Home » Eclipse Projects » Mylyn » Ganymede & Mylyn
Ganymede & Mylyn [message #66855] |
Thu, 19 March 2009 03:15 |
Dennis Messages: 14 Registered: July 2009 |
Junior Member |
I'm trying to pull Mylyn 3.4 (all the way down to 3.1....) without any
success...
this is the most recent site I've tried...
http://download.eclipse.org/tools/mylyn/update/weekly/e3.4
running Eclipse :
Eclipse Platform
Version: 3.4.2
Build id: M20090211-1700
I receive the error:
Cannot complete the request. See the details.
Mylyn Focused UI (Recommended) is already installed, so an update
will be performed instead.
Mylyn Task List (Required) is already installed, so an update will be
performed instead.
Mylyn Bridge: Eclipse IDE is already installed, so an update will be
performed instead.
Mylyn Bridge: Team Support is already installed, so an update will be
performed instead.
Cannot find a solution satisfying the following requirements
org.eclipse.jdt.feature.jar [3.4.0.v20080603-2000-7o7tEAXEFpPqqoXxgaBhhhq].
I've tried to uninstall DTP with a glorious crash and burn, thinking that
maybe that would be the problem (I'm at 1.6.2, with no idea how to
downgrade it to 1.6.1 or anything else for that matter)
In fact if I uninstall anything in this configuration, Ganymede simply
does not start anymore.
This package is causing all kinds of problems with Ganymede, it seems
Everything wants to be bound to it, but I obviously do not have it...
Heres my config: (below the config is my error log...)
[[[ I had to clip the message, it was refused when I attempted to initial
post]]]
Re: Ganymede & Mylyn [message #66873 is a reply to message #66855] |
Thu, 19 March 2009 03:17 |
Junior Member |
*** System properties:
awt.toolkit=sun.awt.windows.WToolkit
eclipse.buildId=M20090211-1700
eclipse.commands=-os
win32
-ws
win32
-arch
x86
-showsplash
C:\Documents and
Settings\Dennis\Desktop\Ganymede\\plugins\org.eclipse.platfo rm_3.3.101.v200902111700\splash.bmp
-launcher
C:\Documents and Settings\Dennis\Desktop\Ganymede\eclipse.exe
-name
Eclipse
--launcher.library
C:\Documents and
Settings\Dennis\Desktop\Ganymede\plugins\org.eclipse.equinox .launcher.win32.win32.x86_1.0.101.R34x_v20080731\eclipse_111 5.dll
-startup
C:\Documents and
Settings\Dennis\Desktop\Ganymede\plugins\org.eclipse.equinox .launcher_1.0.101.R34x_v20081125.jar
-vm
C:\Program Files\Java\jre1.6.0_04\bin\client\jvm.dll
eclipse.ee.install.verify=false
eclipse.home.location=file:/C:/Documents and
Settings/Dennis/Desktop/Ganymede/
eclipse.launcher=C:\Documents and
eclipse.p2.data.area=@config.dir/../p2
eclipse.p2.profile=SDKProfile
eclipse.product=org.eclipse.platform.ide
eclipse.startTime=1237429353221
eclipse.vm=C:\Program Files\Java\jre1.6.0_04\bin\client\jvm.dll
eclipse.vmargs=-Xms40m
-Xmx256m
-Xms40m
-Xmx256m
-XX:MaxPermSize=256m
-Djava.class.path=C:\Documents and
file.encoding=Cp1252
file.encoding.pkg=sun.io
file.separator=\
java.awt.graphicsenv=sun.awt.Win32GraphicsEnvironment
java.awt.printerjob=sun.awt.windows.WPrinterJob
java.class.version=50.0
java.endorsed.dirs=C:\Program Files\Java\jre1.6.0_04\lib\endorsed
java.ext.dirs=C:\Program
Files\Java\jre1.6.0_04\lib\ext;C:\WINDOWS\Sun\Java\lib\ext
java.home=C:\Program Files\Java\jre1.6.0_04
java.io.tmpdir=C:\DOCUME~1\Dennis\LOCALS~1\Temp\1\
java.library.path=C:\Documents and
Settings\Dennis\Desktop\Ganymede;.;C:\WINDOWS\Sun\Java\bin;C :\WINDOWS\system32;C:\WINDOWS;C:/Program
Files/Java/jre1.6.0_04/bin/client;C:/Program
Files/Java/jre1.6.0_04/bin;C:\Program Files\Support
Tools\;C:\ColdFusion8\verity\k2\_nti40\bin;C:\WINDOWS\system 32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\Program
Files\Microsoft Windows Small Business
Server\Networking\;C:\Subversion\bin;C:\Program Files\Microsoft SQL
Server\80\Tools\Binn\;C:\Program Files\Microsoft SQL
Server\90\DTS\Binn\;C:\Program Files\Microsoft SQL
Server\90\Tools\binn\;C:\Program Files\Microsoft SQL
Server\90\Tools\Binn\VSShell\Common7\IDE\;C:\Program Files\Microsoft
Visual Studio 8\Common7\IDE\PrivateAssemblies\;C:\Program
Files\QuickTime\QTSystem\;C:\PROGRA~1\ATT\Graphviz\bin;C:\Pr ogram
Files\GNU\GnuPG\pub;C:\Program Files\TortoiseSVN\bin
java.runtime.name=Java(TM) SE Runtime Environment
java.runtime.version=1.6.0_04-b12
java.specification.name=Java Platform API Specification
java.specification.vendor=Sun Microsystems Inc.
java.specification.version=1.6
java.vendor.url=http://java.sun.com/
java.vendor.url.bug=http://java.sun.com/cgi-bin/bugreport.cgi
java.version=1.6.0_04
java.vm.info=mixed mode
java.vm.name=Java HotSpot(TM) Client VM
java.vm.specification.name=Java Virtual Machine Specification
java.vm.specification.vendor=Sun Microsystems Inc.
java.vm.specification.version=1.0
java.vm.vendor=Sun Microsystems Inc.
java.vm.version=10.0-b19
line.separator=
org.apache.commons.logging.Log=org.apache.commons.logging.im pl.SimpleLog
org.apache.commons.logging.simplelog.defaultlog=off
org.apache.commons.logging.simplelog.log.httpclient.wire.hea der=off
org.apache.commons.logging.simplelog.log.org.apache.commons. httpclient=off
org.eclipse.equinox.launcher.splash.location=C:\Documents and
org.eclipse.mylyn.context.core.context.active=true
org.osgi.framework.executionenvironment=OSGi/Minimum-1.0,OSG i/Minimum-1.1,JRE-1.1,J2SE-1.2,J2SE-1.3,J2SE-1.4,J2SE-1.5,Ja vaSE-1.6
org.osgi.framework.language=en
org.osgi.framework.os.name=Windows2003
org.osgi.framework.os.version=5.2.0
org.osgi.framework.processor=x86
org.osgi.framework.system.packages=javax.accessibility,javax .activation,javax.activity,javax.annotation,javax.annotation .processing,javax.crypto,javax.crypto.interfaces,javax.crypt o.spec,javax.imageio,javax.imageio.event,javax.imageio.metad ata,javax.imageio.plugins.bmp,javax.imageio.plugins.jpeg,jav ax.imageio.spi,javax.imageio.stream,javax.jws,javax.jws.soap ,javax.lang.model,javax.lang.model.element,javax.lang.model. type,javax.lang.model.util,javax.management,javax.management .loading,javax.management.modelmbean,javax.management.monito r,javax.management.openmbean,javax.management.relation,javax .management.remote,javax.management.remote.rmi,javax.managem ent.timer,javax.naming,javax.naming.directory,javax.naming.e vent,javax.naming.ldap,javax.naming.spi,javax.net,javax.net. ssl,javax.print,javax.print.attribute,javax.print.attribute. standard,javax.print.event,javax.rmi,javax.rmi.CORBA,javax.r mi.ssl,javax.script,javax.security.auth,javax.security.auth. callback,javax.security.auth.kerberos,javax.security.auth.lo gin,javax.security.auth.spi,javax.security.auth.x500,javax.s ecurity.cert,javax.security.sasl,javax.sound.midi,javax.soun d.midi.spi,javax.sound.sampled,javax.sound.sampled.spi,javax .sql,javax.sql.rowset,javax.sql.rowset.serial,javax.sql.rows et.spi,javax.swing,javax.swing.border,javax.swing.colorchoos er,javax.swing.event,javax.swing.filechooser,javax.swing.pla f,javax.swing.plaf.basic,javax.swing.plaf.metal,javax.swing. plaf.multi,javax.swing.plaf.synth,javax.swing.table,javax.sw ing.text,javax.swing.text.html,javax.swing.text.html.parser, javax.swing.text.rtf,javax.swing.tree,javax.swing.undo,javax .tools,javax.transaction,javax.transaction.xa,javax.xml,java x.xml.bind,javax.xml.bind.annotation,javax.xml.bind.annotati on.adapters,javax.xml.bind.attachment,javax.xml.bind.helpers ,javax.xml.bind.util,javax.xml.crypto,javax.xml.crypto.dom,j avax.xml.crypto.dsig,javax.xml.crypto.dsig.dom,javax.xml.cry pto.dsig.keyinfo,javax.xml.crypto.dsig.spec,javax.xml.dataty pe,javax.xml.namespace,javax.xml.parsers,javax.xml.soap,java x.xml.stream,javax.xml.stream.events,javax.xml.stream.util,j avax.xml.transform,javax.xml.transform.dom,javax.xml.transfo rm.sax,javax.xml.transform.stax,javax.xml.transform.stream,j avax.xml.validation,javax.xml.ws,javax.xml.ws.handler,javax. xml.ws.handler.soap,javax.xml.ws.http,javax.xml.ws.soap,java x.xml.ws.spi,javax.xml.xpath,org.ietf.jgss,org.omg.CORBA,org .omg.CORBA_2_3,org.omg.CORBA_2_3.portable,org.omg.CORBA.DynA nyPackage,org.omg.CORBA.ORBPackage,org.omg.CORBA.portable,or g.omg.CORBA.TypeCodePackage,org.omg.CosNaming,org.omg.CosNam ing.NamingContextExtPackage,org.omg.CosNaming.NamingContextP ackage,org.omg.Dynamic,org.omg.DynamicAny,org.omg.DynamicAny .DynAnyFactoryPackage,org.omg.DynamicAny.DynAnyPackage,org.o mg.IOP,org.omg.IOP.CodecFactoryPackage,org.omg.IOP.CodecPack age,org.omg.Messaging,org.omg.PortableInterceptor,org.omg.Po rtableInterceptor.ORBInitInfoPackage,org.omg.PortableServer, org.omg.PortableServer.CurrentPackage,org.omg.PortableServer .POAManagerPackage,org.omg.PortableServer.POAPackage,org.omg .PortableServer.portable,org.omg.PortableServer.ServantLocat orPackage,org.omg.SendingContext,org.omg.stub.java.rmi,org.w 3c.dom,org.w3c.dom.bootstrap,org.w3c.dom.css,org.w3c.dom.eve nts,org.w3c.dom.html,org.w3c.dom.ls,org.w3c.dom.ranges,org.w 3c.dom.stylesheets,org.w3c.dom.traversal,org.w3c.dom.views
,org.xml.sax,org.xml.sax.ext,org.xml.sax.helpers
org.osgi.framework.vendor=Eclipse
org.osgi.framework.version=1.4.0
org.osgi.supports.framework.extension=true
org.osgi.supports.framework.fragment=true
org.osgi.supports.framework.requirebundle=true
os.arch=x86
os.name=Windows 2003
os.version=5.2
osgi.arch=x86
osgi.bundles=reference:file:/C:/Documents and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.equinox.common_3.4.0.v20080421-2006.jar@2:start,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.update.configurator_3.2.201.R34x_v20080819.jar@3:start,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.core.run time_3.4.0.v20080512.jar@:start,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.releng.t ools_3.4.0.v20080414/,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.equinox. cm_1.0.1.R34x_v20090107-1200.jar,reference:file:/C:/Document s
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.equinox. device_1.0.1.v20080303.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.equinox. ds_1.0.0.v20080427-0830.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.equinox. event_1.1.0.v20080225.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.equinox. http_1.0.200.v20080421-2006.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.equinox. http.servletbridge_1.0.0.v20080427-0830.jar,reference:file:/ C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.equinox. io_1.0.0.v20080218.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.equinox. ip_1.0.0.v20080218.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.equinox. log_1.1.0.v20080414.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.equinox. metatype_1.0.0.v20070827.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.equinox. p2.ui.admin_1.0.0.v20080522-1735.jar,reference:file:/C:/Docu ments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.equinox. p2.ui.admin.rcp_1.0.0.v20080604.jar,reference:file:/C:/Docum ents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.equinox. servletbridge_1.0.101.R34x_v20090114-1346.jar,reference:file :/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.equinox. transforms.hook_1.0.0.v20080610.jar,reference:file:/C:/Docum ents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.equinox. transforms.xslt_1.0.0.v20080610.jar,reference:file:/C:/Docum ents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.equinox. useradmin_1.1.1.R34x_v20090107-1200.jar,reference:file:/C:/D ocuments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.equinox. util_1.0.0.v20080414.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.equinox. wireadmin_1.0.0.v20080407.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/javax.management_1.2 .0.v200803061811.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/javax.management.rem ote_1.0.0.v200803061811.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/javax.servlet_2.5.0. v200806031605.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.apache.commons.c odec_1.2.0.v20080530-1550.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.apache.commons.h ttpclient_3.1.0.v20080605-1935.jar,reference:file:/C:/Docume nts
and
Settings/Dennis/Desktop/eclipse/plugins/org.apache.ws.common s.util_1.0.0.v20080530-1550.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.apache.ws.jaxme_ 0.5.1.v20080530-1550.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.apache.xmlrpc_3. 0.0.v20080530-1550.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.compare. examples_3.1.100.v20060606/,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.compare. examples.xml_3.3.0.I20080604/,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.core.res ources.jmx_1.0.0.v20070510.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.debug.ex amples.core_1.0.0/,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.debug.ex amples.ui_1.0.0/,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.equinox. jmx.client_1.0.0.v20070515.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.equinox. jmx.client.rmi_1.0.0.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.equinox. jmx.client.xmlrpc_1.0.0.v20070515.jar,reference:file:/C:/Doc uments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.equinox. jmx.common_1.0.0.v20070510.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.equinox. jmx.server_1.0.0.v20071015.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.equinox. jmx.server.rmi_1.0.0.v20070510.jar,reference:file:/C:/Docume nts
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.equinox. jmx.server.xmlrpc_1.0.0.v20070608.jar,reference:file:/C:/Doc uments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.equinox. jmx.vm_1.0.0.v20070515.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.equinox. preferences.jmx_1.0.0.v20070510.jar,reference:file:/C:/Docum ents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.equinox. registry.jmx_1.0.0.v20080610-1530.jar,reference:file:/C:/Doc uments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jdt.ui.e xamples.projects_3.1.102.v20080617/,reference:file:/C:/Docum ents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jface.ex amples.databinding_1.0.100.I20080430-0100.jar,reference:file :/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.osgi.jmx _1.0.0.v20080610-1530.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.sdk.exam ples_3.1.200.v20080612/,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.swt.exam ples_3.4.0/,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.swt.exam ples.browser_3.1.100.v3448f/,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.swt.exam ples.browser.demos_3.1.200.v3448f/,reference:file:/C:/Docume nts
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.swt.exam ples.controls_3.1.100.v3448f/,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.swt.exam ples.launcher_3.1.100.v3448f/,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.swt.exam ples.layouts_3.1.100.v3448f/,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.swt.exam ples.ole.win32_3.1.100.v3448f/,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.swt.exam ples.paint_3.1.100.v3448f/,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.swt.jmx_ 1.0.0.v20070510.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.team.exa mples.filesystem_3.4.0.I20080604/,reference:file:/C:/Documen ts
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.tptp.pla tform.agentcontroller_4.2.202.v200902101418/,reference:file: /C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.tptp.pla tform.iac.administrator_4.4.201.v200901100100.jar,reference: file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.ui.examp les.contributions_3.3.0.I20080606-0100/,reference:file:/C:/D ocuments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.ui.examp les.fieldassist_1.1.0.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.ui.examp les.javaeditor_3.1.100.v20080603-2000/,reference:file:/C:/Do cuments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.ui.examp les.multipageeditor_3.2.100.I20070605-0010/,reference:file:/ C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.ui.examp les.propertysheet_3.2.0.I20070319-0010/,reference:file:/C:/D ocuments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.ui.examp les.readmetool_3.3.0.I20070606-0010/,reference:file:/C:/Docu ments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.ui.examp les.undo_3.2.100.I20080204-0800a.jar,reference:file:/C:/Docu ments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.ui.examp les.views.properties.tabbed.article_3.2.0.I20060605-1400.jar ,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/com.lowagie.itext_1. 5.4.v20080228/,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/javax.activation_1.1 .0.v200806101325.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/javax.mail_1.4.0.v20 0804091730.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/javax.wsdl_1.4.0.v20 0806030407.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/javax.wsdl_1.5.1.v20 0806030408.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/javax.xml_1.3.4.v200 806030440.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/javax.xml.rpc_1.1.0. v200806030420/,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/javax.xml.soap_1.2.0 .v200806030421/,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/net.sourceforge.lpg. lpgjavaruntime_1.1.0.v200803061910.jar,reference:file:/C:/Do cuments
and
Settings/Dennis/Desktop/eclipse/plugins/org.apache.axis_1.4. 0.v200807230600/,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.apache.batik.bri dge_1.6.0.v200805290154.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.apache.batik.css _1.6.0.v200805290154.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.apache.batik.dom _1.6.0.v200805290154.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.apache.batik.dom .svg_1.6.0.v200805290154.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.apache.batik.ext .awt_1.6.0.v200805290154.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.apache.batik.ext ension_1.6.0.v200805290154.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.apache.batik.par ser_1.6.0.v200805290154.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.apache.batik.pdf _1.6.0.v200806031500.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.apache.batik.svg gen_1.6.0.v200805290154.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.apache.batik.swi ng_1.6.0.v200805290154.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.apache.batik.tra nscoder_1.6.0.v200805290154.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.apache.batik.uti l_1.6.0.v200805290154.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.apache.batik.uti l.gui_1.6.0.v200805290154.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.apache.batik.xml _1.6.0.v200805290154.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.apache.commons.c odec_1.3.0.v20080530-1600.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.apache.commons.d iscovery_0.2.0.v200806030120/,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.apache.derby.cor e_10.3.1.4/,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.apache.log4j_1.2 .13.v200806030600.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.apache.wsil4j_1. 0.0.v200806040330.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.apache.xerces_2. 9.0.v200805270400.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.apache.xml.resol ver_1.2.0.v200806030312.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.apache.xml.seria lizer_2.7.1.v200806030322.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt_2.3 .2.r232_v20081010.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.cha rt_2.3.2.r232_v20081010.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.cha rt.cshelp_2.3.2.r232_v20081105/,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.cha rt.device.extension_2.3.2.r232_20090115.jar,reference:file:/ C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.cha rt.device.pdf_2.3.2.r232_20090115.jar,reference:file:/C:/Doc uments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.cha rt.device.svg_2.3.2.r232_20090115.jar,reference:file:/C:/Doc uments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.cha rt.device.swt_2.3.2.r232_20090115.jar,reference:file:/C:/Doc uments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.cha rt.engine_2.3.2.r232_20090211.jar,reference:file:/C:/Documen ts
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.cha rt.engine.extension_2.3.2.r232_20090115.jar,reference:file:/ C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.cha rt.examples_2.3.2.r232_20090211.jar,reference:file:/C:/Docum ents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.cha rt.integration.wtp.ui_2.3.2.r232_20081009/,reference:file:/C :/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.cha rt.reportitem_2.3.2.r232_20090115.jar,reference:file:/C:/Doc uments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.cha rt.reportitem.ui_2.3.2.r232_20090122.jar,reference:file:/C:/ Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.cha rt.runtime_2.3.2.r232_v20081010.jar,reference:file:/C:/Docum ents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.cha rt.ui_2.3.2.r232_20081218.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.cha rt.ui.extension_2.3.2.r232_20081218.jar,reference:file:/C:/D ocuments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.cor e_2.3.2.r232_20090204a.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.cor e.script.function_2.3.2.r232_v20090211.jar,reference:file:/C :/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.cor e.ui_2.3.2.r232_20081009.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.csh elp_2.3.2.r232_v20081113/,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.dat a_2.3.2.r232_v20090211.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.dat a.aggregation_2.3.2.r232_v20090211.jar,reference:file:/C:/Do cuments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.doc _2.3.2.r232_v20081105/,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.exa mple_2.3.2.r232_v20081107.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.int egration.wtp.ui_2.3.2.r232_20090122/,reference:file:/C:/Docu ments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.data.adapter_2.3.2.r232_v20090211.jar,reference:file:/C: /Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.data.oda.jdbc_2.3.2.r232_v20090212/,reference:file:/C:/D ocuments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.data.oda.jdbc.dbprofile_2.3.2.r232_v20090211.jar,referen ce:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.data.oda.jdbc.dbprofile.sampledb_2.3.2.r232_v20090211.ja r,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.data.oda.jdbc.dbprofile.ui_2.3.2.r232_v20090211.jar,refe rence:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.data.oda.jdbc.ui_2.3.2.r232_v20090211.jar,reference:file :/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.data.oda.sampledb_2.3.2.r232_v20090211/,reference:file:/ C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.data.oda.sampledb.ui_2.3.2.r232_v20090211.jar,reference: file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.data.oda.xml_2.3.2.r232_v20090211.jar,reference:file:/C: /Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.data.oda.xml.ui_2.3.2.r232_v20090211.jar,reference:file: /C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.debug.core_2.3.2.r232_20090202.jar,reference:file:/C:/Do cuments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.debug.ui_2.3.2.r232_20090202.jar,reference:file:/C:/Docu ments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.designer_2.3.2.r232_v20081010.jar,reference:file:/C:/Doc uments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.designer.core_2.3.2.r232_20090202.jar,reference:file:/C: /Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.designer.samplereports_2.3.2.r232_20090202.jar,reference :file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.designer.ui_2.3.2.r232_20090202/,reference:file:/C:/Docu ments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.designer.ui.cubebuilder_2.3.2.r232_20090202.jar,referenc e:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.designer.ui.editor.script_2.3.2.r232_20090202.jar,refere nce:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.designer.ui.editor.xml.wtp_2.3.2.r232_20090202.jar,refer ence:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.designer.ui.editors_2.3.2.r232_20090202.jar,reference:fi le:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.designer.ui.editors.schematic_2.3.2.r232_20090202.jar,re ference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.designer.ui.ide_2.3.2.r232_20090202.jar,reference:file:/ C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.designer.ui.lib_2.3.2.r232_20090202.jar,reference:file:/ C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.designer.ui.lib.explorer_2.3.2.r232_20090202.jar,referen ce:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.designer.ui.preview.web_2.3.2.r232_20090202.jar,referenc e:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.designer.ui.samples.ide_2.3.2.r232_20090202.jar,referenc e:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.designer.ui.samplesview_2.3.2.r232_20090202.jar,referenc e:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.designer.ui.views_2.3.2.r232_20090202.jar,reference:file :/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.engine_2.3.2.r232_20090217.jar,reference:file:/C:/Docume nts
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.engine.dataextraction_2.3.2.r232_20090122.jar,reference: file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.engine.dataextraction.csv_2.3.2.r232_20090122.jar,refere nce:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.engine.emitter.html_2.3.2.r232_20090202.jar,reference:fi le:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.engine.emitter.pdf_2.3.2.r232_20090202.jar,reference:fil e:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.engine.emitter.postscript_2.3.2.r232_20090202.jar,refere nce:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.engine.emitter.ppt_2.3.2.r232_20090202.jar,reference:fil e:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.engine.emitter.prototype.excel_2.3.2.r232_20090202.jar,r eference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.engine.emitter.wpml_2.3.2.r232_20090202.jar,reference:fi le:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.engine.fonts_2.3.2.r232_20090202/,reference:file:/C:/Doc uments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.item.crosstab.core_2.3.2.r232_20090202.jar,reference:fil e:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.item.crosstab.ui_2.3.2.r232_20090202.jar,reference:file: /C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.model_2.3.2.r232_20090115.jar,reference:file:/C:/Documen ts
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.model.adapter.oda_2.3.2.r232_20090108.jar,reference:file :/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.runtime_2.3.2.r232_v20081010.jar,reference:file:/C:/Docu ments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.viewer_2.3.2.r232_20090212/,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.res ources_2.3.2.r232_20081030/,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.connectivity_1.1.2.v200901090028.jar,reference:file:/C:/Do cuments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.connectivity.apache.derby_1.0.3.v200902070611.jar,referenc e:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.connectivity.apache.derby.dbdefinition_1.0.2.v200901090940 .jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.connectivity.apache.derby.ui_1.0.1.v200807010433.jar,refer ence:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.connectivity.console.profile_1.0.0.v200805231345.jar,refer ence:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.connectivity.db.generic_1.0.1.v200810140922.jar,reference: file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.connectivity.db.generic.ui_1.0.1.v200805152355.jar,referen ce:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.connectivity.dbdefinition.genericJDBC_1.0.1.v200810300511. jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.connectivity.oda_3.1.3.v200808270255.jar,reference:file:/C :/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.connectivity.oda.consumer_3.1.3.v200808270255.jar,referenc e:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.connectivity.oda.design_3.0.7.v200807231215.jar,reference: file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.connectivity.oda.design.ui_3.0.8.v200901061015.jar,referen ce:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.connectivity.oda.flatfile_3.0.8.v200812171046.jar,referenc e:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.connectivity.oda.flatfile.ui_3.0.8.v200812171046.jar,refer ence:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.connectivity.oda.profile_3.0.7.v200812050755.jar,reference :file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.connectivity.oda.template.ui_3.0.6.v200805152355.jar,refer ence:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.connectivity.sqm.core_1.0.7.v200902180551.jar,reference:fi le:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.connectivity.sqm.core.ui_1.1.3.v200902070558.jar,reference :file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.connectivity.sqm.server.ui_1.1.3.v200902120834.jar,referen ce:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.connectivity.ui_1.1.3.v200901150027.jar,reference:file:/C: /Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.connectivity.ui.dse_1.1.3.v200810140349.jar,reference:file :/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.doc.user_1.6.1.v20080828133713.jar,reference:file:/C:/Docu ments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.finfo_1.5.1.v200805152355.jar,reference:file:/C :/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.hsqldb_1.0.0.v200805152355.jar,reference:file:/ C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.hsqldb.dbdefinition_1.0.0.v200805152355.jar,ref erence:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.hsqldb.ui_1.0.0.v200807220100.jar,reference:fil e:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.ibm.db2.iseries_1.0.1.v200811210224.jar,referen ce:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.ibm.db2.iseries.dbdefinition_1.0.2.v20090109085 3.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.ibm.db2.iseries.ui_1.0.0.v200805160737.jar,refe rence:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.ibm.db2.luw_1.0.1.v200811210224.jar,reference:f ile:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.ibm.db2.luw.dbdefinition_1.0.3.v200901090853.ja r,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.ibm.db2.luw.ui_1.0.1.v200806260315.jar,referenc e:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.ibm.db2.zseries_1.0.1.v200811210224.jar,referen ce:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.ibm.db2.zseries.dbdefinition_1.0.3.v20090106093 8.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.ibm.db2.zseries.ui_1.0.0.v200805160737.jar,refe rence:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.ibm.informix_1.0.0.v200805152355.jar,reference: file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.ibm.informix.dbdefinition_1.0.3.v200811040352.j ar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.ibm.informix.ui_1.0.1.v200806260315.jar,referen ce:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.ibm.ui_1.0.0.v200806271414.jar,reference:file:/ C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.jdt.classpath_1.0.1.v200901170137.jar,reference :file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.msft.sqlserver_1.0.1.v200807181158.jar,referenc e:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.msft.sqlserver.dbdefinition_1.0.0.v200805152355 .jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.msft.sqlserver.ui_1.0.1.v200808222228.jar,refer ence:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.mysql_1.0.2.v200810160130.jar,reference:file:/C :/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.mysql.dbdefinition_1.0.4.v200901090853.jar,refe rence:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.mysql.ui_1.0.0.v200805152355.jar,reference:file :/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.oda.ws_1.1.2.v200812171046.jar,reference:file:/ C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.oda.ws.ui_1.1.2.v200901191112.jar,reference:fil e:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.oda.xml_1.1.2.v200902111040.jar,reference:file: /C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.oda.xml.ui_1.1.2.v200812171046.jar,reference:fi le:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.oracle_1.0.0.v200805152355.jar,reference:file:/ C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.oracle.dbdefinition_1.0.2.v200902030725.jar,ref erence:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.oracle.ui_1.0.1.v200806260315.jar,reference:fil e:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.postgresql_1.0.1.v200805152355.jar,reference:fi le:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.postgresql.dbdefinition_1.0.1.v200901090853.jar ,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.postgresql.ui_1.0.0.v200806060334.jar,reference :file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.sap.maxdb_1.0.0.v200805152355.jar,reference:fil e:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.sap.maxdb.dbdefinition_1.0.0.v200805152355.jar, reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.sap.maxdb.ui_1.0.0.v200805152355.jar,reference: file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.sybase_1.0.1.v200805310538.jar,reference:file:/ C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.sybase.asa_1.0.1.v200901150020.jar,reference:fi le:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.sybase.asa.dbdefinition_1.0.0.v200805240040.jar ,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.sybase.asa.models_1.0.0.v200805152355.jar,refer ence:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.sybase.asa.ui_1.0.1.v200805310538.jar,reference :file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.sybase.ase_1.0.1.v200901170012.jar,reference:fi le:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.sybase.ase.dbdefinition_1.0.0.v200805240040.jar ,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.sybase.ase.models_1.0.1.v200805152355.jar,refer ence:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.sybase.ase.ui_1.0.1.v200806260315.jar,reference :file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.sybase.models_1.0.0.v200805152355.jar,reference :file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.sybase.ui_1.0.0.v20081212.jar,reference:file:/C :/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.help_1.5.0.v200805152355.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.modelbase.dbdefinition_1.0.1.v200901090853.jar,reference:f ile:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.modelbase.derby_1.0.0.v200805152355.jar,reference:file:/C: /Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.modelbase.sql_1.0.1.v200812031125.jar,reference:file:/C:/D ocuments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.modelbase.sql.edit_1.0.0.v200805152355.jar,reference:file: /C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.modelbase.sql.query_1.0.1.v200901241145.jar,reference:file :/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.modelbase.sql.query.edit_1.0.0.v200806070329.jar,reference :file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.modelbase.sql.xml.query_1.0.0.v200807080500.jar,reference: file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.oda.cshelp_1.1.0.v200810240330.jar,reference:file:/C:/Docu ments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.sqltools.common.ui_1.0.0.v200812121740.jar,reference:file: /C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.sqltools.data.core_1.0.1.v200902140515.jar,reference:file: /C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.sqltools.data.ui_1.1.1.v200901140830.jar,reference:file:/C :/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.sqltools.db.derby_1.0.0.v200805152355.jar,reference:file:/ C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.sqltools.db.generic_1.0.0.v200902031600.jar,reference:file :/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.sqltools.ddlgen.ui_1.0.0.v200808140615.jar,reference:file: /C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.sqltools.debugger.core_1.0.0.v200808140615.jar,reference:f ile:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.sqltools.editor.core_1.0.0.v200902031600.jar,reference:fil e:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.sqltools.parsers.sql_1.0.1.v200808140615.jar,reference:fil e:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.sqltools.parsers.sql.lexer_1.0.1.v200811081015.jar,referen ce:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.sqltools.parsers.sql.query_1.0.1.v200810291500.jar,referen ce:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.sqltools.parsers.sql.xml.query_1.0.0.v200808140615.jar,ref erence:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.sqltools.plan_1.0.0.v200812121520.jar,reference:file:/C:/D ocuments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.sqltools.result_1.0.0.v200902120900.jar,reference:file:/C: /Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.sqltools.routineeditor_1.0.0.v200807211830.jar,reference:f ile:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.sqltools.sql_1.0.0.v200902031600.jar,reference:file:/C:/Do cuments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.sqltools.sqlbuilder_1.0.0.v200901280650.jar,reference:file :/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.sqltools.sqleditor_1.0.0.v200901220945.jar,reference:file: /C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.sqltools.sqlscrapbook_1.0.0.v200901151810.jar,reference:fi le:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.sqltools.tabledataeditor_1.0.0.v200901280500.jar,reference :file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.sqltools.tablewizard_1.0.0.v200808140615.jar,reference:fil e:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.draw2d_3 .4.2.v20090114-1330.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.emf_2.4. 0.v200902171115.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.emf.ant_ 2.4.0.v200902171115.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.emf.code gen_2.4.0.v200902171115.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.emf.code gen.ecore_2.4.2.v200902171115.jar,reference:file:/C:/Documen ts
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.emf.code gen.ecore.ui_2.4.1.v200902171115.jar,reference:file:/C:/Docu ments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.emf.code gen.ui_2.4.0.v200902171115.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.emf.comm on_2.4.0.v200902171115.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.emf.comm on.ui_2.4.0.v200902171115.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.emf.conv erter_2.4.0.v200902171115.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.emf.data binding_1.0.0.v200902171115.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.emf.data binding.edit_1.0.0.v200902171115.jar,reference:file:/C:/Docu ments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.emf.ecor e_2.4.2.v200902171115.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.emf.ecor e.change_2.4.0.v200902171115.jar,reference:file:/C:/Document s
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.emf.ecor e.change.edit_2.4.0.v200902171115.jar,reference:file:/C:/Doc uments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.emf.ecor e.edit_2.4.1.v200902171115.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.emf.ecor e.editor_2.4.0.v200902171115.jar,reference:file:/C:/Document s
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.emf.ecor e.xmi_2.4.1.v200902171115.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.emf.edit _2.4.2.v200902171115.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.emf.edit .ui_2.4.2.v200902171115.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.emf.expo rter_2.4.0.v200902171115.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.emf.impo rter_2.4.1.v200902171115.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.emf.impo rter.ecore_2.4.0.v200902171115.jar,reference:file:/C:/Docume nts
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.emf.impo rter.java_2.4.1.v200902171115.jar,reference:file:/C:/Documen ts
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.emf.impo rter.rose_2.4.0.v200902171115.jar,reference:file:/C:/Documen ts
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.emf.mapp ing_2.4.0.v200902171115.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.emf.mapp ing.ecore_2.4.0.v200902171115.jar,reference:file:/C:/Documen ts
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.emf.mapp ing.ecore.editor_2.4.0.v200902171115.jar,reference:file:/C:/ Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.emf.mapp ing.ecore2ecore_2.4.0.v200902171115.jar,reference:file:/C:/D ocuments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.emf.mapp ing.ecore2ecore.editor_2.4.0.v200902171115.jar,reference:fil e:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.emf.mapp ing.ecore2xml_2.4.0.v200902171115.jar,reference:file:/C:/Doc uments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.emf.mapp ing.ecore2xml.ui_2.4.0.v200902171115.jar,reference:file:/C:/ Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.emf.mapp ing.ui_2.4.0.v200902171115.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.gef_3.4. 1.v20080806.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jem_2.0. 202.v200810282000.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jem.bean info_2.0.200.v200811261206.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jem.bean info.vm_2.0.200.v200811260651.jar,reference:file:/C:/Documen ts
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jem.bean info.vm.common_2.0.200.v200811260651.jar,reference:file:/C:/ Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jem.prox y_2.0.100.v200806051600.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jem.ui_2 .0.100.v200806051600.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jem.util _2.0.100.v200805140020.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jem.work bench_2.0.102.v200810230530.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.comm on.annotations.controller_1.1.100.v200805140020.jar,referenc e:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.comm on.annotations.core_1.1.100.v200805140020.jar,reference:file :/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.comm on.annotations.ui_1.1.102.v200806010600.jar,reference:file:/ C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.comm on.frameworks_1.1.201.v200810161330.jar,reference:file:/C:/D ocuments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.comm on.project.facet.core_1.3.1.v200807031821.jar,reference:file :/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.comm on.project.facet.ui_1.3.1.v200807031821.jar,reference:file:/ C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.ejb. doc.user_1.1.100.v200810092245.jar,reference:file:/C:/Docume nts
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.ejb. ui_1.1.203.v200810010400.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.ejb. ui.infopop_1.0.100.v200805222207/,reference:file:/C:/Documen ts
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.j2ee _1.1.206.v200902052030.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.j2ee .core_1.1.203.v200901221030.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.j2ee .doc.user_1.1.1.v200808070608.jar,reference:file:/C:/Documen ts
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.j2ee .ejb_1.1.203.v200811060500.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.j2ee .ejb.annotation.model_1.1.102.v200805140020.jar,reference:fi le:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.j2ee .ejb.annotations.emitter_1.1.102.v200805140135.jar,reference :file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.j2ee .ejb.annotations.ui_1.1.102.v200805140020.jar,reference:file :/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.j2ee .ejb.annotations.xdoclet_1.2.0.v200805140020.jar,reference:f ile:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.j2ee .infopop_1.0.300.v200805140415.jar,reference:file:/C:/Docume nts
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.j2ee .jca_1.1.203.v200811060900.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.j2ee .jca.ui_1.1.200.v200805140020.jar,reference:file:/C:/Documen ts
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.j2ee .navigator.ui_1.1.203.v200901290400.jar,reference:file:/C:/D ocuments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.j2ee .ui_1.1.206.v200901280857.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.j2ee .web_1.1.203.v200901290400.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.j2ee .webservice_1.1.201.v200807240600.jar,reference:file:/C:/Doc uments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.j2ee .webservice.ui_1.1.201.v200811062130.jar,reference:file:/C:/ Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.j2ee .xdoclet.runtime_1.1.102.v200805140135.jar,reference:file:/C :/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.jee_ 1.0.103.v200901220530.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.jee. ejb_1.0.102.v200810230722.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.jee. ui_1.0.104.v200902040818.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.jee. web_1.0.101.v200810230738.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.jsf. common_1.1.4.v20090128.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.jsf. common.runtime_1.0.101.v20090128.jar,reference:file:/C:/Docu ments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.jsf. common.ui_1.1.0.v20080605.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.jsf. core_1.1.103.v200902042324.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.jsf. doc.user_1.1.100.v20080811.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.jsf. facesconfig_1.1.1.v20090129.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.jsf. facesconfig.ui_1.1.3.v20090128.jar,reference:file:/C:/Docume nts
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.jsf. standard.tagsupport_1.1.102.v20090128.jar,reference:file:/C: /Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.jsf. ui_1.1.102.v20090128.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.jsp. core_1.2.121.v200901290830.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.jsp. ui_1.1.312.v200901290909.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.jsp. ui.infopop_1.0.100.v200805301545.jar,reference:file:/C:/Docu ments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.serv er.core_1.1.3.v20090115.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.serv let.ui_1.1.203.v200810222000.jar,reference:file:/C:/Document s
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.serv let.ui.infopop_1.0.300.v200805140415.jar,reference:file:/C:/ Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.stan dard.schemas_1.0.101.v200807220523.jar,reference:file:/C:/Do cuments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.ws_1 .0.307.v200901142050.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.ws.a xis.consumption.core_1.0.306.v200810082309.jar,reference:fil e:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.ws.a xis.consumption.ui_1.0.305.v200809301934.jar,reference:file: /C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.ws.a xis.creation.ui_1.0.306.v200811200248.jar,reference:file:/C: /Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.ws.a xis.infopop_1.0.300.v200805140230.jar,reference:file:/C:/Doc uments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.ws.a xis.ui.doc.user_1.1.0.v200806092139.jar,reference:file:/C:/D ocuments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.ws.c onsumption_1.0.307.v200811220753/,reference:file:/C:/Documen ts
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.ws.c onsumption.infopop_1.0.300.v200805140230.jar,reference:file: /C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.ws.c onsumption.ui_1.1.4.v200901212148.jar,reference:file:/C:/Doc uments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.ws.c onsumption.ui.doc.user_1.0.550.v200901232040.jar,reference:f ile:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.ws.c reation.ejb.ui_1.0.200.v200805140230.jar,reference:file:/C:/ Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.ws.c reation.ui_1.0.308.v200901212148.jar,reference:file:/C:/Docu ments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.ws.d oc.user_1.0.500.v200809092107.jar,reference:file:/C:/Documen ts
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.ws.i nfopop_1.0.300.v200805140230.jar,reference:file:/C:/Document s
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.ws.u ddiregistry_1.0.300.v200805140230.jar,reference:file:/C:/Doc uments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.ws.u i_1.0.304.v200901271844.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.wst.comm and.env_1.0.308.v200811200248/,reference:file:/C:/Documents
and
Re: Ganymede & Mylyn [message #67039 is a reply to message #66855] |
Thu, 19 March 2009 03:18 |
Junior Member |
*** User Preferences:
#Wed Mar 18 20:19:23 PDT 2009
/instance/org.eclipse.core.resources/description.filestatelo ngevity=1209600000
/project/trunk/org.eclipse.wst.html.core/attrInvalidName=2
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__subclipse.tigris.org_update_1.2.x/isSyste m=false
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__subclipse.tigris.org_update_1.2.x/url=http\://subclipse.tigris.org/update_1.2.x
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/file\:_C\:_Documents\
and\
Settings_Dennis_Desktop_Ganymede_p2_org.eclipse.equinox.p2.d irector_rollback/version=1.0.0
/instance/org.eclipse.team.ui/org.eclipse.team.ui.first_time =false
and\
Settings_Dennis_Desktop_Ganymede_configuration_org.eclipse.o sgi_bundles_69_data_listener_1925729951_/url=file\:/C\:/Docu ments
and
Settings/Dennis/Desktop/Ganymede/configuration/org.eclipse.o sgi/bundles/69/data/listener_1925729951/
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__subclipse.tigris.org_update_1.4.x/enabled =true
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/file\:_C\:_Documents\
and\ Settings_Dennis_Desktop_eclipse_.eclipseextension/version=1
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_tools_buckminster_up dates/isSystem=false
and\
Settings_Dennis_Desktop_Ganymede_p2_org.eclipse.equinox.p2.d irector_rollback/type=org.eclipse.equinox.internal.p2.metada ta.repository.LocalMetadataRepository
and\
Settings_Dennis_Desktop_eclipse_configuration_org.eclipse.os gi_bundles_63_data_listener_-205926309/name=artifact
listener file\:/C\:/Documents and
Settings/Dennis/Desktop/eclipse/.eclipseextension
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_eclipse_updates_3.4/ description=
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_releases_ganymede/en abled=true
/instance/org.eclipse.ui.workbench/resourcetypes=<?xml version\="1.0"
encoding\="UTF-8"?>\r\n<editors version\="3.1">\r\n<info extension\="tag"
name\="*">\r\n<editor
id\="org.eclipse.jst.jsp.core.jspsource.source"/>\r\n</info >\r\n<info
extension\="adapter" name\="*">\r\n<editor
id\=" org.eclipse.hyades.logging.adapter.ui.internal.presentation. AdaptorEditorID "/>\r\n</info>\r\n<info
extension\="shtml" name\="*">\r\n<editor
id\="org.eclipse.ui.browser.editorSupport"/>\r\n</info>\r\n <info
extension\="cfm" name\="*">\r\n<editor
id\="org.cfeclipse.cfml.editors.CFMLEditor"/>\r\n</info>\r\n <info
extension\="umldeployment_diagram" name\="*">\r\n<editor
id\="org.eclipse.uml2.diagram.deploy.part.UMLDiagramEditorID "/>\r\n<defaultEditor
id\="org.eclipse.uml2.diagram.deploy.part.UMLDiagramEditorID "/>\r\n</info>\r\n<info
extension\="gmfgraph" name\="*">\r\n<editor
id\="org.eclipse.gmf.gmfgraph.presentation.GMFGraphEditorID "/>\r\n</info>\r\n<info
extension\="cspec" name\="*">\r\n<editor
id\="org.eclipse.buckminster.ui.editors.CSPECEditor"/>\r\n <defaultEditor
id\="org.eclipse.buckminster.ui.editors.CSPECEditor"/>\r\n </info>\r\n<info
extension\="tagf" name\="*">\r\n<editor
extension\="umlusc" name\="*">\r\n<editor
id\="org.eclipse.uml2.diagram.usecase.part.UMLDiagramEditorID "/>\r\n<defaultEditor
id\="org.eclipse.uml2.diagram.usecase.part.UMLDiagramEditorID "/>\r\n</info>\r\n<info
extension\="umlclass" name\="*">\r\n<editor
id\="org.eclipse.uml2.diagram.clazz.part.UMLDiagramEditorID "/>\r\n<defaultEditor
id\="org.eclipse.uml2.diagram.clazz.part.UMLDiagramEditorID "/>\r\n</info>\r\n<info
extension\="umlstm" name\="*">\r\n<editor
id\=" org.eclipse.uml2.diagram.statemachine.part.UMLDiagramEditorI D "/>\r\n<defaultEditor
id\=" org.eclipse.uml2.diagram.statemachine.part.UMLDiagramEditorI D "/>\r\n</info>\r\n<info
extension\="itcl" name\="*">\r\n<editor
id\="org.eclipse.dltk.tcl.ui.editor.TclEditor"/>\r\n<defaultEditor
id\="org.eclipse.dltk.tcl.ui.editor.TclEditor"/>\r\n</info >\r\n<info
extension\="js" name\="*">\r\n<editor
id\="org.eclipse.wst.jsdt.ui.CompilationUnitEditor"/>\r\n <defaultEditor
id\="org.eclipse.wst.jsdt.ui.CompilationUnitEditor"/>\r\n </info>\r\n<info
extension\="gmfmap" name\="*">\r\n<editor
id\="org.eclipse.gmf.mappings.presentation.GMFMapEditorID"/ >\r\n</info>\r\n<info
extension\="sqlpage" name\="*">\r\n<editor
id\=" org.eclipse.datatools.sqltools.sqlscrapbook.SQLScrapbookEdit or "/>\r\n<defaultEditor
id\=" org.eclipse.datatools.sqltools.sqlscrapbook.SQLScrapbookEdit or "/>\r\n</info>\r\n<info
extension\="jsp" name\="*">\r\n<editor
id\="org.eclipse.jst.jsp.core.jspsource.source"/>\r\n<editor
id\="org.eclipse.jst.pagedesigner.PageDesignerEditor"/>\r\n </info>\r\n<info
extension\="cspex" name\="*">\r\n<editor
id\="org.eclipse.buckminster.ui.editors.CSPEXEditor"/>\r\n <defaultEditor
id\="org.eclipse.buckminster.ui.editors.CSPEXEditor"/>\r\n </info>\r\n<info
extension\="override" name\="*">\r\n<editor
id\="org.eclipse.jem.beaninfo.OverrideEditor"/>\r\n</info >\r\n<info
extension\="tagx" name\="*">\r\n<editor
extension\="umlprofile_diagram" name\="*">\r\n<editor
id\="org.eclipse.uml2.diagram.profile.part.UMLDiagramEditorID "/>\r\n<defaultEditor
id\="org.eclipse.uml2.diagram.profile.part.UMLDiagramEditorID "/>\r\n</info>\r\n<info
extension\="gmfgen" name\="*">\r\n<editor
id\="org.eclipse.gmf.codegen.gmfgen.presentation.GMFGenEditorID "/>\r\n</info>\r\n<info
extension\="jspx" name\="*">\r\n<editor
extension\="properties" name\="sample">\r\n<editor
id\="org.eclipse.pde.ui.sampleEditor"/>\r\n<defaultEditor
id\="org.eclipse.pde.ui.sampleEditor"/>\r\n</info>\r\n<info
extension\="class" name\="*">\r\n<editor
id\="de.loskutov.bco.editors.BytecodeClassFileEditor"/>\r\n <defaultEditor
id\="de.loskutov.bco.editors.BytecodeClassFileEditor"/>\r\n </info>\r\n<info
extension\="jspf" name\="*">\r\n<editor
extension\="umlcsd" name\="*">\r\n<editor
id\="org.eclipse.uml2.diagram.csd.part.UMLDiagramEditorID"/ >\r\n<defaultEditor
id\="org.eclipse.uml2.diagram.csd.part.UMLDiagramEditorID"/ >\r\n</info>\r\n<info
extension\="gmftool" name\="*">\r\n<editor
id\="org.eclipse.gmf.tooldef.presentation.GMFToolEditorID"/ >\r\n</info>\r\n<info
extension\="trcpxmi" name\="*">\r\n<editor
id\=" org.eclipse.hyades.trace.ui.internal.editors.TRCProcessEdito r "/>\r\n</info>\r\n<info
extension\="cfc" name\="*">\r\n<editor
extension\="tcl" name\="*">\r\n<editor
extension\="usr" name\="*">\r\n<editor
id\="org.eclipse.ui.examples.propertysheet.UserEditor"/>\r\n </info>\r\n<info
extension\="umlusecase_diagram" name\="*">\r\n<editor
extension\="xpt" name\="*">\r\n<editor
id\="org.eclipse.gmf.xpand.XpandEditor"/>\r\n</info>\r\n <info
extension\="umlactivity_diagram" name\="*">\r\n<editor
id\="org.eclipse.uml2.diagram.activity.part.UMLDiagramEditorID "/>\r\n<defaultEditor
id\="org.eclipse.uml2.diagram.activity.part.UMLDiagramEditorID "/>\r\n</info>\r\n<info
extension\="readme" name\="*">\r\n<editor
id\="org.eclipse.ui.examples.readmetool.ReadmeEditor"/>\r\n </info>\r\n<info
extension\="cfml" name\="*">\r\n<editor
extension\="umlclass_diagram" name\="*">\r\n<editor
extension\="test" name\="*">\r\n<editor
extension\="trcnxmi" name\="*">\r\n<editor
id\="org.eclipse.hyades.trace.ui.internal.editors.TRCNodeEditor "/>\r\n</info>\r\n<info
extension\="sql" name\="*">\r\n<editor
id\=" org.eclipse.datatools.sqltools.sqlscrapbook.SQLScrapbookEdit or "/>\r\n<editor
id\="org.eclipse.datatools.sqltools.sqlbuilder"/>\r\n<defaultEditor
id\="org.eclipse.datatools.sqltools.sqlbuilder"/>\r\n</info >\r\n<info
extension\="exp" name\="*">\r\n<editor
extension\="umldepl" name\="*">\r\n<editor
extension\="jpage" name\="*">\r\n<editor
id\="org.eclipse.jdt.debug.ui.SnippetEditor"/>\r\n</info >\r\n<info
extension\="umlstatemachine_diagram" name\="*">\r\n<editor
extension\="ddl" name\="*">\r\n<editor
extension\="html" name\="*">\r\n<editor
id\="org.cfeclipse.cfml.editors.CFMLEditor"/>\r\n<editor
id\="org.eclipse.jst.pagedesigner.PageDesignerEditor"/>\r\n <editor
extension\="htm" name\="*">\r\n<editor
extension\="mpe" name\="*">\r\n<editor
id\=" org.eclipse.ui.examples.multipageeditor.MultiPageEditorExamp le "/>\r\n</info>\r\n<info
extension\="jsf" name\="*">\r\n<editor
extension\="umlcomponent_diagram" name\="*">\r\n<editor
id\="org.eclipse.uml2.diagram.component.part.UMLDiagramEditorID "/>\r\n<defaultEditor
id\="org.eclipse.uml2.diagram.component.part.UMLDiagramEditorID "/>\r\n</info>\r\n<info
extension\="xml" name\="*">\r\n<editor
id\=" org.eclipse.dd.ipxact.editor.ui.editors.IP-XACTMultiPageEdit or "/>\r\n<editor
id\=" org.eclipse.ui.examples.templateeditor.editors.TemplateEdito r "/>\r\n</info>\r\n<info
extension\="rb" name\="*">\r\n<editor
id\="org.eclipse.dltk.ruby.ui.editor.RubyEditor"/>\r\n<defaultEditor
id\="org.eclipse.dltk.ruby.ui.editor.RubyEditor"/>\r\n</info >\r\n<info
extension\="spirit" name\="*">\r\n<editor
id\=" org.eclipse.dd.ipxact.editor.ui.editors.IP-XACTMultiPageEdit or "/>\r\n</info>\r\n<info
extension\="symptom" name\="*">\r\n<editor
id\=" org.eclipse.tptp.symptom.internal.presentation.SymptomEditor "/>\r\n</info>\r\n<info
extension\="umlcompositestructures_diagram" name\="*">\r\n<editor
extension\="ecore_diagram" name\="*">\r\n<editor
id\="org.eclipse.gmf.ecore.part.EcoreDiagramEditorID"/>\r\n <defaultEditor
id\="org.eclipse.gmf.ecore.part.EcoreDiagramEditorID"/>\r\n </info>\r\n<info
extension\="trcaxmi" name\="*">\r\n<editor
id\="org.eclipse.hyades.trace.ui.internal.editors.TRCAgentEditor "/>\r\n</info>\r\n<info
extension\="xhtml" name\="*">\r\n<editor
extension\="probe" name\="*">\r\n<editor
id\=" org.eclipse.hyades.probekit.editor.internal.presentation.Pro bekitEditorID "/>\r\n<defaultEditor
id\=" org.eclipse.hyades.probekit.editor.internal.presentation.Pro bekitEditorID "/>\r\n</info>\r\n<info
extension\="rmap" name\="*">\r\n<editor
id\="org.eclipse.buckminster.ui.editors.RMAPEditor"/>\r\n <defaultEditor
id\="org.eclipse.buckminster.ui.editors.RMAPEditor"/>\r\n </info>\r\n<info
extension\="jav" name\="*">\r\n<editor
id\="org.eclipse.ui.JavaEditor"/>\r\n</info>\r\n<info extension\="xotcl"
extension\="umlcomp" name\="*">\r\n<editor
extension\="cquery" name\="*">\r\n<editor
id\="org.eclipse.buckminster.ui.editor.QueryEditor"/>\r\n <defaultEditor
id\="org.eclipse.buckminster.ui.editor.QueryEditor"/>\r\n </info>\r\n<info
extension\="umlact" name\="*">\r\n<editor
extension\="pda" name\="*">\r\n<editor id\="pda.editor"/>\r\n<editor
id\="pda.editor"/>\r\n<defaultEditor
id\="pda.editor"/>\r\n</info>\r\n<info extension\="jardesc"
id\="org.eclipse.jdt.ui.JARDescEditor"/>\r\n<defaultEditor
id\="org.eclipse.jdt.ui.JARDescEditor"/>\r\n</info>\r\n <info
extension\="trcmxmi" name\="*">\r\n<editor
id\=" org.eclipse.hyades.trace.ui.internal.editors.TRCMonitorEdito r "/>\r\n</info>\r\n<info
extension\="server" name\="*">\r\n<editor
id\="org.eclipse.wst.server.ui.editor"/>\r\n</info>\r\n <info
extension\="trcdbxmi" name\="*">\r\n<editor
id\="org.eclipse.hyades.sdb.internal.editors.SymptomDBEditor "/>\r\n</info>\r\n</editors>
/instance/org.eclipse.wst.sse.ui/useQuickDiffPrefPage=true
/instance/org.eclipse.wst.sse.core/task-tags/enabled=true
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_eclipse_updates_3.4/ name=The
Eclipse Project Updates
/instance/org.eclipse.wst.jsdt.ui/useQuickDiffPrefPage=true
and\
Settings_Dennis_Desktop_Ganymede_configuration_org.eclipse.o sgi_bundles_63_data_listener_-177846376/suffix=artifacts.xml
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_technology_emft_upda tes_/isSystem=false
@org.eclipse.dltk.mylyn=0.95.1.v20080903-1434
/instance/org.eclipse.core.resources/description.maxfilestat es=100
@org.eclipse.wst.sse.core=1.1.303.v200901290024
/instance/org.eclipse.ui.editors/changeIndicationInOverviewR uler=true
/instance/org.eclipse.datatools.connectivity/org.eclipse.dat atools.connectivity.db.derby.genericDriverTemplate=true
/instance/org.eclipse.mylyn.context.core/mylyn.attention.mig rated=true
/instance/org.eclipse.jdt.ui/useAnnotationsPrefPage=true
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__www.eclipse.org_modeling_emft_?project\=s earch\#search/enabled=false
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.taskTags =TODO
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.compiler .taskPriorities=NORMAL,HIGH,NORMAL
/instance/org.eclipse.wst.jsdt.ui/org.eclipse.wst.jsdt.ui.fo rmatterprofiles.version=11
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__subclipse.tigris.org_update_1.4.x/type=or g.eclipse.equinox.p2.updatesite.metadataRepository
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__www.cfeclipse.org_update/version=1.0.0
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__andrei.gmxhome.de_eclipse/enabled=true
and\
Settings_Dennis_Desktop_eclipse_configuration_org.eclipse.os gi_bundles_69_data_listener_1925729951/name=artifact
listener dropins
@org.eclipse.jdt.core=3.4.4.v_894_R34x
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_technology_epp_updat es_1.0_/enabled=false
/instance/org.cfeclipse.cfml/SQLTextColor=91,249,174
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__andrei.gmxhome.de_eclipse_/type=org.eclip se.equinox.p2.updatesite.metadataRepository
and\
Settings_Dennis_Desktop_eclipse_configuration_org.eclipse.os gi_bundles_63_data_listener_-205926309/url=file\:/C\:/Docume nts
and
Settings/Dennis/Desktop/eclipse/configuration/org.eclipse.os gi/bundles/63/data/listener_-205926309/
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_technology_epp_updat es_1.0/url=http\://download.eclipse.org/technology/epp/updates/1.0/
/instance/org.eclipse.rse.ui/org.eclipse.rse.preferences.ord er.connections=sagan.Local
and\
Settings_Dennis_Desktop_Ganymede_p2_org.eclipse.equinox.p2.c ore_cache/name=download
cache
/project/trunk/org.eclipse.wst.html.core/piInvalidContent=2
and\
Settings_Dennis_Desktop_eclipse_p2_org.eclipse.equinox.p2.co re_cache/url=file\:/C\:/Documents
and Settings/Dennis/Desktop/eclipse/p2/org.eclipse.equinox.p2.co re/cache/
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_tools_gef_update-sit e_releases_site.xml/url= http\://download.eclipse.org/tools/gef/update-site/releases/ site.xml
@org.eclipse.wst.jsdt.core=1.0.104.v200901281939
/instance/org.cfeclipse.cfml/cfnumberColor=226,194,148
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_tools_cdt_releases_g anymede/enabled=false
/project/trunk/org.eclipse.wst.html.core/elemEndInvalidCase= 1
/instance/org.eclipse.wst.sse.ui/matchingBracketsColor=255,0 ,128
/instance/org.cfeclipse.cfml/cfstringColor=191,205,240
and\
Settings_Dennis_Desktop_eclipse_.eclipseextension/url=file\: /C\:/Documents
and Settings/Dennis/Desktop/eclipse/.eclipseextension
/instance/org.eclipse.equinox.p2.ui.sdk/allowNonOKPlan=alway s
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__subclipse.tigris.org_update_1.4.x/version =1
/instance/org.eclipse.dltk.ui/useAnnotationsPrefPage=true
/instance/org.eclipse.dltk.ruby.ui/useAnnotationsPrefPage=tr ue
and\
Settings_Dennis_Desktop_Ganymede_.eclipseextension/url=file\ :/C\:/Documents
and Settings/Dennis/Desktop/Ganymede/.eclipseextension
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_releases_ganymede/ve rsion=1.0.0
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__www.eclipse.org_mylyn_downloads/url=http\://www.eclipse.org/mylyn/downloads/
/instance/org.eclipse.cdt.ui/useAnnotationsPrefPage=true
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__eclipse.svnkit.com_1.2.x/enabled=true
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__eclipse.org_tptp_updates_/enabled=false
/instance/org.eclipse.compare/StructureViewerAliases=CLASSPA TH.XML
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__www.eclipse.org_modeling_emft_?project\=s earch\#search/enabled=false
and\ Settings_Dennis_Desktop_eclipse/description=
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.compiler .taskCaseSensitive=enabled
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__subclipse.tigris.org_update_1.2.x/url=http\://subclipse.tigris.org/update_1.2.x
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_technology_dltk_upda tes_/enabled=false
/project/trunk/org.eclipse.mylyn.tasks.ui/project.repository .url=local
/project/trunk/org.eclipse.wst.html.core/cdataInvalidContent =2
@org.eclipse.jst.j2ee.webservice.ui=1.1.201.v200811062130
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.editor.tab.w idth=
/instance/org.eclipse.equinox.p2.ui.sdk/enabled=true
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_rt_rap_update-site/u rl=http\://download.eclipse.org/rt/rap/update-site
/instance/org.eclipse.core.resources/version=1
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_tools_buckminster_up dates/url=http\://download.eclipse.org/tools/buckminster/updates
@org.eclipse.wst.jsdt.ui=1.0.104.v200901290004
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__andrei.gmxhome.de_eclipse/version=1
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.javadoclocat ions.migrated=true
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_birt_update-site_2.3 /isSystem=false
/project/trunk/org.eclipse.wst.html.core/elemInvalidDirectiv e=1
/instance/org.eclipse.dltk.core/editor_folding_enabled=true
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_releases_ganymede/de scription=
/instance/org.eclipse.wst.jsdt.ui/org.eclipse.wst.jsdt.ui.ge ttersetter.use.is=true
/instance/org.eclipse.jdt.ui/content_assist_favorite_static_ members=
and\
Settings_Dennis_Desktop_Ganymede_configuration_org.eclipse.o sgi_bundles_63_data_listener_-177846376_/name=metadata
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_webtools_updates/isS ystem=false
@org.eclipse.rse.ui=3.0.3.v200902042310
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_releases_ganymede/na me=Ganymede
Update Site
/project/trunk/de.loskutov.anyedit.AnyEditTools/saveAndAddLi ne=false
/instance/org.eclipse.datatools.connectivity/org.eclipse.dat atools.connectivity.db.derby102.genericDriverTemplate=true
/project/trunk/org.eclipse.wst.html.core/attrNameMismatch=2
/instance/org.eclipse.jdt.ui/fontPropagated=true
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_tools_mylyn_update_w eekly_e3.4/name=Mylyn
for Eclipse 3.4
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_eclipse_updates_3.4/ enabled=true
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__andrei.gmxhome.de_eclipse/description=
/instance/org.eclipse.core.runtime/content-types/org.eclipse .wst.html.core.htmlsource/file-extensions=cfm,cfc,cfml
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_modeling_emft_update s/enabled=false
/instance/org.eclipse.ui.workbench/ENABLED_DECORATORS=org.ec lipse.jst.j2ee.navigator.ui.java.resource.decorator\:true,or g.eclipse.jst.jee.navigator.ui.java.resource.decorator\:true ,org.eclipse.team.pessimistic.ui.decorator\:true,org.eclipse .wst.server.ui.decorator\:false,org.cfeclipse.cfml.ui.decora tors.cfcdecorator\:true,org.cfeclipse.cfml.ui.decorators.cfe readonlydecorator\:true,org.eclipse.cdt.ui.indexedFiles\:fal se,org.eclipse.datatools.connectivity.sqm.core.internal.ui.e xplorer.DependencyDecoration\:true,org.eclipse.datatools.con nectivity.sqm.core.internal.ui.explorer.ColumnDecoration\:tr ue,org.eclipse.datatools.connectivity.sqm.core.internal.ui.e xplorer.ForeignKeyDecoration\:true,org.eclipse.datatools.con nectivity.sqm.core.internal.ui.explorer.IndexTriggerDecorati on\:true,org.eclipse.datatools.connectivity.internal.core.ui .bookmarkDecoration\:true,org.eclipse.datatools.connectivity .internal.core.ui.FilterNodeDecoration\:true,org.eclipse.dat atools.connectivity.ui.decorator.contentextension\:false,org .eclipse.datatools.enablement.sybase.asa.proxytabledecorator \:true,org.eclipse.datatools.enablement.sybase.ase.webservic etabledecorator\:true,org.eclipse.datatools.enablement.sybas e.systemtabledecorator\:true,org.eclipse.dd.ipxact.editor.ui .decorators.DuplicateDecorator\:true,org.eclipse.dltk.ruby.p rojectdecorator\:true,org.eclipse.dltk.tcl.decorators.projec tdecorator\:true,org.eclipse.jdt.ui.override.decorator\:true ,org.eclipse.jdt.ui.interface.decorator\:false,org.eclipse.j st.j2ee.internal.ui.util.AnnotationIconDecorator_ejb\:true,o rg.eclipse.jst.j2ee.navigator.internal.J2EEProjectDecorator\ :true,org.eclipse.jst.jee.ui.internal.navigator.ejb.BeanDeco rator\:true,org.eclipse.jst.jee.navigator.internal.JEEProjec tDecorator\:true,org.eclipse.jst.j2ee.internal.ui.util.Annot ationIconDecorator_servlet\:true,org.eclipse.mylyn.context.u i.decorator.interest\:true,org.eclipse.mylyn.tasks.ui.decora tors.task\:true,org.eclipse.mylyn.team.ui.changeset.decorato r\:true,org.eclipse.nab.mwt.ab.core.MwtManageSourceDecorator \:true,org.eclipse.pde.ui.binaryProjectDecorator\:false,org. eclipse.rse.core.virtualobject.decorator\:true,org.eclipse.r se.core.binary.executable.decorator\:true,org.eclipse.rse.co re.script.executable.decorator\:true,org.eclipse.rse.core.ja va.executable.decorator\:true,org.eclipse.rse.core.library.d ecorator\:true,org.eclipse.rse.core.link.decorator\:true,org .eclipse.rse.subsystems.error.decorator\:true,org.eclipse.te am.cvs.ui.decorator\:true,org.eclipse.tptp.monitoring.manage dagent.views.browser.decorator\:true,org.eclipse.ui.LinkedRe sourceDecorator\:true,org.eclipse.ui.ContentTypeDecorator\:t rue,org.eclipse.wst.jsdt.ui.override.decorator\:true,org.ecl ipse.wst.jsdt.ui.interface.decorator\:false,
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_technology_epp_updat es_1.0_/isSystem=false
/instance/org.eclipse.dltk.ui/editor_folding_enabled=true
@org.eclipse.ui=3.4.2.M20090204-0800
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__www.eclipse.org_modeling_emft_?project\=s earch\#search/url= http\://www.eclipse.org/modeling/emft/?project\=search\#sear ch
and\
Settings_Dennis_Desktop_eclipse_configuration_org.eclipse.os gi_bundles_63_data_listener_-205926309/version=1.0.0
/instance/org.eclipse.wst.jsdt.ui/content_assist_category_or der=org.eclipse.wst.jsdt.ui.templateProposalCategory\:0\u000 0org.eclipse.wst.jsdt.ui.javaNoTypeProposalCategory\:1\u0000 org.eclipse.wst.jsdt.ui.textProposalCategory\:2\u0000
/project/trunk/de.loskutov.FileSync/WARNING=DO NOT MODIFY THIS FILE IF YOU
DON'T UNDERSTAND
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_dsdp_nab_updates/isS ystem=false
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__eclipse.svnkit.com_1.2.x/version=1
/instance/org.cfeclipse.cfml/CFUnitFacadeLocation=localhost\ :82/net/sourceforge/cfunit/framework
/instance/org.eclipse.wst.ws.service.policy/org.eclipse.wst. ws.service.policy.ui.servicepols.wsiprofilecomp.wsissbp.defa ultProtocol=http\://schemas.xmlsoap.org/wsdl/soap/
/project/trunk/de.loskutov.anyedit.AnyEditTools/saveAndTrim= true
/instance/org.eclipse.wst.jsdt.core/org.eclipse.wst.jsdt.cor e.timeoutForParameterNameFromAttachedJavadoc=50
/instance/org.cfeclipse.cfml/htmFormTagColor=255,255,128
and\ Settings_Dennis_Desktop_eclipse/suffix=artifacts.xml
/project/trunk/org.eclipse.wst.html.core/docInvalidContent=2
@org.eclipse.dltk.core=0.95.1.v20080920-R0951
/instance/org.eclipse.jdt.ui/proposalOrderMigrated=true
and\ Settings_Dennis_Desktop_eclipse_.eclipseextension/name=C\:\\ Documents
and Settings\\Dennis\\Desktop\\eclipse\\.eclipseextension
@org.eclipse.birt.report.data.oda.jdbc.ui=2.3.2.r232_v200902 11
/instance/org.eclipse.ui.ide/BOOKMARKS_FILTERS_MIGRATE=true
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_eclipse_updates_3.4/ name=file\:/builds/M/org.eclipse.releng.eclipsebuilder/../sr c/repo
- artifacts
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__eclipse.svnkit.com_1.2.x/provider=
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_birt_update-site_2.3 /url=http\://download.eclipse.org/birt/update-site/2.3
/instance/org.cfeclipse.cfml/cfscriptfunctionColor=255,255,0
/instance/org.eclipse.wst.jsdt.ui/useAnnotationsPrefPage=tru e
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_technology_epp_updat es_1.0/isSystem=false
/instance/org.eclipse.birt.report.designer.ui/Palette\ Size=125
and\
Settings_Dennis_Desktop_Ganymede_configuration_org.eclipse.o sgi_bundles_63_data_listener_-177846376/url=file\:/C\:/Docum ents
and
Settings/Dennis/Desktop/Ganymede/configuration/org.eclipse.o sgi/bundles/63/data/listener_-177846376/
/project/trunk/de.loskutov.anyedit.AnyEditTools/removeTraili ngSpaces=true
/instance/org.eclipse.ui/defaultPerspectiveId=org.cfeclipse. cfml.perspective.CFML
and\ Settings_Dennis_Desktop_Ganymede_.eclipseextension/descripti on=
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_webtools_updates/typ e=org.eclipse.equinox.internal.p2.metadata.repository.LocalM etadataRepository
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_eclipse_updates_3.4/ version=1.0.0
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__andrei.gmxhome.de_eclipse/url=http\://andrei.gmxhome.de/eclipse/
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_dsdp_dd_updates/url=http\://download.eclipse.org/dsdp/dd/updates
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_modeling_emft_update s/url=http\://download.eclipse.org/modeling/emft/updates/
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_technology_dltk_upda tes_/isSystem=false
/instance/org.cfeclipse.cfml/cfeclipse.editor.bracketMatchin gStyle=0
/project/PROD/de.loskutov.FileSync/WARNING=DO NOT MODIFY THIS FILE IF YOU
DON'T UNDERSTAND
and\
Settings_Dennis_Desktop_eclipse_p2_org.eclipse.equinox.p2.co re_cache/suffix=artifacts.xml
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__www.cfeclipse.org_update/url=http\://www.cfeclipse.org/update
and\
Settings_Dennis_Desktop_eclipse_configuration_org.eclipse.os gi_bundles_63_data_listener_-205926309/isSystem=true
/project/PROD/de.loskutov.FileSync/defaultVariables=
and\ Settings_Dennis_Desktop_Ganymede_.eclipseextension/isSystem= true
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.forge.objectweb.org_eclipse-upda te_site.xml/url= http\://download.forge.objectweb.org/eclipse-update/site.xml
/project/trunk/org.eclipse.wst.html.core/elemUnclosedEndTag= 1
and\
Settings_Dennis_Desktop_Ganymede_configuration_org.eclipse.o sgi_bundles_69_data_listener_1925729951/provider=
and\
Settings_Dennis_Desktop_eclipse_configuration_org.eclipse.os gi_bundles_69_data_listener_1925729951/isSystem=true
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.compiler .problem.enumIdentifier=error
and\
Settings_Dennis_Desktop_eclipse_configuration_org.eclipse.os gi_bundles_69_data_listener_1925729951/url=file\:/C\:/Docume nts
and
Settings/Dennis/Desktop/eclipse/configuration/org.eclipse.os gi/bundles/69/data/listener_1925729951/
/instance/org.eclipse.dltk.mylyn/org.eclipse.dltk.mylyn.ui.f irst.run=false
@org.eclipse.mylyn.resources.ui=3.0.5.v20090218-1800-e3x
/instance/org.eclipse.jdt.ui/useQuickDiffPrefPage=true
/project/trunk/org.eclipse.wst.html.core/cdataUnclosed=1
/instance/org.eclipse.wst.jsdt.ui/org.eclipse.wst.jsdt.inter nal.ui.navigator.layout=1
and\
Settings_Dennis_Desktop_Ganymede_p2_org.eclipse.equinox.p2.c ore_cache/version=1.0.0
/instance/org.cfeclipse.cfml/cfscriptStringColor=116,237,204
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_modeling_m2m_updates _/isSystem=false
/instance/org.eclipse.ui.ide/OPEN_REQUIRED_PROJECTS=never
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_tools_cdt_releases_g anymede/isSystem=false
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_modeling_emf_updates _/isSystem=false
and\ Settings_Dennis_Desktop_eclipse/provider=
/instance/org.cfeclipse.cfml/cfeclipse.editor.showToolbar=tr ue
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_modeling_emft_update s_/isSystem=false
/configuration/org.eclipse.core.net/org.eclipse.core.net.has Migrated=true
/project/trunk/org.eclipse.mylyn.tasks.ui/project.repository .kind=local
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_modeling_mdt_updates _/isSystem=false
/instance/org.tigris.subversion.subclipse.ui/pref_merge_use_ external=true
and\ Settings_Dennis_Desktop_eclipse_.eclipseextension/isSystem=t rue
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__andrei.gmxhome.de_eclipse_/url=http\://andrei.gmxhome.de/eclipse/
/instance/org.eclipse.team.core/changeSets/SVNStatusSubscrib er/Search\
for\ Contacts.\ Code/comment=Incomplete - taskSearch for Contacts. Code \n
/instance/org.eclipse.core.net/org.eclipse.core.net.hasMigra ted=true
and\ Settings_Dennis_Desktop_Ganymede/provider=
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__andrei.gmxhome.de_eclipse/name=http\://andrei.gmxhome.de/eclipse/
/project/PROD/de.loskutov.FileSync/useCurrentDateForDestinat ionFiles=false
/project/trunk/org.eclipse.wst.html.core/elemMissingStart=1
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__subclipse.tigris.org_update_1.4.x/type=or g.eclipse.equinox.p2.updatesite.artifactRepository
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_tools_mylyn_update_e 3.4/url=http\://download.eclipse.org/tools/mylyn/update/e3.4
and\ Settings_Dennis_Desktop_Ganymede/suffix=artifacts.xml
/instance/org.eclipse.jst.jsp.core/org.eclipse.jst.jsp.core. taglib.TaglibIndex=CLEAN
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_technology_emft_upda tes/isSystem=false
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_modeling_m2m_updates /isSystem=false
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_birt_update-site_2.3 /enabled=false
and\
Settings_Dennis_Desktop_Ganymede_p2_org.eclipse.equinox.p2.c ore_cache/provider=
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.builder. resourceCopyExclusionFilter=*.launch
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_stp_updates_/enabled =false
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_releases_ganymede/en abled=true
/instance/org.eclipse.wst.jsdt.ui/org.eclipse.wst.jsdt.ui.te xt.custom_templates= <?xml
version\="1.0" encoding\="UTF-8" standalone\="no"?><templates/>
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_modeling_emft_update s/isSystem=false
/instance/org.cfeclipse.cfml/unknowTagColors=151,255,177
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_modeling_gmf_updates _releases_/url=http\://download.eclipse.org/modeling/gmf/updates/releases/
and\
Settings_Dennis_Desktop_eclipse_p2_org.eclipse.equinox.p2.co re_cache/isSystem=true
/project/trunk/org.eclipse.wst.html.core/elemInvalidContent= 2
/project/trunk/org.eclipse.wst.html.core/docDoctypeUnclosed= 1
/instance/org.eclipse.cdt.ui/useQuickDiffPrefPage=true
and\
Settings_Dennis_Desktop_eclipse_p2_org.eclipse.equinox.p2.co re_cache/name=download
cache
/instance/org.eclipse.wst.jsdt.core/org.eclipse.wst.jsdt.cor e.codeComplete.visibilityCheck=enabled
/project/trunk/de.loskutov.anyedit.AnyEditTools/replaceAllSp aces=false
and\
Settings_Dennis_Desktop_Ganymede_configuration_org.eclipse.o sgi_bundles_69_data_listener_1925729951_/type=org.eclipse.eq uinox.internal.p2.metadata.repository.LocalMetadataRepositor y
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__subclipse.tigris.org_update_1.4.x/descrip tion=
/instance/org.cfeclipse.cfml/stringColor=188,224,152
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__www.eclipse.org_mylyn_downloads_/url=http\://www.eclipse.org/mylyn/downloads/
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__eclipse.svnkit.com_1.2.x/description=
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__andrei.gmxhome.de_eclipse_/enabled=true
/instance/org.cfeclipse.cfml/SQLKeywordColor=159,205,232
and\
Settings_Dennis_Desktop_Ganymede_p2_org.eclipse.equinox.p2.d irector_rollback/url=file\:/C\:/Documents
and
Settings/Dennis/Desktop/Ganymede/p2/org.eclipse.equinox.p2.d irector/rollback
/project/trunk/org.eclipse.wst.html.core/elemCoexistence=2
/instance/org.eclipse.rse.core/org.eclipse.rse.systemtype.lo cal.systemType.defaultUserId=Dennis
/instance/org.cfeclipse.cfml/cfscriptKeywordColor=131,189,22 4
and\
Settings_Dennis_Desktop_Ganymede/type=org.eclipse.equinox.p2 .artifact.repository.simpleRepository
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__eclipse.org_tptp_updates/enabled=false
and\
Settings_Dennis_Desktop_Ganymede_configuration_org.eclipse.o sgi_bundles_69_data_listener_1925729951_/isSystem=true
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_technology_dltk_upda tes_/url=http\://download.eclipse.org/technology/dltk/updates/
/instance/org.eclipse.wst.sse.ui/hoverModifiers=combinationH over|true|0;problemHover|false|0;documentationHover|false|0; annotationHover|true|Shift;
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_technology_emft_upda tes/url=http\://download.eclipse.org/technology/emft/updates/
/instance/org.tigris.subversion.subclipse.ui/pref_merge_prog ram_location=C\:\\Program
Files\\Compare It\!\\wincmp3.exe
/instance/org.eclipse.jdt.ui/content_assist_proposals_foregr ound=0,0,0
@org.eclipse.ui.editors=3.4.0.v20080603-2000
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_eclipse_updates_3.4/ url=http\://download.eclipse.org/eclipse/updates/3.4
/instance/org.eclipse.jst.j2ee.webservice.ui/areThereWebServ ices=false
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_tools_cdt_releases_g anymede/url=http\://download.eclipse.org/tools/cdt/releases/ganymede
/project/trunk/de.loskutov.FileSync/useCurrentDateForDestina tionFiles=false
/instance/org.eclipse.mylyn.context.ui/org.eclipse.mylyn.ui. perspectives.task.none=org.cfeclipse.cfml.perspective.CFML
and\ Settings_Dennis_Desktop_eclipse_.eclipseextension/descriptio n=
@org.eclipse.cdt.ui=5.0.2.200902130801
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_tools_buckminster_up dates/isSystem=false
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.compiler .problem.assertIdentifier=error
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__www.eclipse.org_modeling_emft_updates_/is System=false
/instance/org.cfeclipse.cfml/cfeclipse.editor.warnReadOnlyFi les=false
/instance/org.eclipse.wst.jsdt.ui/proposalOrderMigrated=true
@org.eclipse.mylyn.java.ui=3.0.5.v20090218-1800-e3x
/instance/org.eclipse.team.core/changeSets/SVNStatusSubscrib er/defaultSet=Search
for Contacts. Code
/instance/org.eclipse.ui.ide/platformState=1236880094838
and\
Settings_Dennis_Desktop_eclipse/type=org.eclipse.equinox.p2. artifact.repository.simpleRepository
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.compiler .codegen.targetPlatform=1.6
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_tools_cdt_releases_g anymede/isSystem=false
and\
Settings_Dennis_Desktop_Ganymede_p2_org.eclipse.equinox.p2.c ore_cache_/type=org.eclipse.equinox.internal.p2.metadata.rep ository.LocalMetadataRepository
@org.eclipse.team.cvs.ui=3.3.100.r34x_20090121
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__eclipse.svnkit.com_1.2.x_/type=org.eclips e.equinox.p2.updatesite.metadataRepository
and\
Settings_Dennis_Desktop_Ganymede_configuration_org.eclipse.o sgi_bundles_63_data_listener_-177846376/provider=
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_releases_ganymede/ve rsion=1.0.0
/project/trunk/org.eclipse.wst.html.core/attrInvalidValue=2
/instance/org.eclipse.ui.editors/lineNumberRuler=true
/project/trunk/org.eclipse.wst.html.core/elemMissingEnd=2
/configuration/org.eclipse.ui.ide/RECENT_WORKSPACES_PROTOCOL =3
and\ Settings_Dennis_Desktop_Ganymede_.eclipseextension/version=1
/project/trunk/org.eclipse.wst.html.core/elemUnnecessaryEnd= 2
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__www.eclipse.org_modeling_emft_?project\=s earch\#search/isSystem=false
/project/trunk/org.eclipse.wst.html.core/piUnclosed=1
/instance/org.cfeclipse.cfml/cftagColor=131,173,252
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__subclipse.tigris.org_update_1.2.x/isSyste m=false
/instance/org.eclipse.team.core/changeSets/CVS\
Workspace/defaultSet=Search for Contacts. Code
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__andrei.gmxhome.de_eclipse_/version=1
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__www.cfeclipse.org_update/description=
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__eclipse.org_tptp_updates/isSystem=false
and\
Settings_Dennis_Desktop_Ganymede_p2_org.eclipse.equinox.p2.c ore_cache/description=
@org.eclipse.cdt.mylyn.ui=5.0.1.200902130801
/instance/org.cfeclipse.cfml/cfscriptTextColor=255,128,128
/project/trunk/org.eclipse.wst.html.core/attrValueMismatch=1
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_tools_mylyn_update_e 3.4/isSystem=false
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__www.eclipse.org_modeling_emft_updates/ena bled=false
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__www.eclipse.org_modeling_emft_?project\=s earch\#search/url= http\://www.eclipse.org/modeling/emft/?project\=search\#sear ch
and\
Settings_Dennis_Desktop_Ganymede_configuration_org.eclipse.o sgi_bundles_63_data_listener_-177846376/type=org.eclipse.equ inox.p2.artifact.repository.simpleRepository
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.taskPrio rities=normal
and\ Settings_Dennis_Desktop_Ganymede/description=
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__subclipse.tigris.org_update_1.4.x/provide r=
/project/trunk/org.eclipse.wst.html.core/elemInvalidName=1
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_tools_mylyn_update_e xtras/url=http\://download.eclipse.org/tools/mylyn/update/extras
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_tools_mylyn_update_e xtras/type=org.eclipse.equinox.internal.p2.metadata.reposito ry.LocalMetadataRepository
/instance/org.eclipse.debug.ui/org.eclipse.debug.ui.PREF_LAU NCH_PERSPECTIVES= <?xml
standalone\="no"?>\r\n<launchPerspectives/>\r\n
and\
Settings_Dennis_Desktop_Ganymede_.eclipseextension/name=C\:\ \Documents and
Settings\\Dennis\\Desktop\\Ganymede\\.eclipseextension
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_releases_ganymede/ty pe=org.eclipse.equinox.p2.artifact.repository.simpleReposito ry
@org.eclipse.jst.jsp.core=1.2.121.v200901290830
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_tools_mylyn_update_w eekly_e3.4/enabled=true
/instance/org.eclipse.epp.usagedata.recording/org.eclipse.ep p.usagedata.recording.last-upload=1236892187523
@org.eclipse.team.core=3.4.2.r34x_20080115
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_webtools_updates/url =http\://download.eclipse.org/webtools/updates
and\ Settings_Dennis_Desktop_eclipse/version=1.0.0
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.forge.objectweb.org_eclipse-upda te_site.xml/isSystem=false
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_rt_rap_update-site/u rl=http\://download.eclipse.org/rt/rap/update-site
/instance/org.cfeclipse.cfml/currentLineColor=95,95,95
/instance/org.eclipse.mylyn.monitor.ui/org.eclipse.mylyn.mon itor.user.activity.enabled=true
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__www.eclipse.org_mylyn_downloads/enabled=t rue
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_dsdp_tm_updates_3.0/ isSystem=false
and\
/project/trunk/org.eclipse.wst.html.core/elemUnclosedStartTa g=1
and\
Settings_Dennis_Desktop_Ganymede_configuration_org.eclipse.o sgi_bundles_63_data_listener_-177846376_/isSystem=true
/project/trunk/org.eclipse.wst.html.core/commentUnclosed=1
/instance/org.eclipse.jdt.ui/spelling_locale_initialized=tru e
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__eclipse.svnkit.com_1.2.x/name=http\://eclipse.svnkit.com/1.2.x/
/instance/org.eclipse.jdt.launching/org.eclipse.jdt.launchin g.PREF_VM_XML= <?xml
version\="1.0" encoding\="UTF-8" standalone\="no"?>\r\n<vmSettings
defaultVM\=" 57,org.eclipse.jdt.internal.debug.ui.launcher.StandardVMType 13,1236894838136 ">\r\n<vmType
id\="org.eclipse.jdt.internal.debug.ui.launcher.StandardVMType ">\r\n<vm
id\="1236894838136" javadocURL\="http\://java.sun.com/javase/6/docs/api/"
name\="jre1.6.0_04" path\="C\:\\Program
Files\\Java\\jre1.6.0_04"/>\r\n</vmType>\r\n</vmSettings >\r\n
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_tools_gef_update-sit e_releases_site.xml/enabled=false
and\ Settings_Dennis_Desktop_Ganymede_.eclipseextension/provider=
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__www.cfeclipse.org_update/name=file\:/User s/markdrew/Documents/Eclipse_Workspaces/cfeclipse2/org.cfecl ipse.cfml.update/
- artifacts
/configuration/org.eclipse.ui.ide/SHOW_WORKSPACE_SELECTION_D IALOG=false
and\
Settings_Dennis_Desktop_eclipse_configuration_org.eclipse.os gi_bundles_69_data_listener_1925729951/provider=
/instance/org.eclipse.mylyn.java.ui/org.eclipse.mylyn.ui.fir st.run.0_4_9=false
/instance/org.eclipse.equinox.p2.ui.sdk/download=true
/project/trunk/de.loskutov.FileSync/defaultVariables=
/instance/org.eclipse.mylyn.context.ui/org.eclipse.mylyn.con text.ui.close.action.manage.warning=false
and\
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__subclipse.tigris.org_update_1.2.x/enabled =false
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__www.eclipse.org_modeling_emft_updates_/ur l=http\://www.eclipse.org/modeling/emft/updates/
/instance/org.eclipse.wst.sse.ui/foldingEnabled=true
and\
Settings_Dennis_Desktop_Ganymede_p2_org.eclipse.equinox.p2.c ore_cache_/enabled=true
and\ Settings_Dennis_Desktop_Ganymede/url=file\:/C\:/Documents and
and\ Settings_Dennis_Desktop_eclipse_.eclipseextension/provider=
Re: Ganymede & Mylyn [message #67054 is a reply to message #66855] |
Thu, 19 March 2009 03:19 |
Dennis Messages: 14 Registered: July 2009 |
Junior Member |
*** Current Install Configuration:
Install configuration:
Last changed on Mar 18, 2009
Settings/Dennis/Desktop/Ganymede/configuration/org.eclipse.u pdate/platform.xml
Configured sites:
platform:/base/
file:/C:/Documents and Settings/Dennis/Desktop/Ganymede/
Configured features:
ID: org.eclipse.dd.dsf.gdb_launch, Version: 1.0.0.v20080609
2.3.2.r232_v20081010-7_7D79_doT2uMPVNwOGoz0HKuyI8
ID: org.eclipse.buckminster.cvs, Version: 1.0.0.r09930
2.3.2.r232_v20081010-4538k797M733K3737
ID: org.eclipse.nab.mwt.native, Version: 0.9.9.200806181757
1.2.0.v200805130238-11-7w311916241349
3.4.1.R342_v20090126-7w7TENgETuNblxYRhBOLydU3ADDC
1.6.2.v200810071455-3019oA55U6_7H6KAC
ID: org.eclipse.ecf.example.collab, Version: 2.1.0.v20081224-1728
ID: com.lowagie.itext, Version: 1.5.4.v20080225-1437w31191339
3.4.2.R342_v20090122-7O7S7GApJ3_vCyk7ETmsfcmjhz0eHnqw7MIjk9V dhe4Ic
ID: org.eclipse.emf.ecore, Version: 2.4.2.v200902171115
ID: org.eclipse.uml2tools.examples, Version: 0.8.0.v200809231457
ID: org.mx4j.jmx, Version: 4.4.100.v200901090956-3-37w311_12211211
1.0.0.v20080115-5318xB6CE899P233613552
1.6.2.v200810071455-443_kE77d7OAPAMJQ
1.0.2.r34x_v20090120-7d-7tEQcCaaYSBeNOClOn02267
1.6.2.v200810071455-1507w31191939244824
2.0.3.v200902181600-7J-7EB-NLwTYlTNN4PlbFLKRNHYG
2.3.2.r232_v20081010-7k8E7fELFluav5n_2NEXh3W6B9_
0.95.1.v20080626-2043-08T07w31191_1402545
2.3.2.r232_v20090212-2217s343A311_1313
ID: org.tigris.subversion.clientadapter, Version: 1.5.3
3.0.0.v20080530-7N-E8ME8McIJXIwdh
2.3.2.r232_v20081010-2217s343Aw31192216
1.1.2.R342_v20090122-7C79E9x9sLM1t6M9YD7_A7
2.1.0.v20080716-1600-7W7AE8OEHhHehFgH1yL4uOE
1.6.2.v200810071455-1-07w311_12281248
1.2.0.v200805130238-35-9oA55S5L8G6FCT
3.0.4.v200812040936-7A7NEH2E7QYGHOIsNrGpVX
3.0.4.v200811261813-7H7QECiED69XqLgwowgm-47C5J
1.5.2.v200809302010-1407w311917141519
2.1.1.v200809041200-4118s733I3J4F5C48
ID: org.eclipse.emf.common, Version: 2.4.0.v200902171115
1.6.2.v200810071455-25184B23NbbGK_OXQXHz-QP
ID: org.eclipse.uml2.search.runtime, Version: 0.7.0.v200806130939
4.4.200.v200901090956-43_77w311_121_1_67
3.0.3.v200810010400-42E_4_kE77c_FAP7X99
3.0.4.v200811211541-7F2ENnCwum8W79A1UYNgSjOcFVJg
1.1.0.v20080731-1518-7K8V4EFp_acwc90fc4fP
ID: org.apache.commons.codec, Version: 1.3.0.v20070920-12-7w3119164102711
0.95.1.v20080626-2043-0EEJ77E9IgKLhLeUz0ALs1x5
2.3.2.r232_v20081010-7N7Y7MAIe2QJZSgfOaAphGBR4t7b
ID: org.eclipse.emf.ecore.editor, Version: 2.4.0.v200902171115
ID: org.eclipse.emf.mint.doc, Version: 0.7.1.v200809162149
ID: org.tigris.subversion.subclipse.graph, Version: 1.0.5
3.4.2.R342_v20090122-9I96EiWElHi8lheoJKJIvhM3JfVsYbRrgVIWL
1.6.2.v200810071455-7D47FEB7sQSBV7hXWQ6R
1.0.2.R342_v20090122-7r7xEKaEJBZu5oGhP3u6nOmbM9VK
ID: org.tigris.subversion.subclipse.core, Version: 1.4.8
ID: org.eclipse.emf.codegen.ecore, Version: 2.4.2.v200902171115
ID: org.eclipse.emf.databinding, Version: 1.0.0.v200902171115
3.0.4.v20090115-791DC9vETDnvTGSaCQNM76BD
2.0.2.v200811110900-2-17w311922221_11
ID: org.eclipse.uml2.source, Version: 2.2.2.v200902101430
1.1.2.v20080916-2008-2108s733I3E4F15B59
1.6.2.v200810071455-6--BcMAB-BKFVEmLF
4.3.200.v200812160100-42_77w311923271211
3.4.2.v20090218-1145-67738084A6665K366B84__58x422
1.1.0.v20080716-1600-2-Ag8s733I3A7C15KCK
1.0.1.r34x_v20080721-7Y-7hEMrtGZhTrQ--t43w02267
1.6.2.v200810071455-502AgI99mASCdBYCN
0.95.1.v20080626-2043-0ECq6E8McIJXJUOr9upp-2
4.5.0.v200805132041-44-7w311916271211
2.1.0.v20090128-3219oA55U5D7N2532
3.4.2.r342_v20081217-7o7tEAoEEDWEm5HTrKn-svO4BbDI
1.6.2.v200810071455-7A-5E9IgKLjM1d1Oepu
2.3.2.r232_v20081204-2217s343A311_1233
3.0.4.v200811240900-7R0EP7E8Ks9v7urtuDJtBcaRV6Ri
1.0.1.r34x_v20080721-7T-7cEJ6Wz-YqXOBdehgpS
1.0.0.v20070608-3--8s733G3C5C
ID: org.eclipse.emf.mapping, Version: 2.4.0.v200902171115
ID: org.eclipse.emf.codegen.ecore.ui, Version: 2.4.1.v200902171115
2.1.1.v20080710-7_40AgI99m9d_O
2.1.1.v200809181500-6678AgI99m9W9X5J79
3.3.101.R34x_v20081125-7H-ELfE8hXnkE15Wh9Tnyu
ID: org.apache.derby.core, Version: 10.3.1.4
ID: org.eclipse.uml2.search.common, Version: 0.7.0.v200806130939
ID: org.eclipse.gmf.doc, Version: 1.2.2.v20080916-2008-2218s733H3H4_1673A
3.0.1.v200808091845-108Y7w31191922
1.6.2.v200810071455-3019oA55V599K5M9_
ID: org.eclipse.uml2.search.ocl, Version: 0.7.0.v200806130939
3.0.150.v200901232034-109K7w311_12343145
ID: org.eclipse.emf.edit, Version: 2.4.2.v200902171115
ID: org.eclipse.epp.usagedata.feature, Version: 1.0.1.R200809220400
3.0.3.v200810090336-40EJs_kE77c8P_TALGS
0.95.1.v20080903-1434-0Bw2_kE77c7a9N3BFKL
ID: org.eclipse.emf.converter, Version: 2.4.1.v200902171115
3.0.100.v200901232040-34EEP9oA55T5J7N9BBK
ID: org.eclipse.ocl.uml, Version: 1.2.3.v200811021759-1127w311_12182518
1.6.2.v200810071455-1507w311918132411
1.6.2.v200810071455-57_2_pFAIQJZIsLSXb8MDD
1.6.2.v200810071455-446_kE77d8H_VALOJ
ID: org.eclipse.uml2.examples, Version: 2.2.0.v200805131030
ID: org.eclipse.dd.ipxact, Version: 0.9.0.v20080609
2.3.2.r232_v20081010-67859cADAamA55V5A89
4.5.0.v200805132041-7879-8192A5695E699A2322
2.3.2.r232_v20081010-7D7J7CC7QXRK0ICmcLILD
ID: org.eclipse.emf.common.ui, Version: 2.4.0.v200902171115
ID: org.eclipse.emf.query, Version: 1.2.0.v200805130238-11-7w311916241349
ID: org.eclipse.emf.mapping.ecore.editor, Version: 2.4.0.v200902171115
ID: de.loskutov.eclipse.jdepend, Version: 1.2.1
3.0.3.v200902042310-7J378DUUEFGEpIz-AW8E
ID: org.tmatesoft.svnkit, Version: 1.2.3.5521
3.0.2.v200809102124-2518s733I3G395I75
1.6.2.v200810071455-442_kE77d7N9VANON
1.6.2.v200810071455-440_kE77c7QAQEIQQ
4.4.100.v200901090956-7B78CE9oA55S8A8M5855
3.4.200.R342_v20090122-989JESTEbig-SVaL8UJHcYBr4A63
ID: org.eclipse.releng.tools, Version: 3.2.200.v20080603-33-7w31191525
1.6.2.v200810071455-797P78CYQCD5DjGdEURT
1.6.2.v200810071455-6-2BcMAAyBWDkEVSb
3.4.2.R342_v20090122-7T7U1E9imVKz-A8Vz-p_jRS
ID: org.eclipse.uml2.doc, Version: 2.2.0.v200805201350
ID: org.eclipse.cvs, Version: 1.1.2.R342_v20090122-7C79E9x9sLM1t6M9YD7_A7
3.4.2.v20090218-1145-67728084A56B4I233613552
3.0.4.v200811251652-7E4EAvDgz-Y1htmiH5158SnFBSiT
3.0.1.v200809171630-78479_kE77c7Q8b8T_F
ID: org.eclipse.mylyn, Version: 3.0.5.v20090218-1800-e3x
ID: org.eclipse.uml2.diagram, Version: 0.8.1.v200809231457
ID: org.eclipse.dd.debug.memory.renderings, Version: 1.0.0.v20080609
1.6.2.v200810071455-7_7K7NDn-QYKjkBKlmD4edYsAX
3.0.4.v200811260650-7Q7AEf1EHhHehNmEARhS7t
1.6.2.v200810071455-7F7d7AE8yz-YIwEvOFuOF3SqVz-z
1.6.2.v200810071455-67S779KdRRFAuQFpKZ2z-0mp49Vx
3.0.4.v200811200248-7C78ELhE8VrRVqtHp4iT8PuSwZ5W
ID: org.eclipse.cdt.mylyn, Version: 5.0.2.200902130801
ID: org.eclipse.emf.mapping.ecore, Version: 2.4.0.v200902171115
ID: org.cfeclipse.cfml, Version: 1.3.2.200901041029
3.0.3.v200902042310-7H37E8qfisI6diJKMbrhR-TV-a3
4.5.0.v200805132041-7J7N-_-M7OKEQDfDTIK95C7
1.0.4.v200812112112-6-E75BcMAAyDJGhFpNN
4.5.0.v200805132041-7879-8s733I3D6B5878
ID: org.eclipse.emf.mapping.ui, Version: 2.4.0.v200902171115
4.5.0.v200805230100-7p80-E9UsMfZXChNc0so95C7
ID: org.eclipse.ecf, Version: 2.1.0.v20081224-1728
1.4.1.v200809302010-13-7w311917141518
ID: de.loskutov.FileSync, Version: 1.3.3
1.6.2.v200810071455-7D8H7P9FT9Ofz-RuiDlMiw8OR2pj
1.6.2.v200810071455-37A09oA55S6H_L8DFG24
1.2.3.v200810041753-2328s733J3_56398B
ID: org.eclipse.emf.codegen.ui, Version: 2.4.0.v200902171115
ID: org.eclipse.jst, Version: 1.0.3.v200901220134-77-E_FCYQCD5EeNgKUUY
ID: org.tigris.subversion.clientadapter.javahl, Version: 1.5.6
1.2.1.v200807161719-2308s733I3E5B4B7J
ID: org.eclipse.rse.services.ssh, Version: 2.1.1.v20080714-7830_kE77c7V8M
1.1.101.v200808291106-108Z7w3119193_2217
ID: org.eclipse.uml2.diagram.source, Version: 0.8.1.v200809231457
ID: com.sun.jna, Version: 3.0.9
ID: org.eclipse.draw2d, Version: 3.4.2.v20090218-1145-3317w311_122502441
0.95.1.v20080626-2043-0EEJ6E9IgKLhLZW8AKz0uq5
1.6.2.v200810071455-2138s733J465I548A
4.3.101.v200901090956-7B79Aj9oA55V585V5VJM
3.0.4.v20090115-20Am8s733J3_4F1256
ID: org.eclipse.emf.databinding.edit, Version: 1.0.0.v200902171115
ID: org.eclipse.dd.dsf.sdk, Version: 1.0.0.v20080609
3.0.4.v200901240221-52EFzAgI99n_WAjGIJb
ID: org.eclipse.emf.ecore.edit, Version: 2.4.1.v200902171115
ID: org.eclipse.nab.mwt, Version: 0.9.9.200806181757
ID: de.loskutov.eclipseskins.extvs, Version: 1.5.1
4.4.101.v200901090956-7F7DDr_kE77g7A7g7gQU
1.6.2.v200810071455-27A18s733I3I7I599G59
2.3.2.r232_v20081010-7X7n7WEBPrSQ6K-eN3CvLiGaMQ4d
1.0.1.r34x_v20080721-7T-7ZEIdY2TtPOAWojptd
1.6.2.v200810071455-3-29oA55S7__D7LCC
1.6.2.v200810071455-442_kE77c7VBQDFNW
3.0.3.v200902042310-7Z37HEB7sQSCRiULOVOE
2.0.1.v20080715-2-07w31191826
3.0.4.v200811240900-7G2EAzAM215iJKQCZssIGG6lQwlL
ID: org.eclipse.emf.edit.ui, Version: 2.4.2.v200902171115
ID: org.tigris.subversion.subclipse.mylyn, Version: 3.0.0
ID: de.loskutov.anyedit.AnyEditTools, Version: 2.1.3.200901071535
3.0.1.v20080730-4-CF_kE77c7SCI58GJ
0.1.3.v200902181600-2269sB9EP_M_W5B5B3822
1.6.2.v200810071455
2.3.2.r232_v20081010-2217s343A3119211_
0.95.1.v20080903-1434-09y08s733I3H3E15B_7
ID: org.eclipse.uml2, Version: 2.2.2.v200902101430
1.6.2.v200810071455-77-0CYQCD7FTIWGyPO
3.0.0.v200805040310-21CE8s733I3D4C56AA
3.0.4.v200811190840-7A-8l8Qqcz0HyVgjXUE-iuOYZ9ai
0.95.1.v20080903-1434-0AR09oA55S5N9J28GBE
ID: org.eclipse.emf.search.ecore, Version: 0.7.0.v200806130939
3.4.2.v20090218-1145-7B7E597OKBd7QHgEHNHn9JKTFJJR
ID: org.w3c.sac, Version: 1.3.0.v20080102-46-_kE77b7U_N56BA
ID: org.eclipse.tm.terminal.view, Version: 2.0.1.v20080715-2-07w31191826
ID: org.eclipse.buckminster.ui, Version: 1.1.0.r09948
4.5.0.v200805132041-44-7w311916243152
1.6.2.v200810071455-7F27SBcMAAxCcHmCNWi
ID: org.eclipse.emf, Version: 2.4.2.v200902171115
ID: org.eclipse.xsd, Version: 2.4.2.v200902171115
2.3.2.r232_v20081010-2217s343Aw31192224
2.3.2.r232_v20081010-7X8n7EELtcA6FxGJtxH7_f
1.6.2.v200810071455-6577AlJCKcLZI2Ljcc8MDD
ID: org.eclipse.emf.mint.source, Version: 0.7.1.v200809162149
1.0.0.v20080115-5318_GCGFGJMZHOMaa6PMUULSPXD
3.0.4.v200811190820-7Y7BFT1EPOwQQfPq5sVdQ6P_QtVn
ID: org.tigris.subversion.clientadapter.svnkit, Version: 1.5.6
1.6.2.v200901211403-7C67XCYQCD7ESIqIQco
1.1.3.v20090122-1525-7c7a7gEWvhKvnd6yDGljor8ukFgQ
1.0.0.v20070507-7B794E7QYGHMGxTcAasgF
ID: org.eclipse.buckminster.maven, Version: 1.1.0.r09904
ID: org.eclipse.sdk.examples.source, Version: 3.2.0.v20080611
ID: org.eclipse.buckminster.remote.feature, Version: 1.0.0.r09842
ID: org.eclipse.emf.search.runtime, Version: 0.7.0.v200806130939
3.0.4.v200811200248-7E2EH6C-2fA3PMioFSbnhI_YkSTU
ID: de.loskutov.BytecodeOutline.feature, Version: 2.2.8
1.0.0.v20070510-7F57CE9IgKLaMASi7KHI3
2.0.3.v200902181600-2-27w311_13292711
1.0.0.v20080522-1--7w3119171503111
ID: org.eclipse.ocl, Version: 1.2.3.v200810101725-3439oA55T5F8H8PAB
ID: org.eclipse.buckminster.p4.ui, Version: 1.0.0.r09908
Version: 2.3.2.r232_v20081010-787A779lxNRkRRSNH-o3EoA3OFYi
3.2.0.v20080611-837bEN1ECCP57BAaYN7HSHEb
ID: org.mozilla.rhino, Version: 1.6.7.v20071217-1567w31191325
ID: org.eclipse.pde.p2, Version: 1.0.0.v20080522-1--7w3119171503111
ID: org.eclipse.xsd.edit, Version: 2.4.0.v200902171115
ID: org.eclipse.dd.dsf.gdb, Version: 1.0.0.v20080609
ID: org.eclipse.emf.search.ecore.ocl, Version: 0.7.0.v200806130939
ID: org.eclipse.buckminster.pde, Version: 1.1.340.r09942
1.1.2.v200812041720-2138s733I573A5G73
ID: org.eclipse.emf.search.ocl, Version: 0.7.0.v200806130939
3.0.4.v200811200248-7C7_EVNE_EkMNtRvY4V6o0
ID: org.eclipse.emf.codegen, Version: 2.4.0.v200902171115
ID: org.eclipse.uml2.examples.source, Version: 2.2.0.v200805131030
ID: org.eclipse.sdk, Version: null
ID: org.eclipse.equinox.p2.user.ui, Version: null
ID: org.eclipse.cvs.source, Version: null
ID: org.eclipse.platform, Version: null
ID: org.eclipse.help.base, Version: null
ID: org.eclipse.jdt, Version: null
ID: org.eclipse.help.source, Version: null
ID: org.eclipse.rcp.source, Version: null
ID: org.eclipse.pde.source, Version: null
ID: org.eclipse.cvs, Version: null
ID: org.eclipse.rcp, Version: null
ID: org.eclipse.platform.source, Version: null
ID: org.eclipse.jdt.source, Version: null
ID: org.eclipse.equinox.p2.user.ui.source, Version: null
1.6.2.v200810071455
ID: org.eclipse.pde, Version: null
ID: org.eclipse.pde.p2.source, Version: null
ID: org.eclipse.pde.p2, Version: null
Re: Ganymede & Mylyn [message #67075 is a reply to message #66855] |
Thu, 19 March 2009 03:21 |
Junior Member |
!SESSION 2009-03-18 19:22:33.221
eclipse.buildId=M20090211-1700
java.version=1.6.0_04
Command-line arguments: -os win32 -ws win32 -arch x86
This is a continuation of log file C:\Code\DENDev\.metadata\.bak_0.log
Created Time: 2009-03-18 19:23:41.316
!ENTRY org.eclipse.ui.workbench.texteditor 4 0 2009-03-18 19:23:41.316
!MESSAGE The
'org.eclipse.wst.jsdt.web.ui.internal.hyperlink.script.JSPJa vaHyperlinkDetector'
extension from plug-in 'org.eclipse.wst.jsdt.web.ui' to the
'org.eclipse.ui.workbench.texteditor.hyperlinkDetectors' extension point
will be ignored because it contains invalid attributes.
!MESSAGE The
'org.eclipse.wst.jsdt.web.ui.internal.hyperlink.script.event .JSPJavaHyperlinkDetector'
!ENTRY org.eclipse.ui.workbench 2 0 2009-03-18 19:23:44.409
!MESSAGE A handler conflict occurred. This may disable some commands.
!SUBENTRY 1 org.eclipse.ui.workbench 2 0 2009-03-18 19:23:44.409
!MESSAGE Conflict for
'AUTOGEN:::org.cfeclipse.cfml.frameworks.contribution1/org.c feclipse.cfml.frameworks.newAction':
HandlerActivation(commandId=AUTOGEN:::org.cfeclipse.cfml.fra meworks.contribution1/org.cfeclipse.cfml.frameworks.newActio n,
handler=ActionDelegateHandlerProxy(null,org.cfeclipse.cfml.f rameworks.popup.actions.SetFrameworkFile),
expression=WorkbenchWindowExpression(org.eclipse.ui.internal.WorkbenchWindow@1e0f790),sourcePriority=16384)
handler=ActionDelegateHandlerProxy(null,org.cfeclipse.cfml.f rameworks.popup.actions.SetAsConfigFolder),
!ENTRY org.eclipse.jface 2 0 2009-03-18 19:23:44.409
!MESSAGE Keybinding conflicts occurred. They may interfere with normal
accelerator operation.
!SUBENTRY 1 org.eclipse.jface 2 0 2009-03-18 19:23:44.409
!MESSAGE A conflict occurred for CTRL+SHIFT+P:
Binding(CTRL+SHIFT+P,
ParameterizedCommand(Command(org.eclipse.ecf.presence.ui.com mands.browse,Open
Contact,
Category(org.eclipse.ecf.ui.commands.category,Communications ,null,true),
org.eclipse.ecf.internal.presence.ui.handlers.BrowseHandler,
,,true),null),
org.eclipse.ui.defaultAcceleratorConfiguration,
org.eclipse.ui.contexts.window,,,system)
ParameterizedCommand(Command(org.eclipse.emf.search.ecore.co mmon.ui.OpenFilteredEPackageMetaElementsSelectionDialogComma nd,Open
Filtered Ecore Package Meta-Elements Dialog,
Open Filtered Ecore Package Meta-Elements Dialog,
Category(org.eclipse.modeling.editors,Modeling Editors,Modeling Editors
Commands,true),
org.eclipse.emf.search.ecore.common.ui.handlers.OpenFiltered EPackageMetaElementSelectionDialogHandler,
,,true),null),
!ENTRY org.eclipse.mylyn.core 4 0 2009-03-18 19:23:47.910
!MESSAGE Context listener failed:
org.eclipse.mylyn.internal.java.ui.TypeHistoryManager
!STACK 0
java.lang.IllegalArgumentException: Class file name must end with .class
org.eclipse.jdt.internal.core.PackageFragment.getClassFile(P ackageFragment.java:182)
org.eclipse.jdt.internal.core.PackageFragment.getHandleFromM emento(PackageFragment.java:270)
org.eclipse.jdt.internal.core.JavaElement.getHandleFromMemen to(JavaElement.java:272)
org.eclipse.jdt.internal.core.PackageFragmentRoot.getHandleF romMemento(PackageFragmentRoot.java:445)
org.eclipse.jdt.internal.core.JavaProject.getHandleFromMemen to(JavaProject.java:1506)
org.eclipse.jdt.internal.core.JavaModel.getHandleFromMemento (JavaModel.java:167)
at org.eclipse.jdt.core.JavaCore.create(JavaCore.java:2353)
at org.eclipse.jdt.core.JavaCore.create(JavaCore.java:2330)
org.eclipse.mylyn.internal.java.ui.TypeHistoryManager.update TypeHistory(TypeHistoryManager.java:48)
org.eclipse.mylyn.internal.java.ui.TypeHistoryManager.contex tActivated(TypeHistoryManager.java:40)
org.eclipse.mylyn.internal.context.core.InteractionContextMa nager.internalActivateContext(InteractionContextManager.java :589)
org.eclipse.mylyn.internal.context.core.InteractionContextMa nager.activateContext(InteractionContextManager.java:159)
org.eclipse.mylyn.internal.tasks.ui.TasksUiPlugin$1.taskActi vated(TasksUiPlugin.java:264)
org.eclipse.mylyn.internal.tasks.core.TaskActivityManager.ac tivateTask(TaskActivityManager.java:413)
org.eclipse.mylyn.internal.tasks.ui.TaskListManager.activate Task(TaskListManager.java:126)
org.eclipse.mylyn.internal.tasks.ui.TasksUiPlugin$TasksUiIni tializationJob.runInUIThread(TasksUiPlugin.java:417)
at org.eclipse.ui.progress.UIJob$1.run(UIJob.java:94)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:133)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3800)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3425)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2384)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2348)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 00)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:495)
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:288)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:490)
org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:113)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:193)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:386)
!ENTRY org.eclipse.osgi 4 0 2009-03-18 19:23:49.972
!MESSAGE An error occurred while automatically activating bundle
org.eclipse.nab.mwt.jni (17354).
!STACK 0
org.osgi.framework.BundleException: The activator
org.widestudio.mwt.MwtPlugin for bundle org.eclipse.nab.mwt.jni is invalid
org.eclipse.osgi.framework.internal.core.AbstractBundle.load BundleActivator(AbstractBundle.java:146)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:980)
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:346)
org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:265)
org.eclipse.osgi.framework.util.SecureAction.start(SecureAct ion.java:400)
org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter .postFindLocalClass(EclipseLazyStarter.java:111)
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass(ClasspathManager.java:427)
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.fin dLocalClass(DefaultClassLoader.java:193)
org.eclipse.osgi.framework.internal.core.BundleLoader.findLo calClass(BundleLoader.java:370)
org.eclipse.osgi.framework.internal.core.SingleSourcePackage .loadClass(SingleSourcePackage.java:33)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl assInternal(BundleLoader.java:443)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:399)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:387)
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:87)
at java.lang.ClassLoader.loadClassInternal(Unknown Source)
at org.eclipse.nab.mwt.ab.core.CorePlugin.start(CorePlugin.java :70)
org.eclipse.osgi.framework.internal.core.BundleContextImpl$2 .run(BundleContextImpl.java:1009)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:1003)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:984)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl assInternal(BundleLoader.java:446)
org.eclipse.osgi.framework.internal.core.BundleLoader.loadCl ass(BundleLoader.java:315)
org.eclipse.osgi.framework.internal.core.BundleHost.loadClas s(BundleHost.java:227)
org.eclipse.osgi.framework.internal.core.AbstractBundle.load Class(AbstractBundle.java:1274)
org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .createExecutableExtension(RegistryStrategyOSGI.java:160)
org.eclipse.core.internal.registry.ExtensionRegistry.createE xecutableExtension(ExtensionRegistry.java:867)
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:243)
org.eclipse.core.internal.registry.ConfigurationElementHandl e.createExecutableExtension(ConfigurationElementHandle.java: 51)
at org.eclipse.ui.internal.WorkbenchPlugin$1.run(WorkbenchPlugi n.java:267)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:52)
org.eclipse.ui.internal.WorkbenchPlugin.createExtension(Work benchPlugin.java:263)
org.eclipse.ui.internal.decorators.LightweightDecoratorDefin ition$1.run(LightweightDecoratorDefinition.java:124)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
at org.eclipse.core.runtime.Platform.run(Platform.java:880)
org.eclipse.ui.internal.decorators.LightweightDecoratorDefin ition.internalGetDecorator(LightweightDecoratorDefinition.ja va:120)
org.eclipse.ui.internal.decorators.LightweightDecoratorDefin ition.decorate(LightweightDecoratorDefinition.java:251)
org.eclipse.ui.internal.decorators.LightweightDecoratorManag er$LightweightRunnable.run(LightweightDecoratorManager.java: 72)
org.eclipse.ui.internal.decorators.LightweightDecoratorManag er.decorate(LightweightDecoratorManager.java:356)
org.eclipse.ui.internal.decorators.LightweightDecoratorManag er.getDecorations(LightweightDecoratorManager.java:338)
org.eclipse.ui.internal.decorators.DecorationScheduler$1.ens ureResultCached(DecorationScheduler.java:374)
org.eclipse.ui.internal.decorators.DecorationScheduler$1.run (DecorationScheduler.java:334)
Caused by: java.lang.UnsatisfiedLinkError: no mwt_java in java.library.path
at java.lang.ClassLoader.loadLibrary(Unknown Source)
at java.lang.Runtime.loadLibrary0(Unknown Source)
at java.lang.System.loadLibrary(Unknown Source)
at org.widestudio.mwt.MwtPlugin.<clinit>(MwtPlugin.java:30)
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Nativ e Method)
at sun.reflect.NativeConstructorAccessorImpl.newInstance(Unknow n Source)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(Un known
Source)
at java.lang.reflect.Constructor.newInstance(Unknown Source)
at java.lang.Class.newInstance0(Unknown Source)
at java.lang.Class.newInstance(Unknown Source)
org.eclipse.osgi.framework.internal.core.AbstractBundle.load BundleActivator(AbstractBundle.java:141)
... 54 more
Root exception:
Source)
org.eclipse.nab.mwt (17356).
!STACK 0
org.osgi.framework.BundleException: Exception in
org.eclipse.nab.mwt.ab.core.CorePlugin.start() of bundle
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:1028)
Caused by: java.lang.NoClassDefFoundError:
org/widestudio/mwt/MwtInitializer
... 35 more
Caused by:
org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter $TerminatingClassNotFoundException:
org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter .postFindLocalClass(EclipseLazyStarter.java:125)
... 39 more
Caused by: org.osgi.framework.BundleException: The activator
... 49 more
Source)
... 54 more
Root exception:
java.lang.NoClassDefFoundError: org/widestudio/mwt/MwtInitializer
Caused by:
... 39 more
... 49 more
Source)
... 54 more
!ENTRY org.eclipse.equinox.registry 4 1 2009-03-18 19:23:49.972
!MESSAGE Plug-in org.eclipse.nab.mwt was unable to load class
org.eclipse.nab.mwt.ab.core.MwtSourceDecorator.
!STACK 0
Caused by: org.osgi.framework.BundleException: Exception in
... 30 more
... 35 more
Caused by:
... 39 more
... 49 more
Source)
... 54 more
!ENTRY org.eclipse.equinox.p2.metadata.repository 2 0 2009-03-18
19:31:59.556
!MESSAGE Error parsing metadata repository
!SUBENTRY 1 org.eclipse.equinox.p2.core 2 0 2009-03-18 19:31:59.556
!MESSAGE Error at line 10, column 99: Missing required attribute in
"repository": url
!MESSAGE Error at line 10, column 99: Illegal value for attribute "url" of
element "repository": null
!MESSAGE Error at line 11, column 102: Missing required attribute in
"repository": url
!MESSAGE Error at line 11, column 102: Illegal value for attribute "url"
of element "repository": null
!MESSAGE Error at line 12, column 99: Missing required attribute in
"repository": url
!MESSAGE Error at line 12, column 99: Illegal value for attribute "url" of
!MESSAGE Error at line 13, column 97: Missing required attribute in
"repository": url
!MESSAGE Error at line 13, column 97: Illegal value for attribute "url" of
!MESSAGE Error at line 14, column 97: Missing required attribute in
"repository": url
!MESSAGE Error at line 14, column 97: Illegal value for attribute "url" of
!MESSAGE Error at line 15, column 102: Missing required attribute in
"repository": url
!MESSAGE Error at line 15, column 102: Illegal value for attribute "url"
!ENTRY org.eclipse.equinox.p2.metadata.generator 4 0 2009-03-18
19:32:37.244
!MESSAGE Error reading site digest
C:\DOCUME~1\Dennis\LOCALS~1\Temp\1\digest23076.zip.
!STACK 0
java.util.zip.ZipException: error in opening zip file
at java.util.zip.ZipFile.open(Native Method)
at java.util.zip.ZipFile.<init>(Unknown Source)
at java.util.jar.JarFile.<init>(Unknown Source)
org.eclipse.equinox.internal.p2.metadata.generator.features. DigestParser.parse(DigestParser.java:75)
org.eclipse.equinox.internal.p2.updatesite.UpdateSite.loadFe aturesFromDigest(UpdateSite.java:402)
org.eclipse.equinox.internal.p2.updatesite.UpdateSite.loadFe atures(UpdateSite.java:375)
org.eclipse.equinox.internal.p2.updatesite.metadata.UpdateSi teMetadataRepository.generateMetadata(UpdateSiteMetadataRepo sitory.java:108)
org.eclipse.equinox.internal.p2.updatesite.metadata.UpdateSi teMetadataRepository. <init>(UpdateSiteMetadataRepository.java:73)
org.eclipse.equinox.internal.p2.updatesite.metadata.UpdateSi teMetadataRepositoryFactory.load(UpdateSiteMetadataRepositor yFactory.java:48)
org.eclipse.equinox.internal.p2.metadata.repository.Metadata RepositoryManager.loadRepository(MetadataRepositoryManager.j ava:485)
org.eclipse.equinox.internal.p2.metadata.repository.Metadata RepositoryManager.loadRepository(MetadataRepositoryManager.j ava:452)
org.eclipse.equinox.internal.p2.metadata.repository.Metadata RepositoryManager.loadRepository(MetadataRepositoryManager.j ava:435)
org.eclipse.equinox.internal.p2.director.SimplePlanner.gathe rAvailableInstallableUnits(SimplePlanner.java:196)
org.eclipse.equinox.internal.p2.director.SimplePlanner.getPr ovisioningPlan(SimplePlanner.java:235)
org.eclipse.equinox.internal.provisional.p2.ui.operations.Pr ovisioningUtil.getProvisioningPlan(ProvisioningUtil.java:210 )
org.eclipse.equinox.internal.provisional.p2.ui.actions.Insta llAction.computeProvisioningPlan(InstallAction.java:80)
org.eclipse.equinox.internal.provisional.p2.ui.actions.Insta llAction.getProvisioningPlan(InstallAction.java:130)
org.eclipse.equinox.internal.provisional.p2.ui.actions.Profi leModificationAction$1.run(ProfileModificationAction.java:61 )
org.eclipse.jface.operation.ModalContext$ModalContextThread. run(ModalContext.java:121)
!ENTRY org.eclipse.equinox.p2.director 4 0 2009-03-18 19:32:46.291
!MESSAGE Problems resolving provisioning plan.
!SUBENTRY 1 org.eclipse.equinox.p2.director 4 0 2009-03-18 19:32:46.291
!MESSAGE No solution found because the problem in
C:\DOCUME~1\Dennis\LOCALS~1\Temp\1\p2Encoding23092.opb is unsatisfiable.
!ENTRY org.eclipse.equinox.p2.ui 4 10005 2009-03-18 19:32:52.135
!MESSAGE Cannot complete the request. See the details.
!SUBENTRY 1 org.eclipse.equinox.p2.ui 4 10005 2009-03-18 19:32:52.135
!SUBENTRY 1 org.eclipse.equinox.p2.ui 1 10002 2009-03-18 19:32:52.135
!MESSAGE Mylyn Focused UI (Recommended) is already installed, so an update
will be performed instead.
!MESSAGE Mylyn Task List (Required) is already installed, so an update
!MESSAGE Mylyn Bridge: Eclipse IDE is already installed, so an update will
!MESSAGE Mylyn Bridge: Team Support is already installed, so an update
!SUBENTRY 1 org.eclipse.equinox.p2.director 4 1 2009-03-18 19:32:52.135
!MESSAGE Cannot find a solution satisfying the following requirements
org.eclipse.jdt.feature.jar [3.4.0.v20080603-2000-7o7tEAXEFpPqqoXxgaBhhhq].
19:39:20.452
!SUBENTRY 1 org.eclipse.equinox.p2.core 2 0 2009-03-18 19:39:20.452
!MESSAGE Error at line 10, column 91: Missing required attribute in
"repository": url
!MESSAGE Error at line 10, column 91: Illegal value for attribute "url" of
!MESSAGE Error at line 11, column 91: Missing required attribute in
"repository": url
!MESSAGE Error at line 11, column 91: Illegal value for attribute "url" of
!MESSAGE Error at line 12, column 90: Missing required attribute in
"repository": url
!MESSAGE Error at line 12, column 90: Illegal value for attribute "url" of
!MESSAGE Error at line 13, column 90: Missing required attribute in
"repository": url
!MESSAGE Error at line 13, column 90: Illegal value for attribute "url" of
19:39:31.015
!SUBENTRY 1 org.eclipse.equinox.p2.core 2 0 2009-03-18 19:39:31.015
"repository": url
!MESSAGE Error at line 11, column 99: Missing required attribute in
"repository": url
!MESSAGE Error at line 11, column 99: Illegal value for attribute "url" of
20:01:56.767
!SUBENTRY 1 org.eclipse.equinox.p2.core 2 0 2009-03-18 20:01:56.767
"repository": url
"repository": url
"repository": url
"repository": url
"repository": url
"repository": url
20:02:24.892
!SUBENTRY 1 org.eclipse.equinox.p2.core 2 0 2009-03-18 20:02:24.892
"repository": url
"repository": url
20:02:26.533
!SUBENTRY 1 org.eclipse.equinox.p2.core 2 0 2009-03-18 20:02:26.533
"repository": url
"repository": url
"repository": url
"repository": url
!ENTRY org.eclipse.equinox.p2.metadata.generator 2 0 2009-03-18
20:02:27.189
!MESSAGE An error occurred while loading the bundle manifest C:\Documents
and
Settings\Dennis\Desktop\Ganymede\plugins\org.eclipse.gmf.doc _1.2.2.v20080916-2008.jar
!STACK 0
org.eclipse.equinox.internal.provisional.p2.metadata.generat or.BundleDescriptionFactory.loadManifest(BundleDescriptionFa ctory.java:124)
org.eclipse.equinox.internal.provisional.p2.metadata.generat or.BundleDescriptionFactory.getBundleDescription(BundleDescr iptionFactory.java:96)
org.eclipse.equinox.internal.provisional.p2.directorywatcher .RepositoryListener.processBundle(RepositoryListener.java:23 6)
org.eclipse.equinox.internal.provisional.p2.directorywatcher .RepositoryListener.process(RepositoryListener.java:226)
org.eclipse.equinox.internal.provisional.p2.directorywatcher .RepositoryListener.added(RepositoryListener.java:201)
org.eclipse.equinox.internal.p2.extensionlocation.BundlePool FilteredListener.added(BundlePoolFilteredListener.java:39)
org.eclipse.equinox.internal.p2.extensionlocation.SiteListen er.added(SiteListener.java:284)
org.eclipse.equinox.internal.provisional.p2.directorywatcher .DirectoryWatcher.processFile(DirectoryWatcher.java:200)
org.eclipse.equinox.internal.provisional.p2.directorywatcher .DirectoryWatcher.scanDirectories(DirectoryWatcher.java:161)
org.eclipse.equinox.internal.provisional.p2.directorywatcher .DirectoryWatcher.poll(DirectoryWatcher.java:108)
org.eclipse.equinox.internal.p2.extensionlocation.ExtensionL ocationMetadataRepository.ensureInitialized(ExtensionLocatio nMetadataRepository.java:72)
org.eclipse.equinox.internal.p2.extensionlocation.ExtensionL ocationMetadataRepository.getProperties(ExtensionLocationMet adataRepository.java:159)
org.eclipse.equinox.internal.p2.metadata.repository.Metadata RepositoryManager.addRepository(MetadataRepositoryManager.ja va:110)
org.eclipse.equinox.internal.p2.metadata.repository.Metadata RepositoryManager.loadRepository(MetadataRepositoryManager.j ava:454)
!ENTRY org.eclipse.equinox.p2.director 4 0 2009-03-18 20:02:30.689
!SUBENTRY 1 org.eclipse.equinox.p2.director 2 0 2009-03-18 20:02:30.689
!MESSAGE Unable to satisfy dependency from org.eclipse.jst.j2ee.web
1.1.105.v200802192030 to requiredCapability:
osgi.bundle/org.eclipse.emf.ecore.xmi/[2.2.0,2.4.0).
osgi.bundle/org.eclipse.emf.edit/[2.2.0,2.4
Re: Ganymede & Mylyn [message #67096 is a reply to message #66855] |
Thu, 19 March 2009 11:12 |
Randall Becker Messages: 13 Registered: July 2009 |
Junior Member |
Hi Dennis,
I just tried the install based on a clean Ganymede J2EE package (3.4.1).
Here's what I did:
1. Downloaded Ganymede 3.4.1 to a clean directory
2. Started my workspace. Mylyn 3.0.4 was included.
3. I had issues here with the Java workspace settings not being loadable,
because the workspace was from 3.3.2, and I had to correct Mylyn user ids.
I
also had to restart to have my problem markers show up.
4. Launched the Ganymede Software Updates window. The Installed Software
tab
Update function didn't work, so I used the Available Software tab. There,
I
modified my Mylyn for Eclipse site to point to
http://download.eclipse.org/tools/mylyn/update/e3.4, which is different
from
the one you reported.
5. I hit the Install... button and Mylyn 3.1.0 was downloaded for me and
installed.
6. The workbench was restarted and Mylyn 3.1.0 came up cleanly with one
Information marker:
"Reset Bugzilla repository configuration cache due to format change"
I did notice that an SQL update appeared to be needed to process the Mylyn
3.1.0 update, and I allowed that through. It may have been a result of my
J2EE configuration. I hope this helps.
Randall
Dennis wrote:
> I'm trying to pull Mylyn 3.4 (all the way down to 3.1....) without any
> success...
> this is the most recent site I've tried...
> http://download.eclipse.org/tools/mylyn/update/weekly/e3.4
> running Eclipse :
> Eclipse Platform
> Version: 3.4.2
> Build id: M20090211-1700
> I receive the error:
> Mylyn Task List (Required) is already installed, so an update will be
> performed instead.
> Mylyn Bridge: Eclipse IDE is already installed, so an update will be
> performed instead.
> Mylyn Bridge: Team Support is already installed, so an update will be
> performed instead.
> I've tried to uninstall DTP with a glorious crash and burn, thinking that
> maybe that would be the problem (I'm at 1.6.2, with no idea how to
> downgrade it to 1.6.1 or anything else for that matter)
> In fact if I uninstall anything in this configuration, Ganymede simply
> does not start anymore.
> This package is causing all kinds of problems with Ganymede, it seems
> Everything wants to be bound to it, but I obviously do not have it...
> Heres my config: (below the config is my error log...)
> [[[ I had to clip the message, it was refused when I attempted to initial
> post]]]
Re: Ganymede & Mylyn [message #67127 is a reply to message #66855] |
Fri, 20 March 2009 08:57 |
Originally posted by: philippe.couton.sercel.com
When I try to update Mylyn to version 3.1, I have this error:
org.eclipse.ui.workbench [3.4.2.M20090127-1700]
My Eclipse version is 3.4.2 from the Eclipse update site
(eclipse.buildId=M20090211-1700).
Is there something to do on my side to be able to update Mylyn?
Philippe
Re: Ganymede & Mylyn [message #67182 is a reply to message #67172] |
Mon, 23 March 2009 09:28 |
It seems that my problems are due to the connector I use, which is not
yet compatible with Mylyn 3.1. I have to wait a little to use the new
stuff of Mylyn.
Anyway, thanks for your help!
Philippe
> Please try updating all installed features first. Then disable all update
> site except for the Mylyn sites and try installing/updating Mylyn.
> If that does not help, please file a bug. Please attach the list of
> installed features and plug-ins to the bug and provide steps to reproduce
> the problem.
> Steffen
Re: Ganymede & Mylyn [message #596822 is a reply to message #66855] |
Thu, 19 March 2009 03:17 |
Junior Member |
*** System properties:
awt.toolkit=sun.awt.windows.WToolkit
eclipse.commands=-os
win32
-ws
win32
-arch
x86
-showsplash
C:\Documents and
Settings\Dennis\Desktop\Ganymede\\plugins\org.eclipse.platfo rm_3.3.101.v200902111700\splash.bmp
-launcher
C:\Documents and Settings\Dennis\Desktop\Ganymede\eclipse.exe
-name
Eclipse
--launcher.library
C:\Documents and
Settings\Dennis\Desktop\Ganymede\plugins\org.eclipse.equinox .launcher.win32.win32.x86_1.0.101.R34x_v20080731\eclipse_111 5.dll
-startup
C:\Documents and
Settings\Dennis\Desktop\Ganymede\plugins\org.eclipse.equinox .launcher_1.0.101.R34x_v20081125.jar
-vm
C:\Program Files\Java\jre1.6.0_04\bin\client\jvm.dll
eclipse.ee.install.verify=false
eclipse.home.location=file:/C:/Documents and
eclipse.launcher=C:\Documents and
eclipse.p2.data.area=@config.dir/../p2
eclipse.p2.profile=SDKProfile
eclipse.product=org.eclipse.platform.ide
eclipse.startTime=1237429353221
eclipse.vm=C:\Program Files\Java\jre1.6.0_04\bin\client\jvm.dll
eclipse.vmargs=-Xms40m
-Xmx256m
-Xms40m
-Xmx256m
-XX:MaxPermSize=256m
-Djava.class.path=C:\Documents and
file.encoding=Cp1252
file.encoding.pkg=sun.io
file.separator=\
java.awt.graphicsenv=sun.awt.Win32GraphicsEnvironment
java.awt.printerjob=sun.awt.windows.WPrinterJob
java.class.version=50.0
java.endorsed.dirs=C:\Program Files\Java\jre1.6.0_04\lib\endorsed
java.ext.dirs=C:\Program
Files\Java\jre1.6.0_04\lib\ext;C:\WINDOWS\Sun\Java\lib\ext
java.home=C:\Program Files\Java\jre1.6.0_04
java.io.tmpdir=C:\DOCUME~1\Dennis\LOCALS~1\Temp\1\
java.library.path=C:\Documents and
Settings\Dennis\Desktop\Ganymede;.;C:\WINDOWS\Sun\Java\bin;C :\WINDOWS\system32;C:\WINDOWS;C:/Program
Files/Java/jre1.6.0_04/bin/client;C:/Program
Files/Java/jre1.6.0_04/bin;C:\Program Files\Support
Tools\;C:\ColdFusion8\verity\k2\_nti40\bin;C:\WINDOWS\system 32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\Program
Files\Microsoft Windows Small Business
Server\Networking\;C:\Subversion\bin;C:\Program Files\Microsoft SQL
Server\80\Tools\Binn\;C:\Program Files\Microsoft SQL
Server\90\DTS\Binn\;C:\Program Files\Microsoft SQL
Server\90\Tools\binn\;C:\Program Files\Microsoft SQL
Server\90\Tools\Binn\VSShell\Common7\IDE\;C:\Program Files\Microsoft
Visual Studio 8\Common7\IDE\PrivateAssemblies\;C:\Program
Files\QuickTime\QTSystem\;C:\PROGRA~1\ATT\Graphviz\bin;C:\Pr ogram
Files\GNU\GnuPG\pub;C:\Program Files\TortoiseSVN\bin
java.runtime.name=Java(TM) SE Runtime Environment
java.runtime.version=1.6.0_04-b12
java.specification.name=Java Platform API Specification
java.specification.vendor=Sun Microsystems Inc.
java.specification.version=1.6
java.vendor.url=http://java.sun.com/
java.vendor.url.bug=http://java.sun.com/cgi-bin/bugreport.cgi
java.vm.info=mixed mode
java.vm.name=Java HotSpot(TM) Client VM
java.vm.specification.name=Java Virtual Machine Specification
java.vm.specification.vendor=Sun Microsystems Inc.
java.vm.specification.version=1.0
java.vm.vendor=Sun Microsystems Inc.
java.vm.version=10.0-b19
line.separator=
org.apache.commons.logging.Log=org.apache.commons.logging.im pl.SimpleLog
org.apache.commons.logging.simplelog.defaultlog=off
org.apache.commons.logging.simplelog.log.httpclient.wire.hea der=off
org.apache.commons.logging.simplelog.log.org.apache.commons. httpclient=off
org.eclipse.equinox.launcher.splash.location=C:\Documents and
org.eclipse.mylyn.context.core.context.active=true
org.osgi.framework.executionenvironment=OSGi/Minimum-1.0,OSG i/Minimum-1.1,JRE-1.1,J2SE-1.2,J2SE-1.3,J2SE-1.4,J2SE-1.5,Ja vaSE-1.6
org.osgi.framework.language=en
org.osgi.framework.os.name=Windows2003
org.osgi.framework.os.version=5.2.0
org.osgi.framework.processor=x86
org.osgi.framework.system.packages=javax.accessibility,javax .activation,javax.activity,javax.annotation,javax.annotation .processing,javax.crypto,javax.crypto.interfaces,javax.crypt o.spec,javax.imageio,javax.imageio.event,javax.imageio.metad ata,javax.imageio.plugins.bmp,javax.imageio.plugins.jpeg,jav ax.imageio.spi,javax.imageio.stream,javax.jws,javax.jws.soap ,javax.lang.model,javax.lang.model.element,javax.lang.model. type,javax.lang.model.util,javax.management,javax.management .loading,javax.management.modelmbean,javax.management.monito r,javax.management.openmbean,javax.management.relation,javax .management.remote,javax.management.remote.rmi,javax.managem ent.timer,javax.naming,javax.naming.directory,javax.naming.e vent,javax.naming.ldap,javax.naming.spi,javax.net,javax.net. ssl,javax.print,javax.print.attribute,javax.print.attribute. standard,javax.print.event,javax.rmi,javax.rmi.CORBA,javax.r mi.ssl,javax.script,javax.security.auth,javax.security.auth. callback,javax.security.auth.kerberos,javax.security.auth.lo gin,javax.security.auth.spi,javax.security.auth.x500,javax.s ecurity.cert,javax.security.sasl,javax.sound.midi,javax.soun d.midi.spi,javax.sound.sampled,javax.sound.sampled.spi,javax .sql,javax.sql.rowset,javax.sql.rowset.serial,javax.sql.rows et.spi,javax.swing,javax.swing.border,javax.swing.colorchoos er,javax.swing.event,javax.swing.filechooser,javax.swing.pla f,javax.swing.plaf.basic,javax.swing.plaf.metal,javax.swing. plaf.multi,javax.swing.plaf.synth,javax.swing.table,javax.sw ing.text,javax.swing.text.html,javax.swing.text.html.parser, javax.swing.text.rtf,javax.swing.tree,javax.swing.undo,javax .tools,javax.transaction,javax.transaction.xa,javax.xml,java x.xml.bind,javax.xml.bind.annotation,javax.xml.bind.annotati on.adapters,javax.xml.bind.attachment,javax.xml.bind.helpers ,javax.xml.bind.util,javax.xml.crypto,javax.xml.crypto.dom,j avax.xml.crypto.dsig,javax.xml.crypto.dsig.dom,javax.xml.cry pto.dsig.keyinfo,javax.xml.crypto.dsig.spec,javax.xml.dataty pe,javax.xml.namespace,javax.xml.parsers,javax.xml.soap,java x.xml.stream,javax.xml.stream.events,javax.xml.stream.util,j avax.xml.transform,javax.xml.transform.dom,javax.xml.transfo rm.sax,javax.xml.transform.stax,javax.xml.transform.stream,j avax.xml.validation,javax.xml.ws,javax.xml.ws.handler,javax. xml.ws.handler.soap,javax.xml.ws.http,javax.xml.ws.soap,java x.xml.ws.spi,javax.xml.xpath,org.ietf.jgss,org.omg.CORBA,org .omg.CORBA_2_3,org.omg.CORBA_2_3.portable,org.omg.CORBA.DynA nyPackage,org.omg.CORBA.ORBPackage,org.omg.CORBA.portable,or g.omg.CORBA.TypeCodePackage,org.omg.CosNaming,org.omg.CosNam ing.NamingContextExtPackage,org.omg.CosNaming.NamingContextP ackage,org.omg.Dynamic,org.omg.DynamicAny,org.omg.DynamicAny .DynAnyFactoryPackage,org.omg.DynamicAny.DynAnyPackage,org.o mg.IOP,org.omg.IOP.CodecFactoryPackage,org.omg.IOP.CodecPack age,org.omg.Messaging,org.omg.PortableInterceptor,org.omg.Po rtableInterceptor.ORBInitInfoPackage,org.omg.PortableServer, org.omg.PortableServer.CurrentPackage,org.omg.PortableServer .POAManagerPackage,org.omg.PortableServer.POAPackage,org.omg .PortableServer.portable,org.omg.PortableServer.ServantLocat orPackage,org.omg.SendingContext,org.omg.stub.java.rmi,org.w 3c.dom,org.w3c.dom.bootstrap,org.w3c.dom.css,org.w3c.dom.eve nts,org.w3c.dom.html,org.w3c.dom.ls,org.w3c.dom.ranges,org.w 3c.dom.stylesheets,org.w3c.dom.traversal,org.w3c.dom.views
,org.xml.sax,org.xml.sax.ext,org.xml.sax.helpers
org.osgi.framework.vendor=Eclipse
org.osgi.framework.version=1.4.0
org.osgi.supports.framework.extension=true
org.osgi.supports.framework.fragment=true
org.osgi.supports.framework.requirebundle=true
os.arch=x86
os.name=Windows 2003
os.version=5.2
osgi.arch=x86
osgi.bundles=reference:file:/C:/Documents and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.equinox.common_3.4.0.v20080421-2006.jar@2:start,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.update.configurator_3.2.201.R34x_v20080819.jar@3:start,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.core.run time_3.4.0.v20080512.jar@:start,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.releng.t ools_3.4.0.v20080414/,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.equinox. cm_1.0.1.R34x_v20090107-1200.jar,reference:file:/C:/Document s
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.equinox. device_1.0.1.v20080303.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.equinox. ds_1.0.0.v20080427-0830.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.equinox. event_1.1.0.v20080225.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.equinox. http_1.0.200.v20080421-2006.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.equinox. http.servletbridge_1.0.0.v20080427-0830.jar,reference:file:/ C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.equinox. io_1.0.0.v20080218.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.equinox. ip_1.0.0.v20080218.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.equinox. log_1.1.0.v20080414.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.equinox. metatype_1.0.0.v20070827.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.equinox. p2.ui.admin_1.0.0.v20080522-1735.jar,reference:file:/C:/Docu ments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.equinox. p2.ui.admin.rcp_1.0.0.v20080604.jar,reference:file:/C:/Docum ents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.equinox. servletbridge_1.0.101.R34x_v20090114-1346.jar,reference:file :/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.equinox. transforms.hook_1.0.0.v20080610.jar,reference:file:/C:/Docum ents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.equinox. transforms.xslt_1.0.0.v20080610.jar,reference:file:/C:/Docum ents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.equinox. useradmin_1.1.1.R34x_v20090107-1200.jar,reference:file:/C:/D ocuments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.equinox. util_1.0.0.v20080414.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.equinox. wireadmin_1.0.0.v20080407.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/javax.management_1.2 .0.v200803061811.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/javax.management.rem ote_1.0.0.v200803061811.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/javax.servlet_2.5.0. v200806031605.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.apache.commons.c odec_1.2.0.v20080530-1550.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.apache.commons.h ttpclient_3.1.0.v20080605-1935.jar,reference:file:/C:/Docume nts
and
Settings/Dennis/Desktop/eclipse/plugins/org.apache.ws.common s.util_1.0.0.v20080530-1550.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.apache.ws.jaxme_ 0.5.1.v20080530-1550.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.apache.xmlrpc_3. 0.0.v20080530-1550.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.compare. examples_3.1.100.v20060606/,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.compare. examples.xml_3.3.0.I20080604/,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.core.res ources.jmx_1.0.0.v20070510.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.debug.ex amples.core_1.0.0/,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.debug.ex amples.ui_1.0.0/,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.equinox. jmx.client_1.0.0.v20070515.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.equinox. jmx.client.rmi_1.0.0.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.equinox. jmx.client.xmlrpc_1.0.0.v20070515.jar,reference:file:/C:/Doc uments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.equinox. jmx.common_1.0.0.v20070510.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.equinox. jmx.server_1.0.0.v20071015.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.equinox. jmx.server.rmi_1.0.0.v20070510.jar,reference:file:/C:/Docume nts
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.equinox. jmx.server.xmlrpc_1.0.0.v20070608.jar,reference:file:/C:/Doc uments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.equinox. jmx.vm_1.0.0.v20070515.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.equinox. preferences.jmx_1.0.0.v20070510.jar,reference:file:/C:/Docum ents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.equinox. registry.jmx_1.0.0.v20080610-1530.jar,reference:file:/C:/Doc uments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jdt.ui.e xamples.projects_3.1.102.v20080617/,reference:file:/C:/Docum ents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jface.ex amples.databinding_1.0.100.I20080430-0100.jar,reference:file :/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.osgi.jmx _1.0.0.v20080610-1530.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.sdk.exam ples_3.1.200.v20080612/,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.swt.exam ples_3.4.0/,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.swt.exam ples.browser_3.1.100.v3448f/,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.swt.exam ples.browser.demos_3.1.200.v3448f/,reference:file:/C:/Docume nts
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.swt.exam ples.controls_3.1.100.v3448f/,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.swt.exam ples.launcher_3.1.100.v3448f/,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.swt.exam ples.layouts_3.1.100.v3448f/,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.swt.exam ples.ole.win32_3.1.100.v3448f/,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.swt.exam ples.paint_3.1.100.v3448f/,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.swt.jmx_ 1.0.0.v20070510.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.team.exa mples.filesystem_3.4.0.I20080604/,reference:file:/C:/Documen ts
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.tptp.pla tform.agentcontroller_4.2.202.v200902101418/,reference:file: /C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.tptp.pla tform.iac.administrator_4.4.201.v200901100100.jar,reference: file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.ui.examp les.contributions_3.3.0.I20080606-0100/,reference:file:/C:/D ocuments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.ui.examp les.fieldassist_1.1.0.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.ui.examp les.javaeditor_3.1.100.v20080603-2000/,reference:file:/C:/Do cuments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.ui.examp les.multipageeditor_3.2.100.I20070605-0010/,reference:file:/ C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.ui.examp les.propertysheet_3.2.0.I20070319-0010/,reference:file:/C:/D ocuments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.ui.examp les.readmetool_3.3.0.I20070606-0010/,reference:file:/C:/Docu ments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.ui.examp les.undo_3.2.100.I20080204-0800a.jar,reference:file:/C:/Docu ments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.ui.examp les.views.properties.tabbed.article_3.2.0.I20060605-1400.jar ,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/com.lowagie.itext_1. 5.4.v20080228/,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/javax.activation_1.1 .0.v200806101325.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/javax.mail_1.4.0.v20 0804091730.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/javax.wsdl_1.4.0.v20 0806030407.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/javax.wsdl_1.5.1.v20 0806030408.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/javax.xml_1.3.4.v200 806030440.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/javax.xml.rpc_1.1.0. v200806030420/,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/javax.xml.soap_1.2.0 .v200806030421/,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/net.sourceforge.lpg. lpgjavaruntime_1.1.0.v200803061910.jar,reference:file:/C:/Do cuments
and
Settings/Dennis/Desktop/eclipse/plugins/org.apache.axis_1.4. 0.v200807230600/,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.apache.batik.bri dge_1.6.0.v200805290154.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.apache.batik.css _1.6.0.v200805290154.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.apache.batik.dom _1.6.0.v200805290154.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.apache.batik.dom .svg_1.6.0.v200805290154.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.apache.batik.ext .awt_1.6.0.v200805290154.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.apache.batik.ext ension_1.6.0.v200805290154.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.apache.batik.par ser_1.6.0.v200805290154.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.apache.batik.pdf _1.6.0.v200806031500.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.apache.batik.svg gen_1.6.0.v200805290154.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.apache.batik.swi ng_1.6.0.v200805290154.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.apache.batik.tra nscoder_1.6.0.v200805290154.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.apache.batik.uti l_1.6.0.v200805290154.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.apache.batik.uti l.gui_1.6.0.v200805290154.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.apache.batik.xml _1.6.0.v200805290154.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.apache.commons.c odec_1.3.0.v20080530-1600.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.apache.commons.d iscovery_0.2.0.v200806030120/,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.apache.derby.cor e_10.3.1.4/,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.apache.log4j_1.2 .13.v200806030600.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.apache.wsil4j_1. 0.0.v200806040330.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.apache.xerces_2. 9.0.v200805270400.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.apache.xml.resol ver_1.2.0.v200806030312.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.apache.xml.seria lizer_2.7.1.v200806030322.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt_2.3 .2.r232_v20081010.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.cha rt_2.3.2.r232_v20081010.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.cha rt.cshelp_2.3.2.r232_v20081105/,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.cha rt.device.extension_2.3.2.r232_20090115.jar,reference:file:/ C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.cha rt.device.pdf_2.3.2.r232_20090115.jar,reference:file:/C:/Doc uments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.cha rt.device.svg_2.3.2.r232_20090115.jar,reference:file:/C:/Doc uments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.cha rt.device.swt_2.3.2.r232_20090115.jar,reference:file:/C:/Doc uments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.cha rt.engine_2.3.2.r232_20090211.jar,reference:file:/C:/Documen ts
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.cha rt.engine.extension_2.3.2.r232_20090115.jar,reference:file:/ C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.cha rt.examples_2.3.2.r232_20090211.jar,reference:file:/C:/Docum ents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.cha rt.integration.wtp.ui_2.3.2.r232_20081009/,reference:file:/C :/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.cha rt.reportitem_2.3.2.r232_20090115.jar,reference:file:/C:/Doc uments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.cha rt.reportitem.ui_2.3.2.r232_20090122.jar,reference:file:/C:/ Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.cha rt.runtime_2.3.2.r232_v20081010.jar,reference:file:/C:/Docum ents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.cha rt.ui_2.3.2.r232_20081218.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.cha rt.ui.extension_2.3.2.r232_20081218.jar,reference:file:/C:/D ocuments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.cor e_2.3.2.r232_20090204a.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.cor e.script.function_2.3.2.r232_v20090211.jar,reference:file:/C :/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.cor e.ui_2.3.2.r232_20081009.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.csh elp_2.3.2.r232_v20081113/,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.dat a_2.3.2.r232_v20090211.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.dat a.aggregation_2.3.2.r232_v20090211.jar,reference:file:/C:/Do cuments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.doc _2.3.2.r232_v20081105/,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.exa mple_2.3.2.r232_v20081107.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.int egration.wtp.ui_2.3.2.r232_20090122/,reference:file:/C:/Docu ments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.data.adapter_2.3.2.r232_v20090211.jar,reference:file:/C: /Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.data.oda.jdbc_2.3.2.r232_v20090212/,reference:file:/C:/D ocuments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.data.oda.jdbc.dbprofile_2.3.2.r232_v20090211.jar,referen ce:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.data.oda.jdbc.dbprofile.sampledb_2.3.2.r232_v20090211.ja r,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.data.oda.jdbc.dbprofile.ui_2.3.2.r232_v20090211.jar,refe rence:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.data.oda.jdbc.ui_2.3.2.r232_v20090211.jar,reference:file :/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.data.oda.sampledb_2.3.2.r232_v20090211/,reference:file:/ C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.data.oda.sampledb.ui_2.3.2.r232_v20090211.jar,reference: file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.data.oda.xml_2.3.2.r232_v20090211.jar,reference:file:/C: /Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.data.oda.xml.ui_2.3.2.r232_v20090211.jar,reference:file: /C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.debug.core_2.3.2.r232_20090202.jar,reference:file:/C:/Do cuments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.debug.ui_2.3.2.r232_20090202.jar,reference:file:/C:/Docu ments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.designer_2.3.2.r232_v20081010.jar,reference:file:/C:/Doc uments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.designer.core_2.3.2.r232_20090202.jar,reference:file:/C: /Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.designer.samplereports_2.3.2.r232_20090202.jar,reference :file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.designer.ui_2.3.2.r232_20090202/,reference:file:/C:/Docu ments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.designer.ui.cubebuilder_2.3.2.r232_20090202.jar,referenc e:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.designer.ui.editor.script_2.3.2.r232_20090202.jar,refere nce:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.designer.ui.editor.xml.wtp_2.3.2.r232_20090202.jar,refer ence:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.designer.ui.editors_2.3.2.r232_20090202.jar,reference:fi le:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.designer.ui.editors.schematic_2.3.2.r232_20090202.jar,re ference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.designer.ui.ide_2.3.2.r232_20090202.jar,reference:file:/ C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.designer.ui.lib_2.3.2.r232_20090202.jar,reference:file:/ C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.designer.ui.lib.explorer_2.3.2.r232_20090202.jar,referen ce:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.designer.ui.preview.web_2.3.2.r232_20090202.jar,referenc e:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.designer.ui.samples.ide_2.3.2.r232_20090202.jar,referenc e:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.designer.ui.samplesview_2.3.2.r232_20090202.jar,referenc e:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.designer.ui.views_2.3.2.r232_20090202.jar,reference:file :/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.engine_2.3.2.r232_20090217.jar,reference:file:/C:/Docume nts
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.engine.dataextraction_2.3.2.r232_20090122.jar,reference: file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.engine.dataextraction.csv_2.3.2.r232_20090122.jar,refere nce:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.engine.emitter.html_2.3.2.r232_20090202.jar,reference:fi le:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.engine.emitter.pdf_2.3.2.r232_20090202.jar,reference:fil e:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.engine.emitter.postscript_2.3.2.r232_20090202.jar,refere nce:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.engine.emitter.ppt_2.3.2.r232_20090202.jar,reference:fil e:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.engine.emitter.prototype.excel_2.3.2.r232_20090202.jar,r eference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.engine.emitter.wpml_2.3.2.r232_20090202.jar,reference:fi le:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.engine.fonts_2.3.2.r232_20090202/,reference:file:/C:/Doc uments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.item.crosstab.core_2.3.2.r232_20090202.jar,reference:fil e:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.item.crosstab.ui_2.3.2.r232_20090202.jar,reference:file: /C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.model_2.3.2.r232_20090115.jar,reference:file:/C:/Documen ts
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.model.adapter.oda_2.3.2.r232_20090108.jar,reference:file :/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.runtime_2.3.2.r232_v20081010.jar,reference:file:/C:/Docu ments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.rep ort.viewer_2.3.2.r232_20090212/,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.birt.res ources_2.3.2.r232_20081030/,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.connectivity_1.1.2.v200901090028.jar,reference:file:/C:/Do cuments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.connectivity.apache.derby_1.0.3.v200902070611.jar,referenc e:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.connectivity.apache.derby.dbdefinition_1.0.2.v200901090940 .jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.connectivity.apache.derby.ui_1.0.1.v200807010433.jar,refer ence:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.connectivity.console.profile_1.0.0.v200805231345.jar,refer ence:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.connectivity.db.generic_1.0.1.v200810140922.jar,reference: file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.connectivity.db.generic.ui_1.0.1.v200805152355.jar,referen ce:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.connectivity.dbdefinition.genericJDBC_1.0.1.v200810300511. jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.connectivity.oda_3.1.3.v200808270255.jar,reference:file:/C :/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.connectivity.oda.consumer_3.1.3.v200808270255.jar,referenc e:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.connectivity.oda.design_3.0.7.v200807231215.jar,reference: file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.connectivity.oda.design.ui_3.0.8.v200901061015.jar,referen ce:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.connectivity.oda.flatfile_3.0.8.v200812171046.jar,referenc e:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.connectivity.oda.flatfile.ui_3.0.8.v200812171046.jar,refer ence:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.connectivity.oda.profile_3.0.7.v200812050755.jar,reference :file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.connectivity.oda.template.ui_3.0.6.v200805152355.jar,refer ence:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.connectivity.sqm.core_1.0.7.v200902180551.jar,reference:fi le:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.connectivity.sqm.core.ui_1.1.3.v200902070558.jar,reference :file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.connectivity.sqm.server.ui_1.1.3.v200902120834.jar,referen ce:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.connectivity.ui_1.1.3.v200901150027.jar,reference:file:/C: /Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.connectivity.ui.dse_1.1.3.v200810140349.jar,reference:file :/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.doc.user_1.6.1.v20080828133713.jar,reference:file:/C:/Docu ments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.finfo_1.5.1.v200805152355.jar,reference:file:/C :/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.hsqldb_1.0.0.v200805152355.jar,reference:file:/ C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.hsqldb.dbdefinition_1.0.0.v200805152355.jar,ref erence:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.hsqldb.ui_1.0.0.v200807220100.jar,reference:fil e:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.ibm.db2.iseries_1.0.1.v200811210224.jar,referen ce:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.ibm.db2.iseries.dbdefinition_1.0.2.v20090109085 3.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.ibm.db2.iseries.ui_1.0.0.v200805160737.jar,refe rence:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.ibm.db2.luw_1.0.1.v200811210224.jar,reference:f ile:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.ibm.db2.luw.dbdefinition_1.0.3.v200901090853.ja r,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.ibm.db2.luw.ui_1.0.1.v200806260315.jar,referenc e:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.ibm.db2.zseries_1.0.1.v200811210224.jar,referen ce:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.ibm.db2.zseries.dbdefinition_1.0.3.v20090106093 8.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.ibm.db2.zseries.ui_1.0.0.v200805160737.jar,refe rence:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.ibm.informix_1.0.0.v200805152355.jar,reference: file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.ibm.informix.dbdefinition_1.0.3.v200811040352.j ar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.ibm.informix.ui_1.0.1.v200806260315.jar,referen ce:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.ibm.ui_1.0.0.v200806271414.jar,reference:file:/ C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.jdt.classpath_1.0.1.v200901170137.jar,reference :file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.msft.sqlserver_1.0.1.v200807181158.jar,referenc e:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.msft.sqlserver.dbdefinition_1.0.0.v200805152355 .jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.msft.sqlserver.ui_1.0.1.v200808222228.jar,refer ence:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.mysql_1.0.2.v200810160130.jar,reference:file:/C :/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.mysql.dbdefinition_1.0.4.v200901090853.jar,refe rence:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.mysql.ui_1.0.0.v200805152355.jar,reference:file :/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.oda.ws_1.1.2.v200812171046.jar,reference:file:/ C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.oda.ws.ui_1.1.2.v200901191112.jar,reference:fil e:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.oda.xml_1.1.2.v200902111040.jar,reference:file: /C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.oda.xml.ui_1.1.2.v200812171046.jar,reference:fi le:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.oracle_1.0.0.v200805152355.jar,reference:file:/ C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.oracle.dbdefinition_1.0.2.v200902030725.jar,ref erence:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.oracle.ui_1.0.1.v200806260315.jar,reference:fil e:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.postgresql_1.0.1.v200805152355.jar,reference:fi le:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.postgresql.dbdefinition_1.0.1.v200901090853.jar ,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.postgresql.ui_1.0.0.v200806060334.jar,reference :file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.sap.maxdb_1.0.0.v200805152355.jar,reference:fil e:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.sap.maxdb.dbdefinition_1.0.0.v200805152355.jar, reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.sap.maxdb.ui_1.0.0.v200805152355.jar,reference: file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.sybase_1.0.1.v200805310538.jar,reference:file:/ C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.sybase.asa_1.0.1.v200901150020.jar,reference:fi le:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.sybase.asa.dbdefinition_1.0.0.v200805240040.jar ,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.sybase.asa.models_1.0.0.v200805152355.jar,refer ence:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.sybase.asa.ui_1.0.1.v200805310538.jar,reference :file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.sybase.ase_1.0.1.v200901170012.jar,reference:fi le:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.sybase.ase.dbdefinition_1.0.0.v200805240040.jar ,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.sybase.ase.models_1.0.1.v200805152355.jar,refer ence:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.sybase.ase.ui_1.0.1.v200806260315.jar,reference :file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.sybase.models_1.0.0.v200805152355.jar,reference :file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.enablement.sybase.ui_1.0.0.v20081212.jar,reference:file:/C :/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.help_1.5.0.v200805152355.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.modelbase.dbdefinition_1.0.1.v200901090853.jar,reference:f ile:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.modelbase.derby_1.0.0.v200805152355.jar,reference:file:/C: /Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.modelbase.sql_1.0.1.v200812031125.jar,reference:file:/C:/D ocuments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.modelbase.sql.edit_1.0.0.v200805152355.jar,reference:file: /C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.modelbase.sql.query_1.0.1.v200901241145.jar,reference:file :/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.modelbase.sql.query.edit_1.0.0.v200806070329.jar,reference :file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.modelbase.sql.xml.query_1.0.0.v200807080500.jar,reference: file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.oda.cshelp_1.1.0.v200810240330.jar,reference:file:/C:/Docu ments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.sqltools.common.ui_1.0.0.v200812121740.jar,reference:file: /C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.sqltools.data.core_1.0.1.v200902140515.jar,reference:file: /C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.sqltools.data.ui_1.1.1.v200901140830.jar,reference:file:/C :/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.sqltools.db.derby_1.0.0.v200805152355.jar,reference:file:/ C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.sqltools.db.generic_1.0.0.v200902031600.jar,reference:file :/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.sqltools.ddlgen.ui_1.0.0.v200808140615.jar,reference:file: /C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.sqltools.debugger.core_1.0.0.v200808140615.jar,reference:f ile:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.sqltools.editor.core_1.0.0.v200902031600.jar,reference:fil e:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.sqltools.parsers.sql_1.0.1.v200808140615.jar,reference:fil e:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.sqltools.parsers.sql.lexer_1.0.1.v200811081015.jar,referen ce:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.sqltools.parsers.sql.query_1.0.1.v200810291500.jar,referen ce:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.sqltools.parsers.sql.xml.query_1.0.0.v200808140615.jar,ref erence:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.sqltools.plan_1.0.0.v200812121520.jar,reference:file:/C:/D ocuments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.sqltools.result_1.0.0.v200902120900.jar,reference:file:/C: /Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.sqltools.routineeditor_1.0.0.v200807211830.jar,reference:f ile:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.sqltools.sql_1.0.0.v200902031600.jar,reference:file:/C:/Do cuments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.sqltools.sqlbuilder_1.0.0.v200901280650.jar,reference:file :/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.sqltools.sqleditor_1.0.0.v200901220945.jar,reference:file: /C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.sqltools.sqlscrapbook_1.0.0.v200901151810.jar,reference:fi le:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.sqltools.tabledataeditor_1.0.0.v200901280500.jar,reference :file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.datatool s.sqltools.tablewizard_1.0.0.v200808140615.jar,reference:fil e:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.draw2d_3 .4.2.v20090114-1330.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.emf_2.4. 0.v200902171115.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.emf.ant_ 2.4.0.v200902171115.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.emf.code gen_2.4.0.v200902171115.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.emf.code gen.ecore_2.4.2.v200902171115.jar,reference:file:/C:/Documen ts
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.emf.code gen.ecore.ui_2.4.1.v200902171115.jar,reference:file:/C:/Docu ments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.emf.code gen.ui_2.4.0.v200902171115.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.emf.comm on_2.4.0.v200902171115.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.emf.comm on.ui_2.4.0.v200902171115.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.emf.conv erter_2.4.0.v200902171115.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.emf.data binding_1.0.0.v200902171115.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.emf.data binding.edit_1.0.0.v200902171115.jar,reference:file:/C:/Docu ments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.emf.ecor e_2.4.2.v200902171115.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.emf.ecor e.change_2.4.0.v200902171115.jar,reference:file:/C:/Document s
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.emf.ecor e.change.edit_2.4.0.v200902171115.jar,reference:file:/C:/Doc uments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.emf.ecor e.edit_2.4.1.v200902171115.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.emf.ecor e.editor_2.4.0.v200902171115.jar,reference:file:/C:/Document s
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.emf.ecor e.xmi_2.4.1.v200902171115.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.emf.edit _2.4.2.v200902171115.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.emf.edit .ui_2.4.2.v200902171115.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.emf.expo rter_2.4.0.v200902171115.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.emf.impo rter_2.4.1.v200902171115.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.emf.impo rter.ecore_2.4.0.v200902171115.jar,reference:file:/C:/Docume nts
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.emf.impo rter.java_2.4.1.v200902171115.jar,reference:file:/C:/Documen ts
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.emf.impo rter.rose_2.4.0.v200902171115.jar,reference:file:/C:/Documen ts
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.emf.mapp ing_2.4.0.v200902171115.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.emf.mapp ing.ecore_2.4.0.v200902171115.jar,reference:file:/C:/Documen ts
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.emf.mapp ing.ecore.editor_2.4.0.v200902171115.jar,reference:file:/C:/ Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.emf.mapp ing.ecore2ecore_2.4.0.v200902171115.jar,reference:file:/C:/D ocuments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.emf.mapp ing.ecore2ecore.editor_2.4.0.v200902171115.jar,reference:fil e:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.emf.mapp ing.ecore2xml_2.4.0.v200902171115.jar,reference:file:/C:/Doc uments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.emf.mapp ing.ecore2xml.ui_2.4.0.v200902171115.jar,reference:file:/C:/ Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.emf.mapp ing.ui_2.4.0.v200902171115.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.gef_3.4. 1.v20080806.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jem_2.0. 202.v200810282000.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jem.bean info_2.0.200.v200811261206.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jem.bean info.vm_2.0.200.v200811260651.jar,reference:file:/C:/Documen ts
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jem.bean info.vm.common_2.0.200.v200811260651.jar,reference:file:/C:/ Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jem.prox y_2.0.100.v200806051600.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jem.ui_2 .0.100.v200806051600.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jem.util _2.0.100.v200805140020.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jem.work bench_2.0.102.v200810230530.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.comm on.annotations.controller_1.1.100.v200805140020.jar,referenc e:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.comm on.annotations.core_1.1.100.v200805140020.jar,reference:file :/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.comm on.annotations.ui_1.1.102.v200806010600.jar,reference:file:/ C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.comm on.frameworks_1.1.201.v200810161330.jar,reference:file:/C:/D ocuments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.comm on.project.facet.core_1.3.1.v200807031821.jar,reference:file :/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.comm on.project.facet.ui_1.3.1.v200807031821.jar,reference:file:/ C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.ejb. doc.user_1.1.100.v200810092245.jar,reference:file:/C:/Docume nts
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.ejb. ui_1.1.203.v200810010400.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.ejb. ui.infopop_1.0.100.v200805222207/,reference:file:/C:/Documen ts
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.j2ee _1.1.206.v200902052030.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.j2ee .core_1.1.203.v200901221030.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.j2ee .doc.user_1.1.1.v200808070608.jar,reference:file:/C:/Documen ts
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.j2ee .ejb_1.1.203.v200811060500.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.j2ee .ejb.annotation.model_1.1.102.v200805140020.jar,reference:fi le:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.j2ee .ejb.annotations.emitter_1.1.102.v200805140135.jar,reference :file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.j2ee .ejb.annotations.ui_1.1.102.v200805140020.jar,reference:file :/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.j2ee .ejb.annotations.xdoclet_1.2.0.v200805140020.jar,reference:f ile:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.j2ee .infopop_1.0.300.v200805140415.jar,reference:file:/C:/Docume nts
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.j2ee .jca_1.1.203.v200811060900.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.j2ee .jca.ui_1.1.200.v200805140020.jar,reference:file:/C:/Documen ts
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.j2ee .navigator.ui_1.1.203.v200901290400.jar,reference:file:/C:/D ocuments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.j2ee .ui_1.1.206.v200901280857.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.j2ee .web_1.1.203.v200901290400.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.j2ee .webservice_1.1.201.v200807240600.jar,reference:file:/C:/Doc uments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.j2ee .webservice.ui_1.1.201.v200811062130.jar,reference:file:/C:/ Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.j2ee .xdoclet.runtime_1.1.102.v200805140135.jar,reference:file:/C :/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.jee_ 1.0.103.v200901220530.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.jee. ejb_1.0.102.v200810230722.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.jee. ui_1.0.104.v200902040818.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.jee. web_1.0.101.v200810230738.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.jsf. common_1.1.4.v20090128.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.jsf. common.runtime_1.0.101.v20090128.jar,reference:file:/C:/Docu ments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.jsf. common.ui_1.1.0.v20080605.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.jsf. core_1.1.103.v200902042324.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.jsf. doc.user_1.1.100.v20080811.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.jsf. facesconfig_1.1.1.v20090129.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.jsf. facesconfig.ui_1.1.3.v20090128.jar,reference:file:/C:/Docume nts
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.jsf. standard.tagsupport_1.1.102.v20090128.jar,reference:file:/C: /Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.jsf. ui_1.1.102.v20090128.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.jsp. core_1.2.121.v200901290830.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.jsp. ui_1.1.312.v200901290909.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.jsp. ui.infopop_1.0.100.v200805301545.jar,reference:file:/C:/Docu ments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.serv er.core_1.1.3.v20090115.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.serv let.ui_1.1.203.v200810222000.jar,reference:file:/C:/Document s
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.serv let.ui.infopop_1.0.300.v200805140415.jar,reference:file:/C:/ Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.stan dard.schemas_1.0.101.v200807220523.jar,reference:file:/C:/Do cuments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.ws_1 .0.307.v200901142050.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.ws.a xis.consumption.core_1.0.306.v200810082309.jar,reference:fil e:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.ws.a xis.consumption.ui_1.0.305.v200809301934.jar,reference:file: /C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.ws.a xis.creation.ui_1.0.306.v200811200248.jar,reference:file:/C: /Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.ws.a xis.infopop_1.0.300.v200805140230.jar,reference:file:/C:/Doc uments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.ws.a xis.ui.doc.user_1.1.0.v200806092139.jar,reference:file:/C:/D ocuments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.ws.c onsumption_1.0.307.v200811220753/,reference:file:/C:/Documen ts
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.ws.c onsumption.infopop_1.0.300.v200805140230.jar,reference:file: /C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.ws.c onsumption.ui_1.1.4.v200901212148.jar,reference:file:/C:/Doc uments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.ws.c onsumption.ui.doc.user_1.0.550.v200901232040.jar,reference:f ile:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.ws.c reation.ejb.ui_1.0.200.v200805140230.jar,reference:file:/C:/ Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.ws.c reation.ui_1.0.308.v200901212148.jar,reference:file:/C:/Docu ments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.ws.d oc.user_1.0.500.v200809092107.jar,reference:file:/C:/Documen ts
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.ws.i nfopop_1.0.300.v200805140230.jar,reference:file:/C:/Document s
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.ws.u ddiregistry_1.0.300.v200805140230.jar,reference:file:/C:/Doc uments
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.jst.ws.u i_1.0.304.v200901271844.jar,reference:file:/C:/Documents
and
Settings/Dennis/Desktop/eclipse/plugins/org.eclipse.wst.comm and.env_1.0.308.v200811200248/,reference:file:/C:/Documents
and
Re: Ganymede & Mylyn [message #596860 is a reply to message #66855] |
Thu, 19 March 2009 03:18 |
Dennis Messages: 14 Registered: July 2009 |
Junior Member |
*** User Preferences:
#Wed Mar 18 20:19:23 PDT 2009
/instance/org.eclipse.core.resources/description.filestatelo ngevity=1209600000
/project/trunk/org.eclipse.wst.html.core/attrInvalidName=2
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__subclipse.tigris.org_update_1.2.x/isSyste m=false
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__subclipse.tigris.org_update_1.2.x/url=http\://subclipse.tigris.org/update_1.2.x
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/file\:_C\:_Documents\
and\
Settings_Dennis_Desktop_Ganymede_p2_org.eclipse.equinox.p2.d irector_rollback/version=1.0.0
/instance/org.eclipse.team.ui/org.eclipse.team.ui.first_time =false
and\
Settings_Dennis_Desktop_Ganymede_configuration_org.eclipse.o sgi_bundles_69_data_listener_1925729951_/url=file\:/C\:/Docu ments
and
Settings/Dennis/Desktop/Ganymede/configuration/org.eclipse.o sgi/bundles/69/data/listener_1925729951/
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__subclipse.tigris.org_update_1.4.x/enabled =true
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/file\:_C\:_Documents\
and\ Settings_Dennis_Desktop_eclipse_.eclipseextension/version=1
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_tools_buckminster_up dates/isSystem=false
and\
Settings_Dennis_Desktop_Ganymede_p2_org.eclipse.equinox.p2.d irector_rollback/type=org.eclipse.equinox.internal.p2.metada ta.repository.LocalMetadataRepository
and\
Settings_Dennis_Desktop_eclipse_configuration_org.eclipse.os gi_bundles_63_data_listener_-205926309/name=artifact
listener file\:/C\:/Documents and
Settings/Dennis/Desktop/eclipse/.eclipseextension
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_eclipse_updates_3.4/ description=
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_releases_ganymede/en abled=true
/instance/org.eclipse.ui.workbench/resourcetypes=<?xml version\="1.0"
encoding\="UTF-8"?>\r\n<editors version\="3.1">\r\n<info extension\="tag"
name\="*">\r\n<editor
id\="org.eclipse.jst.jsp.core.jspsource.source"/>\r\n</info >\r\n<info
extension\="adapter" name\="*">\r\n<editor
id\=" org.eclipse.hyades.logging.adapter.ui.internal.presentation. AdaptorEditorID "/>\r\n</info>\r\n<info
extension\="shtml" name\="*">\r\n<editor
id\="org.eclipse.ui.browser.editorSupport"/>\r\n</info>\r\n <info
extension\="cfm" name\="*">\r\n<editor
id\="org.cfeclipse.cfml.editors.CFMLEditor"/>\r\n</info>\r\n <info
extension\="umldeployment_diagram" name\="*">\r\n<editor
id\="org.eclipse.uml2.diagram.deploy.part.UMLDiagramEditorID "/>\r\n<defaultEditor
id\="org.eclipse.uml2.diagram.deploy.part.UMLDiagramEditorID "/>\r\n</info>\r\n<info
extension\="gmfgraph" name\="*">\r\n<editor
id\="org.eclipse.gmf.gmfgraph.presentation.GMFGraphEditorID "/>\r\n</info>\r\n<info
extension\="cspec" name\="*">\r\n<editor
id\="org.eclipse.buckminster.ui.editors.CSPECEditor"/>\r\n <defaultEditor
id\="org.eclipse.buckminster.ui.editors.CSPECEditor"/>\r\n </info>\r\n<info
extension\="tagf" name\="*">\r\n<editor
extension\="umlusc" name\="*">\r\n<editor
id\="org.eclipse.uml2.diagram.usecase.part.UMLDiagramEditorID "/>\r\n<defaultEditor
id\="org.eclipse.uml2.diagram.usecase.part.UMLDiagramEditorID "/>\r\n</info>\r\n<info
extension\="umlclass" name\="*">\r\n<editor
id\="org.eclipse.uml2.diagram.clazz.part.UMLDiagramEditorID "/>\r\n<defaultEditor
id\="org.eclipse.uml2.diagram.clazz.part.UMLDiagramEditorID "/>\r\n</info>\r\n<info
extension\="umlstm" name\="*">\r\n<editor
id\=" org.eclipse.uml2.diagram.statemachine.part.UMLDiagramEditorI D "/>\r\n<defaultEditor
id\=" org.eclipse.uml2.diagram.statemachine.part.UMLDiagramEditorI D "/>\r\n</info>\r\n<info
extension\="itcl" name\="*">\r\n<editor
id\="org.eclipse.dltk.tcl.ui.editor.TclEditor"/>\r\n<defaultEditor
id\="org.eclipse.dltk.tcl.ui.editor.TclEditor"/>\r\n</info >\r\n<info
extension\="js" name\="*">\r\n<editor
id\="org.eclipse.wst.jsdt.ui.CompilationUnitEditor"/>\r\n <defaultEditor
id\="org.eclipse.wst.jsdt.ui.CompilationUnitEditor"/>\r\n </info>\r\n<info
extension\="gmfmap" name\="*">\r\n<editor
id\="org.eclipse.gmf.mappings.presentation.GMFMapEditorID"/ >\r\n</info>\r\n<info
extension\="sqlpage" name\="*">\r\n<editor
id\=" org.eclipse.datatools.sqltools.sqlscrapbook.SQLScrapbookEdit or "/>\r\n<defaultEditor
id\=" org.eclipse.datatools.sqltools.sqlscrapbook.SQLScrapbookEdit or "/>\r\n</info>\r\n<info
extension\="jsp" name\="*">\r\n<editor
id\="org.eclipse.jst.jsp.core.jspsource.source"/>\r\n<editor
id\="org.eclipse.jst.pagedesigner.PageDesignerEditor"/>\r\n </info>\r\n<info
extension\="cspex" name\="*">\r\n<editor
id\="org.eclipse.buckminster.ui.editors.CSPEXEditor"/>\r\n <defaultEditor
id\="org.eclipse.buckminster.ui.editors.CSPEXEditor"/>\r\n </info>\r\n<info
extension\="override" name\="*">\r\n<editor
id\="org.eclipse.jem.beaninfo.OverrideEditor"/>\r\n</info >\r\n<info
extension\="tagx" name\="*">\r\n<editor
extension\="umlprofile_diagram" name\="*">\r\n<editor
id\="org.eclipse.uml2.diagram.profile.part.UMLDiagramEditorID "/>\r\n<defaultEditor
id\="org.eclipse.uml2.diagram.profile.part.UMLDiagramEditorID "/>\r\n</info>\r\n<info
extension\="gmfgen" name\="*">\r\n<editor
id\="org.eclipse.gmf.codegen.gmfgen.presentation.GMFGenEditorID "/>\r\n</info>\r\n<info
extension\="jspx" name\="*">\r\n<editor
extension\="properties" name\="sample">\r\n<editor
id\="org.eclipse.pde.ui.sampleEditor"/>\r\n<defaultEditor
id\="org.eclipse.pde.ui.sampleEditor"/>\r\n</info>\r\n<info
extension\="class" name\="*">\r\n<editor
id\="de.loskutov.bco.editors.BytecodeClassFileEditor"/>\r\n <defaultEditor
id\="de.loskutov.bco.editors.BytecodeClassFileEditor"/>\r\n </info>\r\n<info
extension\="jspf" name\="*">\r\n<editor
extension\="umlcsd" name\="*">\r\n<editor
id\="org.eclipse.uml2.diagram.csd.part.UMLDiagramEditorID"/ >\r\n<defaultEditor
id\="org.eclipse.uml2.diagram.csd.part.UMLDiagramEditorID"/ >\r\n</info>\r\n<info
extension\="gmftool" name\="*">\r\n<editor
id\="org.eclipse.gmf.tooldef.presentation.GMFToolEditorID"/ >\r\n</info>\r\n<info
extension\="trcpxmi" name\="*">\r\n<editor
id\=" org.eclipse.hyades.trace.ui.internal.editors.TRCProcessEdito r "/>\r\n</info>\r\n<info
extension\="cfc" name\="*">\r\n<editor
extension\="tcl" name\="*">\r\n<editor
extension\="usr" name\="*">\r\n<editor
id\="org.eclipse.ui.examples.propertysheet.UserEditor"/>\r\n </info>\r\n<info
extension\="umlusecase_diagram" name\="*">\r\n<editor
extension\="xpt" name\="*">\r\n<editor
id\="org.eclipse.gmf.xpand.XpandEditor"/>\r\n</info>\r\n <info
extension\="umlactivity_diagram" name\="*">\r\n<editor
id\="org.eclipse.uml2.diagram.activity.part.UMLDiagramEditorID "/>\r\n<defaultEditor
id\="org.eclipse.uml2.diagram.activity.part.UMLDiagramEditorID "/>\r\n</info>\r\n<info
extension\="readme" name\="*">\r\n<editor
id\="org.eclipse.ui.examples.readmetool.ReadmeEditor"/>\r\n </info>\r\n<info
extension\="cfml" name\="*">\r\n<editor
extension\="umlclass_diagram" name\="*">\r\n<editor
extension\="test" name\="*">\r\n<editor
extension\="trcnxmi" name\="*">\r\n<editor
id\="org.eclipse.hyades.trace.ui.internal.editors.TRCNodeEditor "/>\r\n</info>\r\n<info
extension\="sql" name\="*">\r\n<editor
id\=" org.eclipse.datatools.sqltools.sqlscrapbook.SQLScrapbookEdit or "/>\r\n<editor
id\="org.eclipse.datatools.sqltools.sqlbuilder"/>\r\n<defaultEditor
id\="org.eclipse.datatools.sqltools.sqlbuilder"/>\r\n</info >\r\n<info
extension\="exp" name\="*">\r\n<editor
extension\="umldepl" name\="*">\r\n<editor
extension\="jpage" name\="*">\r\n<editor
id\="org.eclipse.jdt.debug.ui.SnippetEditor"/>\r\n</info >\r\n<info
extension\="umlstatemachine_diagram" name\="*">\r\n<editor
extension\="ddl" name\="*">\r\n<editor
extension\="html" name\="*">\r\n<editor
id\="org.cfeclipse.cfml.editors.CFMLEditor"/>\r\n<editor
id\="org.eclipse.jst.pagedesigner.PageDesignerEditor"/>\r\n <editor
extension\="htm" name\="*">\r\n<editor
extension\="mpe" name\="*">\r\n<editor
id\=" org.eclipse.ui.examples.multipageeditor.MultiPageEditorExamp le "/>\r\n</info>\r\n<info
extension\="jsf" name\="*">\r\n<editor
extension\="umlcomponent_diagram" name\="*">\r\n<editor
id\="org.eclipse.uml2.diagram.component.part.UMLDiagramEditorID "/>\r\n<defaultEditor
id\="org.eclipse.uml2.diagram.component.part.UMLDiagramEditorID "/>\r\n</info>\r\n<info
extension\="xml" name\="*">\r\n<editor
id\=" org.eclipse.dd.ipxact.editor.ui.editors.IP-XACTMultiPageEdit or "/>\r\n<editor
id\=" org.eclipse.ui.examples.templateeditor.editors.TemplateEdito r "/>\r\n</info>\r\n<info
extension\="rb" name\="*">\r\n<editor
id\="org.eclipse.dltk.ruby.ui.editor.RubyEditor"/>\r\n<defaultEditor
id\="org.eclipse.dltk.ruby.ui.editor.RubyEditor"/>\r\n</info >\r\n<info
extension\="spirit" name\="*">\r\n<editor
id\=" org.eclipse.dd.ipxact.editor.ui.editors.IP-XACTMultiPageEdit or "/>\r\n</info>\r\n<info
extension\="symptom" name\="*">\r\n<editor
id\=" org.eclipse.tptp.symptom.internal.presentation.SymptomEditor "/>\r\n</info>\r\n<info
extension\="umlcompositestructures_diagram" name\="*">\r\n<editor
extension\="ecore_diagram" name\="*">\r\n<editor
id\="org.eclipse.gmf.ecore.part.EcoreDiagramEditorID"/>\r\n <defaultEditor
id\="org.eclipse.gmf.ecore.part.EcoreDiagramEditorID"/>\r\n </info>\r\n<info
extension\="trcaxmi" name\="*">\r\n<editor
id\="org.eclipse.hyades.trace.ui.internal.editors.TRCAgentEditor "/>\r\n</info>\r\n<info
extension\="xhtml" name\="*">\r\n<editor
extension\="probe" name\="*">\r\n<editor
id\=" org.eclipse.hyades.probekit.editor.internal.presentation.Pro bekitEditorID "/>\r\n<defaultEditor
id\=" org.eclipse.hyades.probekit.editor.internal.presentation.Pro bekitEditorID "/>\r\n</info>\r\n<info
extension\="rmap" name\="*">\r\n<editor
id\="org.eclipse.buckminster.ui.editors.RMAPEditor"/>\r\n <defaultEditor
id\="org.eclipse.buckminster.ui.editors.RMAPEditor"/>\r\n </info>\r\n<info
extension\="jav" name\="*">\r\n<editor
id\="org.eclipse.ui.JavaEditor"/>\r\n</info>\r\n<info extension\="xotcl"
extension\="umlcomp" name\="*">\r\n<editor
extension\="cquery" name\="*">\r\n<editor
id\="org.eclipse.buckminster.ui.editor.QueryEditor"/>\r\n <defaultEditor
id\="org.eclipse.buckminster.ui.editor.QueryEditor"/>\r\n </info>\r\n<info
extension\="umlact" name\="*">\r\n<editor
extension\="pda" name\="*">\r\n<editor id\="pda.editor"/>\r\n<editor
id\="pda.editor"/>\r\n<defaultEditor
id\="pda.editor"/>\r\n</info>\r\n<info extension\="jardesc"
id\="org.eclipse.jdt.ui.JARDescEditor"/>\r\n<defaultEditor
id\="org.eclipse.jdt.ui.JARDescEditor"/>\r\n</info>\r\n <info
extension\="trcmxmi" name\="*">\r\n<editor
id\=" org.eclipse.hyades.trace.ui.internal.editors.TRCMonitorEdito r "/>\r\n</info>\r\n<info
extension\="server" name\="*">\r\n<editor
id\="org.eclipse.wst.server.ui.editor"/>\r\n</info>\r\n <info
extension\="trcdbxmi" name\="*">\r\n<editor
id\="org.eclipse.hyades.sdb.internal.editors.SymptomDBEditor "/>\r\n</info>\r\n</editors>
/instance/org.eclipse.wst.sse.ui/useQuickDiffPrefPage=true
/instance/org.eclipse.wst.sse.core/task-tags/enabled=true
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_eclipse_updates_3.4/ name=The
Eclipse Project Updates
/instance/org.eclipse.wst.jsdt.ui/useQuickDiffPrefPage=true
and\
Settings_Dennis_Desktop_Ganymede_configuration_org.eclipse.o sgi_bundles_63_data_listener_-177846376/suffix=artifacts.xml
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_technology_emft_upda tes_/isSystem=false
@org.eclipse.dltk.mylyn=0.95.1.v20080903-1434
/instance/org.eclipse.core.resources/description.maxfilestat es=100
@org.eclipse.wst.sse.core=1.1.303.v200901290024
/instance/org.eclipse.ui.editors/changeIndicationInOverviewR uler=true
/instance/org.eclipse.datatools.connectivity/org.eclipse.dat atools.connectivity.db.derby.genericDriverTemplate=true
/instance/org.eclipse.mylyn.context.core/mylyn.attention.mig rated=true
/instance/org.eclipse.jdt.ui/useAnnotationsPrefPage=true
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__www.eclipse.org_modeling_emft_?project\=s earch\#search/enabled=false
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.taskTags =TODO
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.compiler .taskPriorities=NORMAL,HIGH,NORMAL
/instance/org.eclipse.wst.jsdt.ui/org.eclipse.wst.jsdt.ui.fo rmatterprofiles.version=11
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__subclipse.tigris.org_update_1.4.x/type=or g.eclipse.equinox.p2.updatesite.metadataRepository
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__www.cfeclipse.org_update/version=1.0.0
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__andrei.gmxhome.de_eclipse/enabled=true
and\
Settings_Dennis_Desktop_eclipse_configuration_org.eclipse.os gi_bundles_69_data_listener_1925729951/name=artifact
listener dropins
@org.eclipse.jdt.core=3.4.4.v_894_R34x
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_technology_epp_updat es_1.0_/enabled=false
/instance/org.cfeclipse.cfml/SQLTextColor=91,249,174
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__andrei.gmxhome.de_eclipse_/type=org.eclip se.equinox.p2.updatesite.metadataRepository
and\
Settings_Dennis_Desktop_eclipse_configuration_org.eclipse.os gi_bundles_63_data_listener_-205926309/url=file\:/C\:/Docume nts
and
Settings/Dennis/Desktop/eclipse/configuration/org.eclipse.os gi/bundles/63/data/listener_-205926309/
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_technology_epp_updat es_1.0/url=http\://download.eclipse.org/technology/epp/updates/1.0/
/instance/org.eclipse.rse.ui/org.eclipse.rse.preferences.ord er.connections=sagan.Local
and\
Settings_Dennis_Desktop_Ganymede_p2_org.eclipse.equinox.p2.c ore_cache/name=download
cache
/project/trunk/org.eclipse.wst.html.core/piInvalidContent=2
and\
Settings_Dennis_Desktop_eclipse_p2_org.eclipse.equinox.p2.co re_cache/url=file\:/C\:/Documents
and Settings/Dennis/Desktop/eclipse/p2/org.eclipse.equinox.p2.co re/cache/
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_tools_gef_update-sit e_releases_site.xml/url= http\://download.eclipse.org/tools/gef/update-site/releases/ site.xml
@org.eclipse.wst.jsdt.core=1.0.104.v200901281939
/instance/org.cfeclipse.cfml/cfnumberColor=226,194,148
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_tools_cdt_releases_g anymede/enabled=false
/project/trunk/org.eclipse.wst.html.core/elemEndInvalidCase= 1
/instance/org.eclipse.wst.sse.ui/matchingBracketsColor=255,0 ,128
/instance/org.cfeclipse.cfml/cfstringColor=191,205,240
and\
Settings_Dennis_Desktop_eclipse_.eclipseextension/url=file\: /C\:/Documents
and Settings/Dennis/Desktop/eclipse/.eclipseextension
/instance/org.eclipse.equinox.p2.ui.sdk/allowNonOKPlan=alway s
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__subclipse.tigris.org_update_1.4.x/version =1
/instance/org.eclipse.dltk.ui/useAnnotationsPrefPage=true
/instance/org.eclipse.dltk.ruby.ui/useAnnotationsPrefPage=tr ue
and\
Settings_Dennis_Desktop_Ganymede_.eclipseextension/url=file\ :/C\:/Documents
and Settings/Dennis/Desktop/Ganymede/.eclipseextension
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_releases_ganymede/ve rsion=1.0.0
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__www.eclipse.org_mylyn_downloads/url=http\://www.eclipse.org/mylyn/downloads/
/instance/org.eclipse.cdt.ui/useAnnotationsPrefPage=true
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__eclipse.svnkit.com_1.2.x/enabled=true
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__eclipse.org_tptp_updates_/enabled=false
/instance/org.eclipse.compare/StructureViewerAliases=CLASSPA TH.XML
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__www.eclipse.org_modeling_emft_?project\=s earch\#search/enabled=false
and\ Settings_Dennis_Desktop_eclipse/description=
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.compiler .taskCaseSensitive=enabled
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__subclipse.tigris.org_update_1.2.x/url=http\://subclipse.tigris.org/update_1.2.x
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_technology_dltk_upda tes_/enabled=false
/project/trunk/org.eclipse.mylyn.tasks.ui/project.repository .url=local
/project/trunk/org.eclipse.wst.html.core/cdataInvalidContent =2
@org.eclipse.jst.j2ee.webservice.ui=1.1.201.v200811062130
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.editor.tab.w idth=
/instance/org.eclipse.equinox.p2.ui.sdk/enabled=true
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_rt_rap_update-site/u rl=http\://download.eclipse.org/rt/rap/update-site
/instance/org.eclipse.core.resources/version=1
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_tools_buckminster_up dates/url=http\://download.eclipse.org/tools/buckminster/updates
@org.eclipse.wst.jsdt.ui=1.0.104.v200901290004
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__andrei.gmxhome.de_eclipse/version=1
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.javadoclocat ions.migrated=true
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_birt_update-site_2.3 /isSystem=false
/project/trunk/org.eclipse.wst.html.core/elemInvalidDirectiv e=1
/instance/org.eclipse.dltk.core/editor_folding_enabled=true
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_releases_ganymede/de scription=
/instance/org.eclipse.wst.jsdt.ui/org.eclipse.wst.jsdt.ui.ge ttersetter.use.is=true
/instance/org.eclipse.jdt.ui/content_assist_favorite_static_ members=
and\
Settings_Dennis_Desktop_Ganymede_configuration_org.eclipse.o sgi_bundles_63_data_listener_-177846376_/name=metadata
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_webtools_updates/isS ystem=false
@org.eclipse.rse.ui=3.0.3.v200902042310
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_releases_ganymede/na me=Ganymede
Update Site
/project/trunk/de.loskutov.anyedit.AnyEditTools/saveAndAddLi ne=false
/instance/org.eclipse.datatools.connectivity/org.eclipse.dat atools.connectivity.db.derby102.genericDriverTemplate=true
/project/trunk/org.eclipse.wst.html.core/attrNameMismatch=2
/instance/org.eclipse.jdt.ui/fontPropagated=true
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_tools_mylyn_update_w eekly_e3.4/name=Mylyn
for Eclipse 3.4
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_eclipse_updates_3.4/ enabled=true
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__andrei.gmxhome.de_eclipse/description=
/instance/org.eclipse.core.runtime/content-types/org.eclipse .wst.html.core.htmlsource/file-extensions=cfm,cfc,cfml
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_modeling_emft_update s/enabled=false
/instance/org.eclipse.ui.workbench/ENABLED_DECORATORS=org.ec lipse.jst.j2ee.navigator.ui.java.resource.decorator\:true,or g.eclipse.jst.jee.navigator.ui.java.resource.decorator\:true ,org.eclipse.team.pessimistic.ui.decorator\:true,org.eclipse .wst.server.ui.decorator\:false,org.cfeclipse.cfml.ui.decora tors.cfcdecorator\:true,org.cfeclipse.cfml.ui.decorators.cfe readonlydecorator\:true,org.eclipse.cdt.ui.indexedFiles\:fal se,org.eclipse.datatools.connectivity.sqm.core.internal.ui.e xplorer.DependencyDecoration\:true,org.eclipse.datatools.con nectivity.sqm.core.internal.ui.explorer.ColumnDecoration\:tr ue,org.eclipse.datatools.connectivity.sqm.core.internal.ui.e xplorer.ForeignKeyDecoration\:true,org.eclipse.datatools.con nectivity.sqm.core.internal.ui.explorer.IndexTriggerDecorati on\:true,org.eclipse.datatools.connectivity.internal.core.ui .bookmarkDecoration\:true,org.eclipse.datatools.connectivity .internal.core.ui.FilterNodeDecoration\:true,org.eclipse.dat atools.connectivity.ui.decorator.contentextension\:false,org .eclipse.datatools.enablement.sybase.asa.proxytabledecorator \:true,org.eclipse.datatools.enablement.sybase.ase.webservic etabledecorator\:true,org.eclipse.datatools.enablement.sybas e.systemtabledecorator\:true,org.eclipse.dd.ipxact.editor.ui .decorators.DuplicateDecorator\:true,org.eclipse.dltk.ruby.p rojectdecorator\:true,org.eclipse.dltk.tcl.decorators.projec tdecorator\:true,org.eclipse.jdt.ui.override.decorator\:true ,org.eclipse.jdt.ui.interface.decorator\:false,org.eclipse.j st.j2ee.internal.ui.util.AnnotationIconDecorator_ejb\:true,o rg.eclipse.jst.j2ee.navigator.internal.J2EEProjectDecorator\ :true,org.eclipse.jst.jee.ui.internal.navigator.ejb.BeanDeco rator\:true,org.eclipse.jst.jee.navigator.internal.JEEProjec tDecorator\:true,org.eclipse.jst.j2ee.internal.ui.util.Annot ationIconDecorator_servlet\:true,org.eclipse.mylyn.context.u i.decorator.interest\:true,org.eclipse.mylyn.tasks.ui.decora tors.task\:true,org.eclipse.mylyn.team.ui.changeset.decorato r\:true,org.eclipse.nab.mwt.ab.core.MwtManageSourceDecorator \:true,org.eclipse.pde.ui.binaryProjectDecorator\:false,org. eclipse.rse.core.virtualobject.decorator\:true,org.eclipse.r se.core.binary.executable.decorator\:true,org.eclipse.rse.co re.script.executable.decorator\:true,org.eclipse.rse.core.ja va.executable.decorator\:true,org.eclipse.rse.core.library.d ecorator\:true,org.eclipse.rse.core.link.decorator\:true,org .eclipse.rse.subsystems.error.decorator\:true,org.eclipse.te am.cvs.ui.decorator\:true,org.eclipse.tptp.monitoring.manage dagent.views.browser.decorator\:true,org.eclipse.ui.LinkedRe sourceDecorator\:true,org.eclipse.ui.ContentTypeDecorator\:t rue,org.eclipse.wst.jsdt.ui.override.decorator\:true,org.ecl ipse.wst.jsdt.ui.interface.decorator\:false,
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_technology_epp_updat es_1.0_/isSystem=false
/instance/org.eclipse.dltk.ui/editor_folding_enabled=true
@org.eclipse.ui=3.4.2.M20090204-0800
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__www.eclipse.org_modeling_emft_?project\=s earch\#search/url= http\://www.eclipse.org/modeling/emft/?project\=search\#sear ch
and\
Settings_Dennis_Desktop_eclipse_configuration_org.eclipse.os gi_bundles_63_data_listener_-205926309/version=1.0.0
/instance/org.eclipse.wst.jsdt.ui/content_assist_category_or der=org.eclipse.wst.jsdt.ui.templateProposalCategory\:0\u000 0org.eclipse.wst.jsdt.ui.javaNoTypeProposalCategory\:1\u0000 org.eclipse.wst.jsdt.ui.textProposalCategory\:2\u0000
/project/trunk/de.loskutov.FileSync/WARNING=DO NOT MODIFY THIS FILE IF YOU
DON'T UNDERSTAND
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_dsdp_nab_updates/isS ystem=false
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__eclipse.svnkit.com_1.2.x/version=1
/instance/org.cfeclipse.cfml/CFUnitFacadeLocation=localhost\ :82/net/sourceforge/cfunit/framework
/instance/org.eclipse.wst.ws.service.policy/org.eclipse.wst. ws.service.policy.ui.servicepols.wsiprofilecomp.wsissbp.defa ultProtocol=http\://schemas.xmlsoap.org/wsdl/soap/
/project/trunk/de.loskutov.anyedit.AnyEditTools/saveAndTrim= true
/instance/org.eclipse.wst.jsdt.core/org.eclipse.wst.jsdt.cor e.timeoutForParameterNameFromAttachedJavadoc=50
/instance/org.cfeclipse.cfml/htmFormTagColor=255,255,128
and\ Settings_Dennis_Desktop_eclipse/suffix=artifacts.xml
/project/trunk/org.eclipse.wst.html.core/docInvalidContent=2
@org.eclipse.dltk.core=0.95.1.v20080920-R0951
/instance/org.eclipse.jdt.ui/proposalOrderMigrated=true
and\ Settings_Dennis_Desktop_eclipse_.eclipseextension/name=C\:\\ Documents
and Settings\\Dennis\\Desktop\\eclipse\\.eclipseextension
@org.eclipse.birt.report.data.oda.jdbc.ui=2.3.2.r232_v200902 11
/instance/org.eclipse.ui.ide/BOOKMARKS_FILTERS_MIGRATE=true
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_eclipse_updates_3.4/ name=file\:/builds/M/org.eclipse.releng.eclipsebuilder/../sr c/repo
- artifacts
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__eclipse.svnkit.com_1.2.x/provider=
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_birt_update-site_2.3 /url=http\://download.eclipse.org/birt/update-site/2.3
/instance/org.cfeclipse.cfml/cfscriptfunctionColor=255,255,0
/instance/org.eclipse.wst.jsdt.ui/useAnnotationsPrefPage=tru e
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_technology_epp_updat es_1.0/isSystem=false
/instance/org.eclipse.birt.report.designer.ui/Palette\ Size=125
and\
Settings_Dennis_Desktop_Ganymede_configuration_org.eclipse.o sgi_bundles_63_data_listener_-177846376/url=file\:/C\:/Docum ents
and
Settings/Dennis/Desktop/Ganymede/configuration/org.eclipse.o sgi/bundles/63/data/listener_-177846376/
/project/trunk/de.loskutov.anyedit.AnyEditTools/removeTraili ngSpaces=true
/instance/org.eclipse.ui/defaultPerspectiveId=org.cfeclipse. cfml.perspective.CFML
and\ Settings_Dennis_Desktop_Ganymede_.eclipseextension/descripti on=
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_webtools_updates/typ e=org.eclipse.equinox.internal.p2.metadata.repository.LocalM etadataRepository
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_eclipse_updates_3.4/ version=1.0.0
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__andrei.gmxhome.de_eclipse/url=http\://andrei.gmxhome.de/eclipse/
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_dsdp_dd_updates/url=http\://download.eclipse.org/dsdp/dd/updates
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_modeling_emft_update s/url=http\://download.eclipse.org/modeling/emft/updates/
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_technology_dltk_upda tes_/isSystem=false
/instance/org.cfeclipse.cfml/cfeclipse.editor.bracketMatchin gStyle=0
/project/PROD/de.loskutov.FileSync/WARNING=DO NOT MODIFY THIS FILE IF YOU
DON'T UNDERSTAND
and\
Settings_Dennis_Desktop_eclipse_p2_org.eclipse.equinox.p2.co re_cache/suffix=artifacts.xml
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__www.cfeclipse.org_update/url=http\://www.cfeclipse.org/update
and\
Settings_Dennis_Desktop_eclipse_configuration_org.eclipse.os gi_bundles_63_data_listener_-205926309/isSystem=true
/project/PROD/de.loskutov.FileSync/defaultVariables=
and\ Settings_Dennis_Desktop_Ganymede_.eclipseextension/isSystem= true
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.forge.objectweb.org_eclipse-upda te_site.xml/url= http\://download.forge.objectweb.org/eclipse-update/site.xml
/project/trunk/org.eclipse.wst.html.core/elemUnclosedEndTag= 1
and\
Settings_Dennis_Desktop_Ganymede_configuration_org.eclipse.o sgi_bundles_69_data_listener_1925729951/provider=
and\
Settings_Dennis_Desktop_eclipse_configuration_org.eclipse.os gi_bundles_69_data_listener_1925729951/isSystem=true
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.compiler .problem.enumIdentifier=error
and\
Settings_Dennis_Desktop_eclipse_configuration_org.eclipse.os gi_bundles_69_data_listener_1925729951/url=file\:/C\:/Docume nts
and
Settings/Dennis/Desktop/eclipse/configuration/org.eclipse.os gi/bundles/69/data/listener_1925729951/
/instance/org.eclipse.dltk.mylyn/org.eclipse.dltk.mylyn.ui.f irst.run=false
@org.eclipse.mylyn.resources.ui=3.0.5.v20090218-1800-e3x
/instance/org.eclipse.jdt.ui/useQuickDiffPrefPage=true
/project/trunk/org.eclipse.wst.html.core/cdataUnclosed=1
/instance/org.eclipse.wst.jsdt.ui/org.eclipse.wst.jsdt.inter nal.ui.navigator.layout=1
and\
Settings_Dennis_Desktop_Ganymede_p2_org.eclipse.equinox.p2.c ore_cache/version=1.0.0
/instance/org.cfeclipse.cfml/cfscriptStringColor=116,237,204
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_modeling_m2m_updates _/isSystem=false
/instance/org.eclipse.ui.ide/OPEN_REQUIRED_PROJECTS=never
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_tools_cdt_releases_g anymede/isSystem=false
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_modeling_emf_updates _/isSystem=false
and\ Settings_Dennis_Desktop_eclipse/provider=
/instance/org.cfeclipse.cfml/cfeclipse.editor.showToolbar=tr ue
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_modeling_emft_update s_/isSystem=false
/configuration/org.eclipse.core.net/org.eclipse.core.net.has Migrated=true
/project/trunk/org.eclipse.mylyn.tasks.ui/project.repository .kind=local
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_modeling_mdt_updates _/isSystem=false
/instance/org.tigris.subversion.subclipse.ui/pref_merge_use_ external=true
and\ Settings_Dennis_Desktop_eclipse_.eclipseextension/isSystem=t rue
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__andrei.gmxhome.de_eclipse_/url=http\://andrei.gmxhome.de/eclipse/
/instance/org.eclipse.team.core/changeSets/SVNStatusSubscrib er/Search\
for\ Contacts.\ Code/comment=Incomplete - taskSearch for Contacts. Code \n
/instance/org.eclipse.core.net/org.eclipse.core.net.hasMigra ted=true
and\ Settings_Dennis_Desktop_Ganymede/provider=
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__andrei.gmxhome.de_eclipse/name=http\://andrei.gmxhome.de/eclipse/
/project/PROD/de.loskutov.FileSync/useCurrentDateForDestinat ionFiles=false
/project/trunk/org.eclipse.wst.html.core/elemMissingStart=1
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__subclipse.tigris.org_update_1.4.x/type=or g.eclipse.equinox.p2.updatesite.artifactRepository
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_tools_mylyn_update_e 3.4/url=http\://download.eclipse.org/tools/mylyn/update/e3.4
and\ Settings_Dennis_Desktop_Ganymede/suffix=artifacts.xml
/instance/org.eclipse.jst.jsp.core/org.eclipse.jst.jsp.core. taglib.TaglibIndex=CLEAN
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_technology_emft_upda tes/isSystem=false
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_modeling_m2m_updates /isSystem=false
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_birt_update-site_2.3 /enabled=false
and\
Settings_Dennis_Desktop_Ganymede_p2_org.eclipse.equinox.p2.c ore_cache/provider=
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.builder. resourceCopyExclusionFilter=*.launch
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_stp_updates_/enabled =false
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_releases_ganymede/en abled=true
/instance/org.eclipse.wst.jsdt.ui/org.eclipse.wst.jsdt.ui.te xt.custom_templates= <?xml
version\="1.0" encoding\="UTF-8" standalone\="no"?><templates/>
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_modeling_emft_update s/isSystem=false
/instance/org.cfeclipse.cfml/unknowTagColors=151,255,177
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_modeling_gmf_updates _releases_/url=http\://download.eclipse.org/modeling/gmf/updates/releases/
and\
Settings_Dennis_Desktop_eclipse_p2_org.eclipse.equinox.p2.co re_cache/isSystem=true
/project/trunk/org.eclipse.wst.html.core/elemInvalidContent= 2
/project/trunk/org.eclipse.wst.html.core/docDoctypeUnclosed= 1
/instance/org.eclipse.cdt.ui/useQuickDiffPrefPage=true
and\
Settings_Dennis_Desktop_eclipse_p2_org.eclipse.equinox.p2.co re_cache/name=download
cache
/instance/org.eclipse.wst.jsdt.core/org.eclipse.wst.jsdt.cor e.codeComplete.visibilityCheck=enabled
/project/trunk/de.loskutov.anyedit.AnyEditTools/replaceAllSp aces=false
and\
Settings_Dennis_Desktop_Ganymede_configuration_org.eclipse.o sgi_bundles_69_data_listener_1925729951_/type=org.eclipse.eq uinox.internal.p2.metadata.repository.LocalMetadataRepositor y
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__subclipse.tigris.org_update_1.4.x/descrip tion=
/instance/org.cfeclipse.cfml/stringColor=188,224,152
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__www.eclipse.org_mylyn_downloads_/url=http\://www.eclipse.org/mylyn/downloads/
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__eclipse.svnkit.com_1.2.x/description=
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__andrei.gmxhome.de_eclipse_/enabled=true
/instance/org.cfeclipse.cfml/SQLKeywordColor=159,205,232
and\
Settings_Dennis_Desktop_Ganymede_p2_org.eclipse.equinox.p2.d irector_rollback/url=file\:/C\:/Documents
and
Settings/Dennis/Desktop/Ganymede/p2/org.eclipse.equinox.p2.d irector/rollback
/project/trunk/org.eclipse.wst.html.core/elemCoexistence=2
/instance/org.eclipse.rse.core/org.eclipse.rse.systemtype.lo cal.systemType.defaultUserId=Dennis
/instance/org.cfeclipse.cfml/cfscriptKeywordColor=131,189,22 4
and\
Settings_Dennis_Desktop_Ganymede/type=org.eclipse.equinox.p2 .artifact.repository.simpleRepository
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__eclipse.org_tptp_updates/enabled=false
and\
Settings_Dennis_Desktop_Ganymede_configuration_org.eclipse.o sgi_bundles_69_data_listener_1925729951_/isSystem=true
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_technology_dltk_upda tes_/url=http\://download.eclipse.org/technology/dltk/updates/
/instance/org.eclipse.wst.sse.ui/hoverModifiers=combinationH over|true|0;problemHover|false|0;documentationHover|false|0; annotationHover|true|Shift;
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_technology_emft_upda tes/url=http\://download.eclipse.org/technology/emft/updates/
/instance/org.tigris.subversion.subclipse.ui/pref_merge_prog ram_location=C\:\\Program
Files\\Compare It\!\\wincmp3.exe
/instance/org.eclipse.jdt.ui/content_assist_proposals_foregr ound=0,0,0
@org.eclipse.ui.editors=3.4.0.v20080603-2000
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_eclipse_updates_3.4/ url=http\://download.eclipse.org/eclipse/updates/3.4
/instance/org.eclipse.jst.j2ee.webservice.ui/areThereWebServ ices=false
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_tools_cdt_releases_g anymede/url=http\://download.eclipse.org/tools/cdt/releases/ganymede
/project/trunk/de.loskutov.FileSync/useCurrentDateForDestina tionFiles=false
/instance/org.eclipse.mylyn.context.ui/org.eclipse.mylyn.ui. perspectives.task.none=org.cfeclipse.cfml.perspective.CFML
and\ Settings_Dennis_Desktop_eclipse_.eclipseextension/descriptio n=
@org.eclipse.cdt.ui=5.0.2.200902130801
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_tools_buckminster_up dates/isSystem=false
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.compiler .problem.assertIdentifier=error
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__www.eclipse.org_modeling_emft_updates_/is System=false
/instance/org.cfeclipse.cfml/cfeclipse.editor.warnReadOnlyFi les=false
/instance/org.eclipse.wst.jsdt.ui/proposalOrderMigrated=true
@org.eclipse.mylyn.java.ui=3.0.5.v20090218-1800-e3x
/instance/org.eclipse.team.core/changeSets/SVNStatusSubscrib er/defaultSet=Search
for Contacts. Code
/instance/org.eclipse.ui.ide/platformState=1236880094838
and\
Settings_Dennis_Desktop_eclipse/type=org.eclipse.equinox.p2. artifact.repository.simpleRepository
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.compiler .codegen.targetPlatform=1.6
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_tools_cdt_releases_g anymede/isSystem=false
and\
Settings_Dennis_Desktop_Ganymede_p2_org.eclipse.equinox.p2.c ore_cache_/type=org.eclipse.equinox.internal.p2.metadata.rep ository.LocalMetadataRepository
@org.eclipse.team.cvs.ui=3.3.100.r34x_20090121
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__eclipse.svnkit.com_1.2.x_/type=org.eclips e.equinox.p2.updatesite.metadataRepository
and\
Settings_Dennis_Desktop_Ganymede_configuration_org.eclipse.o sgi_bundles_63_data_listener_-177846376/provider=
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_releases_ganymede/ve rsion=1.0.0
/project/trunk/org.eclipse.wst.html.core/attrInvalidValue=2
/instance/org.eclipse.ui.editors/lineNumberRuler=true
/project/trunk/org.eclipse.wst.html.core/elemMissingEnd=2
/configuration/org.eclipse.ui.ide/RECENT_WORKSPACES_PROTOCOL =3
and\ Settings_Dennis_Desktop_Ganymede_.eclipseextension/version=1
/project/trunk/org.eclipse.wst.html.core/elemUnnecessaryEnd= 2
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__www.eclipse.org_modeling_emft_?project\=s earch\#search/isSystem=false
/project/trunk/org.eclipse.wst.html.core/piUnclosed=1
/instance/org.cfeclipse.cfml/cftagColor=131,173,252
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__subclipse.tigris.org_update_1.2.x/isSyste m=false
/instance/org.eclipse.team.core/changeSets/CVS\
Workspace/defaultSet=Search for Contacts. Code
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__andrei.gmxhome.de_eclipse_/version=1
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__www.cfeclipse.org_update/description=
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__eclipse.org_tptp_updates/isSystem=false
and\
Settings_Dennis_Desktop_Ganymede_p2_org.eclipse.equinox.p2.c ore_cache/description=
@org.eclipse.cdt.mylyn.ui=5.0.1.200902130801
/instance/org.cfeclipse.cfml/cfscriptTextColor=255,128,128
/project/trunk/org.eclipse.wst.html.core/attrValueMismatch=1
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_tools_mylyn_update_e 3.4/isSystem=false
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__www.eclipse.org_modeling_emft_updates/ena bled=false
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__www.eclipse.org_modeling_emft_?project\=s earch\#search/url= http\://www.eclipse.org/modeling/emft/?project\=search\#sear ch
and\
Settings_Dennis_Desktop_Ganymede_configuration_org.eclipse.o sgi_bundles_63_data_listener_-177846376/type=org.eclipse.equ inox.p2.artifact.repository.simpleRepository
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.taskPrio rities=normal
and\ Settings_Dennis_Desktop_Ganymede/description=
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__subclipse.tigris.org_update_1.4.x/provide r=
/project/trunk/org.eclipse.wst.html.core/elemInvalidName=1
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_tools_mylyn_update_e xtras/url=http\://download.eclipse.org/tools/mylyn/update/extras
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_tools_mylyn_update_e xtras/type=org.eclipse.equinox.internal.p2.metadata.reposito ry.LocalMetadataRepository
/instance/org.eclipse.debug.ui/org.eclipse.debug.ui.PREF_LAU NCH_PERSPECTIVES= <?xml
standalone\="no"?>\r\n<launchPerspectives/>\r\n
and\
Settings_Dennis_Desktop_Ganymede_.eclipseextension/name=C\:\ \Documents and
Settings\\Dennis\\Desktop\\Ganymede\\.eclipseextension
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_releases_ganymede/ty pe=org.eclipse.equinox.p2.artifact.repository.simpleReposito ry
@org.eclipse.jst.jsp.core=1.2.121.v200901290830
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_tools_mylyn_update_w eekly_e3.4/enabled=true
/instance/org.eclipse.epp.usagedata.recording/org.eclipse.ep p.usagedata.recording.last-upload=1236892187523
@org.eclipse.team.core=3.4.2.r34x_20080115
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_webtools_updates/url =http\://download.eclipse.org/webtools/updates
and\ Settings_Dennis_Desktop_eclipse/version=1.0.0
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.forge.objectweb.org_eclipse-upda te_site.xml/isSystem=false
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_rt_rap_update-site/u rl=http\://download.eclipse.org/rt/rap/update-site
/instance/org.cfeclipse.cfml/currentLineColor=95,95,95
/instance/org.eclipse.mylyn.monitor.ui/org.eclipse.mylyn.mon itor.user.activity.enabled=true
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__www.eclipse.org_mylyn_downloads/enabled=t rue
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__download.eclipse.org_dsdp_tm_updates_3.0/ isSystem=false
and\
/project/trunk/org.eclipse.wst.html.core/elemUnclosedStartTa g=1
and\
Settings_Dennis_Desktop_Ganymede_configuration_org.eclipse.o sgi_bundles_63_data_listener_-177846376_/isSystem=true
/project/trunk/org.eclipse.wst.html.core/commentUnclosed=1
/instance/org.eclipse.jdt.ui/spelling_locale_initialized=tru e
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__eclipse.svnkit.com_1.2.x/name=http\://eclipse.svnkit.com/1.2.x/
/instance/org.eclipse.jdt.launching/org.eclipse.jdt.launchin g.PREF_VM_XML= <?xml
version\="1.0" encoding\="UTF-8" standalone\="no"?>\r\n<vmSettings
defaultVM\=" 57,org.eclipse.jdt.internal.debug.ui.launcher.StandardVMType 13,1236894838136 ">\r\n<vmType
id\="org.eclipse.jdt.internal.debug.ui.launcher.StandardVMType ">\r\n<vm
id\="1236894838136" javadocURL\="http\://java.sun.com/javase/6/docs/api/"
name\="jre1.6.0_04" path\="C\:\\Program
Files\\Java\\jre1.6.0_04"/>\r\n</vmType>\r\n</vmSettings >\r\n
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__download.eclipse.org_tools_gef_update-sit e_releases_site.xml/enabled=false
and\ Settings_Dennis_Desktop_Ganymede_.eclipseextension/provider=
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__www.cfeclipse.org_update/name=file\:/User s/markdrew/Documents/Eclipse_Workspaces/cfeclipse2/org.cfecl ipse.cfml.update/
- artifacts
/configuration/org.eclipse.ui.ide/SHOW_WORKSPACE_SELECTION_D IALOG=false
and\
Settings_Dennis_Desktop_eclipse_configuration_org.eclipse.os gi_bundles_69_data_listener_1925729951/provider=
/instance/org.eclipse.mylyn.java.ui/org.eclipse.mylyn.ui.fir st.run.0_4_9=false
/instance/org.eclipse.equinox.p2.ui.sdk/download=true
/project/trunk/de.loskutov.FileSync/defaultVariables=
/instance/org.eclipse.mylyn.context.ui/org.eclipse.mylyn.con text.ui.close.action.manage.warning=false
and\
/configuration/org.eclipse.equinox.p2.artifact.repository/re positories/http\:__subclipse.tigris.org_update_1.2.x/enabled =false
/configuration/org.eclipse.equinox.p2.metadata.repository/re positories/http\:__www.eclipse.org_modeling_emft_updates_/ur l=http\://www.eclipse.org/modeling/emft/updates/
/instance/org.eclipse.wst.sse.ui/foldingEnabled=true
and\
Settings_Dennis_Desktop_Ganymede_p2_org.eclipse.equinox.p2.c ore_cache_/enabled=true
and\ Settings_Dennis_Desktop_Ganymede/url=file\:/C\:/Documents and
and\ Settings_Dennis_Desktop_eclipse_.eclipseextension/provider=
Re: Ganymede & Mylyn [message #596867 is a reply to message #66855] |
Thu, 19 March 2009 03:19 |
Junior Member |
*** Current Install Configuration:
Install configuration:
Last changed on Mar 18, 2009
Settings/Dennis/Desktop/Ganymede/configuration/org.eclipse.u pdate/platform.xml
Configured sites:
platform:/base/
file:/C:/Documents and Settings/Dennis/Desktop/Ganymede/
Configured features:
ID: org.eclipse.dd.dsf.gdb_launch, Version: 1.0.0.v20080609
2.3.2.r232_v20081010-7_7D79_doT2uMPVNwOGoz0HKuyI8
ID: org.eclipse.buckminster.cvs, Version: 1.0.0.r09930
2.3.2.r232_v20081010-4538k797M733K3737
ID: org.eclipse.nab.mwt.native, Version: 0.9.9.200806181757
1.2.0.v200805130238-11-7w311916241349
3.4.1.R342_v20090126-7w7TENgETuNblxYRhBOLydU3ADDC
1.6.2.v200810071455-3019oA55U6_7H6KAC
ID: org.eclipse.ecf.example.collab, Version: 2.1.0.v20081224-1728
ID: com.lowagie.itext, Version: 1.5.4.v20080225-1437w31191339
3.4.2.R342_v20090122-7O7S7GApJ3_vCyk7ETmsfcmjhz0eHnqw7MIjk9V dhe4Ic
ID: org.eclipse.emf.ecore, Version: 2.4.2.v200902171115
ID: org.eclipse.uml2tools.examples, Version: 0.8.0.v200809231457
ID: org.mx4j.jmx, Version: 4.4.100.v200901090956-3-37w311_12211211
1.0.0.v20080115-5318xB6CE899P233613552
1.6.2.v200810071455-443_kE77d7OAPAMJQ
1.0.2.r34x_v20090120-7d-7tEQcCaaYSBeNOClOn02267
1.6.2.v200810071455-1507w31191939244824
2.0.3.v200902181600-7J-7EB-NLwTYlTNN4PlbFLKRNHYG
2.3.2.r232_v20081010-7k8E7fELFluav5n_2NEXh3W6B9_
0.95.1.v20080626-2043-08T07w31191_1402545
2.3.2.r232_v20090212-2217s343A311_1313
ID: org.tigris.subversion.clientadapter, Version: 1.5.3
3.0.0.v20080530-7N-E8ME8McIJXIwdh
2.3.2.r232_v20081010-2217s343Aw31192216
1.1.2.R342_v20090122-7C79E9x9sLM1t6M9YD7_A7
2.1.0.v20080716-1600-7W7AE8OEHhHehFgH1yL4uOE
1.6.2.v200810071455-1-07w311_12281248
1.2.0.v200805130238-35-9oA55S5L8G6FCT
3.0.4.v200812040936-7A7NEH2E7QYGHOIsNrGpVX
3.0.4.v200811261813-7H7QECiED69XqLgwowgm-47C5J
1.5.2.v200809302010-1407w311917141519
2.1.1.v200809041200-4118s733I3J4F5C48
ID: org.eclipse.emf.common, Version: 2.4.0.v200902171115
1.6.2.v200810071455-25184B23NbbGK_OXQXHz-QP
ID: org.eclipse.uml2.search.runtime, Version: 0.7.0.v200806130939
4.4.200.v200901090956-43_77w311_121_1_67
3.0.3.v200810010400-42E_4_kE77c_FAP7X99
3.0.4.v200811211541-7F2ENnCwum8W79A1UYNgSjOcFVJg
1.1.0.v20080731-1518-7K8V4EFp_acwc90fc4fP
ID: org.apache.commons.codec, Version: 1.3.0.v20070920-12-7w3119164102711
0.95.1.v20080626-2043-0EEJ77E9IgKLhLeUz0ALs1x5
2.3.2.r232_v20081010-7N7Y7MAIe2QJZSgfOaAphGBR4t7b
ID: org.eclipse.emf.ecore.editor, Version: 2.4.0.v200902171115
ID: org.eclipse.emf.mint.doc, Version: 0.7.1.v200809162149
ID: org.tigris.subversion.subclipse.graph, Version: 1.0.5
3.4.2.R342_v20090122-9I96EiWElHi8lheoJKJIvhM3JfVsYbRrgVIWL
1.6.2.v200810071455-7D47FEB7sQSBV7hXWQ6R
1.0.2.R342_v20090122-7r7xEKaEJBZu5oGhP3u6nOmbM9VK
ID: org.tigris.subversion.subclipse.core, Version: 1.4.8
ID: org.eclipse.emf.codegen.ecore, Version: 2.4.2.v200902171115
ID: org.eclipse.emf.databinding, Version: 1.0.0.v200902171115
3.0.4.v20090115-791DC9vETDnvTGSaCQNM76BD
2.0.2.v200811110900-2-17w311922221_11
ID: org.eclipse.uml2.source, Version: 2.2.2.v200902101430
1.1.2.v20080916-2008-2108s733I3E4F15B59
1.6.2.v200810071455-6--BcMAB-BKFVEmLF
4.3.200.v200812160100-42_77w311923271211
3.4.2.v20090218-1145-67738084A6665K366B84__58x422
1.1.0.v20080716-1600-2-Ag8s733I3A7C15KCK
1.0.1.r34x_v20080721-7Y-7hEMrtGZhTrQ--t43w02267
1.6.2.v200810071455-502AgI99mASCdBYCN
0.95.1.v20080626-2043-0ECq6E8McIJXJUOr9upp-2
4.5.0.v200805132041-44-7w311916271211
2.1.0.v20090128-3219oA55U5D7N2532
3.4.2.r342_v20081217-7o7tEAoEEDWEm5HTrKn-svO4BbDI
1.6.2.v200810071455-7A-5E9IgKLjM1d1Oepu
2.3.2.r232_v20081204-2217s343A311_1233
3.0.4.v200811240900-7R0EP7E8Ks9v7urtuDJtBcaRV6Ri
1.0.1.r34x_v20080721-7T-7cEJ6Wz-YqXOBdehgpS
1.0.0.v20070608-3--8s733G3C5C
ID: org.eclipse.emf.mapping, Version: 2.4.0.v200902171115
ID: org.eclipse.emf.codegen.ecore.ui, Version: 2.4.1.v200902171115
2.1.1.v20080710-7_40AgI99m9d_O
2.1.1.v200809181500-6678AgI99m9W9X5J79
3.3.101.R34x_v20081125-7H-ELfE8hXnkE15Wh9Tnyu
ID: org.apache.derby.core, Version: 10.3.1.4
ID: org.eclipse.uml2.search.common, Version: 0.7.0.v200806130939
ID: org.eclipse.gmf.doc, Version: 1.2.2.v20080916-2008-2218s733H3H4_1673A
3.0.1.v200808091845-108Y7w31191922
1.6.2.v200810071455-3019oA55V599K5M9_
ID: org.eclipse.uml2.search.ocl, Version: 0.7.0.v200806130939
3.0.150.v200901232034-109K7w311_12343145
ID: org.eclipse.emf.edit, Version: 2.4.2.v200902171115
ID: org.eclipse.epp.usagedata.feature, Version: 1.0.1.R200809220400
3.0.3.v200810090336-40EJs_kE77c8P_TALGS
0.95.1.v20080903-1434-0Bw2_kE77c7a9N3BFKL
ID: org.eclipse.emf.converter, Version: 2.4.1.v200902171115
3.0.100.v200901232040-34EEP9oA55T5J7N9BBK
ID: org.eclipse.ocl.uml, Version: 1.2.3.v200811021759-1127w311_12182518
1.6.2.v200810071455-1507w311918132411
1.6.2.v200810071455-57_2_pFAIQJZIsLSXb8MDD
1.6.2.v200810071455-446_kE77d8H_VALOJ
ID: org.eclipse.uml2.examples, Version: 2.2.0.v200805131030
ID: org.eclipse.dd.ipxact, Version: 0.9.0.v20080609
2.3.2.r232_v20081010-67859cADAamA55V5A89
4.5.0.v200805132041-7879-8192A5695E699A2322
2.3.2.r232_v20081010-7D7J7CC7QXRK0ICmcLILD
ID: org.eclipse.emf.common.ui, Version: 2.4.0.v200902171115
ID: org.eclipse.emf.query, Version: 1.2.0.v200805130238-11-7w311916241349
ID: org.eclipse.emf.mapping.ecore.editor, Version: 2.4.0.v200902171115
ID: de.loskutov.eclipse.jdepend, Version: 1.2.1
3.0.3.v200902042310-7J378DUUEFGEpIz-AW8E
ID: org.tmatesoft.svnkit, Version: 1.2.3.5521
3.0.2.v200809102124-2518s733I3G395I75
1.6.2.v200810071455-442_kE77d7N9VANON
1.6.2.v200810071455-440_kE77c7QAQEIQQ
4.4.100.v200901090956-7B78CE9oA55S8A8M5855
3.4.200.R342_v20090122-989JESTEbig-SVaL8UJHcYBr4A63
ID: org.eclipse.releng.tools, Version: 3.2.200.v20080603-33-7w31191525
1.6.2.v200810071455-797P78CYQCD5DjGdEURT
1.6.2.v200810071455-6-2BcMAAyBWDkEVSb
3.4.2.R342_v20090122-7T7U1E9imVKz-A8Vz-p_jRS
ID: org.eclipse.uml2.doc, Version: 2.2.0.v200805201350
ID: org.eclipse.cvs, Version: 1.1.2.R342_v20090122-7C79E9x9sLM1t6M9YD7_A7
3.4.2.v20090218-1145-67728084A56B4I233613552
3.0.4.v200811251652-7E4EAvDgz-Y1htmiH5158SnFBSiT
3.0.1.v200809171630-78479_kE77c7Q8b8T_F
ID: org.eclipse.mylyn, Version: 3.0.5.v20090218-1800-e3x
ID: org.eclipse.uml2.diagram, Version: 0.8.1.v200809231457
ID: org.eclipse.dd.debug.memory.renderings, Version: 1.0.0.v20080609
1.6.2.v200810071455-7_7K7NDn-QYKjkBKlmD4edYsAX
3.0.4.v200811260650-7Q7AEf1EHhHehNmEARhS7t
1.6.2.v200810071455-7F7d7AE8yz-YIwEvOFuOF3SqVz-z
1.6.2.v200810071455-67S779KdRRFAuQFpKZ2z-0mp49Vx
3.0.4.v200811200248-7C78ELhE8VrRVqtHp4iT8PuSwZ5W
ID: org.eclipse.cdt.mylyn, Version: 5.0.2.200902130801
ID: org.eclipse.emf.mapping.ecore, Version: 2.4.0.v200902171115
ID: org.cfeclipse.cfml, Version: 1.3.2.200901041029
3.0.3.v200902042310-7H37E8qfisI6diJKMbrhR-TV-a3
4.5.0.v200805132041-7J7N-_-M7OKEQDfDTIK95C7
1.0.4.v200812112112-6-E75BcMAAyDJGhFpNN
4.5.0.v200805132041-7879-8s733I3D6B5878
ID: org.eclipse.emf.mapping.ui, Version: 2.4.0.v200902171115
4.5.0.v200805230100-7p80-E9UsMfZXChNc0so95C7
ID: org.eclipse.ecf, Version: 2.1.0.v20081224-1728
1.4.1.v200809302010-13-7w311917141518
ID: de.loskutov.FileSync, Version: 1.3.3
1.6.2.v200810071455-7D8H7P9FT9Ofz-RuiDlMiw8OR2pj
1.6.2.v200810071455-37A09oA55S6H_L8DFG24
1.2.3.v200810041753-2328s733J3_56398B
ID: org.eclipse.emf.codegen.ui, Version: 2.4.0.v200902171115
ID: org.eclipse.jst, Version: 1.0.3.v200901220134-77-E_FCYQCD5EeNgKUUY
ID: org.tigris.subversion.clientadapter.javahl, Version: 1.5.6
1.2.1.v200807161719-2308s733I3E5B4B7J
ID: org.eclipse.rse.services.ssh, Version: 2.1.1.v20080714-7830_kE77c7V8M
1.1.101.v200808291106-108Z7w3119193_2217
ID: org.eclipse.uml2.diagram.source, Version: 0.8.1.v200809231457
ID: com.sun.jna, Version: 3.0.9
ID: org.eclipse.draw2d, Version: 3.4.2.v20090218-1145-3317w311_122502441
0.95.1.v20080626-2043-0EEJ6E9IgKLhLZW8AKz0uq5
1.6.2.v200810071455-2138s733J465I548A
4.3.101.v200901090956-7B79Aj9oA55V585V5VJM
3.0.4.v20090115-20Am8s733J3_4F1256
ID: org.eclipse.emf.databinding.edit, Version: 1.0.0.v200902171115
ID: org.eclipse.dd.dsf.sdk, Version: 1.0.0.v20080609
3.0.4.v200901240221-52EFzAgI99n_WAjGIJb
ID: org.eclipse.emf.ecore.edit, Version: 2.4.1.v200902171115
ID: org.eclipse.nab.mwt, Version: 0.9.9.200806181757
ID: de.loskutov.eclipseskins.extvs, Version: 1.5.1
4.4.101.v200901090956-7F7DDr_kE77g7A7g7gQU
1.6.2.v200810071455-27A18s733I3I7I599G59
2.3.2.r232_v20081010-7X7n7WEBPrSQ6K-eN3CvLiGaMQ4d
1.0.1.r34x_v20080721-7T-7ZEIdY2TtPOAWojptd
1.6.2.v200810071455-3-29oA55S7__D7LCC
1.6.2.v200810071455-442_kE77c7VBQDFNW
3.0.3.v200902042310-7Z37HEB7sQSCRiULOVOE
2.0.1.v20080715-2-07w31191826
3.0.4.v200811240900-7G2EAzAM215iJKQCZssIGG6lQwlL
ID: org.eclipse.emf.edit.ui, Version: 2.4.2.v200902171115
ID: org.tigris.subversion.subclipse.mylyn, Version: 3.0.0
ID: de.loskutov.anyedit.AnyEditTools, Version: 2.1.3.200901071535
3.0.1.v20080730-4-CF_kE77c7SCI58GJ
0.1.3.v200902181600-2269sB9EP_M_W5B5B3822
1.6.2.v200810071455
2.3.2.r232_v20081010-2217s343A3119211_
0.95.1.v20080903-1434-09y08s733I3H3E15B_7
ID: org.eclipse.uml2, Version: 2.2.2.v200902101430
1.6.2.v200810071455-77-0CYQCD7FTIWGyPO
3.0.0.v200805040310-21CE8s733I3D4C56AA
3.0.4.v200811190840-7A-8l8Qqcz0HyVgjXUE-iuOYZ9ai
0.95.1.v20080903-1434-0AR09oA55S5N9J28GBE
ID: org.eclipse.emf.search.ecore, Version: 0.7.0.v200806130939
3.4.2.v20090218-1145-7B7E597OKBd7QHgEHNHn9JKTFJJR
ID: org.w3c.sac, Version: 1.3.0.v20080102-46-_kE77b7U_N56BA
ID: org.eclipse.tm.terminal.view, Version: 2.0.1.v20080715-2-07w31191826
ID: org.eclipse.buckminster.ui, Version: 1.1.0.r09948
4.5.0.v200805132041-44-7w311916243152
1.6.2.v200810071455-7F27SBcMAAxCcHmCNWi
ID: org.eclipse.emf, Version: 2.4.2.v200902171115
ID: org.eclipse.xsd, Version: 2.4.2.v200902171115
2.3.2.r232_v20081010-2217s343Aw31192224
2.3.2.r232_v20081010-7X8n7EELtcA6FxGJtxH7_f
1.6.2.v200810071455-6577AlJCKcLZI2Ljcc8MDD
ID: org.eclipse.emf.mint.source, Version: 0.7.1.v200809162149
1.0.0.v20080115-5318_GCGFGJMZHOMaa6PMUULSPXD
3.0.4.v200811190820-7Y7BFT1EPOwQQfPq5sVdQ6P_QtVn
ID: org.tigris.subversion.clientadapter.svnkit, Version: 1.5.6
1.6.2.v200901211403-7C67XCYQCD7ESIqIQco
1.1.3.v20090122-1525-7c7a7gEWvhKvnd6yDGljor8ukFgQ
1.0.0.v20070507-7B794E7QYGHMGxTcAasgF
ID: org.eclipse.buckminster.maven, Version: 1.1.0.r09904
ID: org.eclipse.sdk.examples.source, Version: 3.2.0.v20080611
ID: org.eclipse.buckminster.remote.feature, Version: 1.0.0.r09842
ID: org.eclipse.emf.search.runtime, Version: 0.7.0.v200806130939
3.0.4.v200811200248-7E2EH6C-2fA3PMioFSbnhI_YkSTU
ID: de.loskutov.BytecodeOutline.feature, Version: 2.2.8
1.0.0.v20070510-7F57CE9IgKLaMASi7KHI3
2.0.3.v200902181600-2-27w311_13292711
1.0.0.v20080522-1--7w3119171503111
ID: org.eclipse.ocl, Version: 1.2.3.v200810101725-3439oA55T5F8H8PAB
ID: org.eclipse.buckminster.p4.ui, Version: 1.0.0.r09908
Version: 2.3.2.r232_v20081010-787A779lxNRkRRSNH-o3EoA3OFYi
3.2.0.v20080611-837bEN1ECCP57BAaYN7HSHEb
ID: org.mozilla.rhino, Version: 1.6.7.v20071217-1567w31191325
ID: org.eclipse.pde.p2, Version: 1.0.0.v20080522-1--7w3119171503111
ID: org.eclipse.xsd.edit, Version: 2.4.0.v200902171115
ID: org.eclipse.dd.dsf.gdb, Version: 1.0.0.v20080609
ID: org.eclipse.emf.search.ecore.ocl, Version: 0.7.0.v200806130939
ID: org.eclipse.buckminster.pde, Version: 1.1.340.r09942
1.1.2.v200812041720-2138s733I573A5G73
ID: org.eclipse.emf.search.ocl, Version: 0.7.0.v200806130939
3.0.4.v200811200248-7C7_EVNE_EkMNtRvY4V6o0
ID: org.eclipse.emf.codegen, Version: 2.4.0.v200902171115
ID: org.eclipse.uml2.examples.source, Version: 2.2.0.v200805131030
ID: org.eclipse.sdk, Version: null
ID: org.eclipse.equinox.p2.user.ui, Version: null
ID: org.eclipse.cvs.source, Version: null
ID: org.eclipse.platform, Version: null
ID: org.eclipse.help.base, Version: null
ID: org.eclipse.jdt, Version: null
ID: org.eclipse.help.source, Version: null
ID: org.eclipse.rcp.source, Version: null
ID: org.eclipse.pde.source, Version: null
ID: org.eclipse.cvs, Version: null
ID: org.eclipse.rcp, Version: null
ID: org.eclipse.platform.source, Version: null
ID: org.eclipse.jdt.source, Version: null
ID: org.eclipse.equinox.p2.user.ui.source, Version: null
1.6.2.v200810071455
ID: org.eclipse.pde, Version: null
ID: org.eclipse.pde.p2.source, Version: null
ID: org.eclipse.pde.p2, Version: null
Re: Ganymede & Mylyn [message #596880 is a reply to message #66855] |
Thu, 19 March 2009 03:21 |
Junior Member |
!SESSION 2009-03-18 19:22:33.221
eclipse.buildId=M20090211-1700
java.version=1.6.0_04
Command-line arguments: -os win32 -ws win32 -arch x86
This is a continuation of log file C:\Code\DENDev\.metadata\.bak_0.log
Created Time: 2009-03-18 19:23:41.316
!ENTRY org.eclipse.ui.workbench.texteditor 4 0 2009-03-18 19:23:41.316
!MESSAGE The
'org.eclipse.wst.jsdt.web.ui.internal.hyperlink.script.JSPJa vaHyperlinkDetector'
extension from plug-in 'org.eclipse.wst.jsdt.web.ui' to the
'org.eclipse.ui.workbench.texteditor.hyperlinkDetectors' extension point
will be ignored because it contains invalid attributes.
!MESSAGE The
'org.eclipse.wst.jsdt.web.ui.internal.hyperlink.script.event .JSPJavaHyperlinkDetector'
!ENTRY org.eclipse.ui.workbench 2 0 2009-03-18 19:23:44.409
!MESSAGE A handler conflict occurred. This may disable some commands.
!SUBENTRY 1 org.eclipse.ui.workbench 2 0 2009-03-18 19:23:44.409
!MESSAGE Conflict for
'AUTOGEN:::org.cfeclipse.cfml.frameworks.contribution1/org.c feclipse.cfml.frameworks.newAction':
HandlerActivation(commandId=AUTOGEN:::org.cfeclipse.cfml.fra meworks.contribution1/org.cfeclipse.cfml.frameworks.newActio n,
handler=ActionDelegateHandlerProxy(null,org.cfeclipse.cfml.f rameworks.popup.actions.SetFrameworkFile),
expression=WorkbenchWindowExpression(org.eclipse.ui.internal.WorkbenchWindow@1e0f790),sourcePriority=16384)
handler=ActionDelegateHandlerProxy(null,org.cfeclipse.cfml.f rameworks.popup.actions.SetAsConfigFolder),
!ENTRY org.eclipse.jface 2 0 2009-03-18 19:23:44.409
!MESSAGE Keybinding conflicts occurred. They may interfere with normal
accelerator operation.
!SUBENTRY 1 org.eclipse.jface 2 0 2009-03-18 19:23:44.409
!MESSAGE A conflict occurred for CTRL+SHIFT+P:
Binding(CTRL+SHIFT+P,
ParameterizedCommand(Command(org.eclipse.ecf.presence.ui.com mands.browse,Open
Contact,
Category(org.eclipse.ecf.ui.commands.category,Communications ,null,true),
org.eclipse.ecf.internal.presence.ui.handlers.BrowseHandler,
,,true),null),
org.eclipse.ui.defaultAcceleratorConfiguration,
org.eclipse.ui.contexts.window,,,system)
ParameterizedCommand(Command(org.eclipse.emf.search.ecore.co mmon.ui.OpenFilteredEPackageMetaElementsSelectionDialogComma nd,Open
Filtered Ecore Package Meta-Elements Dialog,
Open Filtered Ecore Package Meta-Elements Dialog,
Category(org.eclipse.modeling.editors,Modeling Editors,Modeling Editors
Commands,true),
org.eclipse.emf.search.ecore.common.ui.handlers.OpenFiltered EPackageMetaElementSelectionDialogHandler,
,,true),null),
!ENTRY org.eclipse.mylyn.core 4 0 2009-03-18 19:23:47.910
!MESSAGE Context listener failed:
org.eclipse.mylyn.internal.java.ui.TypeHistoryManager
!STACK 0
java.lang.IllegalArgumentException: Class file name must end with .class
org.eclipse.jdt.internal.core.PackageFragment.getClassFile(P ackageFragment.java:182)
org.eclipse.jdt.internal.core.PackageFragment.getHandleFromM emento(PackageFragment.java:270)
org.eclipse.jdt.internal.core.JavaElement.getHandleFromMemen to(JavaElement.java:272)
org.eclipse.jdt.internal.core.PackageFragmentRoot.getHandleF romMemento(PackageFragmentRoot.java:445)
org.eclipse.jdt.internal.core.JavaProject.getHandleFromMemen to(JavaProject.java:1506)
org.eclipse.jdt.internal.core.JavaModel.getHandleFromMemento (JavaModel.java:167)
at org.eclipse.jdt.core.JavaCore.create(JavaCore.java:2353)
at org.eclipse.jdt.core.JavaCore.create(JavaCore.java:2330)
org.eclipse.mylyn.internal.java.ui.TypeHistoryManager.update TypeHistory(TypeHistoryManager.java:48)
org.eclipse.mylyn.internal.java.ui.TypeHistoryManager.contex tActivated(TypeHistoryManager.java:40)
org.eclipse.mylyn.internal.context.core.InteractionContextMa nager.internalActivateContext(InteractionContextManager.java :589)
org.eclipse.mylyn.internal.context.core.InteractionContextMa nager.activateContext(InteractionContextManager.java:159)
org.eclipse.mylyn.internal.tasks.ui.TasksUiPlugin$1.taskActi vated(TasksUiPlugin.java:264)
org.eclipse.mylyn.internal.tasks.core.TaskActivityManager.ac tivateTask(TaskActivityManager.java:413)
org.eclipse.mylyn.internal.tasks.ui.TaskListManager.activate Task(TaskListManager.java:126)
org.eclipse.mylyn.internal.tasks.ui.TasksUiPlugin$TasksUiIni tializationJob.runInUIThread(TasksUiPlugin.java:417)
at org.eclipse.ui.progress.UIJob$1.run(UIJob.java:94)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:133)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3800)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3425)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2384)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2348)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 00)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:495)
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:288)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:490)
org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:113)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:193)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:386)
!ENTRY org.eclipse.osgi 4 0 2009-03-18 19:23:49.972
!MESSAGE An error occurred while automatically activating bundle
org.eclipse.nab.mwt.jni (17354).
!STACK 0
org.osgi.framework.BundleException: The activator
org.widestudio.mwt.MwtPlugin for bundle org.eclipse.nab.mwt.jni is invalid
org.eclipse.osgi.framework.internal.core.AbstractBundle.load BundleActivator(AbstractBundle.java:146)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:980)
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:346)
org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:265)
org.eclipse.osgi.framework.util.SecureAction.start(SecureAct ion.java:400)
org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter .postFindLocalClass(EclipseLazyStarter.java:111)
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass(ClasspathManager.java:427)
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.fin dLocalClass(DefaultClassLoader.java:193)
org.eclipse.osgi.framework.internal.core.BundleLoader.findLo calClass(BundleLoader.java:370)
org.eclipse.osgi.framework.internal.core.SingleSourcePackage .loadClass(SingleSourcePackage.java:33)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl assInternal(BundleLoader.java:443)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:399)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:387)
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:87)
at java.lang.ClassLoader.loadClassInternal(Unknown Source)
at org.eclipse.nab.mwt.ab.core.CorePlugin.start(CorePlugin.java :70)
org.eclipse.osgi.framework.internal.core.BundleContextImpl$2 .run(BundleContextImpl.java:1009)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:1003)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:984)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl assInternal(BundleLoader.java:446)
org.eclipse.osgi.framework.internal.core.BundleLoader.loadCl ass(BundleLoader.java:315)
org.eclipse.osgi.framework.internal.core.BundleHost.loadClas s(BundleHost.java:227)
org.eclipse.osgi.framework.internal.core.AbstractBundle.load Class(AbstractBundle.java:1274)
org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .createExecutableExtension(RegistryStrategyOSGI.java:160)
org.eclipse.core.internal.registry.ExtensionRegistry.createE xecutableExtension(ExtensionRegistry.java:867)
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:243)
org.eclipse.core.internal.registry.ConfigurationElementHandl e.createExecutableExtension(ConfigurationElementHandle.java: 51)
at org.eclipse.ui.internal.WorkbenchPlugin$1.run(WorkbenchPlugi n.java:267)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:52)
org.eclipse.ui.internal.WorkbenchPlugin.createExtension(Work benchPlugin.java:263)
org.eclipse.ui.internal.decorators.LightweightDecoratorDefin ition$1.run(LightweightDecoratorDefinition.java:124)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
at org.eclipse.core.runtime.Platform.run(Platform.java:880)
org.eclipse.ui.internal.decorators.LightweightDecoratorDefin ition.internalGetDecorator(LightweightDecoratorDefinition.ja va:120)
org.eclipse.ui.internal.decorators.LightweightDecoratorDefin ition.decorate(LightweightDecoratorDefinition.java:251)
org.eclipse.ui.internal.decorators.LightweightDecoratorManag er$LightweightRunnable.run(LightweightDecoratorManager.java: 72)
org.eclipse.ui.internal.decorators.LightweightDecoratorManag er.decorate(LightweightDecoratorManager.java:356)
org.eclipse.ui.internal.decorators.LightweightDecoratorManag er.getDecorations(LightweightDecoratorManager.java:338)
org.eclipse.ui.internal.decorators.DecorationScheduler$1.ens ureResultCached(DecorationScheduler.java:374)
org.eclipse.ui.internal.decorators.DecorationScheduler$1.run (DecorationScheduler.java:334)
Caused by: java.lang.UnsatisfiedLinkError: no mwt_java in java.library.path
at java.lang.ClassLoader.loadLibrary(Unknown Source)
at java.lang.Runtime.loadLibrary0(Unknown Source)
at java.lang.System.loadLibrary(Unknown Source)
at org.widestudio.mwt.MwtPlugin.<clinit>(MwtPlugin.java:30)
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Nativ e Method)
at sun.reflect.NativeConstructorAccessorImpl.newInstance(Unknow n Source)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(Un known
Source)
at java.lang.reflect.Constructor.newInstance(Unknown Source)
at java.lang.Class.newInstance0(Unknown Source)
at java.lang.Class.newInstance(Unknown Source)
org.eclipse.osgi.framework.internal.core.AbstractBundle.load BundleActivator(AbstractBundle.java:141)
... 54 more
Root exception:
Source)
org.eclipse.nab.mwt (17356).
!STACK 0
org.osgi.framework.BundleException: Exception in
org.eclipse.nab.mwt.ab.core.CorePlugin.start() of bundle
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:1028)
Caused by: java.lang.NoClassDefFoundError:
org/widestudio/mwt/MwtInitializer
... 35 more
Caused by:
org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter $TerminatingClassNotFoundException:
org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter .postFindLocalClass(EclipseLazyStarter.java:125)
... 39 more
Caused by: org.osgi.framework.BundleException: The activator
... 49 more
Source)
... 54 more
Root exception:
java.lang.NoClassDefFoundError: org/widestudio/mwt/MwtInitializer
Caused by:
... 39 more
... 49 more
Source)
... 54 more
!ENTRY org.eclipse.equinox.registry 4 1 2009-03-18 19:23:49.972
!MESSAGE Plug-in org.eclipse.nab.mwt was unable to load class
org.eclipse.nab.mwt.ab.core.MwtSourceDecorator.
!STACK 0
Caused by: org.osgi.framework.BundleException: Exception in
... 30 more
... 35 more
Caused by:
... 39 more
... 49 more
Source)
... 54 more
!ENTRY org.eclipse.equinox.p2.metadata.repository 2 0 2009-03-18
19:31:59.556
!MESSAGE Error parsing metadata repository
!SUBENTRY 1 org.eclipse.equinox.p2.core 2 0 2009-03-18 19:31:59.556
!MESSAGE Error at line 10, column 99: Missing required attribute in
"repository": url
!MESSAGE Error at line 10, column 99: Illegal value for attribute "url" of
element "repository": null
!MESSAGE Error at line 11, column 102: Missing required attribute in
"repository": url
!MESSAGE Error at line 11, column 102: Illegal value for attribute "url"
of element "repository": null
!MESSAGE Error at line 12, column 99: Missing required attribute in
"repository": url
!MESSAGE Error at line 12, column 99: Illegal value for attribute "url" of
!MESSAGE Error at line 13, column 97: Missing required attribute in
"repository": url
!MESSAGE Error at line 13, column 97: Illegal value for attribute "url" of
!MESSAGE Error at line 14, column 97: Missing required attribute in
"repository": url
!MESSAGE Error at line 14, column 97: Illegal value for attribute "url" of
!MESSAGE Error at line 15, column 102: Missing required attribute in
"repository": url
!MESSAGE Error at line 15, column 102: Illegal value for attribute "url"
!ENTRY org.eclipse.equinox.p2.metadata.generator 4 0 2009-03-18
19:32:37.244
!MESSAGE Error reading site digest
C:\DOCUME~1\Dennis\LOCALS~1\Temp\1\digest23076.zip.
!STACK 0
java.util.zip.ZipException: error in opening zip file
at java.util.zip.ZipFile.open(Native Method)
at java.util.zip.ZipFile.<init>(Unknown Source)
at java.util.jar.JarFile.<init>(Unknown Source)
org.eclipse.equinox.internal.p2.metadata.generator.features. DigestParser.parse(DigestParser.java:75)
org.eclipse.equinox.internal.p2.updatesite.UpdateSite.loadFe aturesFromDigest(UpdateSite.java:402)
org.eclipse.equinox.internal.p2.updatesite.UpdateSite.loadFe atures(UpdateSite.java:375)
org.eclipse.equinox.internal.p2.updatesite.metadata.UpdateSi teMetadataRepository.generateMetadata(UpdateSiteMetadataRepo sitory.java:108)
org.eclipse.equinox.internal.p2.updatesite.metadata.UpdateSi teMetadataRepository. <init>(UpdateSiteMetadataRepository.java:73)
org.eclipse.equinox.internal.p2.updatesite.metadata.UpdateSi teMetadataRepositoryFactory.load(UpdateSiteMetadataRepositor yFactory.java:48)
org.eclipse.equinox.internal.p2.metadata.repository.Metadata RepositoryManager.loadRepository(MetadataRepositoryManager.j ava:485)
org.eclipse.equinox.internal.p2.metadata.repository.Metadata RepositoryManager.loadRepository(MetadataRepositoryManager.j ava:452)
org.eclipse.equinox.internal.p2.metadata.repository.Metadata RepositoryManager.loadRepository(MetadataRepositoryManager.j ava:435)
org.eclipse.equinox.internal.p2.director.SimplePlanner.gathe rAvailableInstallableUnits(SimplePlanner.java:196)
org.eclipse.equinox.internal.p2.director.SimplePlanner.getPr ovisioningPlan(SimplePlanner.java:235)
org.eclipse.equinox.internal.provisional.p2.ui.operations.Pr ovisioningUtil.getProvisioningPlan(ProvisioningUtil.java:210 )
org.eclipse.equinox.internal.provisional.p2.ui.actions.Insta llAction.computeProvisioningPlan(InstallAction.java:80)
org.eclipse.equinox.internal.provisional.p2.ui.actions.Insta llAction.getProvisioningPlan(InstallAction.java:130)
org.eclipse.equinox.internal.provisional.p2.ui.actions.Profi leModificationAction$1.run(ProfileModificationAction.java:61 )
org.eclipse.jface.operation.ModalContext$ModalContextThread. run(ModalContext.java:121)
!ENTRY org.eclipse.equinox.p2.director 4 0 2009-03-18 19:32:46.291
!MESSAGE Problems resolving provisioning plan.
!SUBENTRY 1 org.eclipse.equinox.p2.director 4 0 2009-03-18 19:32:46.291
!MESSAGE No solution found because the problem in
C:\DOCUME~1\Dennis\LOCALS~1\Temp\1\p2Encoding23092.opb is unsatisfiable.
!ENTRY org.eclipse.equinox.p2.ui 4 10005 2009-03-18 19:32:52.135
!MESSAGE Cannot complete the request. See the details.
!SUBENTRY 1 org.eclipse.equinox.p2.ui 4 10005 2009-03-18 19:32:52.135
!SUBENTRY 1 org.eclipse.equinox.p2.ui 1 10002 2009-03-18 19:32:52.135
!MESSAGE Mylyn Focused UI (Recommended) is already installed, so an update
will be performed instead.
!MESSAGE Mylyn Task List (Required) is already installed, so an update
!MESSAGE Mylyn Bridge: Eclipse IDE is already installed, so an update will
!MESSAGE Mylyn Bridge: Team Support is already installed, so an update
!SUBENTRY 1 org.eclipse.equinox.p2.director 4 1 2009-03-18 19:32:52.135
!MESSAGE Cannot find a solution satisfying the following requirements
org.eclipse.jdt.feature.jar [3.4.0.v20080603-2000-7o7tEAXEFpPqqoXxgaBhhhq].
19:39:20.452
!SUBENTRY 1 org.eclipse.equinox.p2.core 2 0 2009-03-18 19:39:20.452
!MESSAGE Error at line 10, column 91: Missing required attribute in
"repository": url
!MESSAGE Error at line 10, column 91: Illegal value for attribute "url" of
!MESSAGE Error at line 11, column 91: Missing required attribute in
"repository": url
!MESSAGE Error at line 11, column 91: Illegal value for attribute "url" of
!MESSAGE Error at line 12, column 90: Missing required attribute in
"repository": url
!MESSAGE Error at line 12, column 90: Illegal value for attribute "url" of
!MESSAGE Error at line 13, column 90: Missing required attribute in
"repository": url
!MESSAGE Error at line 13, column 90: Illegal value for attribute "url" of
19:39:31.015
!SUBENTRY 1 org.eclipse.equinox.p2.core 2 0 2009-03-18 19:39:31.015
"repository": url
!MESSAGE Error at line 11, column 99: Missing required attribute in
"repository": url
!MESSAGE Error at line 11, column 99: Illegal value for attribute "url" of
20:01:56.767
!SUBENTRY 1 org.eclipse.equinox.p2.core 2 0 2009-03-18 20:01:56.767
"repository": url
"repository": url
"repository": url
"repository": url
"repository": url
"repository": url
20:02:24.892
!SUBENTRY 1 org.eclipse.equinox.p2.core 2 0 2009-03-18 20:02:24.892
"repository": url
"repository": url
20:02:26.533
!SUBENTRY 1 org.eclipse.equinox.p2.core 2 0 2009-03-18 20:02:26.533
"repository": url
"repository": url
"repository": url
"repository": url
!ENTRY org.eclipse.equinox.p2.metadata.generator 2 0 2009-03-18
20:02:27.189
!MESSAGE An error occurred while loading the bundle manifest C:\Documents
and
Settings\Dennis\Desktop\Ganymede\plugins\org.eclipse.gmf.doc _1.2.2.v20080916-2008.jar
!STACK 0
org.eclipse.equinox.internal.provisional.p2.metadata.generat or.BundleDescriptionFactory.loadManifest(BundleDescriptionFa ctory.java:124)
org.eclipse.equinox.internal.provisional.p2.metadata.generat or.BundleDescriptionFactory.getBundleDescription(BundleDescr iptionFactory.java:96)
org.eclipse.equinox.internal.provisional.p2.directorywatcher .RepositoryListener.processBundle(RepositoryListener.java:23 6)
org.eclipse.equinox.internal.provisional.p2.directorywatcher .RepositoryListener.process(RepositoryListener.java:226)
org.eclipse.equinox.internal.provisional.p2.directorywatcher .RepositoryListener.added(RepositoryListener.java:201)
org.eclipse.equinox.internal.p2.extensionlocation.BundlePool FilteredListener.added(BundlePoolFilteredListener.java:39)
org.eclipse.equinox.internal.p2.extensionlocation.SiteListen er.added(SiteListener.java:284)
org.eclipse.equinox.internal.provisional.p2.directorywatcher .DirectoryWatcher.processFile(DirectoryWatcher.java:200)
org.eclipse.equinox.internal.provisional.p2.directorywatcher .DirectoryWatcher.scanDirectories(DirectoryWatcher.java:161)
org.eclipse.equinox.internal.provisional.p2.directorywatcher .DirectoryWatcher.poll(DirectoryWatcher.java:108)
org.eclipse.equinox.internal.p2.extensionlocation.ExtensionL ocationMetadataRepository.ensureInitialized(ExtensionLocatio nMetadataRepository.java:72)
org.eclipse.equinox.internal.p2.extensionlocation.ExtensionL ocationMetadataRepository.getProperties(ExtensionLocationMet adataRepository.java:159)
org.eclipse.equinox.internal.p2.metadata.repository.Metadata RepositoryManager.addRepository(MetadataRepositoryManager.ja va:110)
org.eclipse.equinox.internal.p2.metadata.repository.Metadata RepositoryManager.loadRepository(MetadataRepositoryManager.j ava:454)
!ENTRY org.eclipse.equinox.p2.director 4 0 2009-03-18 20:02:30.689
!SUBENTRY 1 org.eclipse.equinox.p2.director 2 0 2009-03-18 20:02:30.689
!MESSAGE Unable to satisfy dependency from org.eclipse.jst.j2ee.web
1.1.105.v200802192030 to requiredCapability:
osgi.bundle/org.eclipse.emf.ecore.xmi/[2.2.0,2.4.0).
osgi.bundle/org.eclipse.emf.edit/[2.2.0,2.4
Re: Ganymede & Mylyn [message #596898 is a reply to message #66855] |
Thu, 19 March 2009 11:12 |
Randall Becker Messages: 13 Registered: July 2009 |
Junior Member |
Hi Dennis,
I just tried the install based on a clean Ganymede J2EE package (3.4.1).
Here's what I did:
1. Downloaded Ganymede 3.4.1 to a clean directory
2. Started my workspace. Mylyn 3.0.4 was included.
3. I had issues here with the Java workspace settings not being loadable,
because the workspace was from 3.3.2, and I had to correct Mylyn user ids.
I
also had to restart to have my problem markers show up.
4. Launched the Ganymede Software Updates window. The Installed Software
tab
Update function didn't work, so I used the Available Software tab. There,
I
modified my Mylyn for Eclipse site to point to
http://download.eclipse.org/tools/mylyn/update/e3.4, which is different
from
the one you reported.
5. I hit the Install... button and Mylyn 3.1.0 was downloaded for me and
installed.
6. The workbench was restarted and Mylyn 3.1.0 came up cleanly with one
Information marker:
"Reset Bugzilla repository configuration cache due to format change"
I did notice that an SQL update appeared to be needed to process the Mylyn
3.1.0 update, and I allowed that through. It may have been a result of my
J2EE configuration. I hope this helps.
Randall
Dennis wrote:
> I'm trying to pull Mylyn 3.4 (all the way down to 3.1....) without any
> success...
> this is the most recent site I've tried...
> http://download.eclipse.org/tools/mylyn/update/weekly/e3.4
> running Eclipse :
> Eclipse Platform
> Version: 3.4.2
> Build id: M20090211-1700
> I receive the error:
> Mylyn Task List (Required) is already installed, so an update will be
> performed instead.
> Mylyn Bridge: Eclipse IDE is already installed, so an update will be
> performed instead.
> Mylyn Bridge: Team Support is already installed, so an update will be
> performed instead.
> I've tried to uninstall DTP with a glorious crash and burn, thinking that
> maybe that would be the problem (I'm at 1.6.2, with no idea how to
> downgrade it to 1.6.1 or anything else for that matter)
> In fact if I uninstall anything in this configuration, Ganymede simply
> does not start anymore.
> This package is causing all kinds of problems with Ganymede, it seems
> Everything wants to be bound to it, but I obviously do not have it...
> Heres my config: (below the config is my error log...)
> [[[ I had to clip the message, it was refused when I attempted to initial
> post]]]
Current Time: Sun Dec 22 06:07:32 GMT 2024
Powered by FUDForum. Page generated in 0.42495 seconds
