Re: Selection in GEF [message #66372 is a reply to message #66321] |
Mon, 24 February 2003 22:48 |
"Hal" <otaconss2@hotmail.com> wrote in message
news:b3djrf$tn7$1@rogue.oti.com...
> I would like to change the appearance of a figure and update my model when
Model? How would you change the model on selection?
> But in the logic editor example, only container add
SELECTION_FEEDBACK_ROLE,
> not the label itself. Where in the example which in install the edit
policy
> for the selection feedback of the label?
Any EditPolicy can decide to change the figure's appearance when the
EditPart is selected. The role is not too important unless you are
dynamically switch edit policies, or subclasses wish to remove a role added
in the superclass.
Re: Selection in GEF [message #66425 is a reply to message #66405] |
Tue, 25 February 2003 03:16 |
The easiest way is to subclass SelectionEditPolicy, or copy the code from
it.
news:b3e8cg$f8s$1@rogue.oti.com...
> Thanks. Could you please tell me how can a editpolicy know if the figure
has
> been selected by the user?
> Thank you again.
> "Randy Hudson" <none@us.ibm.com> wrote in message
> news:b3e5pt$dm9$1@rogue.oti.com...
> > > Hi,
> when
> > policy
> added
> > in the superclass.
FUDForum. Page generated in 0.03246 seconds
