eclipse startup error [message #66284] |
Sat, 08 January 2005 18:59 |
Originally posted by: sakafet03.yahoo.com
I am using eclipse 3.0 with java 1.3.1_15 and I have been getting the
following errors.
!SESSION Jan 08, 2005
11:23:06.164 ---------------------------------------------
eclipse.buildId=I200406251208
java.version=1.3.1_15
!ENTRY org.eclipse.osgi Jan 08, 2005 11:23:06.164
!MESSAGE Error registering XML parser services.
!STACK 0
java.lang.ClassNotFoundException: javax.xml.parsers.SAXParserFactory
at java.net.URLClassLoader$1.run(Unknown Source)
at java.net.URLClassLoader.findClass(Unknown Source)
at java.lang.ClassLoader.loadClassInternal(Unknown Source)
at java.lang.Class.forName0(Native Method)
at java.lang.Class.forName(Unknown Source)
org.eclipse.core.runtime.adaptor.EclipseAdaptor.registerEndo rsedXMLParser(EclipseAdaptor.java:272)
org.eclipse.core.runtime.adaptor.EclipseAdaptor.frameworkSta rt(EclipseAdaptor.java:253)
org.eclipse.osgi.framework.internal.core.SystemBundleActivat or.start(SystemBundleActivator.java:61)
org.eclipse.osgi.framework.internal.core.BundleContextImpl$1 .run(BundleContextImpl.java:958)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:954)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:937)
org.eclipse.osgi.framework.internal.core.StartLevelManager.r esumeBundles(StartLevelManager.java:553)
org.eclipse.osgi.framework.internal.core.StartLevelManager.i ncFWSL(StartLevelManager.java:477)
org.eclipse.osgi.framework.internal.core.StartLevelManager.d oSetStartLevel(StartLevelManager.java:273)
org.eclipse.osgi.framework.internal.core.StartLevelManager.l aunch(StartLevelManager.java:243)
org.eclipse.osgi.framework.internal.core.SystemBundle.resume (SystemBundle.java:166)
org.eclipse.osgi.framework.internal.core.Framework.launch(Fr amework.java:425)
at org.eclipse.osgi.framework.internal.core.OSGi.launch(OSGi.ja va:51)
org.eclipse.core.runtime.adaptor.EclipseStarter.startup(Ecli pseStarter.java:216)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:127)
at java.lang.reflect.Method.invoke(Native Method)
at org.eclipse.core.launcher.Main.basicRun(Main.java:183)
at org.eclipse.core.launcher.Main.run(Main.java:644)
at org.eclipse.core.launcher.Main.main(Main.java:628)
!ENTRY
initial@reference :file:c:/storage/eclipse/eclipse/plugins/org.eclipse.core.ru ntime_3.0.0/
0 0 Jan 08, 2005 11:23:06.464
!MESSAGE FrameworkEvent.ERROR
!STACK 0
org.osgi.framework.BundleException: Exception in
org.eclipse.core.internal.runtime.PlatformActivator.start() of bundle
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:975)
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:421)
org.eclipse.osgi.framework.internal.core.AbstractBundle.resu me(AbstractBundle.java:366)
org.eclipse.osgi.framework.internal.core.Framework.resumeBun dle(Framework.java:999)
org.eclipse.osgi.framework.internal.core.StartLevelManager.r esumeBundles(StartLevelManager.java:577)
org.eclipse.osgi.framework.internal.core.StartLevelManager.i ncFWSL(StartLevelManager.java:488)
org.eclipse.osgi.framework.internal.core.StartLevelManager.d ispatchEvent(StartLevelManager.java:444)
org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEve nt(EventManager.java:186)
at org.eclipse.osgi.framework.eventmgr.EventThread.run(EventThr ead.java:104)
Root exception:
java.lang.NoClassDefFoundError: org/xml/sax/SAXException
org.eclipse.core.internal.runtime.PlatformActivator.startReg istry(PlatformActivator.java:143)
org.eclipse.core.internal.runtime.PlatformActivator.start(Pl atformActivator.java:65)
!ENTRY
initial@reference :file:c:/storage/eclipse/eclipse/plugins/org.eclipse.update. configurator_3.0.0/
0 0 Jan 08, 2005 11:23:06.504
!STACK 0
org.eclipse.update.internal.configurator.ConfigurationActiva tor.start() of
bundle org.eclipse.update.configurator.
Root exception:
java.lang.Exception: Cannot initialize the Update Configurator
org.eclipse.update.internal.configurator.ConfigurationActiva tor.initialize(ConfigurationActivator.java:93)
org.eclipse.update.internal.configurator.ConfigurationActiva tor.start(ConfigurationActivator.java:71)
!ENTRY org.eclipse.osgi Jan 08, 2005 11:23:06.514
!MESSAGE Startup error
!STACK 1
java.lang.IllegalStateException: Bundle
[1] is not active.
org.eclipse.core.runtime.adaptor.EclipseStarter.ensureBundle sActive(EclipseStarter.java:303)
org.eclipse.core.runtime.adaptor.EclipseStarter.startup(Ecli pseStarter.java:227)
As of now I have checked my classpath and added the jars for xerces 2.6.2. I
have tried a stand alone java program that uses a dom parser and that works
so I know that the xml jars can be found but eclipse just won't run. I had
eclipse running with java version 1.4.2 but I need to go down to version
1.3.1.
Can anyone help me make eclipse 3.0 run with java 1.3.1_15
FUDForum. Page generated in 0.02346 seconds
