Home » Eclipse Projects » Remote Application Platform (RAP) » Asserting component enability
Asserting component enability [message #67317] |
Wed, 26 December 2007 11:08 |
Firstly, Merry Christmas to RAP Team.
I need to assert menu enability but I've found no way of doing this using
Selenium since I don't know what attribute to check.
Using Firebug I found that the difference between enabled & disabled menu
is only on the RGB attribute of the resultant div element, but Selenium
does not provide a way to check this attribute.
Any help would be greatly appreciated.
Best Regards,
Setya
Re: Asserting component enability [message #67686 is a reply to message #67386] |
Wed, 02 January 2008 06:04 |
Benny,
Thank you very much for your suggestion.
> One idea is to ask the RAP WidgetManager to give you
> the widget associated with the id of the div (see UITest stuff new in
> RAP CVS) together with WidgetManager#findWidgetById. This will return
> the widget instance itself (a qooxdoo class instance) where you can
> check the enablement of the menu item.
>I think you can package this as a
> selenium extension to have a wrapper which does this kind if stuff (see
> RAP UI Test page - that approach uses also an own selenium extension).
My questions:
1. If I put some widgets in my app I can assign their id's using setData,
but how do you assign id to components rendered by RAP, like menus,
coolbar buttons, views, editors, etc ?
2. I've toyed around with Selenium extension, but I didn't know that I can
return a qooxdoo class instance. Could you elaborate more on this ?
Setya
Re: Asserting component enability [message #68125 is a reply to message #67686] |
Thu, 03 January 2008 10:24 |
I have found out that RAP by default generated the id's for some of the
div elements.
How can I get a reference to WidgetManager from user-extensions.js ?
Setya
Re: Asserting component enability [message #68698 is a reply to message #68125] |
Thu, 03 January 2008 11:26 |
Originally posted by: rherrmann.innoopract.com
Hi Setya,
see my comments inline.
Rüdiger
Setya wrote:
>> setData, but how do you assign id to components rendered by RAP, like
>> menus, coolbar buttons, views, editors, etc ?
> div elements.
If UI tests are enabled, RAP assigns the widget-id to the outermost DOM
element that represents the widget on the client-side.
>> can return a qooxdoo class instance. Could you elaborate more on this ?
The client-side WidgetManager can be used like this:
var wm = org.eclipse.swt.WidgetManager.getInstance()
// obtain reference to qooxdoo widget
var widget = wm.findWidgetById( "<my-widget-id>" );
// obtain id for widget
var widgetId = wm.findIdByWidget( widget );
Please be aware that this is no API (yet) and thus may change without
further notice.
> Setya
Re: Asserting component enability [message #68759 is a reply to message #68698] |
Thu, 03 January 2008 11:53 |
Hi Rüdiger,
Thanks for your example.
I put your example above in my Selenium's user-extension.js :
Selenium.prototype.getWidgetExists = function(locator)
var wm = org.eclipse.swt.WidgetManager.getInstance();
var widget = wm.findWidgetById(locator);
return widget != null;
but Selenium always throws message 'org is not defined'.
It seems that Selenium is unable to find WidgetManager.
Setya
Re: Asserting component enability [message #69289 is a reply to message #68698] |
Wed, 09 January 2008 03:24 |
Rüdiger,
Given your explanation above, is it possible to assign id to children
widgets ? For instance, for Table widget I'd like to assign id to each
TableItem, this way I can use their id's instead of XPath to tell Selenium
to click the rendered element.
Setya
Re: Asserting component enability [message #69522 is a reply to message #69289] |
Wed, 09 January 2008 18:26 |
Setya,
as said, the current implementation only assigns an id to the outermost
DOM element.
Regarding the Table, TableItems are not directly represented by DOM
elements. This was done for performance reasons. Tests showed that even
a table with only 80-90 items, and each item having its own DOM element,
became almost unusable. Therefore, currently, the client-side TableItem
is only a data object that is rendered inside the Tables client area as
soon as it becomes visible.
Rüdiger
Setya wrote:
> Rüdiger,
>> DOM element that represents the widget on the client-side.
> Selenium to click the rendered element.
> Setya
Current Time: Sat Jul 27 16:16:14 GMT 2024
Powered by FUDForum. Page generated in 0.03084 seconds
