How to add existing Visual C++ 6.0 to CDT? [message #69164] |
Thu, 08 May 2003 08:55 |
Originally posted by: markus.rakowski.nospam-gmx.net
Hi, I installed Eclipse 2.1 and the CDT. However, CDT does not recognize
an existing installation of Visual C++ 6.0.
How to add an existing Visual C++ 6.0 installation to CDT in order to be
able to compile/debug/run?
Thanking you
Markus
Re: How to add existing Visual C++ 6.0 to CDT? [message #69186 is a reply to message #69164] |
Thu, 08 May 2003 10:15 |
Originally posted by: dkel.unknown.com
First you need to ensure that VC++ is in your path when you start eclipse.
vcvars32.bat contains
the relevant information if you don't have it already on your path.
You also need to have a make program. I didn't use microsofts nmake program,
I used a unix make
equivalent, and put it on my path, making it easier to use the default make
system of CDT, plus I
am developing cross platform applications, I believe mingw provides a make
program, you could also
search the web or sourceforge. You can extract the make file from VC++
projects, but they may only work with nmake.
To debug, I register msdev.exe as an external tool, once my executable is
built it appears in the project tree
I highlight it and use the external tool to launch msdev with that
executable, I can then debug it.
It isn't as integrated as gcc and gdb, but as I have to use MS compilers on
windows, this still works very
well for me, it's just you have to leave the IDE to debug. I haven't tried
gdb to see if it can debug microsoft compiled code.
Dave
"Markus Rakowski" <markus.rakowski@nospam-gmx.net> wrote in message
news:b9d626$gpn$3@rogue.oti.com...
> Thanking you
> Markus
Re: How to add existing Visual C++ 6.0 to CDT? [message #69645 is a reply to message #69164] |
Fri, 09 May 2003 17:08 |
Just tried Microsoft NMAKE on my make file and it works ok, so I didn't need
another make file utility
I just replaced the default build command with NMAKE and that was all that
was needed.
Now you should be able to extract make files from the VC++ IDE, or write
your own.
Dave
> Thanking you
> Markus
Re: Can I use MFC in CDT? [message #69665 is a reply to message #69441] |
Fri, 09 May 2003 17:10 |
If you hand craft the MFC object use and MFC macro calls, then you can use
MFC in eclipse. It may be quite hard to do without the VC++ wizards to start
you off or the GUI layout tool, unless you build the App
first in VC++ then complete it in CDT.
Dave
"bill" <billhao@hotmail.com> wrote in message
news:b9frai$bkj$1@rogue.oti.com...
FUDForum. Page generated in 0.03405 seconds
