Home » Language IDEs » C / C++ IDE (CDT) » Debugger crash when expanding variable
Debugger crash when expanding variable [message #67126] Tue, 22 April 2003 18:46 Go to next message
Originally posted by: christof.frey.freesurf.ch
when trying to expand a private member variable "context" (which is
initialized) in a state pattern implementation the debugger crashes.
The error message is saying "gdb.exe has encountered a problem and needs
to be closed". After this msg box is popped up Eclipse pops up a msg box
saying "Cygwin GDB debugger timedout"
Anybody an idea what is going wrong here?
Other functions of the debugger seem to work fine (single stepping,
breakpoints, etc.)
I am using Eclipse 2.1 and the latest version of CDT in combination with
MingW tools.
CFR
Re: Debugger crash when expanding variable [message #67137 is a reply to message #67126] Tue, 22 April 2003 20:48 Go to previous message
Originally posted by: mikhailk.qnx.com
Can you send a test case?
It seems that gdb is crashing when CDT tries to get the information about
your variable.
"Christof" <christof.frey@freesurf.ch> wrote in message
news:b842lt$nfc$1@rogue.oti.com...
> breakpoints, etc.)
> MingW tools.
> CFR
Previous Topic:Projects with C/C++ and Java
Next Topic:installation bug - org.eclipse.cdt_1.0.1.jar
Current Time: Thu Dec 26 23:08:20 GMT 2024
Powered by FUDForum. Page generated in 0.03165 seconds
