Home » Language IDEs » AspectJ » Is it possible to capture a newly initialized object in call pointcut?
Is it possible to capture a newly initialized object in call pointcut? [message #67025] Wed, 20 September 2006 19:13
Originally posted by: canterburry.gmail.com
I am pretty new at this aspect stuff and have been reading one of the
Eclipse AspectJ Books. One of the passages concerning initializer pointcuts
states:
"When the method signature of a call expression specifies a constructor,
this will provide the instance (if the call is being made from a nonstatic
context) of the object making the constructor call. target is always
unbound-this means attempts to use it to match on a type or expose the
target of the call will leave you with a pointcut that does not match the
constructor call."
So, is it then at all possible to write a pointcut that both captures the
instance of the calling object and the instance of the object just created?
I would appreciate any alternatives.
i.e
What I really want to write is this:
pointcut newEventSource(ModelChangeEventSource source,
ModelChangeEventSource listener) :
call(ModelChangeEventSource+.new(..)) &&
this(listener+) &&
target(source+) &&
within(*.core.model.*);
after (OntoModelChangeEventSource source,
OntoModelChangeEventSourcelistener) returning :
newEventSource(source, listener)
source.addModelChangeListener(new ChangeListener (listener));
This basically says (or at least should say) if any event source
instantiates any new event source, then add the first source as a listener
to the newly created source.
This is for purposes of event propagation between event sources inside a
domain model.
-HC
Previous Topic:RCP Plugins and AspectJ
Next Topic:Is it possible to capture a newly initialized object in call pointcut?
Current Time: Tue Sep 16 16:03:25 EDT 2025
Powered by FUDForum. Page generated in 0.02502 seconds
