XMI ID Extraction by ATL Transformation [message #66421] |
Tue, 20 November 2007 00:05 |
Originally posted by: gwi.n.world.googlemail.com
Hi all,
If i open a sysML file with text editor, i see any sysML element assigned a
XMI ID, for instance :
<sysML:ModelSYSML xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI"
xmlns:sysML="http://www.topcased.org/1.0/sysML" xmi:id="idModel"
name="test">
<nestedClassifier xmi:type="sysML:Requirement"
xmi:id="_ki2IQJUdEdyTa6qJBCVH1w" name="Requirement2" isAbstract="true"
id="req2" source="SysML_UML_Integration"/>
</sysML:ModelSYSML>
when i transform from sysML to my own model, i lost those XMI IDs, how can i
transform without losing XMI IDs ?
Thanks in advance !!!
Ninh.
Re: XMI ID Extraction by ATL Transformation [message #66483 is a reply to message #66442] |
Tue, 20 November 2007 15:01 |
Hi Alfons,
Thank you for your quick answer, could you please explain what do you mean
with "_xmiID_" and "location" ?
If i say ATL plugin writes output file in sysml format(output_file.sysml)
then i've XMI ID but i want the plugin writes output file with my own
extension. There are methods getID und setID in the class
org.eclipse.emf.ecore.xmi.impl.XMIResourceImpl, i don't know whether ATL
plugin calls those class in order to implement XMI ID ? is there any way i
can do it without extending ATL plugin ?
I'm a newbie and don't have experiences with the plugin extension :*)
Ninh.
"Alfons Laarman" <alfons.laarman@obeo.fr> wrote in message
news:fhufjq$k1a$1@build.eclipse.org...
> Hi Ninh,
> I think XMI id's are also added implicitly to other model elements, thats
> why they are handled differently. Try using "__xmiID__" or "location".
> One of those should work.
> Alfons Laarman
> eclipse.org a
FUDForum. Page generated in 0.03204 seconds
