Re: Unable to create perspective [message #67813 is a reply to message #67597] |
Wed, 02 January 2008 08:43 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: rherrmann.innoopract.com
Salwa,
could you provide more specific information about what causes the
conflict? Did you declare plug-in-dependencies on org.eclipse.ui and
org.eclipse.rap.ui? Does your launch-configuration include both plug-ins?
Rüdiger
salwa wrote:
> Thankx for your reply,
> No, I add all the required plugins. but i found that the problem is that
> i have conflict between "org.eclipse.ui" plugin and
> "org.eclipse.ui.rap"plugin
> when i build both Rap and RCP platform.
> Any help to fix this problem.
> Regards Salwa
Re: Unable to create perspective [message #68045 is a reply to message #67924] |
Wed, 02 January 2008 15:32 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Salwa,
I don't quite understand where conflict should come from.
Could you maybe provide a small self-contained plug-in that reproduces
the problem?
Rüdiger
> org.eclipse.rap.ui? No, Just org.eclipse.rap.ui
> It includes only org.eclipse.rap.ui plugin
FUDForum. Page generated in 0.03099 seconds
