Home » Newcomers » Newcomers » how to manually create a plugin (not from eclipse workbench)
how to manually create a plugin (not from eclipse workbench) [message #66895] Thu, 19 May 2005 18:47 Go to next message
Originally posted by: dlin.vitria.com
I have a template plugin (created by eclipse workbench). I will treat
this as a template and duplicate other plugin (manually, not through
workbench). Does anyone have any good suggestion ? Thanks.
Re: how to manually create a plugin (not from eclipse workbench) [message #67014 is a reply to message #66895] Fri, 20 May 2005 08:55 Go to previous message
Originally posted by: moserm.de.ibm.com
This is a multipart message in MIME format.
--=_alternative 0046D4A8C1257007_=
Content-Type: text/plain; charset="ISO-8859-1"
Hey..=20
If i get this right, you mean, that you dont=B4n want to use the Wizard for=
=20
create the PluginProject?!=20
check the "org.eclipse.pde.ui" plugin.=20
In the package "org.eclipse.pde.internal.ui.wizards.plugin" u will get all =
u need.=20
If u need further advice
just send me an eMail ... maybe i could give u some sample code.
Greetz
Manuel
Content-Type: text/html; charset="ISO-8859-1"
<br><font size=3D2 face=3D"sans-serif">Hey.. </font>
<br>
<br><font size=3D2 face=3D"sans-serif">If i get this right, you mean, that
you dont=B4n want to use the Wizard for create the PluginProject?! </font>
<br>
<br><font size=3D2 face=3D"sans-serif">check the &quot;org.eclipse.pde.ui&q=
uot;
plugin. </font>
<br><font size=3D2 face=3D"sans-serif">In the package &quot;org.eclipse.pde=
internal.ui.wizards.plugin&quot;
u will get all u need. </font>
<br>
<br><font size=3D2 face=3D"sans-serif">If u need further advice</font>
<br><font size=3D2 face=3D"sans-serif">just send me an eMail ... maybe i co=
uld
give u some sample code.</font>
<br>
<br><font size=3D2 face=3D"sans-serif">Greetz</font>
<br><font size=3D2 face=3D"sans-serif">Manuel</font>
<br>
--=_alternative 0046D4A8C1257007_=--
Previous Topic:eclipse crashes on suse 9.3
Next Topic:Multiplatform Installation Issue (Solaris, Linux)
Current Time: Mon Apr 28 00:43:36 EDT 2025
Powered by FUDForum. Page generated in 0.06729 seconds
