| ereference property should pop up selection window but shows a dropdown list and does not set member [message #66786] |
Sat, 21 October 2006 14:37  |
i have a very strange behaviour here:
Given a simple model A---->B, an A is having an arbitrary number of B´s
non containment.
Editing such a model with the EMF Tree editor works cool:
I create an A, and several B´s. In A´s property viev selecting the right
feature (the reference) shows a Button with three dots, and pressing
that button allows me to select some of my B´s to be members of the
reference.
In my GMF based Editor I can create A Nodes, and B Nodes, these map
correctly to the domain model. Now selecting an A Node and selecting the
reference feature in the property view strangely gives me not a button
to select the reference members but a dropdown list. The list contains
all the B´s in the model. I can select one of the B´s but this does not
touch the model in any way. Even if it would change the model it would
be incorrect behavior, since it should be possible to select a set of
B´s to be members of the reference.
This is by no means the behaviour I expect, also because I thought that
the property view code is shared between emf and gmf. (i.e. GMF reuses
the emf.edit/editor code.
Thanks for any suggestions,
Felix
FUDForum. Page generated in 0.03472 seconds
