Home » Eclipse Projects » GEF » [newbie] logic editor as PDE project?
[newbie] logic editor as PDE project? [message #69394] |
Wed, 12 March 2003 09:49 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
I'd like to look over the logic editor example as a PDE project ( so I
can build, step through, etc.). Wondered how I access it, ideally via
CVS. Looked in dev.eclipse.org:/home/tools but couldn't find it there
(nor gef, which suggests I'm looking in the wrong place).
Scott.
Re: [newbie] logic editor as PDE project? [message #69416 is a reply to message #69394] |
Wed, 12 March 2003 14:18 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Maybe you were looking at home/platform, because it is in home/tools
<user@domain.invalid> wrote in message news:b4n031$9tv$1@rogue.oti.com...
> Scott.
Re: [newbie] logic editor as PDE project? [message #69817 is a reply to message #69416] |
Thu, 13 March 2003 08:25 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
If I create a new repository (in eclipse cvs perspective) as follows:
:pserver:anonymous@dev.eclipse.org:/home/tools
the only projects I see are cdt related. (Trying to access
/home/platform fails...).
Am I missing something? (different user reqd?).
Scott.
>>Hi,
>>Thanks,
>>Scott.
Re: [newbie] logic editor as PDE project? [message #69895 is a reply to message #69817] |
Thu, 13 March 2003 13:37 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
You are looking under HEAD? I can see gef, cdt, and cobol projects, but
then again I'm not anonymously logged in right now.
platform is under home/eclipse, not home/platform.
<user@domain.invalid> wrote in message news:b4pfg3$2qk$1@rogue.oti.com...
> Scott.
> >>Hi,
> >>Thanks,
> >>Scott.
Re: [newbie] logic editor as PDE project? [message #70073 is a reply to message #69895] |
Thu, 13 March 2003 17:25 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Yup. Under HEAD, I only get cdt.
/home/eclipse gives me jdt, platform, sdk & pde.
- Scott.
>>Thanks,
>>Scott.
>>>>Hi,
>>>>Thanks,
>>>>Scott.
Re: [newbie] logic editor as PDE project? [message #70113 is a reply to message #70073] |
Thu, 13 March 2003 18:45 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Eric Bordeau![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=ebordeau%40us.ibm.com) Messages: 259 Registered: July 2009 |
I have no problem seeing all the projects. And the web interface
( http://dev.eclipse.org/viewcvs/index.cgi/?cvsroot=Tools_Proj ect) shows
all the projects, too. Have you tried refreshing the view? You could
also check to make sure you don't have a working set applied to your
repository view (click the down arrow in the view's titlebar).
Otherwise, I don't know what could be causing this problem.
Eric
> - Scott.
>>> Thanks,
>>> Scott.
>>>>> Hi,
>>>>> Thanks,
>>>>> Scott.
Re: [newbie] logic editor as PDE project? [message #70288 is a reply to message #70113] |
Fri, 14 March 2003 09:19 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Bingo!
Scott.
Eric Bordeau wrote:
> You could
> Eric
Current Time: Fri Jul 19 05:23:45 GMT 2024
Powered by FUDForum. Page generated in 0.04095 seconds
