Preview not Refreshing [message #69445] |
Wed, 24 August 2005 18:56 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: jhawk28.myrealbox.com
Using the Report Designer, the report does not always refresh the preview
when editing labels and moving things around.
The workaround is to:
1. select a label
2. select the code tab
3. reset the function
4. save the report
The preview now displays the correct information.
Joshua
Re: Preview not Refreshing [message #69465 is a reply to message #69445] |
Wed, 24 August 2005 19:42 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: statineni.issintl.com
Joshua,
I had the same problem .
I think the EMF and GEF plugins are not properly installed or in other
sense you should have compatible versions of everything
[eclipse,Birt,EMF,GEF] .
BIRT is currently tested with the following configurations:
Eclipse 3.0.1, and 3.0.2.
GEF 3.0.1.
EMF 2.0.3.
GEF JRE 1.4.
And
Eclipse 3.1.
GEF 3.1.
EMF 2.1.
GEF JRE 1.4/JRE 1.5.
Sudha.
> 1. select a label
> 4. save the report
> Joshua
FUDForum. Page generated in 0.03408 seconds
