| [Debug] Off by one line problem in debugger (2.1) [message #67582] |
Mon, 09 June 2003 02:01  |
Originally posted by: bob.objfac.com
In one particular class, the debugger steps and stops at the line
immediately preceding code line, e.g., on blank lines or comments above
code. It appears to happen only in this one class.
The appearance is what one would expect if debugging a class that does not
correspond to the source, but class is built from source and I have done a
Rebuild All.
Any idea how to stop this from happening?
Bob
| Re: [Debug] Off by one line problem in debugger (2.1) [message #67631 is a reply to message #67582] |
Mon, 09 June 2003 03:09   |
Once again I learn, if it looks like a duck, it probably is a duck. Was
debugging another version of the class. I don't know quite how, but a plugin
is grabbing a version out of a Java application project to resolve to!
Moreover, I can't make it stop. Even though there is an explicit dependency
in plugin.xml to the correct (plugin) project and this project is checked in
the build dependency list (and the incorrect project is not), when I debug a
breakpoint in the wrong project gets hit.
To make matters worse, even though there is no visible dependency anywhere
on this application project, I can't close it or PDE won't launch! (I've
reported this bug several times, but it always gets closed "can't
reproduce".)
The only cure is to build a completely new workplace. Grrr.
Bob
"Bob Foster" <bob@objfac.com> wrote in message
news:bc174k$o51$1@rogue.oti.com...
> Rebuild All.
> Bob
| Re: [Debug] Off by one line problem in debugger (2.1) [message #70466 is a reply to message #68285] |
Wed, 11 June 2003 02:47  |
"Jared Burns" <jared-eclipse@mn.rr.com> wrote in message
news:bc2kgb$pme$3@rogue.oti.com...
> If you have a reproducible test case for the breakpoint issue, you should
> file a bug against JDT Debug.
Sorry, got carried away whining. Nah, I can't think how to reproduce this,
short of sending you my projects. I think I'll pass.
Bob
> - Jared
anywhere
> > reproduce".)
FUDForum. Page generated in 0.03355 seconds
