Re: Why would a plugin end up as [Installed] and not [Resolved] or [Active]? [message #67403 is a reply to message #66562] |
Mon, 15 May 2006 09:20  |
Hey that's useful!
Thanks!
Geoff
Neil Bartlett wrote:
> Just to add a little to what Stefan said: under Equinox, if a bundle is
> stuck in INSTALLED state it generally means that its dependencies could
> not be resolved. By adding the -console switch when you launch, you can
> use the OSGi console to diagnose the missing dependencies using the "diag"
> command. For example:
> osgi> ss
> Framework is launched.
> id State Bundle
> 0 ACTIVE system.bundle_3.2.0.v20060328
> 1 ACTIVE org.eclipse.equinox.common_3.2.0.v20060329
> 2 INSTALLED org.eclipse.equinox.http_1.0.0.v20060317
> osgi> diag 2
> initial@reference:file:plugins/org.eclipse.equinox.http_1.0.0.v20060317.jar/
> [2]
> Missing imported package javax.servlet_0.0.0.
> Missing imported package javax.servlet.http_0.0.0.
> Missing imported package org.osgi.service.cm_1.0.0.
> Missing imported package org.osgi.service.http_1.1.0.
> Missing imported package org.osgi.service.log_1.0.0.
> Neil
FUDForum. Page generated in 0.02604 seconds
