Home » Archived » BIRT » problem with API
problem with API [message #68797] Mon, 22 August 2005 09:37 Go to next message
Originally posted by: fremen.k9.pl
Hi! I've made webinterface for reports (kind, params, format),
but for security i don't want to use brit-viewer, but do it myself.
Pages are in JSP, viewer as Servlets, but in line:
ReportEngine engine =3D new ReportEngine( config );
i've got expetion:
java.lang.NoClassDefFoundError: org/mozilla/javascript/Scriptable
at reports.ReportServlet.run(ReportServlet.java:298)
I don't know what's wrong and how to avoid that.
I took code from example of using BIRT API.
Mirek
Re: problem with API [message #68816 is a reply to message #68797] Mon, 22 August 2005 10:27 Go to previous messageGo to next message
Ok. I found. It need more than engine and core .jar files,
but next problem, at:
report =3D engine.openReportDesign( name );
it stops... look like no excpetion throws (don't have any
info from try/catch, and no more code is processed)
Could anyone knows what's wrong?
It should be more tutorials and samples how to use BIRT
Fremen
Re: problem with API [message #68836 is a reply to message #68816] Mon, 22 August 2005 10:58 Go to previous messageGo to next message
Fremen
Can you post more of the code here?
Jason Weathresby
BIIRT PMC
"Fremen" <fremen@k9.pl> wrote in message
news:op.svwygaqgasjs9v@localhost.localdomain...
report = engine.openReportDesign( name );
Fremen
Re: problem with API [message #69083 is a reply to message #68836] Tue, 23 August 2005 02:36 Go to previous messageGo to next message
On Mon, 22 Aug 2005 16:58:20 +0200, Jason Weathersby =
<jweathersby@actuate.com> wrote:
> Fremen
Code is almost the same like in example:
EngineConfig config =3D new EngineConfig( );
config.setEngineHome( "/home/fremen/eclipse/plugins/org.eclipse.birt.rep=
ort.viewer_1.0.1/birt/WEB-INF" =
HTMLEmitterConfig hc =3D new HTMLEmitterConfig( );
HTMLCompleteImageHandler imageHandler =3D new HTMLCompleteImageHandler( =
hc.setImageHandler( imageHandler );
config.setEmitterConfiguration( HTMLRenderOption.OUTPUT_FORMAT_HTML, hc =
IReportRunnable report =3D null;
try
report =3D engine.openReportDesign( name ); // <-- here it stops =
catch ( EngineException e )
System.err.println( "Report " + name + " not found!\n" );
engine.destroy( );
return;
Fremen
Re: problem with API [message #69226 is a reply to message #69083] Tue, 23 August 2005 12:52 Go to previous messageGo to next message
Fremen
Take a look at this zip file. It has a readme in it.
It uses ant to do the build, so I hope you have it.
Let me know if the test report runs.
Jason Weathersby
BIRT PMC
news:op.svx7anmoasjs9v@localhost.localdomain...
> Fremen
EngineConfig config = new EngineConfig( );
" /home/fremen/eclipse/plugins/org.eclipse.birt.report.viewer_ 1.0.1/birt/WEB-INF "
HTMLEmitterConfig hc = new HTMLEmitterConfig( );
HTMLCompleteImageHandler imageHandler = new HTMLCompleteImageHandler( );
config.setEmitterConfiguration( HTMLRenderOption.OUTPUT_FORMAT_HTML, hc );
ReportEngine engine = new ReportEngine( config );
IReportRunnable report = null;
try
report = engine.openReportDesign( name ); // <-- here it stops !!!
engine.destroy( );
return;
Fremen
Re: problem with API [message #69307 is a reply to message #69226] Tue, 23 August 2005 14:23 Go to previous messageGo to next message
Originally posted by: statineni.issintl.com
Hey Freeman,
Could you send me the servlet and jsp files you created.As iam about to do
the same and i need some guidence. The example BIRT provided is so huge
and hard to understand.I need a different one like if you already created
a webpage and if you are getting the parameters from it .
could you send it like attached to my email address.
statineni@issintl.com
Appreciate your help.
Sudha
Re: problem with API [message #69385 is a reply to message #69083] Tue, 23 August 2005 19:19 Go to previous messageGo to next message
Fremen,
"Name" below need a full path to the report.
Also check your tomcat log see the exact exception when it "stops"
Jun Zhai
Re: problem with API [message #69581 is a reply to message #69307] Thu, 25 August 2005 08:58 Go to previous message
Hi!
I discovered that:
- path statring with /eclipse/... must end with /WEB-INF/brit, not =
/WEB-INF,
- i didn't want to put full path to eclipse (on local disk, for secure),=
so i'd tried to put those in /webapps/my_reports/birt, but in this case
it won't work (my reports site won't start), but if you put this to =
tomcat/webapps/birt/
and set correct path, it should work without any problems,
- the problem can be missing some *.jar - but this errors should Tomcat =
show (expetion
for class not found)
- code is almost the same as this in example on BIRTs site, i only
do minor changes for my dirs, etc.
Fremen
Using Opera's revolutionary e-mail client: http://www.opera.com/mail/
Previous Topic:cannot see the onRender method after on Birt v1.0.1
Next Topic:Small bug: BIRT1_0_1_20050811_PATCH (Branch): When you click "Run report" button on the re
Current Time: Mon Oct 20 07:28:06 EDT 2025
Powered by FUDForum. Page generated in 0.07765 seconds
