Home » Eclipse Projects » GEF » Change From Build -I20030109 to Build -I20030220
Change From Build -I20030109 to Build -I20030220 [message #66506] Tue, 25 February 2003 13:08
Shady Said is currently offline Shady SaidFriend
I was doing work using GEF build I20030109 but when i migrated to the
version I20030220 , and doing all the necessary compilation changes
I found a difference in the behaviour as follows:
i used to have my own ResizableEditPolicy where i overrided methods for the
view of feedback like createDragSourceFeedbackFigure() in order to make use
of realtimefeedback (useRealtimeFeedback) in the older version , it worked
just fine
but in the newer one , no feedback appears unless i set useRealtimeFeedback
to false (and thus the feedback is ghostFigure)
how can i make it work again or what changes do i need to be aware of?
Previous Topic:Problems with HelloGef2
Next Topic:Add new Category/ new Entry
Current Time: Thu Dec 26 22:48:26 GMT 2024
Powered by FUDForum. Page generated in 0.03394 seconds
