Home » Archived » M2M (model-to-model transformation) » [ATL] Launch programmatically + Transformation from UML2 with Profile
[ATL] Launch programmatically + Transformation from UML2 with Profile [message #66837] |
Wed, 28 November 2007 13:42 |
No real name Messages: 33 Registered: July 2009 |
Member |
I have implemented some rules, tranforming an UML2 model with applied
SysML Profile. When I launch the configuration inside Eclipse, the
transformation works fine. Mainly applied stereotypes are used to
control which rules are executed.
Launching the same configuration programmatically fails, because I
cannot access applied stereotypes. The function getAppliedStereotypes()
always returns an empty sequence. The profile is included into the
model, so a separate in parameter for the profile is not needed.
As starting point I used the code from Milan Milanovic's template bundle:
// register uml2
EPackage.Registry.INSTANCE.put(UMLPackage.eNS_URI,
UMLPackage.eINSTANCE);
Resource.Factory.Registry.INSTANCE.getExtensionToFactoryMap( ).
put(UMLResource.FILE_EXTENSION, UMLResource.Factory.INSTANCE);
// get default emf handler
this.emfMh = (AtlEMFModelHandler)
AtlModelHandler.getDefault(AtlModelHandler.AMH_EMF);
// load uml metamodel
this.uml2Mm = this.emfMh.loadModel("uml", this.emfMh.getMof(),
"uri:http://www.eclipse.org/uml2/2.1.0/UML");
// load the input model
ASMModel in = this.emfMh.loadModel("IN",
this.uml2Mm, URI.createURI(inFileName));
During execution no error is reported and an output model is created.
But due to the empty sequences from getAppliedStereotypes() the output
is completly wrong.
What wrong with my transformation? Do I have to use special parameter?
Best regards
Sebastian
Re: [ATL] Launch programmatically + Transformation from UML2 with Profile [message #67361 is a reply to message #66837] |
Thu, 29 November 2007 07:51 |
Member |
after some further debugging I think I have found one problem. The
following code produces a strange output:
AtlModelHandler.getHandler(uml2Mm).saveModel(in, "tmp.uml");
In the dumped model, the references are not correctly resolved. Each XMI
element is assigned a new xmi:id, but in the stereotype applience the
reference to the element the stereotype is applied to is not updated:
<packagedElement xmi:type="uml:Class" xmi:id="a259" name="System">
</packagedElement>
<Extension:User_RootBlock xmi:id="a1037"
base_Class="_lXz1z524EdytSYwcMVoawA"/>
The attribute base_Class should have the value a259.
Any ideas how to solve the problem?
Best regards
Sebastian
bfeater schrieb:
> // register uml2
> is completly wrong.
> Best regards
> Sebastian
Re: [ATL] Launch programmatically + Transformation from UML2 with Profile [message #67404 is a reply to message #67361] |
Thu, 29 November 2007 08:53 |
Member |
The problem with the references was a mistake of my part. The saved
model is now equal to the loaded model.
But why returnes getAppliedStereotypes() an empty sequence?
bfeater schrieb:
> </packagedElement>
> Best regards
> Sebastian
> bfeater schrieb:
>> getAppliedStereotypes() always returns an empty sequence. The profile
>> is included into the model, so a separate in parameter for the profile
>> is not needed.
>> // register uml2
>> is completly wrong.
>> Best regards
>> Sebastian
Re: [ATL] Launch programmatically + Transformation from UML2 with Profile [message #67712 is a reply to message #67404] |
Thu, 29 November 2007 23:42 |
Frédéric Jouault Messages: 572 Registered: July 2009 |
If you want to use UML2 programmatically, you should make sure it is
properly registered.
When loaded in Eclipse as a plugin, the metadata (i.e., plugin.xml) is
queried for extensions of extension points. This process generally
performs some initializations (like registering the UML2 Resource factory).
However, if you simply add the UML2 jar to your classpath, this will not
automatically take care of proper initialization.
You should first find out what initializations are required to use UML2
outside of Eclipse, then add them in your code.
For reference, here is the information about EMF:
http://wiki.eclipse.org/index.php/EMF-FAQ#How_do_I_use_EMF_i n_standalone_applications_.28such_as_an_ordinary_main.29.3F
The EMF driver of ATL actually registers the XMI Resource factory for
every extension.
Because the UML2 plugin is not simply an EMF metamodel but requires
additional Java code, you most probably have to do similar things.
Once you have solved this, please let us know (e.g., by updating the
wiki with the information, and replying to this thread telling us you did).
Frédéric Jouault
> bfeater schrieb:
>> XMI element is assigned a new xmi:id, but in the stereotype applience
>> the reference to the element the stereotype is applied to is not updated:
>> </packagedElement>
>> Best regards
>> Sebastian
>> bfeater schrieb:
>>> Hi,
>>> bundle:
>>> // register uml2
>>> output is completly wrong.
>>> Best regards
>>> Sebastian
Re: [ATL] Launch programmatically + Transformation from UML2 with Profile [message #67841 is a reply to message #67712] |
Fri, 30 November 2007 12:15 |
Member |
I have found the problem. I created the uri for the input file with the
following instruction:
URI.createFileURI("infile.uml");
After changing it to
URI.createFileURI(new java.io.File("infile.uml").getAbsolutePath());
it works. The stereotypes are found.
Frédéric Jouault schrieb:
> Hello,
> every extension.
> Frédéric Jouault
>> bfeater schrieb:
>>> Hi,
>>> applience the reference to the element the stereotype is applied to
>>> is not updated:
>>> </packagedElement>
>>> Best regards
>>> Sebastian
>>> bfeater schrieb:
>>>> Hi,
>>>> applied SysML Profile. When I launch the configuration inside
>>>> Eclipse, the transformation works fine. Mainly applied stereotypes
>>>> are used to control which rules are executed.
>>>> profile is included into the model, so a separate in parameter for
>>>> bundle:
>>>> // register uml2
>>>> created. But due to the empty sequences from getAppliedStereotypes()
>>>> the output is completly wrong.
>>>> Best regards
>>>> Sebastian
Re: [ATL] Launch programmatically + Transformation from UML2 with Profile [message #67859 is a reply to message #67841] |
Fri, 30 November 2007 15:27 |
Good news! :-)
Could you please put this information on the wiki?
Frédéric Jouault
>> Hello,
>> factory).
>> not automatically take care of proper initialization.
>> UML2 outside of Eclipse, then add them in your code.
>> every extension.
>> did).
>> Thanks,
>> Frédéric Jouault
>>> bfeater schrieb:
>>>> Hi,
>>>> is not updated:
>>>> </packagedElement>
>>>> Best regards
>>>> Sebastian
>>>> bfeater schrieb:
>>>>> Hi,
>>>>> bundle:
>>>>> // register uml2
>>>>> getAppliedStereotypes() the output is completly wrong.
>>>>> Best regards
>>>>> Sebastian
Re: [ATL] Launch programmatically + Transformation from UML2 with Profile [message #68322 is a reply to message #67859] |
Fri, 07 December 2007 07:48 |
Member |
> Hello,
> Good news! :-)
Done
> Frédéric Jouault
>>> Hello,
>>> is queried for extensions of extension points. This process generally
>>> factory).
>>> every extension.
>>> did).
>>> Thanks,
>>> Frédéric Jouault
>>>> bfeater schrieb:
>>>>> Hi,
>>>>> Each XMI element is assigned a new xmi:id, but in the stereotype
>>>>> is not updated:
>>>>> </packagedElement>
>>>>> Best regards
>>>>> Sebastian
>>>>> bfeater schrieb:
>>>>>> Hi,
>>>>>> bundle:
>>>>>> // register uml2
>>>>>> parameter?
>>>>>> Best regards
>>>>>> Sebastian
Current Time: Sun Oct 20 16:23:16 GMT 2024
Powered by FUDForum. Page generated in 0.03588 seconds
