Home » Eclipse Projects » Mylyn » Reccommend a lightweight issue/bug tracker for personal use...
Reccommend a lightweight issue/bug tracker for personal use... [message #66585] Fri, 13 March 2009 22:57 Go to next message
Originally posted by: sean.hollingsworthinsurance.com
Hello Mylyn folks,
I'm looking for a lightweight task/issue/bug tracker to act as a
personal TO-DO list with Mylyn.
Since I use Eclipse on multiple machines and in multiple configurations
on those machines, the Local Task repository will not do.
I have Bugzilla set up already, but would like to know if there is
something 'lighter' available.
Re: Reccommend a lightweight issue/bug tracker for personal use... [message #66606 is a reply to message #66585] Fri, 13 March 2009 23:07 Go to previous messageGo to next message
Yves Schumann is currently offline Yves SchumannFriend
Member
Hello Sean
Maybe you should take a look at Mantis [1].
[1] http://www.mantisbt.org/
Yves
[eisfair-team]
"Ich bin nicht sicher, mit welchen Waffen der dritte Weltkrieg
ausgetragen wird, aber im vierten Weltkrieg werden sie mit Stöcken und
Steinen kämpfen."
-- Albert Einstein
Re: Reccommend a lightweight issue/bug tracker for personal use... [message #66627 is a reply to message #66606] Fri, 13 March 2009 23:20 Go to previous messageGo to next message
Originally posted by: gnl.ballroomdancemusic.info
Yves Schumann wrote:
> Hello Sean
Depends on what you mean by 'lighter', but there is the personal version of Jira
as well:
http://www.atlassian.com/software/jira/personal.jsp
George
Re: Reccommend a lightweight issue/bug tracker for personal use... [message #67267 is a reply to message #66585] Thu, 26 March 2009 22:48 Go to previous messageGo to next message
maarten meijer is currently offline maarten meijerFriend
Hi Sean,
You can also try the Industrial SQL Connector and set up your own little
database, like Derby (included) or mySQL (diy)
http://wiki.eclipse.org/Mylyn/Incubator/Generic_SQL_Connecto r
You can have comments and attachments as well.
Maarten Meijer
Sean Adams wrote:
> Hello Mylyn folks,
> Thanks
Re: Reccommend a lightweight issue/bug tracker for personal use... [message #67277 is a reply to message #66585] Fri, 27 March 2009 07:19 Go to previous message
Peter Stibrany is currently offline Peter StibranyFriend
Member
There is free FogBugz available too:
http://www.fogcreek.com/FogBugz/StudentAndStartup.html
No need to setup anything... it is hosted version.
Foglyn connector works fine with it. (Feel free to mail me to get free
Foglyn license for student/startup edition of FogBugz)
-Peter
Sean Adams wrote:
> Hello Mylyn folks,
> Thanks
Re: Reccommend a lightweight issue/bug tracker for personal use... [message #596749 is a reply to message #66585] Fri, 13 March 2009 23:07 Go to previous message
Member
Hello Sean
Yves
[eisfair-team]
Steinen kämpfen."
-- Albert Einstein
Re: Reccommend a lightweight issue/bug tracker for personal use... [message #596757 is a reply to message #66606] Fri, 13 March 2009 23:20 Go to previous message
George Lindholm is currently offline George LindholmFriend
> Hello Sean
as well:
George
Re: Reccommend a lightweight issue/bug tracker for personal use... [message #597092 is a reply to message #66585] Thu, 26 March 2009 22:48 Go to previous message
Hi Sean,
Maarten Meijer
Sean Adams wrote:
> Hello Mylyn folks,
> Thanks
Re: Reccommend a lightweight issue/bug tracker for personal use... [message #597098 is a reply to message #66585] Fri, 27 March 2009 07:19 Go to previous message
Member
-Peter
Sean Adams wrote:
> Hello Mylyn folks,
> Thanks
Previous Topic:Unable to add "Mylyn Extras" update site
Next Topic:Using subtasks
Current Time: Mon Dec 30 16:47:11 GMT 2024
Powered by FUDForum. Page generated in 0.04111 seconds
