Home » Language IDEs » C / C++ IDE (CDT) » How to use CDT debugger.
How to use CDT debugger. [message #69345] Thu, 08 May 2003 17:29 Go to next message
This must be some sort of newbie error so I am hoping that someone
will set me straight.
When I debug code in the Java perspective I do the following.
1. Create a debug launch configuration.
2. Set the breakpoints in the source code.
3. Launch the debug session
4. Once the code has stopped at the breakpoint I highlight the variable
that I want to inspect and right click.
5. From the drop down menu I select inspect and the information will
appear in the Display view.
When I attempt to do this in CDT I get all the way to the step 5.
The problem is that there is no inspect menu item. I can debug the code
on the command line and show the value of the variables so I know that
the code was created with debugging turned on. I just can't get it to
work within eclipse.
My system consists of the following.
Win2K
Eclipse Version: 2.0.2
Build id: 200211071448
CDT plugin 1.0.1 F1 - Windows
cygwin
gcc GNU gdb 2003-03-03-cvs (cygwin-special)
gdb GNU gdb 2003-03-03-cvs (cygwin-special)
Re: How to use CDT debugger. [message #69365 is a reply to message #69345] Thu, 08 May 2003 17:46 Go to previous messageGo to next message
Originally posted by: mikhailk.qnx.com
Use the "Run" ->"Add Expression (C/C++)" menu or the "Add Expression" item
of the context menu of C editor.
<user@domain.invalid> wrote in message news:b9ei7h$m1k$1@rogue.oti.com...
> Win2K
> cygwin
Re: another problem of debugger. [message #69384 is a reply to message #69365] Fri, 09 May 2003 05:00 Go to previous messageGo to next message
Originally posted by: billhao.hotmail.com
when I add a variable to inspector, and run to next line, the window is
changed to console, I have to change it back to inspector manaully. Any way
to solve this problem?
Thanks.
bill
e-mail: billhao@hotmail.com
MSN Messenger: billhao@hotmail.com
Web: http://www.minivoice.com
"Mikhail Khodjaiants" <mikhailk@qnx.com> д
Re: another problem of debugger. [message #69505 is a reply to message #69384] Fri, 09 May 2003 08:47 Go to previous messageGo to next message
Either arrange your views so that they can both be visible, or uncheck the
2 'Show when program writes to...' options in 'Window->Preferences->Debug->Console'.
> Thanks.
> bill
> "Mikhail Khodjaiants" <mikhailk@qnx.com> дÈëÓʼþ
> news:b9ej8v$mne$1@rogue.oti.com...
>>>Win2K
>>>cygwin
Re: How to use CDT debugger. [message #69525 is a reply to message #69365] Fri, 09 May 2003 09:52 Go to previous messageGo to next message
Maybe I am using the wrong version. I don't have the "Add Expression
(C/C++)" item on the "Run" menu. In fact, even when I am debugging
C/C++ code I still have the "Add Java Exception Breakpoint" on the Run menu.
The good news is that there is an add expression on the C editor context
menu so everything works now.
Thanks for your help.
>>Win2K
>>cygwin
Re: How to use CDT debugger. [message #69545 is a reply to message #69525] Fri, 09 May 2003 10:18 Go to previous message
Originally posted by: mikhailkhod.rogers.com
You have to customize your debug perspective to see all C/C++ actions. In
the Debug perspective open "Window"-->"Customize perspective"-->"Other" and
check the "C/C++ Debug" box. In the latest version it is checked by default.
To customize your views open "Window"-->"Preferences"-->"Debug"-->"Debug
Action Groups" and check/uncheck the "C/C++ Debug" and "Java Debug" boxes.
<user@domain.invalid> wrote in message news:b9gbrb$nau$1@rogue.oti.com...
menu.
item
> >>Win2K
> >>cygwin
Previous Topic:UI framework
Next Topic:not possible to debug
Current Time: Thu Nov 06 18:23:32 EST 2025
Powered by FUDForum. Page generated in 0.24309 seconds
