Home » Eclipse Projects » Equinox » which HTTP registry to use?
which HTTP registry to use? [message #66282] Fri, 05 May 2006 04:48 Go to next message
Peter Neubauer is currently offline Peter NeubauerFriend
Hi, it seems there are two registries in the equinox
incubator(org.....http.registry and org....servlet.ext), both exposing the servlet, context
and resource Extension points, but with a slightly different syntax.
Which one should be used for development, it seems the code is almost the
same?
/peter
Re: which HTTP registry to use? [message #66315 is a reply to message #66282] Fri, 05 May 2006 06:41 Go to previous messageGo to next message
Originally posted by: savagearts.gmail.com
I'm confused by this too.
Re: which HTTP registry to use? [message #66333 is a reply to message #66282] Fri, 05 May 2006 12:10 Go to previous messageGo to next message
Originally posted by: giacomin.vettatech.com
Hi Peter,See bug https://bugs.eclipse.org/bugs/show_bug.cgi?id=128059This
is part of a recent refactoring:[org.eclipse.equinox.servlet.ext] will
become[org.eclipse.equinox.http.registry]Regards,Regards, Ricardo Giacomin
"Peter Neubauer" <peter@neubauer.se> escreveu na mensagem
news:e3eler$oo7$1@utils.eclipse.org...
> servlet, context
> same?
> /peter
Re: which HTTP registry to use? [message #66357 is a reply to message #66315] Fri, 05 May 2006 13:14 Go to previous message
Originally posted by: skaegi.sympatico.ca
Sorry for the confusion,
org.eclipse.equinox.servlet.ext is no longer maintained. I left it there
primarily as a courtesy to anyone who integrated against but eventually
(this summer perhaps) will remove it.
I guess the readme.txt doesn't cut it. ;)
-Simon
"eisenhower" <savagearts@gmail.com> wrote in message
news:31229846.1146811322245.JavaMail.root@cp1.javalobby.org...
Previous Topic:The RSP bundle must be singleton?
Next Topic:multiple instances, osgi kernel stability issues
Current Time: Sat Nov 09 03:11:01 GMT 2024
Powered by FUDForum. Page generated in 0.02879 seconds
