How do I apply an aspect using AJDT??? [message #67103] |
Thu, 05 October 2006 14:00 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: owencorpening.yahoo.com
I have a helloworld in one package and an aspect in another. I have a
build.bat that builds and runs it, and I get the logging I expect from the
aspect. I do "create project from existing source" in eclipse - and none
of the methods in helloworld are advised .... I honestly can't figure out
how to make them "be advised".
Here is the project:
com.howdy.helloworld.java
com.tracing.HelloAspect.aj
This must be simple ... next I will want to just add an aspect jar and
apply it .... I couldn't figure out how to do any of this from watching
the demo's, which is evidently the only documentation on AJDT.
here is the .bat file in case that matters:
set classpath=%classpath%;.
ajc com\howdy\*.java com\tracing\HelloAspect.aj
java com.howdy.HelloWorld
owen
Re: How do I apply an aspect using AJDT??? [message #67121 is a reply to message #67113] |
Thu, 05 October 2006 17:41 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
I hadn't even thought to look in "help" for the docs, I never saw any
reference to any docs elsewhere, thanks.
The fundamental answer seems to have been to add the aspect to the
aspectPath under project properties ...
thanks again,
owen
Matt Chapman wrote:
> Hi Owen,
> Firstly, there is plenty of documentation for AJDT available in the
> Eclipse help system: Help > Help Contents > AspectJ Development User
> Guide. (I see this is only available after installing AJDT, not from
> the website - I'll look into adding it there).
> Building using ajc from a bat file is only really suitable for use
> outside eclipse. For use inside Eclipse you need to create an AspectJ
> project (or convert a Java project).
> Matt.
>> the aspect. I do "create project from existing source" in eclipse - and
>> none of the methods in helloworld are advised .... I honestly can't
>> figure out how to make them "be advised".
>> ajc comhowdy*.java comtracingHelloAspect.aj
>> Thanks,
>> owen
Re: How do I apply an aspect using AJDT??? [message #594895 is a reply to message #67113] |
thanks again,
owen
Matt Chapman wrote:
> Hi Owen,
> Matt.
>> Thanks,
>> owen
FUDForum. Page generated in 0.02642 seconds
