'),
type <- attr.type->debug('UMLPropertyToOOPProperty')
do {
Can somebody check this, please?
Matthias Bohlen
Re: [ATL] NPE in content assist [message #69626 is a reply to message #69569] |
Thu, 13 December 2007 20:46 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Frédéric Jouault![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=frederic.jouault%40univ-nantes.fr) Messages: 572 Registered: July 2009 |
Hi Matthias,
>> model
> The word "model" before the round closing parenthesis is the place where
> I pressed Ctrl-Space.
The content assist code uses TCS to parse programs into models that it
can navigate to provide completion suggestions.
In some cases, the program is not valid when you press Ctrl-Space, which
can generate errors.
These errors should be caught and, for instance, added to the Problem
model that the TCS injector can generate. Please, feel free to file a
bug about this.
Do you get this error in the console, or in the error log? For instance,
if it is in the console, it is probably not preventing you from using
content assist correctly.
Frédéric Jouault
Re: [ATL] NPE in content assist [message #69686 is a reply to message #69626] |
Thu, 13 December 2007 22:24 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Member |
On 2007-12-13 21:46:05 +0100, Frédéric Jouault
<frederic.jouault@univ-nantes.fr> said:
> Hi Matthias,
> >> model
> which can generate errors.
Well, in the first place, I expected a list of attributes to appear
when I type "." or Ctrl-Space. The list should contain the attributes
of the model, so that I can select one of them, for example "name", and
then continue typing the rest of the expression/statement.
> bug about this.
> instance, if it is in the console, it is probably not preventing you
> from using content assist correctly.
I get the error inside the console of the parent instance of Eclipse.
ATL runs inside a runtime workbench, and the exception is displayed in
the console of the original Eclipse instance from where I started the
runtime workbench. Content assist does not work at all, though. No
assistance visible.
I'll add an entry to Bugzilla.
Cheers
Matthias
FUDForum. Page generated in 0.03695 seconds
