Re: Code Coverage [message #69269 is a reply to message #67208] |
Mon, 01 May 2006 19:55 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Originally posted by: Navid_Mehregani_nmehrega.ca.ibm.com
This is a multipart message in MIME format.
--=_alternative 006D6BCC85257161_=
Content-Type: text/plain; charset="US-ASCII"
Check your filters and make sure you're not accidentally filtering out the
information you need. To access your filter set, click on the profile
button, select 'Profile...' -> select your launch configuration -> select
the 'profiling' tab -> click on your profiling set -> edit -> next ->
select the profiling options you like -> next -> check your filterset here
and make sure you're not filter out the things you're interested in ->
finish -> profile.
Navid Mehregani
Content-Type: text/html; charset="US-ASCII"
<br><font size=2 face="sans-serif">Check your filters and make sure you're
not accidentally filtering out the information you need. To access
your filter set, click on the profile button, select 'Profile...' ->
select your launch configuration -> select the 'profiling' tab ->
click on your profiling set -> edit -> next -> select the profiling
options you like -> next -> check your filterset here and make sure
you're not filter out the things you're interested in -> finish ->
profile.</font>
<br>
<br><font size=2 face="sans-serif"> Navid Mehregani</font>
--=_alternative 006D6BCC85257161_=--
FUDForum. Page generated in 0.03761 seconds
