Home » Eclipse Projects » Eclipse Platform » closing editors as a side-effect of resource deletion
closing editors as a side-effect of resource deletion [message #66459] Sat, 07 June 2003 12:45 Go to next message
Encountered this problem in our plugins on WinXP and R2.1, but it seems to
be endemic:
1. Create a simple Java project with two trivial classes, Class1
and Class2.
2. Open a Java editor on each class, ensuring that Class1's editor
totally obscures Class2's (i.e., don't tile the editors).
3. Shut down Eclipse and restart it. Things should look pretty
much the same as before.
4. Choose "New Window" from the Window menu.
5. In the new window, delete Class1 using the Package Explorer.
6. Go to the original window. You'll notice the editor for Class1
is still there. Click on its tab. Kablooie.
Obscured editors aren't instantiated on startup---only when they're
revealed. The error comes from FileEditorInputFactory when it tries
to reload the editor's memento information: the memento's path
points to the now-deleted resource.
Any reasonable workarounds?
Re: closing editors as a side-effect of resource deletion [message #66481 is a reply to message #66459] Sat, 07 June 2003 14:32 Go to previous messageGo to next message
Let's try that again:
and Class2.
2. Open a Java editor on each class, ensuring that **Class2's**
editor totally obscures **Class1's** (i.e., don't tile the
editors).
"John Vlissides" <vlis@us.ibm.com> wrote in message
news:bbt4rr$r34$1@rogue.oti.com...
> be endemic:
> and Class2.
Re: closing editors as a side-effect of resource deletion [message #68055 is a reply to message #66481] Mon, 09 June 2003 10:31 Go to previous message
Originally posted by: simon.ibm.oti.lab
Open a problem report againts Platform - UI
Simon :-)
news:bbtb4l$tqm$1@rogue.oti.com...
> and Class2.
> editors).
to
> > be endemic:
> > and Class2.
Previous Topic:One CVS Branched module fail to load
Next Topic:Output to JAR file instead of class files -- possible?
Current Time: Sun Oct 19 03:31:50 EDT 2025
Powered by FUDForum. Page generated in 0.04318 seconds
