running esclipse [message #66887] |
Thu, 19 May 2005 22:43 |
Originally posted by: henry.le.u210565.wamu.net
Anybody know why Eclipse could not find the compiler even I installed both
java SDK and JRE? I also set the path corectly. If I try to build it from
the DOS prompt, it comipiled successfully.
The following is error messages:
Buildfile: D:\projects\Autoboard\build.xml
clean:
[echo] D:/Projects/autoboard/classes
compile:
[javac] Compiling 87 source files to D:\Projects\autoboard\classes
BUILD FAILED: D:\projects\Autoboard\build.xml:32: Unable to find a javac
compiler;
com.sun.tools.javac.Main is not on the classpath.
Perhaps JAVA_HOME does not point to the JDK
Thank you,
HL
Re: running esclipse [message #66984 is a reply to message #66903] |
Fri, 20 May 2005 10:59 |
Originally posted by: sandip.abc.com
I have the same problem running JSP on Eclipse.
But I can not understand the solution given by as I am new to Eclipse.
Please say in details.
Thanks in advance
Sandip
Re: running esclipse [message #67100 is a reply to message #66984] |
Fri, 20 May 2005 15:21 |
Please read the tutorials and the Help.
Eric
FUDForum. Page generated in 0.08169 seconds
