Re: How does the AGR work, can we customrize it? [message #66817 is a reply to message #66636] |
Mon, 17 April 2006 14:51 |
No real name Messages: 404 Registered: July 2009 |
Hi Ben,
> I want to know how does AGR work. Does AGR use something like
> objectmap? When recording,AGR is more fast than RFT.
I'm not familiar with object maps so I can't confidently answer your
question.
AGR registers listeners with the Display object to capture user events.
> I want to know can I write some extendtion to enable AGR to recongnize
> special swt ui on eclipse view. If this can be done, how much do i need
> to do?
There is a feature opened to allow contributors to extend the number of
commands available: https://bugs.eclipse.org/bugs/show_bug.cgi?id=110416
Feel free to add yourself to the CC list and/or vote for the feature.
> Another thing is that I can't found any document about the AGR marco. I
> know what does it mean of my recorded xml fragment.But i don't konw the
> capability of the marco xml(for example does the marco xml support loop?
> if it does, then what's the xml tag? I tried to look into the soucecode
> of agr and tptp, but it is not easy).
I can see from your second post that you have already found the user guide.
You can add loops in the behavior page of the test suite but you can't add
it as part of the macro.
> last is that is there any way to enable the marco to process other
> things currently now support in tptp.Can I add extention to do this? What
> extendtion point do i need to extend?
I think I've already answered this one. Again, see feature
Thanks for your interest.
"Ben.Xu" <xufengbing@gmail.com> wrote in message
news:b5f1f681dee00d7fb98bd6e5a4bddee3$1@www.eclipse.org...
> we are currently planing a test project to automating functional test
> our developed eclipse plugins on linux platform(our plugin must be run on
> linux).
> We have investigate tools like tptp and rft and others.I used AGR in
> TPTP-4.2.0-200604110100 with eclipe3.2M6 on a redhat linux. It's a amazing
> tool though there are still lot of bugs.
> I have lots of questions on AGR since i can find few document on it.
> Currently AGR can record and play back in linux.(RFT still can's record
> on linux though build on tptp).
> when i use AGR to record some customarized SWT UI on a eclipse view.
> AGR can't recongnize the swt ui().(RFT can do this on windows platform).
> to do?
FUDForum. Page generated in 0.03587 seconds
