| "patch.jar" in MANIFEST.MF [message #66341] |
Fri, 14 December 2007 05:04   |
Eclipse User  |
I have found references of a "patch.jar" in the classpath entry of the
MANIFEST.MF in some RAP bundles, namely "org.eclipse.rap.ui.workbench" or
"org.eclipse.rap.rwt".
Just out of curiosity what is this "patch.jar"?
Tiago
| Re: "patch.jar" in MANIFEST.MF [message #66759 is a reply to message #66741] |
Sun, 16 December 2007 18:36   |
Eclipse User  |
And no, there should be no need to have an empty/fake patch fragment.
Benjamin Muskalla wrote:
> Hi Joel,
> is there a way how to reproduce this error? Even with -errorlog enabled
> I don't see such a problem.
> Greets
>   Benny
> Joel Oliveira wrote:
>> Rüdiger,
>> This means that in order to avoid the following type of warnings at
>> runtime, we need to create a fake/empty patch.jar?
>> 1150 [Framework Event Dispatcher] INFO  [undefined]  - FrameworkEvent
>> INFO
>> org.osgi.framework.BundleException: The bundle class path entry
>> "patch.jar" could not be found for the bundle
>> "initial@reference:file:org.eclipse.rap.jface.jar/"
>>        at
>>  org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findCla ssPathEntry(ClasspathManager.java:161)
>>        at
>>  org.eclipse.osgi.baseadaptor.loader.ClasspathManager.buildCl asspath(ClasspathManager.java:138)
>>        at
>>  org.eclipse.osgi.baseadaptor.loader.ClasspathManager.initial ize(ClasspathManager.java:72)
>>        at
>>  org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.ini tialize(DefaultClassLoader.java:177)
>>        at
>>  org.eclipse.osgi.framework.internal.core.BundleLoader.create BCL(BundleLoader.java:714)
>>        at
>>  org.eclipse.osgi.framework.internal.core.BundleLoader.create BCLPrevileged(BundleLoader.java:689)
>>        at
>>  org.eclipse.osgi.framework.internal.core.BundleLoader.create ClassLoader(BundleLoader.java:318)
>>        at
>>  org.eclipse.osgi.framework.internal.core.BundleLoader.findLo calClass(BundleLoader.java:340)
>>        at
>>  org.eclipse.osgi.framework.internal.core.SingleSourcePackage .loadClass(SingleSourcePackage.java:37)
>>        at
>>  org.eclipse.osgi.framework.internal.core.BundleLoader.findCl assInternal(BundleLoader.java:405)
>>        at
>>  org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:369)
>>        at
>>  org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:357)
>>        at
>>  org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:83)
>> Best regards,
>> Joel Oliveira
>> "Rüdiger Herrmann" <rherrmann@innoopract.com> escreveu na mensagem
>> news:fjtsnb$b0c$1@build.eclipse.org...
>>> Tiago,
>>> since version 1.0.1
>>> (http://www.eclipse.org/rap/noteworthy/relnotes101.php) RAP allows to
>>> patch plug-ins by providing a so called patch-fragments.
>>> See this wiki page for more information:
>>>   http://wiki.eclipse.org/RAP/Patch_Fragments
>>> HTH,
>>> Rüdiger
>>> Tiago wrote:
>>>> Hi,
>>>> the MANIFEST.MF in some RAP bundles, namely
>>>> "org.eclipse.rap.ui.workbench" or "org.eclipse.rap.rwt".
>>>> Tiago
FUDForum. Page generated in 0.12182 seconds
