Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » Lock in case Inheritance
Lock in case Inheritance [message #66320] Wed, 03 January 2007 14:20 Go to next message
Originally posted by: gao.spiehl.cn
Hi Martin,
Happy new years.
In our model wir use inheritance. We have problem with database lock.
We found, that should be a hibernater bug, that is resolved in the version
3.2.0.cr4 (siehe
http://opensource.atlassian.com/projects/hibernate/browse/HH H-1848).
Is a known problem for you?
Do you plan to delivery a new teneo version which contains the new hibernate
version? Or can we change the hibernate version self?
Hui
Re: Lock in case Inheritance [message #66340 is a reply to message #66320] Wed, 03 January 2007 14:41 Go to previous messageGo to next message
Martin Taal is currently offline Martin TaalFriend
Hi Hui,
Happy new year also to you!
I have not tried cr4 yet but normally the api does not change that much so you can give it a try.
gr. Martin
Hui Gao wrote:
> Hi Martin,
> Happy new years.
> 3.2.0.cr4 (siehe
> Best regards,
> Hui
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: Lock in case Inheritance [message #67479 is a reply to message #66340] Tue, 09 January 2007 08:43 Go to previous messageGo to next message
Hi Martin,
So I want to try to replace the hibernate version.
I downloaded the teneo version 0.7.5 and can not find the hibernate.jar
files, which is simple to be found in the elver version 0.7.2 (download time
ca. june 2006)
Where can I found the hibernate.jar in the current teneo version?
Hui
"Martin Taal" <mtaal@elver.org> schrieb im Newsbeitrag
news:engfad$h59$1@utils.eclipse.org...
> Hi Hui,
> gr. Martin
> Hui Gao wrote:
>> Hi Martin,
>> Happy new years.
>> version 3.2.0.cr4 (siehe
>> hibernate version? Or can we change the hibernate version self?
>> Best regards,
>> Hui
> The Netherlands
Re: Lock in case Inheritance [message #67520 is a reply to message #67479] Tue, 09 January 2007 09:18 Go to previous messageGo to next message
Hi Hui,
Hibernate is not distributed together with Teneo because of different licensing. You have to
download hibernate separately and put the hibernate jars in a separate plugin, also check out the
eclipse buddypolicy setting:
http://www.elver.org/hibernate/installation.html
gr. Martin
Hui Gao wrote:
> Hi Martin,
> ca. june 2006)
> Hui
>> Hi Hui,
>> gr. Martin
>> Hui Gao wrote:
>>> Hi Martin,
>>> Happy new years.
>>> Best regards,
>>> Hui
>> The Netherlands
The Netherlands
Re: Lock in case Inheritance [message #67587 is a reply to message #67520] Tue, 09 January 2007 14:58 Go to previous messageGo to next message
Hi Martin,
thanks for your help. Sorry, I have not read the documentation again.
Now I have an another problem:
A hibernate plugin is created. (hibernate3.jar and all .jars under the lib
are included in the classpath of this plugin. All packages of the
hibenate3.jar are exported).
In its manifest.mf: Eclipse-BuddyPolicy: dependent is added
In the plugin (model project) that teneo is used, we do:
add teneo plugin and our hibernate plugin in the dependence of the
plugin.xml. Both are set re-export = true
Problem: in the class (model project) that extend HbDataStore occurs error
message:
"The type org.hibernate.cfg.Configuration can not be resolved. It is
indirecty referenced from required .class file"
Can you help me?
Hui
news:envmlg$23l$1@utils.eclipse.org...
> Hi Hui,
> licensing. You have to download hibernate separately and put the hibernate
> jars in a separate plugin, also check out the eclipse buddypolicy setting:
> gr. Martin
> Hui Gao wrote:
>> Hi Martin,
>> time ca. june 2006)
>> Thanks,
>> Hui
>>> Hi Hui,
>>> gr. Martin
>>> Hui Gao wrote:
>>>> Hi Martin,
>>>> Happy new years.
>>>> Best regards,
>>>> Hui
>>> The Netherlands
> The Netherlands
Re: Lock in case Inheritance [message #67609 is a reply to message #67587] Tue, 09 January 2007 16:19 Go to previous messageGo to next message
Hi Hui,
I am not sure if it applies to you but did you check this:
http://www.elver.org/hibernate/troubleshooting.html#java.lan g.NoClassDefFoundError+when+starting%2Finitializing+runtime+ layer
So the hibernate plugin should be imported in the plugin with the widest classpath.
Another thing is to start eclipse with -clean.
gr. Martin
Hui Gao wrote:
> Hi Martin,
> message:
> Can you help me?
> Hui
>> Hi Hui,
>> gr. Martin
>> Hui Gao wrote:
>>> Hi Martin,
>>> time ca. june 2006)
>>> Thanks,
>>> Hui
>>>> Hi Hui,
>>>> gr. Martin
>>>> Hui Gao wrote:
>>>>> Hi Martin,
>>>>> Happy new years.
>>>>> Best regards,
>>>>> Hui
>>>> The Netherlands
>> The Netherlands
The Netherlands
Re: Lock in case Inheritance [message #67685 is a reply to message #67609] Wed, 10 January 2007 11:05 Go to previous message
Hi Martin,
the problem is solved. Wrong: I have created just a plugin project for the
hibernate jars.
I should create a Plugin :
Plug-in Development-> Plug-in from existing JAR archives
now I can using hibenate classes.
Thanks!
Hui
news:eo0fbs$lvl$1@utils.eclipse.org...
> Hi Hui,
> classpath.
> gr. Martin
> Hui Gao wrote:
>> Hi Martin,
>> lib are included in the classpath of this plugin. All packages of the
>> error message:
>> Can you help me?
>> Thanks,
>> Hui
>>> Hi Hui,
>>> hibernate jars in a separate plugin, also check out the eclipse
>>> gr. Martin
>>> Hui Gao wrote:
>>>> Hi Martin,
>>>> time ca. june 2006)
>>>> Thanks,
>>>> Hui
>>>>> Hi Hui,
>>>>> gr. Martin
>>>>> Hui Gao wrote:
>>>>>> Hi Martin,
>>>>>> Happy new years.
>>>>>> Best regards,
>>>>>> Hui
>>>>> The Netherlands
>>> The Netherlands
> The Netherlands
Re: Lock in case Inheritance [message #600573 is a reply to message #66320] Wed, 03 January 2007 14:41 Go to previous message
Hi Hui,
gr. Martin
Hui Gao wrote:
> Hi Martin,
> Happy new years.
> 3.2.0.cr4 (siehe
> Best regards,
> Hui
The Netherlands
Re: Lock in case Inheritance [message #600991 is a reply to message #66340] Tue, 09 January 2007 08:43 Go to previous message
Hui Gao is currently offline Hui GaoFriend
Hi Martin,
ca. june 2006)
Hui
> Hi Hui,
> gr. Martin
> Hui Gao wrote:
>> Hi Martin,
>> Happy new years.
>> Best regards,
>> Hui
> The Netherlands
Re: Lock in case Inheritance [message #601001 is a reply to message #67479] Tue, 09 January 2007 09:18 Go to previous message
Hi Hui,
gr. Martin
Hui Gao wrote:
> Hi Martin,
> ca. june 2006)
> Hui
>> Hi Hui,
>> gr. Martin
>> Hui Gao wrote:
>>> Hi Martin,
>>> Happy new years.
>>> Best regards,
>>> Hui
>> The Netherlands
The Netherlands
Re: Lock in case Inheritance [message #601020 is a reply to message #67520] Tue, 09 January 2007 14:58 Go to previous message
Hi Martin,
message:
Can you help me?
Hui
> Hi Hui,
> gr. Martin
> Hui Gao wrote:
>> Hi Martin,
>> time ca. june 2006)
>> Thanks,
>> Hui
>>> Hi Hui,
>>> gr. Martin
>>> Hui Gao wrote:
>>>> Hi Martin,
>>>> Happy new years.
>>>> Best regards,
>>>> Hui
>>> The Netherlands
> The Netherlands
Re: Lock in case Inheritance [message #601025 is a reply to message #67587] Tue, 09 January 2007 16:19 Go to previous message
Hi Hui,
gr. Martin
Hui Gao wrote:
> Hi Martin,
> message:
> Can you help me?
> Hui
>> Hi Hui,
>> gr. Martin
>> Hui Gao wrote:
>>> Hi Martin,
>>> time ca. june 2006)
>>> Thanks,
>>> Hui
>>>> Hi Hui,
>>>> gr. Martin
>>>> Hui Gao wrote:
>>>>> Hi Martin,
>>>>> Happy new years.
>>>>> Best regards,
>>>>> Hui
>>>> The Netherlands
>> The Netherlands
The Netherlands
Re: Lock in case Inheritance [message #601047 is a reply to message #67609] Wed, 10 January 2007 11:05 Go to previous message
Hi Martin,
hibernate jars.
Thanks!
Hui
> Hi Hui,
> classpath.
> gr. Martin
> Hui Gao wrote:
>> Hi Martin,
>> error message:
>> Can you help me?
>> Thanks,
>> Hui
>>> Hi Hui,
>>> gr. Martin
>>> Hui Gao wrote:
>>>> Hi Martin,
>>>> time ca. june 2006)
>>>> Thanks,
>>>> Hui
>>>>> Hi Hui,
>>>>> gr. Martin
>>>>> Hui Gao wrote:
>>>>>> Hi Martin,
>>>>>> Happy new years.
>>>>>> Best regards,
>>>>>> Hui
>>>>> The Netherlands
>>> The Netherlands
> The Netherlands
Previous Topic:jet editor
Next Topic:[teneo] How to specify table generators?
Current Time: Sat Dec 21 15:11:36 GMT 2024
Powered by FUDForum. Page generated in 0.04793 seconds
