Home » Language IDEs » Java Development Tools (JDT) » About implemented class name to fullyqualify name!
About implemented class name to fullyqualify name! [message #66825] Wed, 25 June 2003 07:56 Go to next message
Originally posted by: soshila.bbc.com
Such as IMethod , i can get parameter name from it and look like "QString;"
or "QComponent;",
But how can i get the fullyqualify of them?
Thx so much!
Re: About implemented class name to fullyqualify name! [message #67337 is a reply to message #66825] Wed, 25 June 2003 08:07 Go to previous messageGo to next message
Originally posted by: scheglov_ke.nlmk.ru
> or "QComponent;",
Hm...
May be something like this?
private boolean isSuccessorOf(ITypeBinding type, String name) {
if (type == null)
return false;
if (type.getQualifiedName().toString().equals(name))
return true;
return isSuccessorOf(type.getSuperclass(), name);
System.out.println(
"class: "
+ type.getName()
+ " is XXX: "
+ isSuccessorOf(type.resolveBinding(), "com.abc.XXX"));
SY, Konstantin.
Re: About implemented class name to fullyqualify name! [message #67548 is a reply to message #66825] Wed, 25 June 2003 17:02 Go to previous messageGo to next message
Originally posted by: adam.kiezun.gmx.net.remove
it's an FAQ:
IType:resolveType
a.
eclipse.org
Re: About implemented class name to fullyqualify name! [message #67758 is a reply to message #66825] Wed, 25 June 2003 21:56 Go to previous messageGo to next message
Sorry, i have try ITye ty resolve super class, it's work.
But in method, i use the parameter type to resolve by it's parent IType, but
it will return null, why?
Thx so much
"soshila" <soshila@bbc.com> wrote in message
news:bdc2cf$r3n$1@rogue.oti.com...
"QString;"
> or "QComponent;",
> Thx so much!
Re: About implemented class name to fullyqualify name! [message #68023 is a reply to message #67758] Thu, 26 June 2003 06:58 Go to previous message
According to the spec, it returns <code>null</code> if unable to find any
matching type.
Make sure you pass a simple name (not the signature). Make sure the targeted
type is visible.
If you think it should find it, enter a bug report against JDT/Core with
build number and detailed steps to reproduce the problem.
Jerome
news:bddjkt$alb$1@rogue.oti.com...
but
> Thx so much
> "QString;"
> > or "QComponent;",
> > Thx so much!
Previous Topic:About how to convert readable to Signature!
Next Topic:Indenting simple if statements
Current Time: Fri Mar 14 06:25:04 EDT 2025
Powered by FUDForum. Page generated in 0.72917 seconds
