Home » Archived » M2M (model-to-model transformation) » [ATL] problem with launcher and UML driver
[ATL] problem with launcher and UML driver [message #66835] Wed, 28 November 2007 04:54 Go to next message
Originally posted by: tristan.faure.c-s.fr
We already have no problem to do transformation from UML Metamodel to UML
Metamodel with a metamodel MyProfile.ecore
This profile references UML Metamodel and aProfile.uml
when we create the launch configuration in Eclipse and when we runs the
transformation it's ok the profiles are loaded but when we restart eclipse
the launcher doesn't work, more over the profiles are not used (we make a
profile copy transformation which not work). . .
We think because the launcher doesn't use the UML 2 driver after the
restart is it normal ??? Is something we did wrong ? Is it a bug ?
Re: [ATL] problem with launcher and UML driver [message #66838 is a reply to message #66835] Wed, 28 November 2007 10:35 Go to previous message
--------------090903000109090600060509
Tristan FAURE a
Previous Topic:[ATL] Writing to helpers in model element context
Next Topic:[ATL] let the EMFModelHandler save the resource relative
Current Time: Mon Apr 28 00:39:07 EDT 2025
Powered by FUDForum. Page generated in 0.02361 seconds
