Home » Eclipse Projects » Mylyn » JIRA connector does not display correct task attributes?
JIRA connector does not display correct task attributes? [message #69353] Wed, 10 June 2009 19:31 Go to next message
Kristof Vanbecelaere is currently offline Kristof VanbecelaereFriend
I am using Mylyn 3.1.1 with the JIRA connector. It looks like the task
editor does not display the correct attributes for "Affects Versions",
"Fix Versions" and "Components". Is this a known issue?
Kristof
Re: JIRA connector does not display correct task attributes? [message #69373 is a reply to message #69353] Wed, 10 June 2009 21:49 Go to previous messageGo to next message
Steffen Pingel is currently offline Steffen PingelFriend
Have you tried refreshing the repository configuration? You can use the
refresh icon in the top-right corner of the attributes section in the task
editor.
Please file a bug if that does not resolve the problem for you:
http://www.eclipse.org/mylyn/support/
Steffen
> Kristof
Steffen Pingel
Committer, http://eclipse.org/mylyn
Senior Developer, http://tasktop.com
Re: JIRA connector does not display correct task attributes? [message #69413 is a reply to message #69373] Thu, 11 June 2009 10:44 Go to previous messageGo to next message
Sorry, I never noticed this icon.
Now I see all possible values but none is selected. Submitting causes the
version and component attributes to be reset. I guess that is a bug?
Re: JIRA connector does not display correct task attributes? [message #69433 is a reply to message #69413] Thu, 11 June 2009 10:47 Go to previous message
Right, after refreshing none of the values were selected. Closing and
re-opening the task editor solved that bit. All is fine then.
Thanks.
Re: JIRA connector does not display correct task attributes? [message #597785 is a reply to message #69353] Wed, 10 June 2009 21:49 Go to previous message
editor.
Steffen
> Kristof
Steffen Pingel
Re: JIRA connector does not display correct task attributes? [message #597796 is a reply to message #69373] Thu, 11 June 2009 10:44 Go to previous message
Re: JIRA connector does not display correct task attributes? [message #597803 is a reply to message #69413] Thu, 11 June 2009 10:47 Go to previous message
Thanks.
Previous Topic:Questions about adding tasks from own connector
Next Topic:Mylyn 3.2RC2 is now available
Current Time: Thu Dec 26 22:11:43 GMT 2024
Powered by FUDForum. Page generated in 0.03346 seconds
