Newbie: aspectj runtime [message #66763] |
Wed, 09 August 2006 10:43 |
Originally posted by: Daniel.Hirscher.innovations.de
I played around with ADJT and could get running some examples
and tests. I also tested with AOP in plug-in projects.
Then I realized that I have to add the aspectj runtime
to the manifest.mf as plug-in dependency.
So, why is this needed?
I thought the aspects are woven into the class files.
What does the runtime do?
I would like to use AOP in my plug-in projects but the
dependency to AJDT is not what I want.
Are there other solutions to get the runtime without
a dependency to AJDT? What are the best practices?
Daniel
Re: Newbie: aspectj runtime [message #66866 is a reply to message #66763] |
Wed, 09 August 2006 13:31 |
Matt Chapman Messages: 429 Registered: July 2009 |
Yes, aspects are woven into class files, but there will be references to
classes in the runtime library. This needs to be distributed with your
plugins. This is unavoidable, but you don't need a dependency on AJDT,
only on the very small org.aspectj.runtime plugin.
Matt.
Daniel Hirscher wrote:
> Daniel
Re: Newbie: aspectj runtime [message #594634 is a reply to message #66763] |
Matt.
> Daniel
FUDForum. Page generated in 0.03743 seconds
