Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » Teneo: More than one class with same name
Teneo: More than one class with same name [message #69358] |
Tue, 30 January 2007 06:19  |
As I am having more than one ecore models, it is possible that classes
in different models can have the same name though in different packages.
By default, hibernate file generated by Teneo does not qualify entity
name with package, so that result in duplicate mapping error.
I tried to qualify entities with full package name then hibernate
complains that duplicate import and suggests:
try using auto-import="false"
So just wondering, where & how to specify this?
Though during initialization I specify some hibernate properties using
hbds.setHibernateProperties
and I don’t see this property in Environment class of hibernate.
Another issue is, if in case I don’t want to persist one of the entity
i.e. more than one class with same name in different packages), then I
comment out mapping for that class in hibernate file, but class still
exist in package and Teneo complains that more then one EClass with same
name:
java.lang.IllegalArgumentException: There is more than one EClass with
the same name (. . . . . A different EClassResolver should be used.
org.eclipse.emf.teneo.ecore.DefaultEClassNameStrategy.toECla ss(DefaultEClassNameStrategy.java:60)
org.eclipse.emf.teneo.hibernate.HbDataStore.setRefersToOfSup ers(HbDataStore.java:812)
org.eclipse.emf.teneo.hibernate.HbDataStore.setRefersToOfSup ers(HbDataStore.java:826)
org.eclipse.emf.teneo.hibernate.HbDataStore.computeReferers( HbDataStore.java:800)
org.eclipse.emf.teneo.hibernate.HbDataStore.initialize(HbDat aStore.java:163)
Any idea how to solve it?
Thanks.
- Parvez
Re: Teneo: More than one class with same name [message #69379 is a reply to message #69358] |
Tue, 30 January 2007 06:35   |
How did you qualify the entity name (using the QUALIFY_ENTITY_NAME persistenceoption?)? Can you post
the last part of the stacktrace (incl. the exception message)?
With the other issue, are you sure that the mapping xml file is used? You need to tell Teneo
explicitly that a mapping file should be used and where it is used (using the persistenceoption:
PersistenceOptions.USE_MAPPING_FILE).
Can you also post the ecore if the above does not help?
auto-import is set on the hibernate-mapping tag in the mapping xml:
<hibernate-mapping
schema="schemaName" (1)
default-cascade="none|save-update" (2)
auto-import="true|false" (3)
package="package.name" (4)
but I would not try that just now, it should work without setting auto-import explicitly.
gr. Martin
PC wrote:
> name:
> at
> at
> at
> at
> at
> Thanks.
> - Parvez
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: Teneo: More than one class with same name [message #69478 is a reply to message #69379] |
Tue, 30 January 2007 09:50   |
Hi Martin,
I am using the option PersistenceOptions.USE_MAPPING_FILE with value "true"
but not the QUALIFY_ENTITY_NAME, I am not sure what should be its value.
In hibernate file, I have added full package name i.e.
<joined-subclass entity-name="com.pilz.pas.network.model.Network" ...
<joined-subclass entity-name="com.pilz.pas.platform.model.Network" ...
Now, I tried changing line to
<hibernate-mapping>
to
<hibernate-mapping auto-import="false">
and I get error::
!MESSAGE There is more than one EClass with the same name (Network in
EPackage model and model. A different EClassResolver should be used.
!STACK 0
the same name (Network in EPackage model and model. A different
If I use:
<hibernate-mapping>
then I get error:
!MESSAGE duplicate import: Network refers to both
com.pilz.pas.network.model.Network and
com.pilz.pas.platform.model.Network (try using auto-import="false")
!STACK 0
org.hibernate.DuplicateMappingException: duplicate import: Network
refers to both com.pilz.pas.network.model.Network and
at org.hibernate.cfg.Mappings.addImport(Mappings.java:141)
org.hibernate.cfg.HbmBinder.bindPersistentClassCommonValues( HbmBinder.java:614)
at org.hibernate.cfg.HbmBinder.bindClass(HbmBinder.java:527)
at org.hibernate.cfg.HbmBinder.bindJoinedSubclass(HbmBinder.jav a:848)
at org.hibernate.cfg.HbmBinder.handleJoinedSubclass(HbmBinder.j ava:2202)
at org.hibernate.cfg.HbmBinder.bindRoot(HbmBinder.java:153)
at org.hibernate.cfg.Configuration.add(Configuration.java:669)
at org.hibernate.cfg.Configuration.addInputStream(Configuration .java:504)
org.eclipse.emf.teneo.hibernate.HbDataStore.mapModel(HbDataS tore.java:360)
org.eclipse.emf.teneo.hibernate.HbDataStore.initialize(HbDat aStore.java:156)
And if I don’t qualify name i.e. us like
<joined-subclass entity-name="Network" ...
!MESSAGE Duplicate class/entity mapping Network
!STACK 0
org.hibernate.DuplicateMappingException: Duplicate class/entity mapping
Network
at org.hibernate.cfg.Mappings.addClass(Mappings.java:118)
at org.hibernate.cfg.HbmBinder.handleJoinedSubclass(HbmBinder.j ava:2204)
If I comment one of the class mapping then I get error:
!STACK 0
- Parvez
Martin Taal wrote:
> persistenceoption?)? Can you post the last part of the stacktrace (incl.
> You need to tell Teneo explicitly that a mapping file should be used and
> <hibernate-mapping
> gr. Martin
> PC wrote:
>> same name:
>> at
>> at
>> at
>> at
>> at
>> Thanks.
>> - Parvez
Re: Teneo: More than one class with same name [message #69498 is a reply to message #69478] |
Tue, 30 January 2007 10:38   |
Hi Parvez,
It is described here:
http://www.elver.org/hibernate/options.html
see QUALIFY_ENTITY_NAME. If you use that then the naming issue should be solved and you don't need
to edit the xml file.
Btw, the entityname should not be set to the java classname but to the (qualified) eclass name.
See also here:
http://www.elver.org/hibernate/troubleshooting.html#org.hibe rnate.DuplicateMappingException%3A+Duplicate+class%2Fentitym apping
gr. Martin
PC wrote:
> Hi Martin,
> <hibernate-mapping>
> to
> and I get error::
> !STACK 0
> at
> at
> at
> at
> at
> If I use:
> <hibernate-mapping>
> then I get error:
> !STACK 0
> at
> at
> at
> at
> at
> !STACK 0
> Network
> at
> at
> at
> at
> !STACK 0
> at
> at
> at
> at
> at
> - Parvez
> Martin Taal wrote:
>> <hibernate-mapping
>> gr. Martin
>> PC wrote:
>>> Hi,
>>> classes in different models can have the same name though in
>>> different packages.
>>> entity i.e. more than one class with same name in different
>>> packages), then I comment out mapping for that class in hibernate
>>> file, but class still exist in package and Teneo complains that more
>>> then one EClass with same name:
>>> with the same name (. . . . . A different EClassResolver should be used.
>>> at
>>> at
>>> at
>>> at
>>> at
>>> Thanks.
>>> - Parvez
The Netherlands
Re: Teneo: More than one class with same name [message #69519 is a reply to message #69498] |
Tue, 30 January 2007 11:01   |
Thanks Martin.
I will try using:
props.setProperty(PersistenceOptions.QUALIFY_ENTITY_NAME,Per sistenceOptions.QUALIFY_ENTITY_NAME_NSPREFIX);
And I guess, if one hibernate file contains 2 or more classes with same
name then Teneo will use
<meta attribute="epackage">...</meta>
to find package name, is it?
- Parvez
Martin Taal wrote:
> Hi Parvez,
> solved and you don't need to edit the xml file.
> See also here:
> gr. Martin
> PC wrote:
>> Hi Martin,
>> "true"
>> <hibernate-mapping>
>> to
>> and I get error::
>> !STACK 0
>> at
>> at
>> at
>> at
>> at
>> If I use:
>> <hibernate-mapping>
>> then I get error:
>> !STACK 0
>> at
>> at
>> at
>> at
>> at
>> !STACK 0
>> mapping Network
>> at
>> at
>> at
>> at
>> !STACK 0
>> at
>> at
>> at
>> at
>> at
>> - Parvez
>> Martin Taal wrote:
>>> Hi,
>>> <hibernate-mapping
>>> gr. Martin
>>> PC wrote:
>>>> Hi,
>>>> different packages.
>>>> entity name with package, so that result in duplicate mapping error.
>>>> used.
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> Thanks.
>>>> - Parvez
Re: Teneo: More than one class with same name [message #69539 is a reply to message #69519] |
Tue, 30 January 2007 11:22   |
Hi Parvez,
The entity-name in the xml will be qualified. You can set the option and see how the mapping file
looks. Note you need to use the setpersistenceproperties on the hbdatastore for these options (and
setHibernateProperties for the hibernateproperties).
gr. Martin
PC wrote:
> Thanks Martin.
> I will try using:
> - Parvez
> Martin Taal wrote:
>> Hi Parvez,
>> be solved and you don't need to edit the xml file.
>> See also here:
>> gr. Martin
>> PC wrote:
>>> Hi Martin,
>>> "true"
>>> <hibernate-mapping>
>>> to
>>> and I get error::
>>> !STACK 0
>>> with the same name (Network in EPackage model and model. A different
>>> at
>>> at
>>> at
>>> at
>>> at
>>> If I use:
>>> <hibernate-mapping>
>>> then I get error:
>>> !STACK 0
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> !STACK 0
>>> mapping Network
>>> at
>>> at
>>> at
>>> at
>>> !STACK 0
>>> at
>>> at
>>> at
>>> at
>>> at
>>> - Parvez
>>> Martin Taal wrote:
>>>> Hi,
>>>> used? You need to tell Teneo explicitly that a mapping file should
>>>> <hibernate-mapping
>>>> gr. Martin
>>>> PC wrote:
>>>>> Hi,
>>>>> different packages.
>>>>> more then one EClass with same name:
>>>>> used.
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> Thanks.
>>>>> - Parvez
The Netherlands
Re: Teneo: More than one class with same name [message #69559 is a reply to message #69539] |
Tue, 30 January 2007 12:17   |
Sorry Martin, I "think" may be I got confused now about how
QUALIFY_ENTITY_NAME is going to work.
It looks to me that this option may not work for me, because I generate
hibernate file before running the application i.e. by right clicking on
ecore file and I use PersistenceOptions.USE_MAPPING_FILE, "true".
So I guess that won’t change hibernate file, but may be it can update
the loaded xml data. I will try it and will update accordingly.
- Parvez
Martin Taal wrote:
> Hi Parvez,
> see how the mapping file looks. Note you need to use the
> gr. Martin
> PC wrote:
>> Thanks Martin.
>> I will try using:
>> same name then Teneo will use
>> - Parvez
>> Martin Taal wrote:
>>> Hi Parvez,
>>> See also here:
>>> gr. Martin
>>> PC wrote:
>>>> Hi Martin,
>>>> "true"
>>>> value.
>>>> <hibernate-mapping>
>>>> to
>>>> and I get error::
>>>> in EPackage model and model. A different EClassResolver should be used.
>>>> !STACK 0
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> If I use:
>>>> <hibernate-mapping>
>>>> then I get error:
>>>> !STACK 0
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> !STACK 0
>>>> mapping Network
>>>> at
>>>> at
>>>> at
>>>> at
>>>> !STACK 0
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> - Parvez
>>>> Martin Taal wrote:
>>>>> Hi,
>>>>> <hibernate-mapping
>>>>> gr. Martin
>>>>> PC wrote:
>>>>>> Hi,
>>>>>> different packages.
>>>>>> using
>>>>>> used.
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> Thanks.
>>>>>> - Parvez
Re: Teneo: More than one class with same name [message #69579 is a reply to message #69559] |
Tue, 30 January 2007 12:24  |
Updating the loaded xml will not work I think (afaik).
You can also write a small java app (with just a static main method) which calls
HbHelper.INSTANCE.generateMapping to generate a mapping file. This method allows you to pass the
persistenceproperties.
gr. Martin
> - Parvez
> Martin Taal wrote:
>> Hi Parvez,
>> and see how the mapping file looks. Note you need to use the
>> gr. Martin
>> PC wrote:
>>> Thanks Martin.
>>> I will try using:
>>> - Parvez
>>> Martin Taal wrote:
>>>> Hi Parvez,
>>>> should be solved and you don't need to edit the xml file.
>>>> See also here:
>>>> gr. Martin
>>>> PC wrote:
>>>>> Hi Martin,
>>>>> value "true"
>>>>> value.
>>>>> <hibernate-mapping>
>>>>> to
>>>>> and I get error::
>>>>> used.
>>>>> !STACK 0
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> If I use:
>>>>> <hibernate-mapping>
>>>>> then I get error:
>>>>> !STACK 0
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> !STACK 0
>>>>> mapping Network
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> used.
>>>>> !STACK 0
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> - Parvez
>>>>> Martin Taal wrote:
>>>>>> Hi,
>>>>>> <hibernate-mapping
>>>>>> gr. Martin
>>>>>> PC wrote:
>>>>>>> Hi,
>>>>>>> different packages.
>>>>>>> using
>>>>>>> be used.
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> Thanks.
>>>>>>> - Parvez
The Netherlands
Re: Teneo: More than one class with same name [message #601736 is a reply to message #69358] |
<hibernate-mapping
gr. Martin
PC wrote:
> name:
> at
> at
> at
> at
> at
> Thanks.
> - Parvez
The Netherlands
Re: Teneo: More than one class with same name [message #601775 is a reply to message #69379] |
Hi Martin,
<hibernate-mapping>
to
and I get error::
!STACK 0
If I use:
<hibernate-mapping>
then I get error:
!STACK 0
!STACK 0
Network
!STACK 0
- Parvez
Martin Taal wrote:
> <hibernate-mapping
> gr. Martin
> PC wrote:
>> same name:
>> at
>> at
>> at
>> at
>> at
>> Thanks.
>> - Parvez
Re: Teneo: More than one class with same name [message #601781 is a reply to message #69478] |
Hi Parvez,
See also here:
gr. Martin
PC wrote:
> Hi Martin,
> <hibernate-mapping>
> to
> and I get error::
> !STACK 0
> at
> at
> at
> at
> at
> If I use:
> <hibernate-mapping>
> then I get error:
> !STACK 0
> at
> at
> at
> at
> at
> !STACK 0
> Network
> at
> at
> at
> at
> !STACK 0
> at
> at
> at
> at
> at
> - Parvez
> Martin Taal wrote:
>> <hibernate-mapping
>> gr. Martin
>> PC wrote:
>>> Hi,
>>> different packages.
>>> at
>>> at
>>> at
>>> at
>>> at
>>> Thanks.
>>> - Parvez
The Netherlands
Re: Teneo: More than one class with same name [message #601785 is a reply to message #69498] |
Thanks Martin.
I will try using:
- Parvez
Martin Taal wrote:
> Hi Parvez,
> See also here:
> gr. Martin
> PC wrote:
>> Hi Martin,
>> "true"
>> <hibernate-mapping>
>> to
>> and I get error::
>> !STACK 0
>> at
>> at
>> at
>> at
>> at
>> If I use:
>> <hibernate-mapping>
>> then I get error:
>> !STACK 0
>> at
>> at
>> at
>> at
>> at
>> !STACK 0
>> mapping Network
>> at
>> at
>> at
>> at
>> !STACK 0
>> at
>> at
>> at
>> at
>> at
>> - Parvez
>> Martin Taal wrote:
>>> Hi,
>>> <hibernate-mapping
>>> gr. Martin
>>> PC wrote:
>>>> Hi,
>>>> different packages.
>>>> used.
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> Thanks.
>>>> - Parvez
Re: Teneo: More than one class with same name [message #601794 is a reply to message #69519] |
Hi Parvez,
gr. Martin
PC wrote:
> Thanks Martin.
> I will try using:
> - Parvez
> Martin Taal wrote:
>> Hi Parvez,
>> See also here:
>> gr. Martin
>> PC wrote:
>>> Hi Martin,
>>> "true"
>>> <hibernate-mapping>
>>> to
>>> and I get error::
>>> !STACK 0
>>> at
>>> at
>>> at
>>> at
>>> at
>>> If I use:
>>> <hibernate-mapping>
>>> then I get error:
>>> !STACK 0
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> !STACK 0
>>> mapping Network
>>> at
>>> at
>>> at
>>> at
>>> !STACK 0
>>> at
>>> at
>>> at
>>> at
>>> at
>>> - Parvez
>>> Martin Taal wrote:
>>>> Hi,
>>>> <hibernate-mapping
>>>> gr. Martin
>>>> PC wrote:
>>>>> Hi,
>>>>> different packages.
>>>>> used.
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> Thanks.
>>>>> - Parvez
The Netherlands
Re: Teneo: More than one class with same name [message #601800 is a reply to message #69539] |
- Parvez
Martin Taal wrote:
> Hi Parvez,
> gr. Martin
> PC wrote:
>> Thanks Martin.
>> I will try using:
>> - Parvez
>> Martin Taal wrote:
>>> Hi Parvez,
>>> See also here:
>>> gr. Martin
>>> PC wrote:
>>>> Hi Martin,
>>>> "true"
>>>> value.
>>>> <hibernate-mapping>
>>>> to
>>>> and I get error::
>>>> !STACK 0
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> If I use:
>>>> <hibernate-mapping>
>>>> then I get error:
>>>> !STACK 0
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> !STACK 0
>>>> mapping Network
>>>> at
>>>> at
>>>> at
>>>> at
>>>> !STACK 0
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> - Parvez
>>>> Martin Taal wrote:
>>>>> Hi,
>>>>> <hibernate-mapping
>>>>> gr. Martin
>>>>> PC wrote:
>>>>>> Hi,
>>>>>> different packages.
>>>>>> using
>>>>>> used.
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> Thanks.
>>>>>> - Parvez
Re: Teneo: More than one class with same name [message #601806 is a reply to message #69559] |
gr. Martin
> - Parvez
> Martin Taal wrote:
>> Hi Parvez,
>> gr. Martin
>> PC wrote:
>>> Thanks Martin.
>>> I will try using:
>>> - Parvez
>>> Martin Taal wrote:
>>>> Hi Parvez,
>>>> See also here:
>>>> gr. Martin
>>>> PC wrote:
>>>>> Hi Martin,
>>>>> value "true"
>>>>> value.
>>>>> <hibernate-mapping>
>>>>> to
>>>>> and I get error::
>>>>> used.
>>>>> !STACK 0
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> If I use:
>>>>> <hibernate-mapping>
>>>>> then I get error:
>>>>> !STACK 0
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> !STACK 0
>>>>> mapping Network
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> used.
>>>>> !STACK 0
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> - Parvez
>>>>> Martin Taal wrote:
>>>>>> Hi,
>>>>>> <hibernate-mapping
>>>>>> gr. Martin
>>>>>> PC wrote:
>>>>>>> Hi,
>>>>>>> different packages.
>>>>>>> using
>>>>>>> be used.
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> Thanks.
>>>>>>> - Parvez
The Netherlands
Current Time: Mon Apr 28 02:55:01 EDT 2025
Powered by FUDForum. Page generated in 0.04126 seconds
